Getting rejected by assignment server (GPU)
drougnor
Post by drougnor »
Fired up my GPU folding for the first time in a couple of weeks and am seeing the same message in the logs for both GPUS:
13:33:08:WU01:FS01:Connecting to assign-GPU.stanford.edu:8080
13:33:09:WARNING:WU01:FS01:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: No connection could be made because the target machine actively refused it
I did try to connect to the server address through web browsers on a couple of different pcs and got rejected/no connection on each pc.
The server status page indicates no issues, however.
Just wanted to give the heads up.
NookieBandit
Hardware configuration: AMD Opteron 2 x 6274 (32 Cores)
AMD FX-8350 (8 Cores)
Intel i7-4790K (8 Cores)
Intel i7-4771K (8 Cores)
Intel i7-3770K (8 Cores)
Intel i7-3770S (8 Cores)
Intel i7-3930K (12 Cores)
Nvidia GPUs:
GTX 780ti
GTX 780ti
GTX 780ti
GTX 780ti
GTX 780
GTX 690
GTX 690
AMD GPUs:
HD 7970 GBE
HD 7970 GBE
HD 7990
HD 7990
HD 7990
R9 295X2
R9 295X2
R9 295X2
Re: Getting rejected by assignment server (GPU)
Post by NookieBandit »
I'm having the same issue, exactly the same error messages you've received.
bollix47
Post by bollix47 »
Thank you for your reports ... I'm seeing an issue here as well on my both my AMD and nvidia cards (Windows and Linux).
PG notified but it's still very early on the west coast so it may be a while.
drougnor
Post by drougnor »
No worries on timing - Just wanted to make sure the word got spread as soon as I saw it. Thanks!!
Mactin
Post by Mactin »
Same thing here...
on both a GTS250 (core11) and HD7790
bcavnaugh
Post by bcavnaugh »
I have 7 GPU's down now. :cry:
If I drop any more I will have to turn my Heat On!
Temps are down to 53 have to turn on the Heat to stay at least 60F
US Army Retired | Folding@EVGA The Number One Team in the Folding@Home Community.
kiore
Post by kiore »
bollix47 wrote:Thank you for your reports ... I'm seeing an issue here as well on my both my AMD and nvidia cards (Windows and Linux).
OK thanks, so time for a bit of maintenance blowing out dust and things here.
blackhawkdoc64
Hardware configuration: Intel 990x, GTX 580 x 3, 24G 1600 Ram.
Post by blackhawkdoc64 »
Same issue here :shock: :eo . Can't wait for it to get fixed I'm going into folding withdrawl from the cold in my room :lol: . Need to fire my GTX 580s back up.
HaloJones
Post by HaloJones »
<alanis>Ironic, all my kit has been off for the last five hours due to a power cut and now they're back on, they can't get new work! </alanis.
4070 super
VijayPande
Pande Group Member
Post by VijayPande »
Thanks. We see the problem and have notified our sysadmins. They are on a reduced schedule due to Stanford's closure this week.
Prof. Vijay Pande, PhD
Chair, Biophysics
Stanford University
VijayPande
Pande Group Member
Update: The good news is that the VM server has been rebooted. The bad news is that it looks to be going through an fsck cycle right now, so reboot time will be delayed. We'll post more when we have it, but this is good progress.
Chair, Biophysics
Stanford University
VijayPande
Pande Group Member
PS We are also planning on setting up a redundant GPU AS. This wasn't as necessary in the early days when GPUs were more experimental, but as we push more to GPUs, this is now a very high priority. With that done, then an outage like this wouldn't affect GPU assignments.
Chair, Biophysics
Stanford University
drougnor
Post by drougnor »
Thank you for the updates, Dr. Pande!
oliverjdent
Intel CORE i7-13700K
ASUS Prime Z790-P
ASUS TUF RTX4070-TI-12G
Machine #2:
AMD Ryzen 7 1700
MSI Carbon Pro
NVIDIA GeForce RTX 3060 Ti
Re: AS servers - network problem
Post by oliverjdent »
Sometime overnight my GPU completed its latest project. However, it has not been able to get a new project. It keeps getting the following messages from the assignment servers:
18:46:08:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:46:09:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: No connection could be made because the target machine actively refused it.
18:46:09:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
18:46:10:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: No connection could be made because the target machine actively refused it.
18:46:10:ERROR:WU00:FS00:Exception: Could not get an assignment
18:48:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
18:48:46:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Failed to connect to assign-GPU.stanford.edu:80: No connection could be made because the target machine actively refused it.
18:48:46:WU00:FS00:Connecting to assign-GPU.stanford.edu:8080
18:48:47:WARNING:WU00:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Failed to connect to assign-GPU.stanford.edu:8080: No connection could be made because the target machine actively refused it.
18:48:47:ERROR:WU00:FS00:Exception: Could not get an assignment
18:43:26:******************************** Build ********************************
18:43:26:      Version: 7.3.6
18:43:26:         Date: Feb 18 2013
18:43:26:         Time: 15:25:17
18:43:26:      SVN Rev: 3923
18:43:26:       Branch: fah/trunk/client
18:43:26:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:43:26:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:43:26:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:43:26:     Platform: win32 XP
18:43:26:         Bits: 32
18:43:26:         Mode: Release
18:43:26:******************************* System ********************************
18:43:26:          CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
18:43:26:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
18:43:26:         CPUs: 4
18:43:26:       Memory: 7.95GiB
18:43:26:  Free Memory: 4.84GiB
18:43:26:      Threads: WINDOWS_THREADS
18:43:26:  Has Battery: false
18:43:26:   On Battery: false
18:43:26:   UTC offset: -6
18:43:26:          PID: 7640
18:43:26:          CWD: C:/Users/Rodney/AppData/Roaming/FAHClient
18:43:26:           OS: Windows 7 Professional
18:43:26:      OS Arch: AMD64
18:43:26:         GPUs: 1
18:43:26:        GPU 0: NVIDIA:3 GK104 [GeForce GTX 670]
18:43:26:         CUDA: 3.0
18:43:26:  CUDA Driver: 6000
18:43:26:Win32 Service: false
18:43:26:***********************************************************************
I have a GTX 670 that has been folding since I purchased it last year. I am running the latest drivers - 331.82. My machine is running Windows 7 Pro 64-bit on an Intel Core i5-4670K with 8G of RAM. My CPU seems to be folding correctly and has pulled down a project this morning during the time the GPU has been unable to.
Thank you.
Any help you can provide will be greatly appreciated.
HaloJones
Post by HaloJones »
The servers are down! Look above your post, it is very clear. You just have to wait like everyone else. It will be back when the fscking fsck is fscking finished. :)
EDIT: Sorry about the above, there was no indication that this post had been moved into this thread hence my comment about looking above. The rest of this post remains valid.
EDIT2: Is there no way to indicate that a post has been moved? It appearing in this thread without any warning just made the poster look foolish and made me look mean.
4070 super
