Stats are back up
Jim Saunders
- Hardware configuration: A: i5 + 2 GTX 660
B: i5 + 2 GTX 670
C: i7 + GTX670
Stats are back up
As for 1208 MST the stats server appears to be back up.
Jim
ETA - The update appears to be an ongoing process as results have changed more often than the usual once per hour.
Jim
Good science and heat for my basement you say?
billford
- Hardware configuration: Full Time:
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop - Location: Near Oxford, United Kingdom
Re: Stats are back up
Yup
It's a few WUs light, but hopefully it'll keep running this time and get to them in due course.
Nice! Not sure if its got all of my WU's.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
It probably hasn't, it certainly hasn't got all mine.Clyde46 wrote:Nice! Not sure if its got all of my WU's.
That's common after a prolonged outage, it can take a few update runs to clear the backlog.
Serverstat still reports 8795 WUs received but not yet credited ... and there are likely some "in transit" places that more credits may be lurking. Give it a bit longer.
johnblommers
My experience is that we saw a massive spike of points at the end of Friday at Extreme Over Clocking. It's quite a thrill.
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
I saw the same, and on Kakao. But it wasn't as big as it should have beenjohnblommers wrote:My experience is that we saw a massive spike of points at the end of Friday at Extreme Over Clocking. It's quite a thrill.
What are the PRCG numbers of your 4 missing work units?
billford
2x NVidia GTX 980
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
It turned out to be 5 rather than 4, and they were provided (and sorted out) in this topic, in which you posted an hour earlier.7im wrote:What are the PRCG numbers of your 4 missing work units?
Keep up lad, keep up
