WU got DUMPED !
Justin
WU got DUMPED !
Post by Justin »
Hi, new to this (for a second time, just got a message that I can't include URLs so am typing the post again)....
On 20th November I paused both CPU and GPU as the system needed to re-boot. Here is the end of the log showing it shutting down.
10:31:18:WU02:FS00:0x15:Completed  22500000 out of 25000000 steps (90%).
10:32:56:WU01:FS01:0xa4:Completed 1825000 out of 2500000 steps  (73%)
10:47:23:FS00:Paused
10:47:23:FS00:Shutting core down
10:47:24:WU02:FS00:0x15:Client no longer detected. Shutting down core
10:47:24:WU02:FS00:0x15:Folding@home Core Shutdown: CLIENT_DIED
10:47:24:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:47:27:FS01:Paused
10:47:27:FS01:Shutting core down
10:47:33:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
Here is the log showing it starting up again...
10:50:57:  <!-- Folding Slots -->
10:50:57:  <slot id='1' type='CPU'/>
10:50:57:  <slot id='0' type='GPU'/>
10:50:57:</config>
10:50:57:Trying to access database...
10:50:59:Successfully acquired database lock
10:50:59:Enabled folding slot
10:50:59:ERROR:Exception: Option 'gpu-index' has no default and is not set.
10:50:59:Enabled folding slot 00: READY gpu:0:GF106 [GeForce GT 555M SDDR3]
10:50:59:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping
10:51:00:WU02:FS00:Starting
10:51:00:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 703 -lifeline 5016 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
10:51:00:WU02:FS00:Started FahCore on PID 5688
10:51:01:WU02:FS00:Core PID:5716
10:51:01:WU02:FS00:FahCore 0x15 started
10:51:01:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:7646 run:7 clone:0 gen:172 core:0xa4 unit:0x00000194664f2dcd4fa7fdc4d4769e5d
10:51:01:WU01:FS01:Connecting to 171.64.65.101:8080
Why did it DUMP the WU from Slot ID 1 ?
It then happily resumed folding on the GPU...
10:52:19:WU02:FS00:0x15:fcCheckPointResume: state restored 2
10:52:19:WU02:FS00:0x15:Resumed from checkpoint
10:52:19:WARNING:WU02:FS00:Detected clock skew (1 mins 18 secs), adjusting time estimates
10:52:19:WU02:FS00:0x15:Setting checkpoint frequency: 250000
10:52:19:WU02:FS00:0x15:Completed  22500001 out of 25000000 steps (90%).
10:55:12:Adding folding slot 01: READY cpu:4
10:55:12:Saving configuration to config.xml
... and added the CPU back on Slot 01, downloaded a WU and started processing that quite happily.
At first, being new to this, I thought it was something to do with the ‘clock skew’ warning but having read up on the subject I see that that really isn’t a problem.
Can you tell me what caused this and is there anything I can do to stop it happening again?
Thanks
Re: WU got DUMPED !
Welcome to the folding forum.
As for why the client dumped the WU, we would need more information. There have been a few reports of a folding slot being deleted, in some cases it was determined to be from settings changes that were incompatible. With no folding slot the WU was dumped.
Could you post the beginning of the first log that shows the system configuration and the original folding slot setup? The log from after the restart through the point that the CPU slot was detected as gone, and then recreated would also be useful.
Re: WU got DUMPED !
Joe_H wrote:...Could you post the beginning of the first log that shows the system configuration and the original folding slot setup? The log from after the restart through the point that the CPU slot was detected as gone, and then recreated would also be useful.
The previous logs, up to 16 by default, are kept in a logs folder which you can access by:
Start -> All Programs -> FAHClient -> Data Directory -> Logs
Re: WU got DUMPED !
Welcome to foldingforum.org, Justin.
Are you starting FAHClient manually or is it being started automatically by the original installation?
Have you been editing the config, either manually or with FAHControl (aka Advanced Control)?
Justin
Re: WU got DUMPED !
Post by Justin »
Thanks for the welcome.
The FAHclient is started automatically when the PC boots and I use the Advanced Control to see what's going on. I also had problems trying to figure out why the GPU wasn't doing anything when I first installed the software so did dip into the configuration but I'm fairly certain that several WUs for CPU/GPU got completed before the reboot and the dump took place.
Have attached the logs, I deleted lots of messages relating to % complete and % upload. Also realised that I've removed most of the date stamps as well.
Before:
*********************** Log Started 2013-11-09T12:43:42Z ***********************
12:43:42:************************* Folding@home Client *************************
12:43:42:      Website: http://folding.stanford.edu/
12:43:42:    Copyright: (c) 2009-2013 Stanford University
12:43:42:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:43:42:         Args: --open-web-control
12:43:42:       Config: <none>
12:43:42:******************************** Build ********************************
12:43:42:      Version: 7.3.6
12:43:42:         Date: Feb 18 2013
12:43:42:         Time: 15:25:17
12:43:42:      SVN Rev: 3923
12:43:42:       Branch: fah/trunk/client
12:43:42:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:43:42:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:43:42:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
12:43:42:     Platform: win32 XP
12:43:42:         Bits: 32
12:43:42:         Mode: Release
12:43:42:******************************* System ********************************
12:43:42:          CPU: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
12:43:42:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:43:42:         CPUs: 4
12:43:42:       Memory: 5.86GiB
12:43:42:  Free Memory: 3.45GiB
12:43:42:      Threads: WINDOWS_THREADS
12:43:42:  Has Battery: true
12:43:42:   On Battery: true
12:43:42:   UTC offset: 0
12:43:42:          PID: 1308
12:43:42:          CWD: C:/Users/HRH/AppData/Roaming/FAHClient
12:43:42:           OS: Windows 7 Home Premium
12:43:42:      OS Arch: AMD64
12:43:42:         GPUs: 1
12:43:42:        GPU 0: NVIDIA:2 GF106 [GeForce GT 555M SDDR3]
12:43:42:         CUDA: 2.1
12:43:42:  CUDA Driver: 3020
12:43:42:Win32 Service: false
12:43:42:***********************************************************************
12:43:42:<config>
12:43:42:  <!-- Folding Slots -->
12:43:42:</config>
12:43:42:Connecting to assign-GPU.stanford.edu:80
12:43:43:Connecting to assign-GPU.stanford.edu:8080
12:43:44:Read GPUs.txt
12:43:44:Trying to access database...
12:43:44:Successfully acquired database lock
12:43:44:Enabled folding slot 00: PAUSED gpu:0:GF106 [GeForce GT 555M SDDR3] (not configured)
12:43:44:Enabled folding slot 01: PAUSED cpu:2 (not configured)
12:44:50:12:127.0.0.1:New Web connection
12:45:01:Saving configuration to config.xml
12:45:01:<config>
12:45:01:  <!-- Network -->
12:45:01:  <proxy v=':8080'/>
12:45:01:
12:45:01:  <!-- User Information -->
12:45:01:  <team v=''/>
12:45:01:  <user v=''/>
12:45:01:
12:45:01:  <!-- Folding Slots -->
12:45:01:  <slot id='0' type='GPU'/>
12:45:01:  <slot id='1' type='CPU'/>
12:45:01:</config>
12:45:01:Set client configured
12:46:50:Saving configuration to config.xml
12:46:50:<config>
12:46:50:  <!-- Network -->
12:46:50:  <proxy v=':8080'/>
12:46:50:
12:46:50:  <!-- User Information -->
12:46:50:  <passkey v='********************************'/>
12:46:50:  <team v=''/>
12:46:50:  <user v=''/>
12:46:50:
12:46:50:  <!-- Folding Slots -->
12:46:50:  <slot id='0' type='GPU'/>
12:46:50:  <slot id='1' type='CPU'/>
12:46:50:</config>
12:47:20:Saving configuration to config.xml
12:47:20:<config>
12:47:20:  <!-- Network -->
12:47:20:  <proxy v=':8080'/>
12:47:20:
12:47:20:  <!-- Slot Control -->
12:47:20:  <pause-on-battery v='false'/>
12:47:20:
12:47:20:  <!-- User Information -->
12:47:20:  <passkey v='********************************'/>
12:47:20:  <team v=''/>
12:47:20:  <user v=''/>
12:47:20:
12:47:20:  <!-- Folding Slots -->
12:47:20:  <slot id='0' type='GPU'/>
12:47:20:  <slot id='1' type='CPU'/>
12:47:20:</config>
12:51:16:WU00:FS01:Connecting to assign-GPU.stanford.edu:80
12:51:20:WU00:FS01:Connecting to assign3.stanford.edu:8080
12:51:21:WU00:FS01:News: Welcome to Folding@Home
12:51:21:WU00:FS01:Assigned to work server 128.143.231.202
12:51:21:WU00:FS01:Requesting new work unit for slot 01: READY cpu:2 from 128.143.231.202
12:51:21:WU00:FS01:Connecting to 128.143.231.202:8080
12:51:22:WU00:FS01:Downloading 3.67MiB
12:51:26:WU00:FS01:Download complete
12:51:26:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8580 run:0 clone:0 gen:296 core:0xa3 unit:0x00000d600a3b1e595122609acb258ede
12:51:26:WU00:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah
12:51:26:WU00:FS01:Connecting to www.stanford.edu:80
12:51:27:WU00:FS01:FahCore a3: Downloading 2.89MiB
12:51:33:WU00:FS01:FahCore a3: 32.46%
12:51:39:WU00:FS01:FahCore a3: 58.43%
12:51:45:WU00:FS01:FahCore a3: 93.06%
12:51:46:WU00:FS01:FahCore a3: Download complete
12:51:46:WU00:FS01:Valid core signature
12:51:46:WU00:FS01:Unpacked 9.59MiB to cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe
12:51:46:WU00:FS01:Starting
12:51:46:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -np 2
12:51:46:WU00:FS01:Started FahCore on PID 6832
12:51:50:WU00:FS01:Core PID:6996
12:51:50:WU00:FS01:FahCore 0xa3 started
12:51:50:WU00:FS01:0xa3:
12:51:50:WU00:FS01:0xa3:*------------------------------*
12:51:50:WU00:FS01:0xa3:Folding@Home Gromacs SMP Core
12:51:50:WU00:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
12:51:50:WU00:FS01:0xa3:Preparing to commence simulation
12:51:50:WU00:FS01:0xa3:- Looking at optimizations...
12:51:50:WU00:FS01:0xa3:- Created dyn
12:51:50:WU00:FS01:0xa3:- Files status OK
12:51:51:WU00:FS01:0xa3:- Expanded 3849931 -> 4387808 (decompressed 113.9 percent)
12:51:51:WU00:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3849931 data_size=4387808, decompressed_data_size=4387808 diff=0
12:51:51:WU00:FS01:0xa3:- Digital signature verified
12:51:51:WU00:FS01:0xa3:Project: 8580 (Run 0, Clone 0, Gen 296)
12:51:51:WU00:FS01:0xa3:Assembly optimizations on if available.
12:51:51:WU00:FS01:0xa3:Entering M.D.
12:51:57:WU00:FS01:0xa3:Mapping NT from 2 to 2
12:51:58:WU00:FS01:0xa3:Completed 0 out of 500000 steps  (0%)
12:56:40:Saving configuration to config.xml
12:56:40:<config>
12:56:40:  <!-- Network -->
12:56:40:  <proxy v=':8080'/>
12:56:40:
12:56:40:  <!-- Slot Control -->
12:56:40:  <pause-on-battery v='false'/>
12:56:40:
12:56:40:  <!-- User Information -->
12:56:40:  <passkey v='********************************'/>
12:56:40:  <team v=''/>
12:56:40:  <user v=''/>
12:56:40:
12:56:40:  <!-- Folding Slots -->
12:56:40:  <slot id='1' type='CPU'/>
12:56:40:</config>
12:57:36:Adding folding slot 00: PAUSED gpu:0:GF106 [GeForce GT 555M SDDR3] (waiting for idle)
12:57:36:Saving configuration to config.xml
12:57:36:<config>
12:57:36:  <!-- Network -->
12:57:36:  <proxy v=':8080'/>
12:57:36:
12:57:36:  <!-- Slot Control -->
12:57:36:  <pause-on-battery v='false'/>
12:57:36:
12:57:36:  <!-- User Information -->
12:57:36:  <passkey v='********************************'/>
12:57:36:  <team v=''/>
12:57:36:  <user v=''/>
12:57:36:
12:57:36:  <!-- Folding Slots -->
12:57:36:  <slot id='1' type='CPU'/>
12:57:36:  <slot id='0' type='GPU'/>
12:57:36:</config>
13:03:35:FS01:Shutting core down
13:03:36:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
13:03:37:WU01:FS00:News: Welcome to Folding@Home
13:03:37:WU01:FS00:Assigned to work server 171.67.108.142
13:03:37:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GF106 [GeForce GT 555M SDDR3] from 171.67.108.142
13:03:37:WU01:FS00:Connecting to 171.67.108.142:8080
13:03:38:WU01:FS00:Downloading 142.75KiB
13:03:39:WU01:FS00:Download complete
13:03:39:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8018 run:904 clone:1 gen:70 core:0x15 unit:0x000000556953ee2e500f1e725cd7b986
13:03:39:WU01:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
13:03:39:WU01:FS00:Connecting to www.stanford.edu:80
13:03:40:WU01:FS00:FahCore 15: Downloading 1.88MiB
13:03:42:WU00:FS01:0xa3:Client no longer detected. Shutting down core
13:03:42:WU00:FS01:0xa3:Folding@home Core Shutdown: CLIENT_DIED
13:03:42:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
13:03:42:WU00:FS01:Starting
13:03:42:WARNING:WU00:FS01:Changed SMP threads from 2 to 4 this can cause some work units to fail
13:03:42:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -np 4
13:03:42:WU00:FS01:Started FahCore on PID 5448
13:03:42:WU00:FS01:Core PID:2324
13:03:42:WU00:FS01:FahCore 0xa3 started
13:03:43:WU00:FS01:0xa3:
13:03:43:WU00:FS01:0xa3:*------------------------------*
13:03:43:WU00:FS01:0xa3:Folding@Home Gromacs SMP Core
13:03:43:WU00:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
13:03:43:WU00:FS01:0xa3:Preparing to commence simulation
13:03:43:WU00:FS01:0xa3:- Looking at optimizations...
13:03:43:WU00:FS01:0xa3:- Files status OK
13:03:43:WU00:FS01:0xa3:- Expanded 3849931 -> 4387808 (decompressed 113.9 percent)
13:03:43:WU00:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3849931 data_size=4387808, decompressed_data_size=4387808 diff=0
13:03:43:WU00:FS01:0xa3:- Digital signature verified
13:03:43:WU00:FS01:0xa3:Project: 8580 (Run 0, Clone 0, Gen 296)
13:03:43:WU00:FS01:0xa3:Assembly optimizations on if available.
13:03:43:WU00:FS01:0xa3:Entering M.D.
13:03:46:WU01:FS00:FahCore 15: 46.65%
13:03:49:WU00:FS01:0xa3:Mapping NT from 4 to 4
13:03:50:WU00:FS01:0xa3:Completed 0 out of 500000 steps  (0%)
13:03:50:FS01:Shutting core down
13:03:51:WU01:FS00:FahCore 15: Download complete
13:03:52:WU01:FS00:Valid core signature
13:03:52:WU01:FS00:Unpacked 7.71MiB to cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe
13:03:53:WU00:FS01:0xa3:Client no longer detected. Shutting down core
13:03:53:WU00:FS01:0xa3:Folding@home Core Shutdown: CLIENT_DIED
13:03:53:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
13:03:56:WU01:FS00:Starting
13:03:56:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 01 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
13:03:56:WU01:FS00:Started FahCore on PID 6968
13:03:58:WU01:FS00:Core PID:608
13:03:58:WU01:FS00:FahCore 0x15 started
13:03:58:WU01:FS00:0x15:
13:03:58:WU01:FS00:0x15:*------------------------------*
13:03:58:WU01:FS00:0x15:Folding@Home GPU Core
13:03:58:WU01:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
13:03:58:WU01:FS00:0x15:Build host             AmoebaRemote
13:03:58:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
13:03:58:WU01:FS00:0x15:Core                   15
13:03:58:WU01:FS00:0x15:Window's signal control handler registered.
13:03:58:WU01:FS00:0x15:Preparing to commence simulation
13:03:58:WU01:FS00:0x15:- Looking at optimizations...
13:03:58:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
13:03:58:WU01:FS00:0x15:- Created dyn
13:03:58:WU01:FS00:0x15:- Files status OK
13:03:58:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
13:03:58:WU01:FS00:0x15:- Expanded 145669 -> 660986 (decompressed 453.7 percent)
13:03:58:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=145669 data_size=660986, decompressed_data_size=660986 diff=0
13:03:58:WU01:FS00:0x15:- Digital signature verified
13:03:58:WU01:FS00:0x15:Project: 8018 (Run 904, Clone 1, Gen 70)
13:03:58:WU01:FS00:0x15:Assembly optimizations on if available.
13:03:58:WU01:FS00:0x15:Entering M.D.
13:04:00:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  2531961050 1636251217 409349421 2480008240 1765300708
13:04:00:WU01:FS00:0x15:GPU device id=0
13:04:00:WU01:FS00:0x15:Working on GRowing Old MAkes el Chrono Sweat
13:04:00:WU01:FS00:0x15:Client config unavailable.
13:04:00:WU01:FS00:0x15:Starting GUI Server
13:04:42:WU00:FS01:Starting
13:04:42:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 00 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -np 4
13:04:42:WU00:FS01:Started FahCore on PID 5800
13:04:42:WU00:FS01:Core PID:5240
13:04:42:WU00:FS01:FahCore 0xa3 started
13:04:43:WU00:FS01:0xa3:
13:04:43:WU00:FS01:0xa3:*------------------------------*
13:04:43:WU00:FS01:0xa3:Folding@Home Gromacs SMP Core
13:04:43:WU00:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
13:04:43:WU00:FS01:0xa3:Preparing to commence simulation
13:04:43:WU00:FS01:0xa3:- Looking at optimizations...
13:04:43:WU00:FS01:0xa3:- Files status OK
13:04:43:WU00:FS01:0xa3:- Expanded 3849931 -> 4387808 (decompressed 113.9 percent)
13:04:43:WU00:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3849931 data_size=4387808, decompressed_data_size=4387808 diff=0
13:04:43:WU00:FS01:0xa3:- Digital signature verified
13:04:43:WU00:FS01:0xa3:Project: 8580 (Run 0, Clone 0, Gen 296)
13:04:43:WU00:FS01:0xa3:Assembly optimizations on if available.
13:04:43:WU00:FS01:0xa3:Entering M.D.
13:04:49:WU00:FS01:0xa3:Mapping NT from 4 to 4
13:04:50:WU00:FS01:0xa3:Completed 0 out of 500000 steps  (0%)
13:05:03:Saving configuration to config.xml
13:05:03:<config>
13:05:03:  <!-- Folding Slot Configuration -->
13:05:03:  <power v='full'/>
13:05:03:
13:05:03:  <!-- Network -->
13:05:03:  <proxy v=':8080'/>
13:05:03:
13:05:03:  <!-- Slot Control -->
13:05:03:  <pause-on-battery v='false'/>
13:05:03:
13:05:03:  <!-- User Information -->
13:05:03:  <passkey v='********************************'/>
13:05:03:  <team v=''/>
13:05:03:  <user v=''/>
13:05:03:
13:05:03:  <!-- Folding Slots -->
13:05:03:  <slot id='1' type='CPU'/>
13:05:03:  <slot id='0' type='GPU'/>
13:05:03:</config>
13:05:26:WU01:FS00:0x15:Setting checkpoint frequency: 250000
13:05:26:WU01:FS00:0x15:Completed         3 out of 25000000 steps (0%).
13:38:08:WU01:FS00:0x15:Completed    250000 out of 25000000 steps (1%).
14:03:06:WU00:FS01:0xa3:Completed 5000 out of 500000 steps  (1%)
*** Just completed messages cut (multiple days) ***
21:51:03:WU01:FS00:0x15:Completed  15500000 out of 25000000 steps (62%).
21:51:51:WU00:FS01:0xa3:Completed 490000 out of 500000 steps  (98%)
21:51:52:WU02:FS01:Connecting to assign3.stanford.edu:8080
21:51:53:WU02:FS01:News: Welcome to Folding@Home
21:51:53:WU02:FS01:Assigned to work server 155.247.166.219
21:51:53:WU02:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 155.247.166.219
21:51:53:WU02:FS01:Connecting to 155.247.166.219:8080
21:51:53:WU02:FS01:Downloading 80.85KiB
21:51:53:WU02:FS01:Download complete
21:51:53:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:6364 run:2 clone:83 gen:38 core:0xa4 unit:0x0000002e0002894b52668b6d3554845e
21:51:53:WU02:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
21:51:53:WU02:FS01:Connecting to www.stanford.edu:80
21:51:54:WU02:FS01:FahCore a4: Downloading 2.89MiB
21:52:00:WU02:FS01:FahCore a4: 36.79%
21:52:06:WU02:FS01:FahCore a4: 75.75%
21:52:09:WU02:FS01:FahCore a4: Download complete
21:52:09:WU02:FS01:Valid core signature
21:52:10:WU02:FS01:Unpacked 9.59MiB to cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
22:43:54:WU00:FS01:0xa3:Completed 495000 out of 500000 steps  (99%)
22:46:51:WU01:FS00:0x15:Completed  15750000 out of 25000000 steps (63%).
23:33:48:WU00:FS01:0xa3:Completed 500000 out of 500000 steps  (100%)
23:33:53:WU00:FS01:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
23:34:03:WU00:FS01:0xa3:
23:34:03:WU00:FS01:0xa3:Finished Work Unit:
23:34:03:WU00:FS01:0xa3:- Reading up to 8058192 from "00/wudata_01.trr": Read 8058192
23:34:03:WU00:FS01:0xa3:trr file hash check passed.
23:34:03:WU00:FS01:0xa3:edr file hash check passed.
23:34:03:WU00:FS01:0xa3:logfile size: 76915
23:34:03:WU00:FS01:0xa3:Leaving Run
23:34:08:WU00:FS01:0xa3:- Writing 8171939 bytes of core data to disk...
23:34:09:WU00:FS01:0xa3:Done: 8171427 -> 7533083 (compressed to 92.1 percent)
23:34:09:WU00:FS01:0xa3:  ... Done.
23:34:14:WU00:FS01:0xa3:- Shutting down core
23:34:14:WU00:FS01:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
23:34:14:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
23:34:14:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:8580 run:0 clone:0 gen:296 core:0xa3 unit:0x00000d600a3b1e595122609acb258ede
23:34:14:WU00:FS01:Uploading 7.18MiB to 128.143.231.202
23:34:14:WU00:FS01:Connecting to 128.143.231.202:8080
23:34:15:WU02:FS01:Starting
23:34:15:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -np 4
23:34:15:WU02:FS01:Started FahCore on PID 1556
23:34:15:WU02:FS01:Core PID:7124
23:34:15:WU02:FS01:FahCore 0xa4 started
23:34:15:WU02:FS01:0xa4:
23:34:15:WU02:FS01:0xa4:*------------------------------*
23:34:15:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
23:34:15:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
23:34:15:WU02:FS01:0xa4:Preparing to commence simulation
23:34:15:WU02:FS01:0xa4:- Looking at optimizations...
23:34:15:WU02:FS01:0xa4:- Created dyn
23:34:15:WU02:FS01:0xa4:- Files status OK
23:34:15:WU02:FS01:0xa4:- Expanded 82278 -> 175532 (decompressed 213.3 percent)
23:34:15:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=82278 data_size=175532, decompressed_data_size=175532 diff=0
23:34:15:WU02:FS01:0xa4:- Digital signature verified
23:34:15:WU02:FS01:0xa4:Project: 6364 (Run 2, Clone 83, Gen 38)
23:34:15:WU02:FS01:0xa4:Assembly optimizations on if available.
23:34:15:WU02:FS01:0xa4:Entering M.D.
23:34:21:WU02:FS01:0xa4:Mapping NT from 4 to 4
23:34:21:WU00:FS01:Upload 10.44%
23:34:21:WU02:FS01:0xa4:Completed 0 out of 5000000 steps  (0%)
23:34:28:WU00:FS01:Upload 14.79%
*** Upload messages cut ***
23:36:44:WU00:FS01:Upload 100.00%
23:36:58:WU00:FS01:Upload complete
23:36:58:WU00:FS01:Server responded WORK_ACK (400)
23:36:58:WU00:FS01:Final credit estimate, 5721.00 points
23:36:58:WU00:FS01:Cleaning up
23:40:05:WU02:FS01:0xa4:Completed 50000 out of 5000000 steps  (1%)
******************************* Date: 2013-11-12 *******************************
23:45:53:WU02:FS01:0xa4:Completed 100000 out of 5000000 steps  (2%)
23:51:36:WU02:FS01:0xa4:Completed 150000 out of 5000000 steps  (3%)
09:01:53:WU02:FS01:0xa4:Completed 4850000 out of 5000000 steps  (97%)
09:03:17:WU01:FS00:0x15:Completed  17500000 out of 25000000 steps (70%).
09:11:50:WU02:FS01:0xa4:Completed 4900000 out of 5000000 steps  (98%)
09:11:51:WU00:FS01:Connecting to assign3.stanford.edu:8080
09:11:52:WU00:FS01:News: Welcome to Folding@Home
09:11:52:WU00:FS01:Assigned to work server 171.64.65.99
09:11:52:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 171.64.65.99
09:11:52:WU00:FS01:Connecting to 171.64.65.99:8080
09:11:54:WU00:FS01:Downloading 1.96MiB
09:11:58:WU00:FS01:Download complete
09:11:58:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7808 run:8 clone:250 gen:142 core:0xa4 unit:0x000000db0a3b1e874e31013feeb40f68
09:19:07:WU02:FS01:0xa4:Completed 4950000 out of 5000000 steps  (99%)
09:28:07:WU02:FS01:0xa4:Completed 5000000 out of 5000000 steps  (100%)
09:28:07:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
09:28:17:WU02:FS01:0xa4:
09:28:17:WU02:FS01:0xa4:Finished Work Unit:
09:28:17:WU02:FS01:0xa4:- Reading up to 827640 from "02/wudata_01.trr": Read 827640
09:28:17:WU02:FS01:0xa4:trr file hash check passed.
09:28:17:WU02:FS01:0xa4:- Reading up to 63480 from "02/wudata_01.xtc": Read 63480
09:28:17:WU02:FS01:0xa4:xtc file hash check passed.
09:28:17:WU02:FS01:0xa4:edr file hash check passed.
09:28:17:WU02:FS01:0xa4:logfile size: 82838
09:28:17:WU02:FS01:0xa4:Leaving Run
09:28:21:WU02:FS01:0xa4:- Writing 1044590 bytes of core data to disk...
09:28:21:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:28:21:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:6364 run:2 clone:83 gen:38 core:0xa4 unit:0x0000002e0002894b52668b6d3554845e
09:28:21:WU02:FS01:Uploading 847.08KiB to 155.247.166.219
09:28:21:WU02:FS01:Connecting to 155.247.166.219:8080
09:28:21:WU00:FS01:Starting
09:28:21:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -np 4
09:28:21:WU00:FS01:Started FahCore on PID 7104
09:28:21:WU00:FS01:Core PID:5836
09:28:21:WU00:FS01:FahCore 0xa4 started
09:28:22:WU00:FS01:0xa4:
09:28:22:WU00:FS01:0xa4:*------------------------------*
09:28:22:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
09:28:22:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
09:28:22:WU00:FS01:0xa4:Preparing to commence simulation
09:28:22:WU00:FS01:0xa4:- Looking at optimizations...
09:28:22:WU00:FS01:0xa4:- Created dyn
09:28:22:WU00:FS01:0xa4:- Files status OK
09:28:22:WU00:FS01:0xa4:- Expanded 2053839 -> 5365960 (decompressed 261.2 percent)
09:28:22:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053839 data_size=5365960, decompressed_data_size=5365960 diff=0
09:28:22:WU00:FS01:0xa4:- Digital signature verified
09:28:22:WU00:FS01:0xa4:Project: 7808 (Run 8, Clone 250, Gen 142)
09:28:22:WU00:FS01:0xa4:Assembly optimizations on if available.
09:28:22:WU00:FS01:0xa4:Entering M.D.
09:28:27:WU02:FS01:Upload 90.66%
09:28:28:WU00:FS01:0xa4:Mapping NT from 4 to 4
09:28:28:WU00:FS01:0xa4:Completed 0 out of 1500000 steps  (0%)
09:28:41:WU02:FS01:Upload complete
09:28:41:WU02:FS01:Server responded WORK_ACK (400)
09:28:41:WU02:FS01:Final credit estimate, 655.00 points
09:28:41:WU02:FS01:Cleaning up
09:34:50:WU01:FS00:0x15:Completed  17750000 out of 25000000 steps (71%).
10:13:36:WU00:FS01:0xa4:Completed 15000 out of 1500000 steps  (1%)
21:48:30:WU00:FS01:0xa4:Completed 765000 out of 1500000 steps  (51%)
21:55:44:WU01:FS00:0x15:Completed  24500000 out of 25000000 steps (98%).
21:55:45:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
21:55:46:WU02:FS00:News: Welcome to Folding@Home
21:55:46:WU02:FS00:Assigned to work server 171.67.108.142
21:55:46:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GF106 [GeForce GT 555M SDDR3] from 171.67.108.142
21:55:46:WU02:FS00:Connecting to 171.67.108.142:8080
21:55:46:WU02:FS00:Downloading 142.42KiB
21:55:48:WU02:FS00:Download complete
21:55:48:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8018 run:174 clone:0 gen:182 core:0x15 unit:0x000000d26953ee2e500f1be2f6c23eb0
22:33:12:WU00:FS01:0xa4:Completed 780000 out of 1500000 steps  (52%)
23:11:19:WU01:FS00:0x15:Completed  24750000 out of 25000000 steps (99%).
23:17:28:WU00:FS01:0xa4:Completed 795000 out of 1500000 steps  (53%)
00:01:43:WU00:FS01:0xa4:Completed 810000 out of 1500000 steps  (54%)
00:28:02:WU01:FS00:0x15:Completed  25000000 out of 25000000 steps (100%).
00:28:21:WU01:FS00:0x15:Finished fah_main status=0
00:28:21:WU01:FS00:0x15:Successful run
00:28:21:WU01:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
00:28:31:WU01:FS00:0x15:Reserved 435916 bytes for xtc file; Cosm status=0
00:28:31:WU01:FS00:0x15:Allocated 435916 bytes for xtc file
00:28:31:WU01:FS00:0x15:- Reading up to 435916 from "01/wudata_01.xtc": Read 435916
00:28:31:WU01:FS00:0x15:Read 435916 bytes from xtc file; available packet space=785994548
00:28:31:WU01:FS00:0x15:xtc file hash check passed.
00:28:31:WU01:FS00:0x15:Reserved 54408 54408 785994548 bytes for arc file=<01/wudata_01.trr> Cosm status=0
00:28:31:WU01:FS00:0x15:Allocated 54408 bytes for arc file
00:28:31:WU01:FS00:0x15:- Reading up to 54408 from "01/wudata_01.trr": Read 54408
00:28:31:WU01:FS00:0x15:Read 54408 bytes from arc file; available packet space=785940140
00:28:31:WU01:FS00:0x15:trr file hash check passed.
00:28:31:WU01:FS00:0x15:Allocated 544 bytes for edr file
00:28:31:WU01:FS00:0x15:Read bedfile
00:28:31:WU01:FS00:0x15:edr file hash check passed.
00:28:31:WU01:FS00:0x15:Allocated 32125 bytes for logfile
00:28:31:WU01:FS00:0x15:Read logfile
00:28:31:WU01:FS00:0x15:GuardedRun: success in DynamicWrapper
00:28:31:WU01:FS00:0x15:GuardedRun: done
00:28:31:WU01:FS00:0x15:Run: GuardedRun completed.
00:28:34:WU01:FS00:0x15:+ Opened results file
00:28:34:WU01:FS00:0x15:- Writing 523505 bytes of core data to disk...
00:28:35:WU01:FS00:0x15:Done: 522993 -> 500743 (compressed to 95.7 percent)
00:28:35:WU01:FS00:0x15:  ... Done.
00:28:35:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
00:28:35:WU01:FS00:0x15:Shutting down core
00:28:35:WU01:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
00:28:35:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:28:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8018 run:904 clone:1 gen:70 core:0x15 unit:0x000000556953ee2e500f1e725cd7b986
00:28:35:WU01:FS00:Uploading 489.51KiB to 171.67.108.142
00:28:35:WU01:FS00:Connecting to 171.67.108.142:8080
00:28:35:WU02:FS00:Starting
00:28:35:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
00:28:35:WU02:FS00:Started FahCore on PID 6320
00:28:36:WU02:FS00:Core PID:1328
00:28:36:WU02:FS00:FahCore 0x15 started
00:28:36:WU02:FS00:0x15:
00:28:36:WU02:FS00:0x15:*------------------------------*
00:28:36:WU02:FS00:0x15:Folding@Home GPU Core
00:28:36:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
00:28:36:WU02:FS00:0x15:Build host             AmoebaRemote
00:28:36:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
00:28:36:WU02:FS00:0x15:Core                   15
00:28:36:WU02:FS00:0x15:Window's signal control handler registered.
00:28:36:WU02:FS00:0x15:Preparing to commence simulation
00:28:36:WU02:FS00:0x15:- Looking at optimizations...
00:28:36:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
00:28:36:WU02:FS00:0x15:- Created dyn
00:28:36:WU02:FS00:0x15:- Files status OK
00:28:36:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
00:28:36:WU02:FS00:0x15:- Expanded 145322 -> 660986 (decompressed 454.8 percent)
00:28:36:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=145322 data_size=660986, decompressed_data_size=660986 diff=0
00:28:36:WU02:FS00:0x15:- Digital signature verified
00:28:36:WU02:FS00:0x15:Project: 8018 (Run 174, Clone 0, Gen 182)
00:28:36:WU02:FS00:0x15:Assembly optimizations on if available.
00:28:36:WU02:FS00:0x15:Entering M.D.
00:28:38:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1446005502 279202831 2215731687 1657145824 2420177018
00:28:38:WU02:FS00:0x15:GPU device id=0
00:28:38:WU02:FS00:0x15:Working on GRowing Old MAkes el Chrono Sweat
00:28:38:WU02:FS00:0x15:Client config unavailable.
00:28:38:WU02:FS00:0x15:Starting GUI Server
00:28:49:WU01:FS00:Upload complete
00:28:49:WU01:FS00:Server responded WORK_ACK (400)
00:28:49:WU01:FS00:Final credit estimate, 5757.00 points
00:28:49:WU01:FS00:Cleaning up
00:29:44:WU02:FS00:0x15:Setting checkpoint frequency: 250000
00:29:44:WU02:FS00:0x15:Completed         3 out of 25000000 steps (0%).
00:43:22:WU00:FS01:0xa4:Completed 825000 out of 1500000 steps  (55%)
******************************* Date: 2013-11-15 *******************************
01:24:46:WU00:FS01:0xa4:Completed 840000 out of 1500000 steps  (56%)
01:58:53:WU02:FS00:0x15:Completed    250000 out of 25000000 steps (1%).
04:35:55:WU00:FS01:0xa4:Completed 1425000 out of 1500000 steps  (95%)
05:14:14:WU02:FS00:0x15:Completed   5000000 out of 25000000 steps (20%).
05:57:20:WU00:FS01:0xa4:Completed 1455000 out of 1500000 steps  (97%)
06:38:09:WU00:FS01:0xa4:Completed 1470000 out of 1500000 steps  (98%)
06:38:10:WU01:FS01:Connecting to assign3.stanford.edu:8080
06:38:11:WU01:FS01:News: Welcome to Folding@Home
06:38:11:WU01:FS01:Assigned to work server 171.64.65.101
06:38:11:WU01:FS01:Requesting new work unit for slot 01: RUNNING cpu:4 from 171.64.65.101
06:38:11:WU01:FS01:Connecting to 171.64.65.101:8080
06:38:11:WU01:FS01:Downloading 534.95KiB
06:38:14:WU01:FS01:Download complete
06:38:14:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7646 run:7 clone:0 gen:172 core:0xa4 unit:0x00000194664f2dcd4fa7fdc4d4769e5d
06:43:42:WU02:FS00:0x15:Completed   5250000 out of 25000000 steps (21%).
07:18:48:WU00:FS01:0xa4:Completed 1485000 out of 1500000 steps  (99%)
07:59:52:WU00:FS01:0xa4:Completed 1500000 out of 1500000 steps  (100%)
07:59:53:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
08:00:03:WU00:FS01:0xa4:
08:00:03:WU00:FS01:0xa4:Finished Work Unit:
08:00:03:WU00:FS01:0xa4:- Reading up to 2851056 from "00/wudata_01.trr": Read 2851056
08:00:03:WU00:FS01:0xa4:trr file hash check passed.
08:00:03:WU00:FS01:0xa4:- Reading up to 1524156 from "00/wudata_01.xtc": Read 1524156
08:00:03:WU00:FS01:0xa4:xtc file hash check passed.
08:00:03:WU00:FS01:0xa4:edr file hash check passed.
08:00:03:WU00:FS01:0xa4:logfile size: 40991
08:00:03:WU00:FS01:0xa4:Leaving Run
08:00:05:WU00:FS01:0xa4:- Writing 4421215 bytes of core data to disk...
08:00:06:WU00:FS01:0xa4:Done: 4420703 -> 4245588 (compressed to 96.0 percent)
08:00:06:WU00:FS01:0xa4:  ... Done.
08:00:08:WU00:FS01:0xa4:- Shutting down core
08:00:08:WU00:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
08:00:08:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:00:08:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:7808 run:8 clone:250 gen:142 core:0xa4 unit:0x000000db0a3b1e874e31013feeb40f68
08:00:08:WU00:FS01:Uploading 4.05MiB to 171.64.65.99
08:00:08:WU01:FS01:Starting
08:00:08:WU00:FS01:Connecting to 171.64.65.99:8080
08:00:08:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 1308 -checkpoint 15 -np 4
08:00:08:WU01:FS01:Started FahCore on PID 5868
08:00:08:WU01:FS01:Core PID:5708
08:00:08:WU01:FS01:FahCore 0xa4 started
08:00:09:WU01:FS01:0xa4:
08:00:09:WU01:FS01:0xa4:*------------------------------*
08:00:09:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
08:00:09:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
08:00:09:WU01:FS01:0xa4:Preparing to commence simulation
08:00:09:WU01:FS01:0xa4:- Looking at optimizations...
08:00:09:WU01:FS01:0xa4:- Created dyn
08:00:09:WU01:FS01:0xa4:- Files status OK
08:00:09:WU01:FS01:0xa4:- Expanded 547277 -> 844760 (decompressed 154.3 percent)
08:00:09:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547277 data_size=844760, decompressed_data_size=844760 diff=0
08:00:09:WU01:FS01:0xa4:- Digital signature verified
08:00:09:WU01:FS01:0xa4:Project: 7646 (Run 7, Clone 0, Gen 172)
08:00:09:WU01:FS01:0xa4:Assembly optimizations on if available.
08:00:09:WU01:FS01:0xa4:Entering M.D.
08:00:14:WU00:FS01:Upload 16.98%
08:00:15:WU01:FS01:0xa4:Mapping NT from 4 to 4
08:00:15:WU01:FS01:0xa4:Completed 0 out of 2500000 steps  (0%)
08:00:20:WU00:FS01:Upload 23.15%
*** Upload progress cut ***
08:01:27:WU00:FS01:Upload 97.24%
08:01:42:WU00:FS01:Upload complete
08:01:42:WU00:FS01:Server responded WORK_ACK (400)
08:01:42:WU00:FS01:Final credit estimate, 5565.00 points
08:01:42:WU00:FS01:Cleaning up
08:13:10:WU02:FS00:0x15:Completed   5500000 out of 25000000 steps (22%).
******************************* Date: 2013-11-16 *******************************
09:21:44:WU01:FS01:0xa4:Completed 25000 out of 2500000 steps  (1%)
09:26:47:WU02:FS00:0x15:Completed   5750000 out of 25000000 steps (23%).
*** Just completed messages cut (multiple days) NOW on 20 November 2013 ***
08:51:55:WU01:FS01:0xa4:Completed 1800000 out of 2500000 steps  (72%)
09:27:26:WU02:FS00:0x15:Completed  22250000 out of 25000000 steps (89%).
After:
*********************** Log Started 2013-11-20T10:50:57Z ***********************
10:50:57:************************* Folding@home Client *************************
10:50:57:      Website: http://folding.stanford.edu/
10:50:57:    Copyright: (c) 2009-2013 Stanford University
10:50:57:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:50:57:         Args:
10:50:57:       Config: C:/Users/HRH/AppData/Roaming/FAHClient/config.xml
10:50:57:******************************** Build ********************************
10:50:57:      Version: 7.3.6
10:50:57:         Date: Feb 18 2013
10:50:57:         Time: 15:25:17
10:50:57:      SVN Rev: 3923
10:50:57:       Branch: fah/trunk/client
10:50:57:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
10:50:57:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
10:50:57:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
10:50:57:     Platform: win32 XP
10:50:57:         Bits: 32
10:50:57:         Mode: Release
10:50:57:******************************* System ********************************
10:50:57:          CPU: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
10:50:57:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
10:50:57:         CPUs: 4
10:50:57:       Memory: 5.86GiB
10:50:57:  Free Memory: 4.23GiB
10:50:57:      Threads: WINDOWS_THREADS
10:50:57:  Has Battery: true
10:50:57:   On Battery: false
10:50:57:   UTC offset: 0
10:50:57:          PID: 5016
10:50:57:          CWD: C:/Users/HRH/AppData/Roaming/FAHClient
10:50:57:           OS: Windows 7 Home Premium
10:50:57:      OS Arch: AMD64
10:50:57:         GPUs: 1
10:50:57:        GPU 0: NVIDIA:2 GF106 [GeForce GT 555M SDDR3]
10:50:57:         CUDA: 2.1
10:50:57:  CUDA Driver: 3020
10:50:57:Win32 Service: false
10:50:57:***********************************************************************
10:50:57:<config>
10:50:57:  <!-- Folding Slot Configuration -->
10:50:57:  <power v='full'/>
10:50:57:
10:50:57:  <!-- Network -->
10:50:57:  <proxy v=':8080'/>
10:50:57:
10:50:57:  <!-- Slot Control -->
10:50:57:  <pause-on-battery v='false'/>
10:50:57:
10:50:57:  <!-- User Information -->
10:50:57:  <passkey v='********************************'/>
10:50:57:  <team v=''/>
10:50:57:  <user v=''/>
10:50:57:
10:50:57:</config>
10:51:01:WU02:FS00:0x15:
10:51:01:WU02:FS00:0x15:*------------------------------*
10:51:01:WU02:FS00:0x15:Folding@Home GPU Core
10:51:01:WU02:FS00:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
10:51:01:WU02:FS00:0x15:Build host             AmoebaRemote
10:51:01:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
10:51:01:WU02:FS00:0x15:Core                   15
10:51:01:WU02:FS00:0x15:Window's signal control handler registered.
10:51:01:WU02:FS00:0x15:Preparing to commence simulation
10:51:01:WU02:FS00:0x15:- Looking at optimizations...
10:51:01:WU02:FS00:0x15:- Files status OK
10:51:01:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
10:51:01:WU02:FS00:0x15:- Expanded 145322 -> 660986 (decompressed 454.8 percent)
10:51:01:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=145322 data_size=660986, decompressed_data_size=660986 diff=0
10:51:01:WU02:FS00:0x15:- Digital signature verified
10:51:01:WU02:FS00:0x15:Project: 8018 (Run 174, Clone 0, Gen 182)
10:51:01:WU02:FS00:0x15:Assembly optimizations on if available.
10:51:01:WU02:FS00:0x15:Entering M.D.
10:51:02:WU01:FS01:Server responded WORK_ACK (400)
10:51:02:WU01:FS01:Cleaning up
10:51:03:WU02:FS00:0x15:Will resume from checkpoint file 02/wudata_01.ckp
10:51:03:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1446005502 279202831 2215731687 1657145824 2420177018
10:51:03:WU02:FS00:0x15:GPU device id=0
10:51:04:WU02:FS00:0x15:Working on GRowing Old MAkes el Chrono Sweat
10:51:04:WU02:FS00:0x15:Client config unavailable.
10:51:04:WU02:FS00:0x15:Starting GUI Server
10:52:19:WU02:FS00:0x15:Resuming from checkpoint
10:52:19:WU02:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
10:52:19:WU02:FS00:0x15:   0   1446005502   1446005502
10:52:19:WU02:FS00:0x15:   1    279202831    279202831
10:52:19:WU02:FS00:0x15:   2   2215731687   2215731687
10:52:19:WU02:FS00:0x15:   3   1657145824   1657145824
10:52:19:WU02:FS00:0x15:   4   2420177018   2420177018
10:52:19:WU02:FS00:0x15:fcCheckPointResume: file hashes same.
10:52:19:WU02:FS00:0x15:fcCheckPointResume: state restored.
10:52:19:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.log Verified 02/wudata_01.log
10:52:19:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.trr Verified 02/wudata_01.trr
10:52:19:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.xtc Verified 02/wudata_01.xtc
10:52:19:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.edr Verified 02/wudata_01.edr
10:55:12:<config>
10:55:12:  <!-- Folding Slot Configuration -->
10:55:12:  <power v='full'/>
10:55:12:
10:55:12:  <!-- Network -->
10:55:12:  <proxy v=':8080'/>
10:55:12:
10:55:12:  <!-- Slot Control -->
10:55:12:  <pause-on-battery v='false'/>
10:55:12:
10:55:12:  <!-- User Information -->
10:55:12:  <passkey v='********************************'/>
10:55:12:  <team v=''/>
10:55:12:  <user v=''/>
10:55:12:
10:55:12:  <!-- Folding Slots -->
10:55:12:  <slot id='0' type='GPU'/>
10:55:12:  <slot id='1' type='CPU'>
10:55:12:    <cpus v='-1'/>
10:55:12:  </slot>
10:55:12:</config>
10:55:12:WU00:FS01:Connecting to assign3.stanford.edu:8080
10:55:13:WU00:FS01:News: Welcome to Folding@Home
10:55:13:WU00:FS01:Assigned to work server 171.64.65.101
10:55:13:WU00:FS01:Requesting new work unit for slot 01: READY cpu:4 from 171.64.65.101
10:55:13:WU00:FS01:Connecting to 171.64.65.101:8080
10:55:14:WU00:FS01:Downloading 535.67KiB
10:55:16:WU00:FS01:Download complete
10:55:16:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7647 run:14 clone:0 gen:172 core:0xa4 unit:0x00000221664f2dcd4fa7fe34fd49254b
10:55:16:WU00:FS01:Starting
10:55:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/HRH/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 5016 -checkpoint 15 -np 4
10:55:16:WU00:FS01:Started FahCore on PID 6324
10:55:16:WU00:FS01:Core PID:6420
10:55:16:WU00:FS01:FahCore 0xa4 started
10:55:17:WU00:FS01:0xa4:
10:55:17:WU00:FS01:0xa4:*------------------------------*
10:55:17:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
10:55:17:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
10:55:17:WU00:FS01:0xa4:Preparing to commence simulation
10:55:17:WU00:FS01:0xa4:- Looking at optimizations...
10:55:17:WU00:FS01:0xa4:- Created dyn
10:55:17:WU00:FS01:0xa4:- Files status OK
10:55:17:WU00:FS01:0xa4:- Expanded 548012 -> 847596 (decompressed 154.6 percent)
10:55:17:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=548012 data_size=847596, decompressed_data_size=847596 diff=0
10:55:17:WU00:FS01:0xa4:- Digital signature verified
10:55:17:WU00:FS01:0xa4:Project: 7647 (Run 14, Clone 0, Gen 172)
10:55:17:WU00:FS01:0xa4:Assembly optimizations on if available.
10:55:17:WU00:FS01:0xa4:Entering M.D.
10:55:23:WU00:FS01:0xa4:Mapping NT from 4 to 4
10:55:23:WU00:FS01:0xa4:Completed 0 out of 2500000 steps  (0%)
11:54:42:WU02:FS00:0x15:Completed  22750000 out of 25000000 steps (91%).
Re: WU got DUMPED !
When you started FAH for the first time, it should have asked you for your user name and other identifying information. They were not set, and normally they're recorded in the configuration file. For some reason, that didn't happen.
In your case, the config.xml file is located at C:/Users/HRH/AppData/Roaming/FAHClient/config.xml and apparently it now contains the following:
<config>
  <power v='full'/>
 <!-- Network -->
 <proxy v=':8080'/>
  <team v=''/>
  <user v=''/>
</config>
Notice that "user" and "team" are not set, although you do have a passkey. That's perfectly valid, but rather unusual. Similarly, slot id=1 is defined before slot id=0 which is also unusual (but also non-fatal). Your "before" log shows lots of changes, and it's not clear what you were trying to accomplish. FAH normally works quite nicely with default settings and/or minimal changes.
The only reason the WU was DUMPED was that the slot that the WU was associated with was deleted and it has been recreated automatically (but after the WU was gone). That never happens to most people.
Re: WU got DUMPED !
Justin wrote:...I also had problems trying to figure out why the GPU wasn't doing anything when I first installed the software so did dip into the configuration but I'm fairly certain that several WUs for CPU/GPU got completed before the reboot and the dump took place...
FYI, by default, the GPU is only utilized if the system is idle since screen lag may have a negative impact on the donor. However, that can be changed by setting the Power Slider to Full, which you have done.
If the system is non-dedicated and you use daily applications, it may be possible that F@H folds better with 3 CPUs instead of 4 CPUs. The reason is that CPU folding is highly synchronous process so any disruptions to it will have a negative impact, like other applications "borrowing" CPU cycles from CPU folding. To change the CPU value, please open Advanced Control (AKA FAHControl) -> Configure -> Slots Tab -> CPU -> There you can change the value from -1 to 3 and then save it.
Justin
Re: WU got DUMPED !
Post by Justin »
Sorry for the confusion, I read someone's post saying to remove the user details from the logs. So I did !
What I was trying to do on the 9th was to get the GPU to fold before I left it alone to get on with it. If I'd just left it alone it would have folded, but I didn't know that then :roll:
I also changed it so it would fold on battery.
I have 6 config files, I list them below in chronological order and their contents (I have removed the Team, User, Passkey info):
config-20131109-124650.xml  timestamp: 09/11/2013 12:45
<?xml version="1.0"?>
-<config>
<!-- Network -->
<proxy v=":8080"/>
<team v="Team_ID"/> <user v="User_ID"/>
<slot type="GPU" id="0"/>
<slot type="CPU" id="1"/>
</config>
config-20131109-124720.xml  timestamp: 09/11/2013 12:46
-<config>
<!-- Network -->
<proxy v=":8080"/>
<passkey v="Passkey_ID"/> <team v="Team_ID"/> <user v="User_ID"/>
</config>
config-20131109-125640.xml  timestamp: 09/11/2013 12:47
-<config>
<!-- Network -->
<proxy v=":8080"/>
<pause-on-battery v="false"/>
</config>
config-20131109-125736.xml  timestamp: 09/11/2013 12:56
-<config>
<!-- Network -->
<proxy v=":8080"/>
</config>
config-20131109-130503.xml  timestamp: 09/11/2013 12:57
-<config>
<!-- Network -->
<proxy v=":8080"/>
</config>
config-20131120-105512.xml  timestamp: 20/11/2013 13:05
-<config>
<power v="full"/>
<!-- Network -->
<proxy v=":8080"/>
</config>
Re: WU got DUMPED !
Please note that what you posted above are all previous configurations. It means that F@H isn't using them now. The current configuration is visible in the initial section of the log file. To get the best idea of your set-up, do a restart of FAHClient or the system (which ever is easier for you) and after F@H has been running for an hour or so, please post the entire log so we can have an idea of your system and can guide you for further tweaks if needed.
