project:7811 run:0 clone:105 gen:581
davidcoton
Post by davidcoton »
Is it just me? This GPU otherwise apparently stable on last 25 units, all 7810/7811, since moving from Windows PC to Linux PC.
03:29:10:WU02:FS01:0x17:*********************** Log Started 2013-11-19T03:29:10Z ***********************
04:17:47:WU02:FS01:0x17:Bad State detected... attempting to resume from last good checkpoint  [i]three times[/i]
04:28:10:WU02:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
04:28:10:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:28:10:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:7811 run:0 clone:105 gen:581 core:0x17 unit:0x000002840a3b1e8651db471fa6931adb
David
ChristianVirtual
Re: project:7811 run:0 clone:105 gen:581
Post by ChristianVirtual »
Please add the config section from log file ... What GPU ? Overclocked ?
davidcoton
GTX660ti. Has adaptive clocking which is flat out (705MHz) but no forced overclocking. Temp stable below 60C.
Card was also previously reasonably error free running in a Windows PC.
I can't see any clues here, hence the post here to see if the WU is known bad, known good, or so far unknown.
*********************** Log Started 2013-11-16T00:04:21Z ***********************
00:04:21:************************* Folding@home Client *************************
00:04:21:    Website: http://folding.stanford.edu/
00:04:21:  Copyright: (c) 2009-2013 Stanford University
00:04:21:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:04:21:       Args: --child --lifeline 1031 /etc/fahclient/config.xml --run-as
00:04:21:             fahclient --pid-file=/var/run/fahclient.pid --daemon
00:04:21:     Config: /etc/fahclient/config.xml
00:04:21:******************************** Build ********************************
00:04:21:    Version: 7.3.6
00:04:21:       Date: Feb 18 2013
00:04:21:       Time: 07:24:08
00:04:21:    SVN Rev: 3923
00:04:21:     Branch: fah/trunk/client
00:04:21:   Compiler: GNU 4.4.7
00:04:21:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
00:04:21:             -fno-unsafe-math-optimizations -msse2
00:04:21:   Platform: linux2 3.2.0-1-amd64
00:04:21:       Bits: 64
00:04:21:       Mode: Release
00:04:21:******************************* System ********************************
00:04:21:        CPU: AMD Phenom(tm) II X6 1055T Processor
00:04:21:     CPU ID: AuthenticAMD Family 16 Model 10 Stepping 0
00:04:21:       CPUs: 6
00:04:21:     Memory: 3.86GiB
00:04:21:Free Memory: 3.50GiB
00:04:21:    Threads: POSIX_THREADS
00:04:21:Has Battery: false
00:04:21: On Battery: false
00:04:21: UTC offset: 0
00:04:21:        PID: 1082
00:04:21:        CWD: /var/lib/fahclient
00:04:21:         OS: Linux 3.8.0-27-generic x86_64
00:04:21:    OS Arch: AMD64
00:04:21:       GPUs: 1
00:04:21:      GPU 0: NVIDIA:3 GK104 [GeForce GTX 660 Ti]
00:04:21:       CUDA: 3.0
00:04:21:CUDA Driver: 5000
00:04:21:***********************************************************************
00:04:21:<config>
00:04:21:  <!-- Client Control -->
00:04:21:  <fold-anon v='true'/>
00:04:21:
00:04:21:  <!-- Folding Slot Configuration -->
00:04:21:  <client-type v='advanced'/>
00:04:21:  <power v='full'/>
00:04:21:
00:04:21:  <!-- HTTP Server -->
00:04:21:  <allow v='127.0.0.1 192.168.1.0/24'/>
00:04:21:
00:04:21:  <!-- Network -->
00:04:21:  <proxy v=':8080'/>
00:04:21:
00:04:21:  <!-- Remote Command Server -->
00:04:21:  <password v='*******'/>
00:04:21:
00:04:21:  <!-- User Information -->
00:04:21:  <passkey v='********************************'/>
00:04:21:  <user v='davidcoton'/>
00:04:21:
00:04:21:  <!-- Folding Slots -->
00:04:21:  <slot id='0' type='CPU'>
00:04:21:    <cpus v='5'/>
00:04:21:  </slot>
00:04:21:  <slot id='1' type='GPU'/>
00:04:21:</config>
David
Persons have reported that stable overclocks in Windows have not been stable in Linux. Is there a factory overclock on the card or is it running at reference settings?
And yes, someone else has successfully completed the WU already.
davidcoton
OK, I'll keep an eye on it. It's only one occurrence in 25 WUs so far (correction: now 26 WUs).
From memory, this was a reference setting card -- I've had it some time and factory overclocks were not (widely) available then.
David
I successfully folded several FahCore_17 WUs under Ubuntu LTS 64-bit on my EVGA GTX 660 Ti (factory overclocked) without any issues. The only time I encountered hardware issues was when my CPU/RAM was overclocked from the BIOS. While the settings were stable under Windows, they were unstable under Ubuntu so in the end, I created a default settings profile in the BIOS and would load that up before booting into Ubuntu and change it back to the overclocked when booting into Windows.
