change to not run as service
tmillic
Hardware configuration: AMD3200+ w/ NVIDIA GT220.
Tyan S2912 with 1 Opteron 2347HE.
Via C3.
Post by tmillic »
Hello,
I made the mistake of setting folding at home to run as a service during installation. I would just let it finish a work unit completely, then re-install with the correct setting, but the following command isn't working:
tom@quartet:~$ sudo /etc/init.d/FAHClient start -- finish
Starting fahclient ... FAIL
tom@quartet:~$
Is there a way to either get the option to stop at the end of the work unit to work, or to change the options of whether to start as a service or not?
Thanks.
bollix47
Re: change to not run as service
Post by bollix47 »
If you have FAHControl installed you can right click on the slot and select Finish.
There is also a max-units config option:
max-units               <integer=0>             Process at most this number of units, then pause.
To stop the service (i.e. FAHClient) type: sudo /etc/init.d/FAHClient stop
To remove the service type: sudo update-rc.d -f FAHClient remove
To offer the best alternative, please explain why the service install is not working, and if not starting the client as a service, do you plan to start it manually each time?
tmillic
Via C3.
Post by tmillic »
The service install does work, but I'd like to have the computer's resources for other things from time to time and would like to be able to let it complete a unit and stop before I intend to use it for other things. I would like to start it manually each time as well, so that it won't start and download a work unit that it won't be able to finish before being given other tasks (by me).
I don't have fahcontrol installed. There is no desktop environment at all installed for a gui program like fahcontrol.
Post by calxalot »
You could leave the service install alone, and just set to not start the service at boot:
Create file /etc/default/fahclient with one line:
ENABLE=false
You can then manually start and stop the service with the usual commands.
If you need to start the service with extra args passed to the client, you need to use '--'. eg
sudo /etc/init.d/FAHClient start -- --finish
You can also start without options, and use
FAHClient --send-finish
But it is probably better to just use FAHControl (which you can use remotely).
Edit: you might also want to add pause-on-start true to the client config.xml
Edit2: note that if you use --finish, the client will exit after uploading but the client will immediately respawn and get more work if you don't have pause-on-start. (because service starts client with --daemon)
tmillic
Via C3.
Post by tmillic »
Thanks!
It looks like I had that command wrong by not having 2 sets of dashes. (Why 2?)
Post by calxalot »
Two dashes is the standard for longopts. The first two dashes mark end of options for the start script, so anything else is passed to the client.
Post by calxalot »
If you use ENABLE=false, you will need to start the service with
sudo /etc/init.d/FAHClient force-start
tmillic wrote: the following command isn't working:
tom@quartet:~$
I'm not a linux guru so don't shoot me if I' wrong. Shouldn't that be
sudo /etc/init.d/FAHClient start --finish
(no space before finish).
... or maybe
FAHClient --send-command finish
(which doesn't need the sudo).
Yep.
