No appropriate work server was available
Nathan_P
Not currently folding
Post by Nathan_P »
One of my machines will not connect to the work severs.
Have tried the following so far
Restarted the client
Rebooted the machine
swapped ports on the switch
switched client from -bigadv to -smp
The machine will connect to the rest of the internet fine and I can get it to pull up the OK message from the AS in a firefox window.
Machine is a dedicated 24/7 folder running Ubuntu 12:04, v6 client
Ask before connecting: No
[16:36:56] - User name: Nathan_P (Team 33)
[16:36:56] - User ID: EF13A7A0213FB5F
[16:36:56] - Machine ID: 1
[16:36:56]
[16:36:56] Loaded queue successfully.
[16:36:56] - Preparing to get new work unit...
[16:36:56] Cleaning up work directory
[16:36:56] - Autosending finished units... [December 27 16:36:56 UTC]
[16:36:56] Trying to send all finished work units
[16:36:56] + No unsent completed units remaining.
[16:36:56] - Autosend completed
[16:36:56] + Attempting to get work packet
[16:36:56] Passkey found
[16:36:56] - Will indicate memory of 12009 MB
[16:36:56] - Connecting to assignment server
[16:36:56] Connecting to http://assign.stanford.edu:8080/
[16:36:57] Posted data.
[16:36:57] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:36:57] + Couldn't get work instructions.
[16:36:57] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[16:37:16] + Attempting to get work packet
[16:37:16] Passkey found
[16:37:16] - Will indicate memory of 12009 MB
[16:37:16] - Connecting to assignment server
[16:37:16] Connecting to http://assign.stanford.edu:8080/
[16:37:16] Posted data.
[16:37:16] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:37:16] + Couldn't get work instructions.
[16:37:16] - Attempt #2  to get work failed, and no other work to do.
[16:37:34] + Attempting to get work packet
[16:37:34] Passkey found
[16:37:34] - Will indicate memory of 12009 MB
[16:37:34] - Connecting to assignment server
[16:37:34] Connecting to http://assign.stanford.edu:8080/
[16:37:34] Posted data.
[16:37:34] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:37:34] + Couldn't get work instructions.
[16:37:34] - Attempt #3  to get work failed, and no other work to do.
[16:37:56] + Attempting to get work packet
[16:37:56] Passkey found
[16:37:56] - Will indicate memory of 12009 MB
[16:37:56] - Connecting to assignment server
[16:37:56] Connecting to http://assign.stanford.edu:8080/
[16:37:57] Posted data.
[16:37:57] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:37:57] + Couldn't get work instructions.
[16:37:57] - Attempt #4  to get work failed, and no other work to do.
[16:38:45] + Attempting to get work packet
[16:38:45] Passkey found
[16:38:45] - Will indicate memory of 12009 MB
[16:38:45] - Connecting to assignment server
[16:38:45] Connecting to http://assign.stanford.edu:8080/
[16:38:51] Posted data.
[16:38:51] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:38:51] + Couldn't get work instructions.
[16:38:51] - Attempt #5  to get work failed, and no other work to do.
[16:40:21] + Attempting to get work packet
[16:40:21] Passkey found
[16:40:21] - Will indicate memory of 12009 MB
[16:40:21] - Connecting to assignment server
[16:40:21] Connecting to http://assign.stanford.edu:8080/
[16:40:22] Posted data.
[16:40:22] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[16:40:22] + Couldn't get work instructions.
[16:40:22] - Attempt #6  to get work failed, and no other work to do.
any ideas?
Re: No appropriate work server was available
Assuming that it is v6.34 (latest v6 version), how about the following:
Delete the userinfo.dat (or some other files which will make your client a "new" one)
Change the max packet size from big to small to see if any difference is there
According to the Server Status, all SMP Servers are fully functional with the exception of 2 Servers (171.64.65.54, 171.67.108.35). Moreover, there is another Server (128.143.199.96) which is having a high CPU load.
Nathan_P
Post by Nathan_P »
deleting machinedependant.dat, queue.dat and myfolding.txt cleared the problem
Thx
Other persons using V6 who have experienced this issue have fixed it by deleting just the queue.dat file and then restarting the client.
