Yesterday, my new GTX 780 Ti arrived. I set it up to fold and got the expected ~200k PPD for a few hours, and went to bed expecting everything to be working. When I got up, however, it seemed as though the 780 had done no work at all. Looking at the log files, it seems to have completed a single unit, before it started to fail with ERROR:exception: Bad platformId size. I would upload the entire logs, but since I reinstalled the client they have been deleted, and all the work units were the same anyway. Here is one example:
07:45:27:WU00:FS00:Connecting to 171.64.65.69:8080
07:45:27:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
07:45:28:WU01:FS00:News: Welcome to Folding@Home
07:45:28:WU01:FS00:Assigned to work server 171.64.65.69
07:45:28:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK110 [GeForce GTX 780 Ti] from 171.64.65.69
07:45:28:WU01:FS00:Connecting to 171.64.65.69:8080
07:45:28:WU01:FS00:Downloading 4.17MiB
07:45:33:WU01:FS00:Download complete
07:45:33:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:76 clone:6 gen:72 core:0x17 unit:0x0000006e028c126651a6377714c6e7ba
07:45:33:WU01:FS00:Starting
07:45:33:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/admin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 2840 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
07:45:33:WU01:FS00:Started FahCore on PID 6088
07:45:34:WU01:FS00:Core PID:6052
07:45:34:WU01:FS00:FahCore 0x17 started
07:45:34:WU01:FS00:0x17:*********************** Log Started 2014-01-29T07:45:34Z ***********************
07:45:34:WU01:FS00:0x17:Project: 8900 (Run 76, Clone 6, Gen 72)
07:45:34:WU01:FS00:0x17:Unit: 0x0000006e028c126651a6377714c6e7ba
07:45:34:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
07:45:34:WU01:FS00:0x17:Machine: 0
07:45:34:WU01:FS00:0x17:Reading tar file state.xml
07:45:35:WU01:FS00:0x17:Reading tar file system.xml
07:45:35:WU01:FS00:0x17:Reading tar file integrator.xml
07:45:35:WU01:FS00:0x17:Reading tar file core.xml
07:45:35:WU01:FS00:0x17:Digital signatures verified
07:45:35:WU01:FS00:0x17:Folding@home GPU core17
07:45:35:WU01:FS00:0x17:Version 0.0.52
07:45:35:WU01:FS00:0x17:ERROR:exception: Bad platformId size.
07:45:35:WU01:FS00:0x17:Saving result file logfile_01.txt
07:45:35:WU01:FS00:0x17:Saving result file log.txt
07:45:35:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
07:45:35:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:45:35:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:76 clone:6 gen:72 core:0x17 unit:0x0000006e028c126651a6377714c6e7ba
07:45:35:WU01:FS00:Uploading 1.84KiB to 171.64.65.69
07:45:35:WU01:FS00:Connecting to 171.64.65.69:8080
07:45:36:WU01:FS00:Upload complete
07:45:36:WU01:FS00:Server responded WORK_ACK (400)
07:45:36:WU01:FS00:Cleaning up
07:45:36:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
07:45:36:WU02:FS00:News: Welcome to Folding@Home
07:45:36:WU02:FS00:Assigned to work server 171.64.65.69
07:45:36:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GK110 [GeForce GTX 780 Ti] from 171.64.65.69
07:45:36:WU02:FS00:Connecting to 171.64.65.69:8080
07:45:37:WU02:FS00:Downloading 4.18MiB
07:45:43:WU02:FS00:Download 94.27%
07:45:43:WU02:FS00:Download complete
07:45:43:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:762 clone:2 gen:57 core:0x17 unit:0x00000060028c126651a6d029b9a05ff2
07:45:43:WU02:FS00:Starting
07:45:43:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/admin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 2840 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
07:45:43:WU02:FS00:Started FahCore on PID 4448
07:45:43:WU02:FS00:Core PID:5216
07:45:43:WU02:FS00:FahCore 0x17 started
07:45:43:WU02:FS00:0x17:*********************** Log Started 2014-01-29T07:45:43Z ***********************
07:45:43:WU02:FS00:0x17:Project: 8900 (Run 762, Clone 2, Gen 57)
07:45:43:WU02:FS00:0x17:Unit: 0x00000060028c126651a6d029b9a05ff2
07:45:43:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
07:45:43:WU02:FS00:0x17:Machine: 0
07:45:43:WU02:FS00:0x17:Reading tar file state.xml
07:45:44:WU02:FS00:0x17:Reading tar file system.xml
07:45:44:WU02:FS00:0x17:Reading tar file integrator.xml
07:45:44:WU02:FS00:0x17:Reading tar file core.xml
07:45:44:WU02:FS00:0x17:Digital signatures verified
07:45:44:WU02:FS00:0x17:Folding@home GPU core17
07:45:45:WU02:FS00:0x17:Version 0.0.52
07:45:45:WU02:FS00:0x17:ERROR:exception: Bad platformId size.
07:45:45:WU02:FS00:0x17:Saving result file logfile_01.txt
07:45:45:WU02:FS00:0x17:Saving result file log.txt
07:45:45:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
07:45:45:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
07:45:45:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:762 clone:2 gen:57 core:0x17 unit:0x00000060028c126651a6d029b9a05ff2
07:45:45:WU02:FS00:Uploading 1.83KiB to 171.64.65.69
07:45:45:WU02:FS00:Connecting to 171.64.65.69:8080
07:45:46:WU02:FS00:Upload complete
07:45:46:WU02:FS00:Server responded WORK_ACK (400)
07:45:46:WU02:FS00:Cleaning up
07:45:48:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
07:45:48:WU00:FS00:Connecting to 171.64.65.69:80
07:45:48:WU00:FS00:Upload 100.00%
07:45:48:WU00:FS00:Upload complete
07:45:48:WU00:FS00:Server responded WORK_ACK (400)
07:45:48:WU00:FS00:Cleaning up
EDIT: It appears that since Remote Desktop doesn't use the actual GPU of the computer, Folding@Home can't use it either if started over RDP. Therefore, the solution was simply to use an alternative to RDP, and the graphics card is now folding at 192k PPD. Sorry to bother you with this stupid problem.
