Client-type advanced?
billford
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop
Post by billford »
Re the FahCore_17 - Information & Unresolved Issues post, it says:
Officially Supported Platforms
Windows 32-bit -> AMD, Nvidia
Windows 64-bit -> AMD, Nvidia
Debian/*buntu/Mint 64-bit -> Nvidia (client-type needs to be set to advanced)
I'm running an NVidia GTX-650 Ti, Mint 16, 319.32 drivers (cos that's what the Driver Manager recommended), client-type is at default and it seems to be working fine at ~30,000 PPD. Although it's only ever picked up 8900 WUs so far.
Should I change it? I'm slightly reluctant to, if I'm honest, but will if there's good reason.
Log extract, as someone is bound to ask for it :wink:
13:52:13:************************* Folding@home Client *************************
13:52:13:    Website: http://folding.stanford.edu/
13:52:13:  Copyright: (c) 2009-2013 Stanford University
13:52:13:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:52:13:       Args: --child --lifeline 1087 /etc/fahclient/config.xml --run-as
13:52:13:             fahclient --pid-file=/var/run/fahclient.pid --daemon
13:52:13:     Config: /etc/fahclient/config.xml
13:52:13:******************************** Build ********************************
13:52:13:    Version: 7.3.6
13:52:13:       Date: Feb 18 2013
13:52:13:       Time: 07:24:08
13:52:13:    SVN Rev: 3923
13:52:13:     Branch: fah/trunk/client
13:52:13:   Compiler: GNU 4.4.7
13:52:13:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
13:52:13:             -fno-unsafe-math-optimizations -msse2
13:52:13:   Platform: linux2 3.2.0-1-amd64
13:52:13:       Bits: 64
13:52:13:       Mode: Release
13:52:13:******************************* System ********************************
13:52:13:        CPU: Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz
13:52:13:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
13:52:13:       CPUs: 4
13:52:13:     Memory: 3.82GiB
13:52:13:Free Memory: 3.57GiB
13:52:13:    Threads: POSIX_THREADS
13:52:13:Has Battery: false
13:52:13: On Battery: false
13:52:13: UTC offset: 0
13:52:13:        PID: 1146
13:52:13:        CWD: /var/lib/fahclient
13:52:13:         OS: Linux 3.11.0-12-generic x86_64
13:52:13:    OS Arch: AMD64
13:52:13:       GPUs: 1
13:52:13:      GPU 0: NVIDIA:3 GK106 [GeForce GTX 650 Ti]
13:52:13:       CUDA: 3.0
13:52:13:CUDA Driver: 5050
13:52:13:***********************************************************************
13:52:13:<config>
13:52:13:  <!-- Client Control -->
13:52:13:  <fold-anon v='true'/>
13:52:13:
13:52:13:  <!-- Folding Slot Configuration -->
13:52:13:  <power v='full'/>
13:52:13:
13:52:13:  <!-- HTTP Server -->
13:52:13:  <allow v='127.0.0.1 192.168.1.24 192.168.1.18'/>
13:52:13:
13:52:13:  <!-- Network -->
13:52:13:  <proxy v=':8080'/>
13:52:13:
13:52:13:  <!-- Remote Command Server -->
13:52:13:  <command-allow-no-pass v='127.0.0.1 192.168.1.24 192.168.1.18'/>
13:52:13:
13:52:13:  <!-- Slot Control -->
13:52:13:  <pause-on-start v='true'/>
13:52:13:
13:52:13:  <!-- User Information -->
13:52:13:  <passkey v='********************************'/>
13:52:13:  <user v=[removed]/>
13:52:13:
13:52:13:  <!-- Folding Slots -->
13:52:13:  <slot id='0' type='CPU'>
13:52:13:    <cpus v='3'/>
13:52:13:    <next-unit-percentage v='100'/>
13:52:13:  </slot>
13:52:13:  <slot id='1' type='GPU'/>
13:52:13:</config>
bollix47
Re: Client-type advanced?
Post by bollix47 »
AFAIK there is no need to set the client-type to advanced at this time. P8900 is currently the only project available but there have been indications that more are on the way.
Have a look at this blog entry.
... we’re rolling out core 17 to full fah (not just adv).
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
Thanks, I'll leave it alone.
EXT64
Post by EXT64 »
I had heard that they originally left P8900 on advanced for Linux when the rest went to full (because Linux required 64-bit or something like that), but as you are getting work without the flag at some point they must have switched it over to full. If you ever fail to get work on the card you can try adding the flag, but if you are getting work there is no reason to.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
EXT64 wrote:I had heard that they originally left P8900 on advanced for Linux when the rest went to full (because Linux required 64-bit or something like that), but as you are getting work without the flag at some point they must have switched it over to full.
That makes sense.
A succession of P8900's is getting a bit monotonous, but while they keep coming I'll put up with it rather than set the advanced flag!
The original issue was that 32-bit versions were getting FahCore_17 WUs but FahCore_17 couldn't run on 32-bit OS, it required 64-bit OS. Thus the requirement to have advanced client-type. It might have changed during the GPU Server issues hence why you are now getting it with default settings. Nonetheless, I have updated the information in the post.
billford wrote:A succession of P8900's is getting a bit monotonous, but while they keep coming I'll put up with it rather than set the advanced flag!
GPU support on Linux is still what I would call "new" and with all new processes, it starts small and grows. P8900 is a nice big project with (most of the time) plenty of work for everybody so that's what you're getting. It takes time to create newer projects that (A) do important research and (B) work reliably on everybody's GPU. There are a number of new projects in the pipeline which will probably be released soon, but at the present time, monotony is a GOOD thing. Have patience and it will certainly change.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
Post by billford »
bruce wrote:Have patience and it will certainly change.
The comment was made with tongue firmly planted in cheek- when it comes to labels I'm a lot more interested in PPD than PRCG, and if the GPU is getting bored then tough :D
It's simply that, when I was asking for advice on installing the GPU, it was suggested that I might need to enable the fan control for some projects, I said that I'd see how it goes- NVidia firmly advise against messing with it, so I don't want to do it unless I have to.
P8900 doesn't seem to need it, but so far I've got no other information on which to base a decision! There's no real hurry.
(As an aside, I really can't see why temperature control via the fan speed isn't built into the hardware, but c'est la vie)
