ERROR:WU00:FS01:: Access is denied.
Prariredog
Post by Prariredog »
I keep on getting this error when i'm even trying to fold with my CPU? I am not receiving WU?
10:46:56:WU01:FS00:News: Welcome to Folding@Home10:46:56:WU01:FS00:Assigned to work server 171.67.108.11
10:46:56:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.11
10:46:56:WU01:FS00:Connecting to 171.67.108.11:8080
10:46:57:WU01:FS00:Downloading 46.04KiB
10:46:57:WU01:FS00:Download complete
10:46:57:WU01:FS00:Received Unit:
10:46:57:ERROR:WU01:FS00:Exception: Failed to advance statement result: Some kind of disk I/O error occurred
10:46:57:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GT200 [GeForce GTX 260] from 171.67.108.11
10:46:57:WU01:FS00:Connecting to 171.67.108.11:8080
10:46:57:WU01:FS00:Downloading 46.10KiB
Work server *NOT DOWN:
http://fah-web.stanford.edu/logs/155.24 ... 9.log.html
Collection Server:
http://fah-web.stanford.edu/logs/155.24 ... 0.log.html
Re: ERROR:WU00:FS01:: Access is denied.
Welcome to the F@H Forum Prariredog,
Please note that we can't view the image that you posted. I checked it, and it seems that you need to be logged (into the other forum) to view the image.
The log shows us that your FAHClient contacted the Servers for the WU:
Was assigned to the Work Server that best matches your Slot configuration:
The Work Server assigned you a WU:
The WU was successfully downloaded:
However, it seems that it couldn't save the GPU WU on your system. The same process happened again on a different WU.
Can you please post the initial section of the F@H log so that we can see what is your system configuration and your F@H settings? Moreover, have you run check disk (http://www.howtogeek.com/howto/windows- ... ws-vista/#) on your system? Do you have sufficient free space on your disk?
How is FAH being started? Maybe it configured itself to start automatically after a reboot or maybe you're starting it manually. If you're starting it manually, are you using a shortcut that was supplied during installation? Does more than one user who might be using FAH log on to your OS?
What is your FAH account name?
Prariredog
I have enough storage I have a 3tb and a 160gig hard drive but I keep on getting this anyways my graphics card is overclocked.
Prariredog
Got it never mind had to run it on full and as a administrator
It is either not installed correctly or you're not starting it correctly.
The program is supposed to be started in a predefined directory, not in the root directory or the program_files directory. You will NOT need administrator privileges to start it. In the All Programs directory, find FAHClient and inside of that, you should find a few shortcuts. Use them.
If those shortcuts do not exist, uninstall and reinstall the software. Then open the FAH Data Directory and you should find subdirectories such as logs, cores, themes, configs work and files such as sample-config.xml and config.xml. You're using an empty config.xml which means you did not properly process the setup which asked you for your username and other preferences.
