Hi, My current WU is LIPID ONLY aO, I cant find a reference to it, what is it and how many points.
TIA Pete
LIPID?
Re: LIPID?
From http://fah-web.stanford.edu/psummary.html :
p2614 using Gromacs33 core, worth 287 points.
2614 171.64.65.65 p2614_LIPID ONLY 149277 20.00 40.00 287.00 100 GROMACS33 Description kassonRe: LIPID?
Thanks, strange it doesnt show a project No.
Pete
Pete
Re: LIPID?
I don't understand what you mean by project ...
For me, it's project # 2614, and it's called "LIPID ONLY" ...
parkut
- Hardware configuration: Running exclusively Linux headless blades. All are dedicated crunching machines.
Re: LIPID?
The project number doesn't show up in unitinfo.txt. If you look in the log file, you will see it.
