Bad GPU's ?
Roswell_ET
Hardware configuration: ASRock X79 Extreme6
Intel Xeon E5-2609 Sandy Bridge-EP 2.4GHz 10MB L3 Cache
Kingston HyperX Beast 32GB (4 x 8GB)
(1) Radeon HD 7990
(1) Radeon HD 7970
(1) GTX 780
450,000 ppd
LIGHTNING-1300 1300W Continuous
Kingston SSDNow 120 GB
Windows 7 Home Premium SP1 64-bit
Rosewill THOR V2 Gaming ATX Full Tower
Bad GPU's ?
Post by Roswell_ET »
I think I have problems!
Started a new system and it was running just fine until I stopped it and added a new card from another system.
new system hd 7990 and hd 7970 added gtx 780. FAHControl when turned on saw the hd7970, gtx 780 and half of the hd7990.
I added a slot and started FAHControl only to have one of the WU's ignored and a new one started.
*********************** Log Started 2013-11-09T23:38:52Z ***********************
23:38:52:************************* Folding@home Client *************************
23:38:52:      Website: http://folding.stanford.edu/
23:38:52:    Copyright: (c) 2009-2013 Stanford University
23:38:52:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:38:52:         Args: --open-web-control
23:38:52:       Config: e:/Users/Roswell_ET/AppData/Roaming/FAHClient/config.xml
23:38:52:******************************** Build ********************************
23:38:52:      Version: 7.3.6
23:38:52:         Date: Feb 18 2013
23:38:52:         Time: 15:25:17
23:38:52:      SVN Rev: 3923
23:38:52:       Branch: fah/trunk/client
23:38:52:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:38:52:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:38:52:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:38:52:     Platform: win32 XP
23:38:52:         Bits: 32
23:38:52:         Mode: Release
23:38:52:******************************* System ********************************
23:38:52:          CPU: Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
23:38:52:       CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
23:38:52:         CPUs: 8
23:38:52:       Memory: 31.92GiB
23:38:52:  Free Memory: 26.75GiB
23:38:52:      Threads: WINDOWS_THREADS
23:38:52:  Has Battery: false
23:38:52:   On Battery: false
23:38:52:   UTC offset: -8
23:38:52:          PID: 3904
23:38:52:          CWD: e:/Users/Roswell_ET/AppData/Roaming/FAHClient
23:38:52:           OS: Windows 8
23:38:52:      OS Arch: AMD64
23:38:52:         GPUs: 4
23:38:52:        GPU 0: ATI:5 Tahiti [Radeon HD 7900 Series]
23:38:52:        GPU 1: ATI:5 Tahiti XT [Radeon HD 7970]
23:38:52:        GPU 2: NVIDIA:3 GK110 [GeForce GTX 780]
23:38:52:        GPU 3: ATI:5 Tahiti [Radeon HD 7900 Series]
23:38:52:         CUDA: 3.5
23:38:52:  CUDA Driver: 5050
23:38:52:Win32 Service: false
23:38:52:***********************************************************************
23:38:52:<config>
23:38:52:  <!-- Folding Slot Configuration -->
23:38:52:  <client-type v='advanced'/>
23:38:52:  <power v='full'/>
23:38:52:
23:38:52:  <!-- Network -->
23:38:52:  <proxy v=':8080'/>
23:38:52:
23:38:52:  <!-- Slot Control -->
23:38:52:  <pause-on-start v='true'/>
23:38:52:
23:38:52:  <!-- User Information -->
23:38:52:  <passkey v='********************************'/>
23:38:52:  <team v='69411'/>
23:38:52:  <user v='Roswell_ET'/>
23:38:52:
23:38:52:  <!-- Folding Slots -->
23:38:52:  <slot id='0' type='GPU'/>
23:38:52:  <slot id='1' type='GPU'/>
23:38:52:  <slot id='3' type='GPU'/>
23:38:52:  <slot id='2' type='GPU'/>
23:38:52:</config>
23:38:52:Trying to access database...
23:38:52:Successfully acquired database lock
23:38:52:Enabled folding slot 00: PAUSED gpu:0:Tahiti [Radeon HD 7900 Series] (paused)
23:38:52:Enabled folding slot 01: PAUSED gpu:1:Tahiti XT [Radeon HD 7970] (paused)
23:38:52:Enabled folding slot 03: PAUSED gpu:2:GK110 [GeForce GTX 780] (paused)
23:38:52:Enabled folding slot 02: PAUSED gpu:3:Tahiti [Radeon HD 7900 Series] (paused)
23:38:57:3:127.0.0.1:New Web connection
23:39:46:FS00:Unpaused
23:39:46:FS01:Unpaused
23:39:46:FS03:Unpaused
23:39:46:FS02:Unpaused
23:39:57:WU03:FS03:Starting
23:39:57:WU03:FS03:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 03 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:39:57:WU03:FS03:Started FahCore on PID 2288
23:39:57:WU03:FS03:Core PID:3696
23:39:57:WU03:FS03:FahCore 0x15 started
23:39:57:WU02:FS02:Starting
23:39:57:WU02:FS02:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 3 -gpu-vendor ati
23:39:57:WU02:FS02:Started FahCore on PID 4712
23:39:57:WU02:FS02:Core PID:2448
23:39:57:WU02:FS02:FahCore 0x17 started
23:39:57:WU05:FS01:Starting
23:39:57:WU05:FS01:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 05 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 1 -gpu-vendor ati
23:39:57:WU05:FS01:Started FahCore on PID 3792
23:39:57:WU05:FS01:Core PID:4180
23:39:57:WU05:FS01:FahCore 0x17 started
23:39:57:WU00:FS00:Starting
23:39:57:WU00:FS00:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 0 -gpu-vendor ati
23:39:57:WU00:FS00:Started FahCore on PID 3980
23:39:57:WU00:FS00:Core PID:3604
23:39:57:WU00:FS00:FahCore 0x17 started
23:39:58:WU03:FS03:0x15:
23:39:58:WU03:FS03:0x15:*------------------------------*
23:39:58:WU03:FS03:0x15:Folding@Home GPU Core
23:39:58:WU03:FS03:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:39:58:WU03:FS03:0x15:Build host             AmoebaRemote
23:39:58:WU03:FS03:0x15:Board Type             NVIDIA/CUDA
23:39:58:WU03:FS03:0x15:Core                   15
23:39:58:WU03:FS03:0x15:Window's signal control handler registered.
23:39:58:WU03:FS03:0x15:Preparing to commence simulation
23:39:58:WU03:FS03:0x15:- Looking at optimizations...
23:39:58:WU03:FS03:0x15:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
23:39:58:WU03:FS03:0x15:- Created dyn
23:39:58:WU03:FS03:0x15:- Files status OK
23:39:58:WU03:FS03:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:39:58:WU03:FS03:0x15:- Expanded 145704 -> 660986 (decompressed 453.6 percent)
23:39:58:WU03:FS03:0x15:Called DecompressByteArray: compressed_data_size=145704 data_size=660986, decompressed_data_size=660986 diff=0
23:39:58:WU03:FS03:0x15:- Digital signature verified
23:39:58:WU03:FS03:0x15:Project: 8018 (Run 293, Clone 0, Gen 193)
23:39:58:WU03:FS03:0x15:Assembly optimizations on if available.
23:39:58:WU02:FS02:0x17:*********************** Log Started 2013-11-09T23:39:57Z ***********************
23:39:58:WU03:FS03:0x15:Entering M.D.
23:39:58:WU02:FS02:0x17:Project: 8900 (Run 595, Clone 4, Gen 1)
23:39:58:WU02:FS02:0x17:Unit: 0x00000004028c126651a6ab0f937fc86e
23:39:58:WU02:FS02:0x17:CPU: 0x00000000000000000000000000000000
23:39:58:WU02:FS02:0x17:Machine: 2
23:39:58:WU05:FS01:0x17:*********************** Log Started 2013-11-09T23:39:57Z ***********************
23:39:58:WU02:FS02:0x17:Digital signatures verified
23:39:58:WU05:FS01:0x17:Project: 8900 (Run 563, Clone 0, Gen 231)
23:39:58:WU05:FS01:0x17:Unit: 0x00000114028c126651a6a3df7bb66762
23:39:58:WU00:FS00:0x17:*********************** Log Started 2013-11-09T23:39:57Z ***********************
23:39:58:WU05:FS01:0x17:CPU: 0x00000000000000000000000000000000
23:39:58:WU00:FS00:0x17:Project: 8900 (Run 14, Clone 3, Gen 193)
23:39:58:WU05:FS01:0x17:Machine: 1
23:39:58:WU00:FS00:0x17:Unit: 0x000000ec028c1266519a622ff3c71540
23:39:58:WU05:FS01:0x17:Digital signatures verified
23:39:58:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
23:39:58:WU00:FS00:0x17:Machine: 2
23:39:58:WU00:FS00:0x17:Digital signatures verified
23:39:58:WU02:FS02:0x17:  Found a checkpoint file
23:39:58:WU05:FS01:0x17:  Found a checkpoint file
23:39:58:WU00:FS00:0x17:  Found a checkpoint file
23:39:59:WU03:FS03:0x15:Tpr hash 03/wudata_01.tpr:  1771790457 1201405876 2890240536 2776289624 289497086
23:39:59:WU03:FS03:0x15:GPU device id=0
23:39:59:WU03:FS03:0x15:Working on GRowing Old MAkes el Chrono Sweat
23:39:59:WU03:FS03:0x15:Client config unavailable.
23:40:00:WU03:FS03:0x15:Starting GUI Server
23:40:00:WU03:FS03:0x15:Finished fah_main status=59
23:40:00:WU03:FS03:0x15:mdrun_gpu returned 59
23:40:00:WU03:FS03:0x15:GPU memtest failure
23:40:00:WU03:FS03:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:40:00:WARNING:WU03:FS03:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:40:00:WU03:FS03:Starting
23:40:00:WU03:FS03:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 03 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:40:00:WU03:FS03:Started FahCore on PID 320
23:40:00:WU03:FS03:Core PID:1132
23:40:00:WU03:FS03:FahCore 0x15 started
23:40:01:WU03:FS03:0x15:
23:40:01:WU03:FS03:0x15:*------------------------------*
23:40:01:WU03:FS03:0x15:Folding@Home GPU Core
23:40:01:WU03:FS03:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:40:01:WU03:FS03:0x15:Build host             AmoebaRemote
23:40:01:WU03:FS03:0x15:Board Type             NVIDIA/CUDA
23:40:01:WU03:FS03:0x15:Core                   15
23:40:01:WU03:FS03:0x15:Window's signal control handler registered.
23:40:01:WU03:FS03:0x15:Preparing to commence simulation
23:40:01:WU03:FS03:0x15:- Looking at optimizations...
23:40:01:WU03:FS03:0x15:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
23:40:01:WU03:FS03:0x15:- Created dyn
23:40:01:WU03:FS03:0x15:- Files status OK
23:40:01:WU03:FS03:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:40:01:WU03:FS03:0x15:- Expanded 145704 -> 660986 (decompressed 453.6 percent)
23:40:01:WU03:FS03:0x15:Called DecompressByteArray: compressed_data_size=145704 data_size=660986, decompressed_data_size=660986 diff=0
23:40:01:WU03:FS03:0x15:- Digital signature verified
23:40:01:WU03:FS03:0x15:Project: 8018 (Run 293, Clone 0, Gen 193)
23:40:01:WU03:FS03:0x15:Assembly optimizations on if available.
23:40:01:WU03:FS03:0x15:Entering M.D.
23:40:02:WU03:FS03:0x15:Tpr hash 03/wudata_01.tpr:  1771790457 1201405876 2890240536 2776289624 289497086
23:40:02:WU03:FS03:0x15:GPU device id=0
23:40:02:WU03:FS03:0x15:Working on GRowing Old MAkes el Chrono Sweat
23:40:02:WU03:FS03:0x15:Client config unavailable.
23:40:02:WU03:FS03:0x15:Finished fah_main status=59
23:40:02:WU03:FS03:0x15:mdrun_gpu returned 59
23:40:02:WU03:FS03:0x15:GPU memtest failure
23:40:02:WU03:FS03:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:40:03:WARNING:WU03:FS03:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:40:03:WARNING:WU03:FS03:Too many errors, failing
23:40:03:WU03:FS03:Sending unit results: id:03 state:SEND error:FAILED project:8018 run:293 clone:0 gen:193 core:0x15 unit:0x000000df6953ee2e500f1c4cd44837a9
23:40:03:WU03:FS03:Connecting to 171.67.108.142:8080
23:40:03:WU03:FS03:Server responded WORK_QUIT (404)
23:40:03:WARNING:WU03:FS03:Server did not like results, dumping
23:40:03:WU03:FS03:Cleaning up
23:40:03:WU06:FS03:Connecting to assign-GPU.stanford.edu:80
23:40:04:WU06:FS03:News: Welcome to Folding@Home
23:40:04:WU06:FS03:Assigned to work server 171.67.108.142
23:40:04:WU06:FS03:Requesting new work unit for slot 03: READY gpu:2:GK110 [GeForce GTX 780] from 171.67.108.142
23:40:04:WU06:FS03:Connecting to 171.67.108.142:8080
23:40:04:WU06:FS03:Downloading 142.68KiB
23:40:05:WU06:FS03:Download complete
23:40:05:WU06:FS03:Received Unit: id:06 state:DOWNLOAD error:NO_ERROR project:8018 run:688 clone:0 gen:161 core:0x15 unit:0x000000ca6953ee2e500f1db099770038
23:40:05:WU06:FS03:Starting
23:40:05:WU06:FS03:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 06 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:40:05:WU06:FS03:Started FahCore on PID 3976
23:40:05:WU06:FS03:Core PID:4280
23:40:05:WU06:FS03:FahCore 0x15 started
23:40:06:WU06:FS03:0x15:
23:40:06:WU06:FS03:0x15:*------------------------------*
23:40:06:WU06:FS03:0x15:Folding@Home GPU Core
23:40:06:WU06:FS03:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:40:06:WU06:FS03:0x15:Build host             AmoebaRemote
23:40:06:WU06:FS03:0x15:Board Type             NVIDIA/CUDA
23:40:06:WU06:FS03:0x15:Core                   15
23:40:06:WU06:FS03:0x15:Window's signal control handler registered.
23:40:06:WU06:FS03:0x15:Preparing to commence simulation
23:40:06:WU06:FS03:0x15:- Looking at optimizations...
23:40:06:WU06:FS03:0x15:DeleteFrameFiles: successfully deleted file=06/wudata_01.ckp
23:40:06:WU06:FS03:0x15:- Created dyn
23:40:06:WU06:FS03:0x15:- Files status OK
23:40:06:WU06:FS03:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:40:06:WU06:FS03:0x15:- Expanded 145590 -> 660986 (decompressed 454.0 percent)
23:40:06:WU06:FS03:0x15:Called DecompressByteArray: compressed_data_size=145590 data_size=660986, decompressed_data_size=660986 diff=0
23:40:06:WU06:FS03:0x15:- Digital signature verified
23:40:06:WU06:FS03:0x15:Project: 8018 (Run 688, Clone 0, Gen 161)
23:40:06:WU06:FS03:0x15:Assembly optimizations on if available.
23:40:06:WU06:FS03:0x15:Entering M.D.
23:40:07:WU06:FS03:0x15:Tpr hash 06/wudata_01.tpr:  625628606 2325468089 3963734056 328330338 643951421
23:40:07:WU06:FS03:0x15:GPU device id=0
23:40:07:WU06:FS03:0x15:Working on GRowing Old MAkes el Chrono Sweat
23:40:07:WU06:FS03:0x15:Client config unavailable.
23:40:07:WU06:FS03:0x15:Finished fah_main status=59
23:40:07:WU06:FS03:0x15:mdrun_gpu returned 59
23:40:07:WU06:FS03:0x15:GPU memtest failure
23:40:07:WU06:FS03:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:40:08:WARNING:WU06:FS03:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:40:08:WU06:FS03:Starting
23:40:08:WU06:FS03:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 06 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:40:08:WU06:FS03:Started FahCore on PID 2520
23:40:08:WU06:FS03:Core PID:3068
23:40:08:WU06:FS03:FahCore 0x15 started
23:40:08:WU06:FS03:0x15:
23:40:08:WU06:FS03:0x15:*------------------------------*
23:40:08:WU06:FS03:0x15:Folding@Home GPU Core
23:40:08:WU06:FS03:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:40:08:WU06:FS03:0x15:Build host             AmoebaRemote
23:40:08:WU06:FS03:0x15:Board Type             NVIDIA/CUDA
23:40:08:WU06:FS03:0x15:Core                   15
23:40:08:WU06:FS03:0x15:Window's signal control handler registered.
23:40:08:WU06:FS03:0x15:Preparing to commence simulation
23:40:08:WU06:FS03:0x15:- Looking at optimizations...
23:40:08:WU06:FS03:0x15:DeleteFrameFiles: successfully deleted file=06/wudata_01.ckp
23:40:08:WU06:FS03:0x15:- Created dyn
23:40:08:WU06:FS03:0x15:- Files status OK
23:40:08:WU06:FS03:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:40:08:WU06:FS03:0x15:- Expanded 145590 -> 660986 (decompressed 454.0 percent)
23:40:08:WU06:FS03:0x15:Called DecompressByteArray: compressed_data_size=145590 data_size=660986, decompressed_data_size=660986 diff=0
23:40:08:WU06:FS03:0x15:- Digital signature verified
23:40:08:WU06:FS03:0x15:Project: 8018 (Run 688, Clone 0, Gen 161)
23:40:08:WU06:FS03:0x15:Assembly optimizations on if available.
23:40:08:WU06:FS03:0x15:Entering M.D.
23:40:10:WU06:FS03:0x15:Tpr hash 06/wudata_01.tpr:  625628606 2325468089 3963734056 328330338 643951421
23:40:10:WU06:FS03:0x15:GPU device id=0
23:40:10:WU06:FS03:0x15:Working on GRowing Old MAkes el Chrono Sweat
23:40:10:WU06:FS03:0x15:Client config unavailable.
23:40:10:WU06:FS03:0x15:Finished fah_main status=59
23:40:10:WU06:FS03:0x15:mdrun_gpu returned 59
23:40:10:WU06:FS03:0x15:GPU memtest failure
23:40:10:WU06:FS03:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:40:10:WARNING:WU06:FS03:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:40:58:Saving configuration to config.xml
23:40:58:<config>
23:40:58:  <!-- Folding Slot Configuration -->
23:40:58:  <client-type v='advanced'/>
23:40:58:  <power v='full'/>
23:40:58:
23:40:58:  <!-- Network -->
23:40:58:  <proxy v=':8080'/>
23:40:58:
23:40:58:  <!-- Slot Control -->
23:40:58:  <pause-on-start v='true'/>
23:40:58:
23:40:58:  <!-- User Information -->
23:40:58:  <passkey v='********************************'/>
23:40:58:  <team v='69411'/>
23:40:58:  <user v='Roswell_ET'/>
23:40:58:
23:40:58:  <!-- Folding Slots -->
23:40:58:  <slot id='0' type='GPU'/>
23:40:58:  <slot id='1' type='GPU'/>
23:40:58:  <slot id='3' type='GPU'/>
23:40:58:  <slot id='2' type='GPU'/>
23:40:58:</config>
23:41:08:WU06:FS03:Starting
23:41:08:WU06:FS03:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 06 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
23:41:08:WU06:FS03:Started FahCore on PID 2788
23:41:08:WU06:FS03:Core PID:832
23:41:08:WU06:FS03:FahCore 0x15 started
23:41:08:WU06:FS03:0x15:
23:41:08:WU06:FS03:0x15:*------------------------------*
23:41:08:WU06:FS03:0x15:Folding@Home GPU Core
23:41:08:WU06:FS03:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
23:41:08:WU06:FS03:0x15:Build host             AmoebaRemote
23:41:08:WU06:FS03:0x15:Board Type             NVIDIA/CUDA
23:41:08:WU06:FS03:0x15:Core                   15
23:41:08:WU06:FS03:0x15:Window's signal control handler registered.
23:41:08:WU06:FS03:0x15:Preparing to commence simulation
23:41:08:WU06:FS03:0x15:- Looking at optimizations...
23:41:08:WU06:FS03:0x15:DeleteFrameFiles: successfully deleted file=06/wudata_01.ckp
23:41:08:WU06:FS03:0x15:- Created dyn
23:41:08:WU06:FS03:0x15:- Files status OK
23:41:08:WU06:FS03:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:41:08:WU06:FS03:0x15:- Expanded 145590 -> 660986 (decompressed 454.0 percent)
23:41:08:WU06:FS03:0x15:Called DecompressByteArray: compressed_data_size=145590 data_size=660986, decompressed_data_size=660986 diff=0
23:41:08:WU06:FS03:0x15:- Digital signature verified
23:41:08:WU06:FS03:0x15:Project: 8018 (Run 688, Clone 0, Gen 161)
23:41:08:WU06:FS03:0x15:Assembly optimizations on if available.
23:41:08:WU06:FS03:0x15:Entering M.D.
23:41:10:WU06:FS03:0x15:Tpr hash 06/wudata_01.tpr:  625628606 2325468089 3963734056 328330338 643951421
23:41:10:WU06:FS03:0x15:GPU device id=0
23:41:10:WU06:FS03:0x15:Working on GRowing Old MAkes el Chrono Sweat
23:41:10:WU06:FS03:0x15:Client config unavailable.
23:41:10:WU06:FS03:0x15:Finished fah_main status=59
23:41:10:WU06:FS03:0x15:mdrun_gpu returned 59
23:41:10:WU06:FS03:0x15:GPU memtest failure
23:41:10:WU06:FS03:0x15:Folding@home Core Shutdown: GPU_MEMTEST_ERROR
23:41:10:WARNING:WU06:FS03:FahCore returned: GPU_MEMTEST_ERROR (124 = 0x7c)
23:41:27:FS03:Paused
23:41:51:WU05:FS01:0x17:Completed 650000 out of 2500000 steps (26%)
23:41:51:WU00:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
23:42:13:WU02:FS02:0x17:ERROR:exception: Force RMSE error of 176.033 with threshold of 5
23:42:13:WU02:FS02:0x17:Saving result file logfile_01.txt
23:42:13:WU02:FS02:0x17:Saving result file badStateCheckpoint_41
23:42:14:WU02:FS02:0x17:Saving result file badStateForceGroup0_41Core.xml
23:42:16:WU02:FS02:0x17:Saving result file badStateForceGroup0_41Ref.xml
23:42:17:WU02:FS02:0x17:Saving result file badStateForceGroup1_41Core.xml
23:42:19:WU02:FS02:0x17:Saving result file badStateForceGroup1_41Ref.xml
23:42:20:WU02:FS02:0x17:Saving result file badStateForceGroup2_41Core.xml
23:42:22:WU02:FS02:0x17:Saving result file badStateForceGroup2_41Ref.xml
23:42:23:WU02:FS02:0x17:Saving result file log.txt
23:42:23:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:42:23:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:595 clone:4 gen:1 core:0x17 unit:0x00000004028c126651a6ab0f937fc86e
23:42:23:WU02:FS02:Uploading 20.69MiB to 171.64.65.69
23:42:23:WU02:FS02:Connecting to 171.64.65.69:8080
23:42:24:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
23:42:24:WU03:FS02:News: Welcome to Folding@Home
23:42:24:WU03:FS02:Assigned to work server 171.64.65.69
23:42:24:WU03:FS02:Requesting new work unit for slot 02: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
23:42:24:WU03:FS02:Connecting to 171.64.65.69:8080
23:42:27:WU03:FS02:Downloading 4.18MiB
23:42:29:WU02:FS02:Upload 19.93%
23:42:33:WU03:FS02:Download 5.99%
23:42:35:WU02:FS02:Upload 39.87%
23:42:39:WU03:FS02:Download 23.95%
23:42:41:WU02:FS02:Upload 59.80%
23:42:45:WU03:FS02:Download 68.86%
23:42:47:WU02:FS02:Upload 79.74%
23:42:48:WU03:FS02:Download complete
23:42:48:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8900 run:107 clone:2 gen:6 core:0x17 unit:0x0000000d028c126651a63e46af239a33
23:42:48:WU03:FS02:Starting
23:42:48:WU03:FS02:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 3 -gpu-vendor ati
23:42:48:WU03:FS02:Started FahCore on PID 3020
23:42:48:WU03:FS02:Core PID:1428
23:42:48:WU03:FS02:FahCore 0x17 started
23:42:48:WU03:FS02:0x17:*********************** Log Started 2013-11-09T23:42:48Z ***********************
23:42:48:WU03:FS02:0x17:Project: 8900 (Run 107, Clone 2, Gen 6)
23:42:48:WU03:FS02:0x17:Unit: 0x0000000d028c126651a63e46af239a33
23:42:48:WU03:FS02:0x17:CPU: 0x00000000000000000000000000000000
23:42:48:WU03:FS02:0x17:Machine: 2
23:42:48:WU03:FS02:0x17:Reading tar file state.xml
23:42:49:WU03:FS02:0x17:Reading tar file system.xml
23:42:49:WU03:FS02:0x17:Reading tar file integrator.xml
23:42:49:WU03:FS02:0x17:Reading tar file core.xml
23:42:49:WU03:FS02:0x17:Digital signatures verified
23:42:53:WU02:FS02:Upload 99.67%
23:42:54:WU02:FS02:Upload complete
23:42:54:WU02:FS02:Server responded WORK_ACK (400)
23:42:54:WU02:FS02:Cleaning up
23:45:02:WU03:FS02:0x17:ERROR:exception: Force RMSE error of 180.161 with threshold of 5
23:45:02:WU03:FS02:0x17:Saving result file logfile_01.txt
23:45:02:WU03:FS02:0x17:Saving result file badStateCheckpoint_41
23:45:02:WU03:FS02:0x17:Saving result file badStateForceGroup0_41Core.xml
23:45:04:WU03:FS02:0x17:Saving result file badStateForceGroup0_41Ref.xml
23:45:06:WU03:FS02:0x17:Saving result file badStateForceGroup1_41Core.xml
23:45:08:WU03:FS02:0x17:Saving result file badStateForceGroup1_41Ref.xml
23:45:09:WU03:FS02:0x17:Saving result file badStateForceGroup2_41Core.xml
23:45:10:WU03:FS02:0x17:Saving result file badStateForceGroup2_41Ref.xml
23:45:12:WU03:FS02:0x17:Saving result file log.txt
23:45:12:WU03:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:45:12:WARNING:WU03:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:45:12:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:107 clone:2 gen:6 core:0x17 unit:0x0000000d028c126651a63e46af239a33
23:45:12:WU03:FS02:Uploading 20.66MiB to 171.64.65.69
23:45:12:WU03:FS02:Connecting to 171.64.65.69:8080
23:45:13:WU02:FS02:Connecting to assign-GPU.stanford.edu:80
23:45:13:WU02:FS02:News: Welcome to Folding@Home
23:45:13:WU02:FS02:Assigned to work server 171.64.65.69
23:45:13:WU02:FS02:Requesting new work unit for slot 02: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
23:45:13:WU02:FS02:Connecting to 171.64.65.69:8080
23:45:16:WU02:FS02:Downloading 4.51MiB
23:45:18:WU03:FS02:Upload 14.22%
23:45:24:WU02:FS02:Download 18.03%
23:45:24:WU03:FS02:Upload 30.85%
23:45:30:WU03:FS02:Upload 50.82%
23:45:30:WU02:FS02:Download 33.28%
23:45:36:WU03:FS02:Upload 70.48%
23:45:36:WU02:FS02:Download 59.63%
23:45:40:WU02:FS02:Download complete
23:45:40:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:512 clone:5 gen:0 core:0x17 unit:0x00000001028c126651a698a8a23a841b
23:45:40:WU02:FS02:Starting
23:45:40:WU02:FS02:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 3 -gpu-vendor ati
23:45:40:WU02:FS02:Started FahCore on PID 1336
23:45:40:WU02:FS02:Core PID:736
23:45:40:WU02:FS02:FahCore 0x17 started
23:45:40:WU02:FS02:0x17:*********************** Log Started 2013-11-09T23:45:40Z ***********************
23:45:40:WU02:FS02:0x17:Project: 8900 (Run 512, Clone 5, Gen 0)
23:45:40:WU02:FS02:0x17:Unit: 0x00000001028c126651a698a8a23a841b
23:45:40:WU02:FS02:0x17:CPU: 0x00000000000000000000000000000000
23:45:40:WU02:FS02:0x17:Machine: 2
23:45:40:WU02:FS02:0x17:Reading tar file system.xml
23:45:41:WU02:FS02:0x17:Reading tar file integrator.xml
23:45:41:WU02:FS02:0x17:Reading tar file state.xml
23:45:41:WU02:FS02:0x17:Reading tar file core.xml
23:45:41:WU02:FS02:0x17:Digital signatures verified
23:45:42:WU03:FS02:Upload 90.75%
23:45:46:WU03:FS02:Upload complete
23:45:46:WU03:FS02:Server responded WORK_ACK (400)
23:45:46:WU03:FS02:Cleaning up
23:45:58:WU05:FS01:0x17:Completed 675000 out of 2500000 steps (27%)
23:46:01:WU00:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
23:47:53:WU02:FS02:0x17:ERROR:exception: Force RMSE error of 173.113 with threshold of 5
23:47:53:WU02:FS02:0x17:Saving result file logfile_01.txt
23:47:53:WU02:FS02:0x17:Saving result file badStateCheckpoint_41
23:47:54:WU02:FS02:0x17:Saving result file badStateForceGroup0_41Core.xml
23:47:55:WU02:FS02:0x17:Saving result file badStateForceGroup0_41Ref.xml
23:47:57:WU02:FS02:0x17:Saving result file badStateForceGroup1_41Core.xml
23:47:59:WU02:FS02:0x17:Saving result file badStateForceGroup1_41Ref.xml
23:48:00:WU02:FS02:0x17:Saving result file badStateForceGroup2_41Core.xml
23:48:02:WU02:FS02:0x17:Saving result file badStateForceGroup2_41Ref.xml
23:48:03:WU02:FS02:0x17:Saving result file log.txt
23:48:03:WU02:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:48:04:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:48:04:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:512 clone:5 gen:0 core:0x17 unit:0x00000001028c126651a698a8a23a841b
23:48:04:WU02:FS02:Uploading 20.61MiB to 171.64.65.69
23:48:04:WU02:FS02:Connecting to 171.64.65.69:8080
23:48:04:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
23:48:04:WU03:FS02:News: Welcome to Folding@Home
23:48:04:WU03:FS02:Assigned to work server 171.64.65.69
23:48:04:WU03:FS02:Requesting new work unit for slot 02: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
23:48:04:WU03:FS02:Connecting to 171.64.65.69:8080
23:48:06:WU03:FS02:Downloading 4.18MiB
23:48:10:WU02:FS02:Upload 22.44%
23:48:12:WU03:FS02:Download 7.48%
23:48:16:WU02:FS02:Upload 42.45%
23:48:18:WU03:FS02:Download 25.44%
23:48:22:WU02:FS02:Upload 62.47%
23:48:24:WU03:FS02:Download 49.39%
23:48:28:WU02:FS02:Upload 82.48%
23:48:30:WU03:FS02:Download 83.81%
23:48:32:WU03:FS02:Download complete
23:48:32:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8900 run:736 clone:2 gen:5 core:0x17 unit:0x00000013028c126651a6ca5e7e3afebe
23:48:32:WU03:FS02:Starting
23:48:32:WU03:FS02:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 3 -gpu-vendor ati
23:48:32:WU03:FS02:Started FahCore on PID 3728
23:48:32:WU03:FS02:Core PID:2144
23:48:32:WU03:FS02:FahCore 0x17 started
23:48:33:WU03:FS02:0x17:*********************** Log Started 2013-11-09T23:48:32Z ***********************
23:48:33:WU03:FS02:0x17:Project: 8900 (Run 736, Clone 2, Gen 5)
23:48:33:WU03:FS02:0x17:Unit: 0x00000013028c126651a6ca5e7e3afebe
23:48:33:WU03:FS02:0x17:CPU: 0x00000000000000000000000000000000
23:48:33:WU03:FS02:0x17:Machine: 2
23:48:33:WU03:FS02:0x17:Reading tar file state.xml
23:48:33:WU03:FS02:0x17:Reading tar file system.xml
23:48:34:WU03:FS02:0x17:Reading tar file integrator.xml
23:48:34:WU03:FS02:0x17:Reading tar file core.xml
23:48:34:WU03:FS02:0x17:Digital signatures verified
23:48:34:WU02:FS02:Upload complete
23:48:34:WU02:FS02:Server responded WORK_ACK (400)
23:48:34:WU02:FS02:Cleaning up
23:49:54:WU05:FS01:0x17:Completed 700000 out of 2500000 steps (28%)
23:50:01:WU00:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
23:50:48:WU03:FS02:0x17:ERROR:exception: Force RMSE error of 174.286 with threshold of 5
23:50:48:WU03:FS02:0x17:Saving result file logfile_01.txt
23:50:48:WU03:FS02:0x17:Saving result file badStateCheckpoint_41
23:50:48:WU03:FS02:0x17:Saving result file badStateForceGroup0_41Core.xml
23:50:50:WU03:FS02:0x17:Saving result file badStateForceGroup0_41Ref.xml
23:50:52:WU03:FS02:0x17:Saving result file badStateForceGroup1_41Core.xml
23:50:53:WU03:FS02:0x17:Saving result file badStateForceGroup1_41Ref.xml
23:50:55:WU03:FS02:0x17:Saving result file badStateForceGroup2_41Core.xml
23:50:56:WU03:FS02:0x17:Saving result file badStateForceGroup2_41Ref.xml
23:50:58:WU03:FS02:0x17:Saving result file log.txt
23:50:58:WU03:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:50:58:WARNING:WU03:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:50:58:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:736 clone:2 gen:5 core:0x17 unit:0x00000013028c126651a6ca5e7e3afebe
23:50:58:WU03:FS02:Uploading 20.67MiB to 171.64.65.69
23:50:58:WU03:FS02:Connecting to 171.64.65.69:8080
23:50:58:WU02:FS02:Connecting to assign-GPU.stanford.edu:80
23:50:59:WU02:FS02:News: Welcome to Folding@Home
23:50:59:WU02:FS02:Assigned to work server 171.64.65.69
23:50:59:WU02:FS02:Requesting new work unit for slot 02: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
23:50:59:WU02:FS02:Connecting to 171.64.65.69:8080
23:51:00:WU02:FS02:Downloading 4.17MiB
23:51:04:WU03:FS02:Upload 21.77%
23:51:06:WU02:FS02:Download 7.49%
23:51:10:WU03:FS02:Upload 41.73%
23:51:12:WU02:FS02:Download 28.46%
23:51:16:WU03:FS02:Upload 61.69%
23:51:18:WU02:FS02:Download 76.39%
23:51:19:WU02:FS02:Download complete
23:51:19:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:365 clone:4 gen:6 core:0x17 unit:0x0000000a028c126651a677db0c00984f
23:51:19:WU02:FS02:Starting
23:51:19:WU02:FS02:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 3904 -checkpoint 15 -gpu 3 -gpu-vendor ati
23:51:19:WU02:FS02:Started FahCore on PID 4116
23:51:19:WU02:FS02:Core PID:4736
23:51:19:WU02:FS02:FahCore 0x17 started
23:51:20:WU02:FS02:0x17:*********************** Log Started 2013-11-09T23:51:19Z ***********************
23:51:20:WU02:FS02:0x17:Project: 8900 (Run 365, Clone 4, Gen 6)
23:51:20:WU02:FS02:0x17:Unit: 0x0000000a028c126651a677db0c00984f
23:51:20:WU02:FS02:0x17:CPU: 0x00000000000000000000000000000000
23:51:20:WU02:FS02:0x17:Machine: 2
23:51:20:WU02:FS02:0x17:Reading tar file state.xml
23:51:20:WU02:FS02:0x17:Reading tar file system.xml
23:51:21:WU02:FS02:0x17:Reading tar file integrator.xml
23:51:21:WU02:FS02:0x17:Reading tar file core.xml
23:51:21:WU02:FS02:0x17:Digital signatures verified
23:51:22:WU03:FS02:Upload 81.64%
23:51:29:WU03:FS02:Upload complete
23:51:29:WU03:FS02:Server responded WORK_ACK (400)
23:51:29:WU03:FS02:Cleaning up
23:53:33:WU02:FS02:0x17:ERROR:exception: Force RMSE error of 181.694 with threshold of 5
23:53:33:WU02:FS02:0x17:Saving result file logfile_01.txt
23:53:33:WU02:FS02:0x17:Saving result file badStateCheckpoint_41
23:53:34:WU02:FS02:0x17:Saving result file badStateForceGroup0_41Core.xml
23:53:35:WU02:FS02:0x17:Saving result file badStateForceGroup0_41Ref.xml
23:53:37:WU02:FS02:0x17:Saving result file badStateForceGroup1_41Core.xml
23:53:39:WU02:FS02:0x17:Saving result file badStateForceGroup1_41Ref.xml
23:53:40:WU02:FS02:0x17:Saving result file badStateForceGroup2_41Core.xml
23:53:42:WU02:FS02:0x17:Saving result file badStateForceGroup2_41Ref.xml
23:53:43:WU02:FS02:0x17:Saving result file log.txt
23:53:43:WU02:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:53:44:WARNING:WU02:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:53:44:WU02:FS02:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:365 clone:4 gen:6 core:0x17 unit:0x0000000a028c126651a677db0c00984f
23:53:44:WU02:FS02:Uploading 20.64MiB to 171.64.65.69
23:53:44:WU02:FS02:Connecting to 171.64.65.69:8080
23:53:50:WU02:FS02:Upload 13.93%
23:53:56:WU02:FS02:Upload 34.52%
23:54:02:WU02:FS02:Upload 54.20%
23:54:07:WU05:FS01:0x17:Completed 725000 out of 2500000 steps (29%)
23:54:08:WU02:FS02:Upload 74.49%
23:54:14:WU02:FS02:Upload 94.47%
23:54:17:WU00:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
23:54:17:WU02:FS02:Upload complete
23:54:17:WU02:FS02:Server responded WORK_ACK (400)
23:54:17:WU02:FS02:Cleaning up
23:58:07:WU05:FS01:0x17:Completed 750000 out of 2500000 steps (30%)
23:58:19:WU00:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
00:02:19:WU05:FS01:0x17:Completed 775000 out of 2500000 steps (31%)
00:02:34:WU00:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
HD 7970
Re: Bad GPU's ?
Mixing vendors is always problematic. Finish all current work units. Then uninstall and reinstall the fah software. The installer may help sort out the new GPU order. If not you will need to learn how to set the indexes manually.
Roswell_ET
(1) Radeon HD 7990
(1) Radeon HD 7970
(1) GTX 780
450,000 ppd
Re: Bad GPU's ?
OK!
Did a complete new install of FAH 7.3.6. It will load the client and see's everything but FAHControl will not run. Re-installed twice plus downloaded new install from Stanford still no FAHCONTROL?
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Re: Bad GPU's ?
Post by Jesse_V »
Roswell_ET wrote:OK!
I don't understand what you mean here. How exactly is FAHControl not running? Please describe what you see and what is happening.
Re: Bad GPU's ?
So you right click on the tray icon and select advanced control, then what happens?
Roswell_ET
(1) Radeon HD 7990
(1) Radeon HD 7970
(1) GTX 780
450,000 ppd
Re: Bad GPU's ?
The desktop icon is a short cut for webcontrol which starts the client. I have no tray icon on any of the systems I 'am running. I have to go into the folder to start FAHControl which then allows me to select configure or whatever else is to be done.
What happened was that when I installed windows on the new system files were lost and or corrupted. windows then over time started locking me out of my own system.
Did a complete re-install of windows and am up and running BUT have had a failure.
22:08:20:Saving configuration to config.xml
22:08:20:<config>
22:08:20:  <!-- Folding Slot Configuration -->
22:08:20:  <client-type v='advanced'/>
22:08:20:  <power v='off'/>
22:08:20:
22:08:20:  <!-- Network -->
22:08:20:  <proxy v=':8080'/>
22:08:20:
22:08:20:  <!-- Slot Control -->
22:08:20:  <pause-on-start v='true'/>
22:08:20:
22:08:20:  <!-- User Information -->
22:08:20:  <passkey v='********************************'/>
22:08:20:  <team v='69411'/>
22:08:20:  <user v='Roswell_ET'/>
22:08:20:
22:08:20:  <!-- Folding Slots -->
22:08:20:  <slot id='0' type='GPU'/>
22:08:20:  <slot id='1' type='GPU'/>
22:08:20:  <slot id='2' type='GPU'/>
22:08:20:  <slot id='3' type='GPU'/>
22:08:20:</config>
22:08:20:WARNING:WU00:Slot ID 4 no longer exists and there are no other matching slots, dumping
22:08:20:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:9004 run:36 clone:0 gen:40 core:0xa4 unit:0x00000029664f2de45265b30ccef5f44c
22:08:20:WU00:Connecting to 171.64.65.124:8080
22:08:21:WU00:Server responded WORK_ACK (400)
22:08:21:WU00:Cleaning up
22:10:00:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
22:10:00:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
22:10:00:WU00:FS00:News: Welcome to Folding@Home
22:10:00:WU00:FS00:Assigned to work server 171.64.65.69
22:10:00:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
22:10:00:WU00:FS00:Connecting to 171.64.65.69:8080
22:10:00:WU02:FS02:Connecting to assign-GPU.stanford.edu:80
22:10:01:WU01:FS01:News: Welcome to Folding@Home
22:10:01:WU01:FS01:Assigned to work server 171.64.65.69
22:10:01:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:Tahiti XT [Radeon HD 7970] from 171.64.65.69
22:10:01:WU01:FS01:Connecting to 171.64.65.69:8080
22:10:01:WU03:FS03:Connecting to assign-GPU.stanford.edu:80
22:10:01:WU02:FS02:News: Welcome to Folding@Home
22:10:01:WU02:FS02:Assigned to work server 171.67.108.142
22:10:01:WU02:FS02:Requesting new work unit for slot 02: READY gpu:2:GK110 [GeForce GTX 780] from 171.67.108.142
22:10:01:WU02:FS02:Connecting to 171.67.108.142:8080
22:10:01:WU00:FS00:Downloading 4.18MiB
22:10:01:WU03:FS03:News: Welcome to Folding@Home
22:10:01:WU03:FS03:Assigned to work server 171.64.65.69
22:10:01:WU03:FS03:Requesting new work unit for slot 03: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
22:10:01:WU03:FS03:Connecting to 171.64.65.69:8080
22:10:01:WU01:FS01:Downloading 4.17MiB
22:10:01:WU02:FS02:Downloading 142.85KiB
22:10:02:WU03:FS03:Downloading 4.17MiB
22:10:02:WU02:FS02:Download complete
22:10:02:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8018 run:1082 clone:1 gen:78 core:0x15 unit:0x000000646953ee2e500f1f102af60cb7
22:10:02:WU02:FS02:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
22:10:02:WU02:FS02:Connecting to www.stanford.edu:80
22:10:03:WU02:FS02:FahCore 15: Downloading 1.88MiB
22:10:07:WU00:FS00:Download 94.27%
22:10:07:WU01:FS01:Download 92.83%
22:10:07:WU00:FS00:Download complete
22:10:07:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:422 clone:1 gen:214 core:0x17 unit:0x000000fd028c126651a6847a64cd73e0
22:10:07:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah
22:10:07:WU00:FS00:Connecting to www.stanford.edu:80
22:10:07:WU01:FS01:Download complete
22:10:07:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:231 clone:2 gen:14 core:0x17 unit:0x00000022028c126651a659f63fe970bb
22:10:07:WU00:FS00:FahCore 17: Downloading 2.55MiB
22:10:07:WU03:FS03:Download complete
22:10:08:WU03:FS03:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8900 run:479 clone:2 gen:5 core:0x17 unit:0x0000000d028c126651a6913ed988dfde
22:10:09:WU02:FS02:FahCore 15: 89.97%
22:10:11:WU02:FS02:FahCore 15: Download complete
22:10:11:WU02:FS02:Valid core signature
22:10:11:WU02:FS02:Unpacked 7.71MiB to cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe
22:10:11:WU02:FS02:Starting
22:10:11:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 02 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
22:10:11:WU02:FS02:Started FahCore on PID 1044
22:10:11:WU02:FS02:Core PID:1344
22:10:11:WU02:FS02:FahCore 0x15 started
22:10:12:WU02:FS02:0x15:
22:10:12:WU02:FS02:0x15:*------------------------------*
22:10:12:WU02:FS02:0x15:Folding@Home GPU Core
22:10:12:WU02:FS02:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
22:10:12:WU02:FS02:0x15:Build host             AmoebaRemote
22:10:12:WU02:FS02:0x15:Board Type             NVIDIA/CUDA
22:10:12:WU02:FS02:0x15:Core                   15
22:10:12:WU02:FS02:0x15:Window's signal control handler registered.
22:10:12:WU02:FS02:0x15:Preparing to commence simulation
22:10:12:WU02:FS02:0x15:- Looking at optimizations...
22:10:12:WU02:FS02:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
22:10:12:WU02:FS02:0x15:- Created dyn
22:10:12:WU02:FS02:0x15:- Files status OK
22:10:12:WU02:FS02:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
22:10:12:WU02:FS02:0x15:- Expanded 145770 -> 660986 (decompressed 453.4 percent)
22:10:12:WU02:FS02:0x15:Called DecompressByteArray: compressed_data_size=145770 data_size=660986, decompressed_data_size=660986 diff=0
22:10:12:WU02:FS02:0x15:- Digital signature verified
22:10:12:WU02:FS02:0x15:Project: 8018 (Run 1082, Clone 1, Gen 78)
22:10:12:WU02:FS02:0x15:Assembly optimizations on if available.
22:10:12:WU02:FS02:0x15:Entering M.D.
22:10:13:WU00:FS00:FahCore 17: 44.11%
22:10:14:WU02:FS02:0x15:Tpr hash 02/wudata_01.tpr:  1253154399 3520430155 660998496 2960628762 2864808948
22:10:14:WU02:FS02:0x15:GPU device id=0
22:10:14:WU02:FS02:0x15:Working on GRowing Old MAkes el Chrono Sweat
22:10:14:WU02:FS02:0x15:Client config unavailable.
22:10:14:WU02:FS02:0x15:Starting GUI Server
22:10:17:WU00:FS00:FahCore 17: Download complete
22:10:17:WU00:FS00:Valid core signature
22:10:17:WU00:FS00:Unpacked 8.60MiB to cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe
22:10:17:WU00:FS00:Starting
22:10:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:10:17:WU00:FS00:Started FahCore on PID 3064
22:10:17:WU00:FS00:Core PID:3112
22:10:17:WU00:FS00:FahCore 0x17 started
22:10:17:WU01:FS01:Starting
22:10:17:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 1 -gpu-vendor ati
22:10:17:WU01:FS01:Started FahCore on PID 2712
22:10:18:WU01:FS01:Core PID:3508
22:10:18:WU01:FS01:FahCore 0x17 started
22:10:18:WU03:FS03:Starting
22:10:18:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 3 -gpu-vendor ati
22:10:18:WU03:FS03:Started FahCore on PID 3108
22:10:18:WU03:FS03:Core PID:2168
22:10:18:WU03:FS03:FahCore 0x17 started
22:10:18:WU00:FS00:0x17:*********************** Log Started 2013-11-09T22:10:18Z ***********************
22:10:18:WU00:FS00:0x17:Project: 8900 (Run 422, Clone 1, Gen 214)
22:10:18:WU00:FS00:0x17:Unit: 0x000000fd028c126651a6847a64cd73e0
22:10:18:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
22:10:18:WU00:FS00:0x17:Machine: 0
22:10:18:WU00:FS00:0x17:Reading tar file state.xml
22:10:18:WU01:FS01:0x17:*********************** Log Started 2013-11-09T22:10:18Z ***********************
22:10:18:WU01:FS01:0x17:Project: 8900 (Run 231, Clone 2, Gen 14)
22:10:18:WU01:FS01:0x17:Unit: 0x00000022028c126651a659f63fe970bb
22:10:18:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
22:10:18:WU01:FS01:0x17:Machine: 1
22:10:18:WU01:FS01:0x17:Reading tar file state.xml
22:10:18:WU03:FS03:0x17:*********************** Log Started 2013-11-09T22:10:18Z ***********************
22:10:18:WU03:FS03:0x17:Project: 8900 (Run 479, Clone 2, Gen 5)
22:10:18:WU03:FS03:0x17:Unit: 0x0000000d028c126651a6913ed988dfde
22:10:18:WU03:FS03:0x17:CPU: 0x00000000000000000000000000000000
22:10:18:WU03:FS03:0x17:Machine: 3
22:10:18:WU03:FS03:0x17:Reading tar file state.xml
22:10:18:WU00:FS00:0x17:Reading tar file system.xml
22:10:19:WU01:FS01:0x17:Reading tar file system.xml
22:10:19:WU03:FS03:0x17:Reading tar file system.xml
22:10:19:WU01:FS01:0x17:Reading tar file integrator.xml
22:10:19:WU01:FS01:0x17:Reading tar file core.xml
22:10:19:WU01:FS01:0x17:Digital signatures verified
22:10:19:WU01:FS01:0x17:Folding@home GPU core17
22:10:19:WU01:FS01:0x17:Version 0.0.52
22:10:19:WU03:FS03:0x17:Reading tar file integrator.xml
22:10:19:WU03:FS03:0x17:Reading tar file core.xml
22:10:19:WU03:FS03:0x17:Digital signatures verified
22:10:19:WU03:FS03:0x17:Folding@home GPU core17
22:10:19:WU03:FS03:0x17:Version 0.0.52
22:10:19:WU00:FS00:0x17:Reading tar file integrator.xml
22:10:19:WU00:FS00:0x17:Reading tar file core.xml
22:10:19:WU00:FS00:0x17:Digital signatures verified
22:10:19:WU00:FS00:0x17:Folding@home GPU core17
22:10:19:WU00:FS00:0x17:Version 0.0.52
22:11:01:Saving configuration to config.xml
22:11:01:<config>
22:11:01:  <!-- Folding Slot Configuration -->
22:11:01:  <client-type v='advanced'/>
22:11:01:  <power v='full'/>
22:11:01:
22:11:01:  <!-- Network -->
22:11:01:  <proxy v=':8080'/>
22:11:01:
22:11:01:  <!-- Slot Control -->
22:11:01:  <pause-on-start v='true'/>
22:11:01:
22:11:01:  <!-- User Information -->
22:11:01:  <passkey v='********************************'/>
22:11:01:  <team v='69411'/>
22:11:01:  <user v='Roswell_ET'/>
22:11:01:
22:11:01:  <!-- Folding Slots -->
22:11:01:  <slot id='0' type='GPU'/>
22:11:01:  <slot id='1' type='GPU'/>
22:11:01:  <slot id='2' type='GPU'/>
22:11:01:  <slot id='3' type='GPU'/>
22:11:01:</config>
22:11:31:WU02:FS02:0x15:Setting checkpoint frequency: 250000
22:11:31:WU02:FS02:0x15:Completed         3 out of 25000000 steps (0%).
22:11:59:WU03:FS03:0x17:ERROR:exception: Force RMSE error of 178.91 with threshold of 5
22:11:59:WU03:FS03:0x17:Saving result file logfile_01.txt
22:11:59:WU03:FS03:0x17:Saving result file log.txt
22:11:59:WU03:FS03:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
22:11:59:WARNING:WU03:FS03:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:11:59:WU03:FS03:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:479 clone:2 gen:5 core:0x17 unit:0x0000000d028c126651a6913ed988dfde
22:11:59:WU03:FS03:Uploading 2.44KiB to 171.64.65.69
22:11:59:WU03:FS03:Connecting to 171.64.65.69:8080
22:11:59:WU03:FS03:Upload complete
22:11:59:WU03:FS03:Server responded WORK_ACK (400)
22:11:59:WU03:FS03:Cleaning up
22:11:59:WU04:FS03:Connecting to assign-GPU.stanford.edu:80
22:12:00:WU04:FS03:News: Welcome to Folding@Home
22:12:00:WU04:FS03:Assigned to work server 171.64.65.69
22:12:00:WU04:FS03:Requesting new work unit for slot 03: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
22:12:00:WU04:FS03:Connecting to 171.64.65.69:8080
22:12:00:WU04:FS03:Downloading 4.17MiB
22:12:06:WU04:FS03:Download 76.36%
22:12:06:WU04:FS03:Download complete
22:12:06:WU04:FS03:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:8900 run:357 clone:4 gen:3 core:0x17 unit:0x00000009028c126651a67612195e2a4d
22:12:07:WU04:FS03:Starting
22:12:07:WU04:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 04 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 3 -gpu-vendor ati
22:12:07:WU04:FS03:Started FahCore on PID 72
22:12:07:WU04:FS03:Core PID:1472
22:12:07:WU04:FS03:FahCore 0x17 started
22:12:07:WU04:FS03:0x17:*********************** Log Started 2013-11-09T22:12:07Z ***********************
22:12:07:WU04:FS03:0x17:Project: 8900 (Run 357, Clone 4, Gen 3)
22:12:07:WU04:FS03:0x17:Unit: 0x00000009028c126651a67612195e2a4d
22:12:07:WU04:FS03:0x17:CPU: 0x00000000000000000000000000000000
22:12:07:WU04:FS03:0x17:Machine: 3
22:12:07:WU04:FS03:0x17:Reading tar file state.xml
22:12:07:WU01:FS01:0x17:Completed 0 out of 2500000 steps (0%)
22:12:07:WU01:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:12:08:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
22:12:08:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
22:12:08:WU04:FS03:0x17:Reading tar file system.xml
22:12:08:WU04:FS03:0x17:Reading tar file integrator.xml
22:12:08:WU04:FS03:0x17:Reading tar file core.xml
22:12:08:WU04:FS03:0x17:Digital signatures verified
22:12:08:WU04:FS03:0x17:Folding@home GPU core17
22:12:08:WU04:FS03:0x17:Version 0.0.52
22:13:51:WU04:FS03:0x17:ERROR:exception: Force RMSE error of 183.4 with threshold of 5
22:13:51:WU04:FS03:0x17:Saving result file logfile_01.txt
22:13:51:WU04:FS03:0x17:Saving result file log.txt
22:13:51:WU04:FS03:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
22:13:51:WARNING:WU04:FS03:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:13:52:WU04:FS03:Sending unit results: id:04 state:SEND error:FAULTY project:8900 run:357 clone:4 gen:3 core:0x17 unit:0x00000009028c126651a67612195e2a4d
22:13:52:WU04:FS03:Uploading 2.45KiB to 171.64.65.69
22:13:52:WU04:FS03:Connecting to 171.64.65.69:8080
22:13:52:WU03:FS03:Connecting to assign-GPU.stanford.edu:80
22:13:52:WU03:FS03:News: Welcome to Folding@Home
22:13:52:WU03:FS03:Assigned to work server 171.64.65.69
22:13:52:WU03:FS03:Requesting new work unit for slot 03: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
22:13:52:WU03:FS03:Connecting to 171.64.65.69:8080
22:13:52:WU04:FS03:Upload complete
22:13:53:WU03:FS03:Downloading 4.18MiB
22:13:53:WU04:FS03:Server responded WORK_ACK (400)
22:13:53:WU04:FS03:Cleaning up
22:13:58:WU03:FS03:Download complete
22:13:58:WU03:FS03:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8900 run:319 clone:1 gen:157 core:0x17 unit:0x000000cd028c126651a66d91a66b7204
22:13:58:WU03:FS03:Starting
22:13:58:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 3 -gpu-vendor ati
22:13:58:WU03:FS03:Started FahCore on PID 1016
22:13:58:WU03:FS03:Core PID:3308
22:13:58:WU03:FS03:FahCore 0x17 started
22:13:59:WU03:FS03:0x17:*********************** Log Started 2013-11-09T22:13:59Z ***********************
22:13:59:WU03:FS03:0x17:Project: 8900 (Run 319, Clone 1, Gen 157)
22:13:59:WU03:FS03:0x17:Unit: 0x000000cd028c126651a66d91a66b7204
22:13:59:WU03:FS03:0x17:CPU: 0x00000000000000000000000000000000
22:13:59:WU03:FS03:0x17:Machine: 3
22:13:59:WU03:FS03:0x17:Reading tar file state.xml
22:14:00:WU03:FS03:0x17:Reading tar file system.xml
22:14:00:WU03:FS03:0x17:Reading tar file integrator.xml
22:14:00:WU03:FS03:0x17:Reading tar file core.xml
22:14:00:WU03:FS03:0x17:Digital signatures verified
22:14:00:WU03:FS03:0x17:Folding@home GPU core17
22:14:00:WU03:FS03:0x17:Version 0.0.52
22:14:11:WU02:FS02:0x15:Completed    250000 out of 25000000 steps (1%).
22:15:42:WU03:FS03:0x17:ERROR:exception: Force RMSE error of 168.213 with threshold of 5
22:15:42:WU03:FS03:0x17:Saving result file logfile_01.txt
22:15:42:WU03:FS03:0x17:Saving result file log.txt
22:15:42:WU03:FS03:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
22:15:43:WARNING:WU03:FS03:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:15:43:WU03:FS03:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:319 clone:1 gen:157 core:0x17 unit:0x000000cd028c126651a66d91a66b7204
22:15:43:WU03:FS03:Uploading 2.45KiB to 171.64.65.69
22:15:43:WU03:FS03:Connecting to 171.64.65.69:8080
22:15:43:WU03:FS03:Upload complete
22:15:43:WU03:FS03:Server responded WORK_ACK (400)
22:15:43:WU03:FS03:Cleaning up
22:15:43:WU04:FS03:Connecting to assign-GPU.stanford.edu:80
22:15:43:WU04:FS03:News: Welcome to Folding@Home
22:15:43:WU04:FS03:Assigned to work server 171.64.65.69
22:15:43:WU04:FS03:Requesting new work unit for slot 03: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
22:15:43:WU04:FS03:Connecting to 171.64.65.69:8080
22:15:44:WU04:FS03:Downloading 4.17MiB
22:15:49:WU04:FS03:Download complete
22:15:49:WU04:FS03:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:8900 run:270 clone:2 gen:10 core:0x17 unit:0x00000017028c126651a662acce4eb5f3
22:15:49:WU04:FS03:Starting
22:15:49:WU04:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 04 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 3 -gpu-vendor ati
22:15:49:WU04:FS03:Started FahCore on PID 2096
22:15:49:WU04:FS03:Core PID:2468
22:15:49:WU04:FS03:FahCore 0x17 started
22:15:50:WU04:FS03:0x17:*********************** Log Started 2013-11-09T22:15:50Z ***********************
22:15:50:WU04:FS03:0x17:Project: 8900 (Run 270, Clone 2, Gen 10)
22:15:50:WU04:FS03:0x17:Unit: 0x00000017028c126651a662acce4eb5f3
22:15:50:WU04:FS03:0x17:CPU: 0x00000000000000000000000000000000
22:15:50:WU04:FS03:0x17:Machine: 3
22:15:50:WU04:FS03:0x17:Reading tar file state.xml
22:15:50:WU04:FS03:0x17:Reading tar file system.xml
22:15:51:WU04:FS03:0x17:Reading tar file integrator.xml
22:15:51:WU04:FS03:0x17:Reading tar file core.xml
22:15:51:WU04:FS03:0x17:Digital signatures verified
22:15:51:WU04:FS03:0x17:Folding@home GPU core17
22:15:51:WU04:FS03:0x17:Version 0.0.52
22:16:18:WU01:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
22:16:31:WU00:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
22:16:51:WU02:FS02:0x15:Completed    500000 out of 25000000 steps (2%).
22:17:33:WU04:FS03:0x17:ERROR:exception: Force RMSE error of 184.588 with threshold of 5
22:17:33:WU04:FS03:0x17:Saving result file logfile_01.txt
22:17:33:WU04:FS03:0x17:Saving result file log.txt
22:17:33:WU04:FS03:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
22:17:33:WARNING:WU04:FS03:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:17:33:WU04:FS03:Sending unit results: id:04 state:SEND error:FAULTY project:8900 run:270 clone:2 gen:10 core:0x17 unit:0x00000017028c126651a662acce4eb5f3
22:17:34:WU04:FS03:Uploading 2.44KiB to 171.64.65.69
22:17:34:WU04:FS03:Connecting to 171.64.65.69:8080
22:17:34:WU04:FS03:Upload complete
22:17:34:WU04:FS03:Server responded WORK_ACK (400)
22:17:34:WU04:FS03:Cleaning up
22:17:34:WU03:FS03:Connecting to assign-GPU.stanford.edu:80
22:17:34:WU03:FS03:News: Welcome to Folding@Home
22:17:34:WU03:FS03:Assigned to work server 171.64.65.69
22:17:34:WU03:FS03:Requesting new work unit for slot 03: READY gpu:3:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
22:17:34:WU03:FS03:Connecting to 171.64.65.69:8080
22:17:35:WU03:FS03:Downloading 4.18MiB
22:17:41:WU03:FS03:Download 95.77%
22:17:41:WU03:FS03:Download complete
22:17:41:WU03:FS03:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8900 run:141 clone:6 gen:1 core:0x17 unit:0x00000002028c126651a645f9718cc5c3
22:17:41:WU03:FS03:Starting
22:17:41:WU03:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 1256 -checkpoint 15 -gpu 3 -gpu-vendor ati
22:17:41:WU03:FS03:Started FahCore on PID 3108
22:17:41:WU03:FS03:Core PID:3008
22:17:41:WU03:FS03:FahCore 0x17 started
22:17:41:WU03:FS03:0x17:*********************** Log Started 2013-11-09T22:17:41Z ***********************
22:17:41:WU03:FS03:0x17:Project: 8900 (Run 141, Clone 6, Gen 1)
22:17:41:WU03:FS03:0x17:Unit: 0x00000002028c126651a645f9718cc5c3
22:17:41:WU03:FS03:0x17:CPU: 0x00000000000000000000000000000000
22:17:41:WU03:FS03:0x17:Machine: 3
22:17:41:WU03:FS03:0x17:Reading tar file state.xml
22:17:42:WU03:FS03:0x17:Reading tar file system.xml
22:17:42:WU03:FS03:0x17:Reading tar file integrator.xml
22:17:42:WU03:FS03:0x17:Reading tar file core.xml
22:17:42:WU03:FS03:0x17:Digital signatures verified
22:17:42:WU03:FS03:0x17:Folding@home GPU core17
22:17:42:WU03:FS03:0x17:Version 0.0.52
22:19:25:WU03:FS03:0x17:ERROR:exception: Force RMSE error of 174.583 with threshold of 5
22:19:25:WU03:FS03:0x17:Saving result file logfile_01.txt
22:19:25:WU03:FS03:0x17:Saving result file log.txt
22:19:25:WU03:FS03:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
22:19:25:WARNING:WU03:FS03:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:19:25:WU03:FS03:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:141 clone:6 gen:1 core:0x17 unit:0x00000002028c126651a645f9718cc5c3
22:19:25:WU03:FS03:Uploading 2.44KiB to 171.64.65.69
22:19:25:WU03:FS03:Connecting to 171.64.65.69:8080
22:19:26:WU03:FS03:Upload complete
22:19:26:WU03:FS03:Server responded WORK_ACK (400)
22:19:26:WU03:FS03:Cleaning up
22:19:32:WU02:FS02:0x15:Completed    750000 out of 25000000 steps (3%).
22:20:19:WU01:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
22:20:46:WU00:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
22:22:13:WU02:FS02:0x15:Completed   1000000 out of 25000000 steps (4%).
22:24:27:WU01:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
22:24:56:WU02:FS02:0x15:Completed   1250000 out of 25000000 steps (5%).
22:25:09:WU00:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
22:27:38:WU02:FS02:0x15:Completed   1500000 out of 25000000 steps (6%).
22:28:25:WU01:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
22:29:21:WU00:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
22:30:20:WU02:FS02:0x15:Completed   1750000 out of 25000000 steps (7%).
22:32:34:WU01:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
22:33:02:WU02:FS02:0x15:Completed   2000000 out of 25000000 steps (8%).
22:33:45:WU00:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
22:35:44:WU02:FS02:0x15:Completed   2250000 out of 25000000 steps (9%).
22:36:32:WU01:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
22:37:56:WU00:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
22:38:26:WU02:FS02:0x15:Completed   2500000 out of 25000000 steps (10%).
22:40:41:WU01:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
22:41:09:WU02:FS02:0x15:Completed   2750000 out of 25000000 steps (11%).
22:42:19:WU00:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
22:43:51:WU02:FS02:0x15:Completed   3000000 out of 25000000 steps (12%).
22:44:39:WU01:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
22:46:30:WU00:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
22:46:33:WU02:FS02:0x15:Completed   3250000 out of 25000000 steps (13%).
22:48:47:WU01:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
22:49:15:WU02:FS02:0x15:Completed   3500000 out of 25000000 steps (14%).
22:50:53:WU00:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
22:51:58:WU02:FS02:0x15:Completed   3750000 out of 25000000 steps (15%).
22:52:46:WU01:FS01:0x17:Completed 250000 out of 2500000 steps (10%)
P5-133XL
Machine #2:
Machine 3:
Re: Bad GPU's ?
Post by P5-133XL »
There should be a system tray icon for folding. Perhaps it is hidden and you need to customize your system tray icons (the little up-arrow in the system tray or you can do it from the control panel) so that it shows all the time. If you want, you can also create a shortcut to FAHControl and put it on the desktop or even in the startup folder: Whatever is convenient.
Roswell_ET
Hardware configuration: ASRock X79 Extreme6
Intel Xeon E5-2609 Sandy Bridge-EP 2.4GHz 10MB L3 Cache
Kingston HyperX Beast 32GB (4 x 8GB)
(1) Radeon HD 7990
(1) Radeon HD 7970
(1) GTX 780
450,000 ppd
LIGHTNING-1300 1300W Continuous
Kingston SSDNow 120 GB
Windows 7 Home Premium SP1 64-bit
Rosewill THOR V2 Gaming ATX Full Tower
Re: Bad GPU's ?
Post by Roswell_ET »
Please bare with me. I just started learning about computers and how everything really works in July.
Given that I do not know what the warnings and errors mean, is the following an indication that I have a bad gpu core?
23:09:08:FS03:Paused
******************************* Date: 2013-11-10 *******************************
P5-133XL
Machine #2:
Machine 3:
Re: Bad GPU's ?
Post by P5-133XL »
I don't know the cause of that section of errors. Given that you have four very high-end GPU's in a single box my guess would be insufficient power (especially if you are OC'ing) rather than a flaw in any one video card but yes, it is possible you have a bad GPU. It is not easy to find a PS that is capable of producing clean and accurate power over 1500W (My estimate as to the minimum power needed for those cards). A power supply running close to maximum continuously is a recipe for frustration in diagnosis especially over time as PS age.
My first step would be to take it slow and operate each video card individually (pause everything using pause-on-start and manually start a slot) to see if it is working properly. Once you know each one is working individually then start adding another and don't add anymore till two are running together successfully etc.
Roswell_ET
(1) Radeon HD 7990
(1) Radeon HD 7970
(1) GTX 780
450,000 ppd
Re: Bad GPU's ?
Using 800 watts at the plug from a 1300 watt psu
P5-133XL
Machine #2:
Machine 3:
Re: Bad GPU's ?
Post by P5-133XL »
Have you checked to make sure each card is on its own unique rail?
Still my process is good: Run each card individually till they all run properly. Only after that do you add a second card till two run properly without error. Then one at a time. add the 3rd, then the 4th.
Roswell_ET
(1) Radeon HD 7990
(1) Radeon HD 7970
(1) GTX 780
450,000 ppd
Re: Bad GPU's ?
Have an hour before all WU's are complete will start process then.
Roswell_ET
(1) Radeon HD 7990
(1) Radeon HD 7970
(1) GTX 780
450,000 ppd
Re: Bad GPU's ?
P5-133XL wrote:Have you checked to make sure each card is on its own unique rail?
Did everything as you said and have found no problems.
*********************** Log Started 2013-11-11T16:35:49Z ***********************
16:35:49:************************* Folding@home Client *************************
16:35:49:      Website: http://folding.stanford.edu/
16:35:49:    Copyright: (c) 2009-2013 Stanford University
16:35:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:35:49:         Args: --open-web-control
16:35:49:       Config: <none>
16:35:49:******************************** Build ********************************
16:35:49:      Version: 7.3.6
16:35:49:         Date: Feb 18 2013
16:35:49:         Time: 15:25:17
16:35:49:      SVN Rev: 3923
16:35:49:       Branch: fah/trunk/client
16:35:49:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:35:49:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:35:49:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:35:49:     Platform: win32 XP
16:35:49:         Bits: 32
16:35:49:         Mode: Release
16:35:49:******************************* System ********************************
16:35:49:          CPU: Intel(R) Core(TM) i7-4820K CPU @ 3.70GHz
16:35:49:       CPU ID: GenuineIntel Family 6 Model 62 Stepping 4
16:35:49:         CPUs: 8
16:35:49:       Memory: 31.92GiB
16:35:49:  Free Memory: 26.61GiB
16:35:49:      Threads: WINDOWS_THREADS
16:35:49:  Has Battery: false
16:35:49:   On Battery: false
16:35:49:   UTC offset: -8
16:35:49:          PID: 3468
16:35:49:          CWD: e:/Users/Roswell_ET/AppData/Roaming/FAHClient
16:35:49:           OS: Windows 8
16:35:49:      OS Arch: AMD64
16:35:49:         GPUs: 3
16:35:49:        GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
16:35:49:        GPU 1: ATI:5 Tahiti [Radeon HD 7900 Series]
16:35:49:        GPU 2: ATI:5 Tahiti [Radeon HD 7900 Series]
16:35:49:         CUDA: 3.5
16:35:49:  CUDA Driver: 6000
16:35:49:Win32 Service: false
16:35:49:***********************************************************************
16:35:49:<config>
16:35:49:  <!-- Folding Slots -->
16:35:49:</config>
16:35:49:Connecting to assign-GPU.stanford.edu:80
16:35:49:Connecting to assign-GPU.stanford.edu:8080
16:35:50:Read GPUs.txt
16:35:50:Trying to access database...
16:35:50:Successfully acquired database lock
16:35:50:Enabled folding slot 00: PAUSED gpu:0:Tahiti XT [Radeon HD 7970] (not configured)
16:35:50:Enabled folding slot 01: PAUSED gpu:1:Tahiti [Radeon HD 7900 Series] (not configured)
16:35:50:Enabled folding slot 02: PAUSED gpu:2:Tahiti [Radeon HD 7900 Series] (not configured)
16:35:50:Enabled folding slot 03: PAUSED gpu:3:GK110 [GeForce GTX 780] (not configured)
16:35:50:Enabled folding slot 04: PAUSED cpu:7 (not configured)
16:35:54:3:127.0.0.1:New Web connection
16:37:07:Set client configured
16:37:07:WU00:FS04:Connecting to assign-GPU.stanford.edu:80
16:37:08:WU00:FS04:Connecting to assign3.stanford.edu:8080
16:37:08:WU00:FS04:News: Welcome to Folding@Home
16:37:08:WU00:FS04:Assigned to work server 171.64.65.124
16:37:08:WU00:FS04:Requesting new work unit for slot 04: READY cpu:7 from 171.64.65.124
16:37:08:WU00:FS04:Connecting to 171.64.65.124:8080
16:37:09:WU00:FS04:Downloading 808.12KiB
16:37:12:WU00:FS04:Download complete
16:37:12:WU00:FS04:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9004 run:95 clone:1 gen:13 core:0xa4 unit:0x00000010664f2de45265b5f1e5096dae
16:37:12:WU00:FS04:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
16:37:12:WU00:FS04:Connecting to www.stanford.edu:80
16:37:12:WU00:FS04:FahCore a4: Downloading 2.89MiB
16:37:18:WU00:FS04:FahCore a4: 54.10%
16:37:22:WU00:FS04:FahCore a4: Download complete
16:37:22:WU00:FS04:Valid core signature
16:37:22:WU00:FS04:Unpacked 9.59MiB to cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
16:38:14:Saving configuration to config.xml
16:38:14:<config>
16:38:14:  <!-- Folding Slot Configuration -->
16:38:14:  <power v='off'/>
16:38:14:
16:38:14:  <!-- User Information -->
16:38:14:  <passkey v='********************************'/>
16:38:14:  <team v='69411'/>
16:38:14:  <user v='larry'/>
16:38:14:
16:38:14:  <!-- Folding Slots -->
16:38:14:  <slot id='0' type='GPU'/>
16:38:14:  <slot id='1' type='GPU'/>
16:38:14:  <slot id='2' type='GPU'/>
16:38:14:  <slot id='3' type='GPU'/>
16:38:14:  <slot id='4' type='CPU'/>
16:38:14:</config>
16:38:55:Saving configuration to config.xml
16:38:55:<config>
16:38:55:  <!-- Folding Slot Configuration -->
16:38:55:  <power v='off'/>
16:38:55:
16:38:55:  <!-- Network -->
16:38:55:  <proxy v=':8080'/>
16:38:55:
16:38:55:  <!-- User Information -->
16:38:55:  <passkey v='********************************'/>
16:38:55:  <team v='69411'/>
16:38:55:  <user v='larry'/>
16:38:55:
16:38:55:  <!-- Folding Slots -->
16:38:55:  <slot id='0' type='GPU'/>
16:38:55:  <slot id='1' type='GPU'/>
16:38:55:  <slot id='2' type='GPU'/>
16:38:55:  <slot id='3' type='GPU'/>
16:38:55:</config>
16:38:55:WARNING:WU00:Slot ID 4 no longer exists and there are no other matching slots, dumping
16:38:55:WU00:Sending unit results: id:00 state:SEND error:DUMPED project:9004 run:95 clone:1 gen:13 core:0xa4 unit:0x00000010664f2de45265b5f1e5096dae
16:38:55:WU00:Connecting to 171.64.65.124:8080
16:38:56:WU00:Server responded WORK_ACK (400)
16:38:56:WU00:Cleaning up
17:01:20:Saving configuration to config.xml
17:01:20:<config>
17:01:20:  <!-- Folding Slot Configuration -->
17:01:20:  <power v='off'/>
17:01:20:
17:01:20:  <!-- Network -->
17:01:20:  <proxy v=':8080'/>
17:01:20:
17:01:20:  <!-- Slot Control -->
17:01:20:  <pause-on-start v='true'/>
17:01:20:
17:01:20:  <!-- User Information -->
17:01:20:  <passkey v='********************************'/>
17:01:20:  <team v='69411'/>
17:01:20:  <user v='larry'/>
17:01:20:
17:01:20:  <!-- Folding Slots -->
17:01:20:  <slot id='0' type='GPU'/>
17:01:20:  <slot id='1' type='GPU'/>
17:01:20:  <slot id='2' type='GPU'/>
17:01:20:  <slot id='3' type='GPU'/>
17:01:20:</config>
17:01:26:FS03:Paused
17:01:30:FS02:Paused
17:01:34:FS01:Paused
17:01:37:FS00:Paused
17:02:07:FS03:Unpaused
17:02:07:WU00:FS03:Connecting to assign-GPU.stanford.edu:80
17:02:07:WU00:FS03:News: Welcome to Folding@Home
17:02:07:WU00:FS03:Assigned to work server 171.64.65.105
17:02:07:WU00:FS03:Requesting new work unit for slot 03: READY gpu:3:GK110 [GeForce GTX 780] from 171.64.65.105
17:02:07:WU00:FS03:Connecting to 171.64.65.105:8080
17:02:08:WU00:FS03:Downloading 122.79KiB
17:02:09:WU00:FS03:Download complete
17:02:09:WU00:FS03:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7625 run:594 clone:0 gen:62 core:0x15 unit:0x0000004d664f2dd14fe6188d8f73b2ef
17:02:09:WU00:FS03:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
17:02:09:WU00:FS03:Connecting to www.stanford.edu:80
17:02:09:WU00:FS03:FahCore 15: Downloading 1.88MiB
17:02:15:WU00:FS03:FahCore 15: 79.97%
17:02:16:WU00:FS03:FahCore 15: Download complete
17:02:16:WU00:FS03:Valid core signature
17:02:16:WU00:FS03:Unpacked 7.71MiB to cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe
17:02:16:WU00:FS03:Starting
17:02:16:WU00:FS03:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe -dir 00 -suffix 01 -version 703 -lifeline 3468 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
17:02:16:WU00:FS03:Started FahCore on PID 328
17:02:16:WU00:FS03:Core PID:400
17:02:16:WU00:FS03:FahCore 0x15 started
17:02:17:WU00:FS03:0x15:
17:02:17:WU00:FS03:0x15:*------------------------------*
17:02:17:WU00:FS03:0x15:Folding@Home GPU Core
17:02:17:WU00:FS03:0x15:Version                2.25 (Wed May 9 17:03:01 EDT 2012)
17:02:17:WU00:FS03:0x15:Build host             AmoebaRemote
17:02:17:WU00:FS03:0x15:Board Type             NVIDIA/CUDA
17:02:17:WU00:FS03:0x15:Core                   15
17:02:17:WU00:FS03:0x15:Window's signal control handler registered.
17:02:17:WU00:FS03:0x15:Preparing to commence simulation
17:02:17:WU00:FS03:0x15:- Looking at optimizations...
17:02:17:WU00:FS03:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
17:02:17:WU00:FS03:0x15:- Created dyn
17:02:17:WU00:FS03:0x15:- Files status OK
17:02:17:WU00:FS03:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:02:17:WU00:FS03:0x15:- Expanded 125224 -> 502918 (decompressed 401.6 percent)
17:02:17:WU00:FS03:0x15:Called DecompressByteArray: compressed_data_size=125224 data_size=502918, decompressed_data_size=502918 diff=0
17:02:17:WU00:FS03:0x15:- Digital signature verified
17:02:17:WU00:FS03:0x15:Project: 7625 (Run 594, Clone 0, Gen 62)
17:02:17:WU00:FS03:0x15:Assembly optimizations on if available.
17:02:17:WU00:FS03:0x15:Entering M.D.
17:02:18:WU00:FS03:0x15:Tpr hash 00/wudata_01.tpr:  1934924371 2369514010 1123906017 744856184 1080143844
17:02:18:WU00:FS03:0x15:GPU device id=0
17:02:18:WU00:FS03:0x15:Working on Protein
17:02:18:WU00:FS03:0x15:Client config unavailable.
17:02:19:WU00:FS03:0x15:Starting GUI Server
17:02:47:Saving configuration to config.xml
17:02:47:<config>
17:02:47:  <!-- Folding Slot Configuration -->
17:02:47:  <power v='full'/>
17:02:47:
17:02:47:  <!-- Network -->
17:02:47:  <proxy v=':8080'/>
17:02:47:
17:02:47:  <!-- Slot Control -->
17:02:47:  <pause-on-start v='true'/>
17:02:47:
17:02:47:  <!-- User Information -->
17:02:47:  <passkey v='********************************'/>
17:02:47:  <team v='69411'/>
17:02:47:  <user v='larry'/>
17:02:47:
17:02:47:  <!-- Folding Slots -->
17:02:47:  <slot id='0' type='GPU'/>
17:02:47:  <slot id='1' type='GPU'/>
17:02:47:  <slot id='2' type='GPU'/>
17:02:47:  <slot id='3' type='GPU'/>
17:02:47:</config>
17:03:22:WU00:FS03:0x15:Setting checkpoint frequency: 400000
17:03:22:WU00:FS03:0x15:Completed         3 out of 40000000 steps (0%).
17:04:52:FS02:Unpaused
17:04:52:WU01:FS02:Connecting to assign-GPU.stanford.edu:80
17:04:53:WU01:FS02:News: Welcome to Folding@Home
17:04:53:WU01:FS02:Assigned to work server 171.64.65.69
17:04:53:WU01:FS02:Requesting new work unit for slot 02: READY gpu:2:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
17:04:53:WU01:FS02:Connecting to 171.64.65.69:8080
17:04:53:WU01:FS02:Downloading 4.18MiB
17:04:59:WU01:FS02:Download 77.82%
17:04:59:WU01:FS02:Download complete
17:04:59:WU01:FS02:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:470 clone:4 gen:5 core:0x17 unit:0x00000007028c126651a68f473c2b0e1e
17:04:59:WU01:FS02:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah
17:04:59:WU01:FS02:Connecting to www.stanford.edu:80
17:05:00:WU01:FS02:FahCore 17: Downloading 2.55MiB
17:05:06:WU01:FS02:FahCore 17: 68.62%
17:05:08:WU01:FS02:FahCore 17: Download complete
17:05:09:WU01:FS02:Valid core signature
17:05:09:WU01:FS02:Unpacked 8.60MiB to cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe
17:05:09:WU01:FS02:Starting
17:05:09:WU01:FS02:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 3468 -checkpoint 15 -gpu 2 -gpu-vendor ati
17:05:09:WU01:FS02:Started FahCore on PID 992
17:05:09:WU01:FS02:Core PID:2144
17:05:09:WU01:FS02:FahCore 0x17 started
17:05:09:WU01:FS02:0x17:*********************** Log Started 2013-11-11T17:05:09Z ***********************
17:05:09:WU01:FS02:0x17:Project: 8900 (Run 470, Clone 4, Gen 5)
17:05:09:WU01:FS02:0x17:Unit: 0x00000007028c126651a68f473c2b0e1e
17:05:09:WU01:FS02:0x17:CPU: 0x00000000000000000000000000000000
17:05:09:WU01:FS02:0x17:Machine: 2
17:05:09:WU01:FS02:0x17:Reading tar file state.xml
17:05:10:WU01:FS02:0x17:Reading tar file system.xml
17:05:10:WU01:FS02:0x17:Reading tar file integrator.xml
17:05:10:WU01:FS02:0x17:Reading tar file core.xml
17:05:10:WU01:FS02:0x17:Digital signatures verified
17:05:10:WU01:FS02:0x17:Folding@home GPU core17
17:05:10:WU01:FS02:0x17:Version 0.0.52
17:06:53:WU00:FS03:0x15:Completed    400000 out of 40000000 steps (1%).
17:06:56:WU01:FS02:0x17:Completed 0 out of 2500000 steps (0%)
17:06:56:WU01:FS02:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:09:06:FS01:Unpaused
17:09:06:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
17:09:07:WU02:FS01:News: Welcome to Folding@Home
17:09:07:WU02:FS01:Assigned to work server 171.64.65.69
17:09:07:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:Tahiti [Radeon HD 7900 Series] from 171.64.65.69
17:09:07:WU02:FS01:Connecting to 171.64.65.69:8080
17:09:07:WU02:FS01:Downloading 4.18MiB
17:09:13:WU02:FS01:Download 70.36%
17:09:14:WU02:FS01:Download complete
17:09:14:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:123 clone:0 gen:222 core:0x17 unit:0x00000107028c126651a641cdd11d12c8
17:09:14:WU02:FS01:Starting
17:09:14:WU02:FS01:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 3468 -checkpoint 15 -gpu 1 -gpu-vendor ati
17:09:14:WU02:FS01:Started FahCore on PID 1756
17:09:14:WU02:FS01:Core PID:2348
17:09:14:WU02:FS01:FahCore 0x17 started
17:09:14:WU02:FS01:0x17:*********************** Log Started 2013-11-11T17:09:14Z ***********************
17:09:14:WU02:FS01:0x17:Project: 8900 (Run 123, Clone 0, Gen 222)
17:09:14:WU02:FS01:0x17:Unit: 0x00000107028c126651a641cdd11d12c8
17:09:14:WU02:FS01:0x17:CPU: 0x00000000000000000000000000000000
17:09:14:WU02:FS01:0x17:Machine: 1
17:09:14:WU02:FS01:0x17:Reading tar file state.xml
17:09:15:WU02:FS01:0x17:Reading tar file system.xml
17:09:15:WU02:FS01:0x17:Reading tar file integrator.xml
17:09:15:WU02:FS01:0x17:Reading tar file core.xml
17:09:15:WU02:FS01:0x17:Digital signatures verified
17:09:15:WU02:FS01:0x17:Folding@home GPU core17
17:09:15:WU02:FS01:0x17:Version 0.0.52
17:10:25:WU00:FS03:0x15:Completed    800000 out of 40000000 steps (2%).
17:11:02:WU02:FS01:0x17:Completed 0 out of 2500000 steps (0%)
17:11:02:WU02:FS01:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:11:13:WU01:FS02:0x17:Completed 25000 out of 2500000 steps (1%)
17:13:16:FS00:Unpaused
17:13:17:WU03:FS00:Connecting to assign-GPU.stanford.edu:80
17:13:17:WU03:FS00:News: Welcome to Folding@Home
17:13:17:WU03:FS00:Assigned to work server 171.64.65.69
17:13:17:WU03:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970] from 171.64.65.69
17:13:17:WU03:FS00:Connecting to 171.64.65.69:8080
17:13:17:WU03:FS00:Downloading 4.17MiB
17:13:23:WU03:FS00:Download 71.88%
17:13:24:WU03:FS00:Download complete
17:13:24:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:8900 run:487 clone:5 gen:3 core:0x17 unit:0x00000004028c126651a693153b82d3a4
17:13:24:WU03:FS00:Starting
17:13:24:WU03:FS00:Running FahCore: "e:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" e:/Users/Roswell_ET/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 03 -suffix 01 -version 703 -lifeline 3468 -checkpoint 15 -gpu 0 -gpu-vendor ati
17:13:24:WU03:FS00:Started FahCore on PID 332
17:13:24:WU03:FS00:Core PID:2968
17:13:24:WU03:FS00:FahCore 0x17 started
17:13:24:WU03:FS00:0x17:*********************** Log Started 2013-11-11T17:13:24Z ***********************
17:13:24:WU03:FS00:0x17:Project: 8900 (Run 487, Clone 5, Gen 3)
17:13:24:WU03:FS00:0x17:Unit: 0x00000004028c126651a693153b82d3a4
17:13:24:WU03:FS00:0x17:CPU: 0x00000000000000000000000000000000
17:13:24:WU03:FS00:0x17:Machine: 0
17:13:24:WU03:FS00:0x17:Reading tar file state.xml
17:13:25:WU03:FS00:0x17:Reading tar file system.xml
17:13:25:WU03:FS00:0x17:Reading tar file integrator.xml
17:13:25:WU03:FS00:0x17:Reading tar file core.xml
17:13:25:WU03:FS00:0x17:Digital signatures verified
17:13:25:WU03:FS00:0x17:Folding@home GPU core17
17:13:25:WU03:FS00:0x17:Version 0.0.52
17:14:02:WU00:FS03:0x15:Completed   1200000 out of 40000000 steps (3%).
17:15:07:WU02:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
17:15:12:WU03:FS00:0x17:Completed 0 out of 2500000 steps (0%)
17:15:12:WU03:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
17:15:19:WU01:FS02:0x17:Completed 50000 out of 2500000 steps (2%)
17:17:39:WU00:FS03:0x15:Completed   1600000 out of 40000000 steps (4%).
17:19:05:WU02:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
17:19:21:WU03:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
17:19:39:WU01:FS02:0x17:Completed 75000 out of 2500000 steps (3%)
17:21:19:WU00:FS03:0x15:Completed   2000000 out of 40000000 steps (5%).
17:23:14:WU02:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
17:23:20:WU03:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
17:23:46:WU01:FS02:0x17:Completed 100000 out of 2500000 steps (4%)
17:24:58:WU00:FS03:0x15:Completed   2400000 out of 40000000 steps (6%).
17:27:12:WU02:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
17:27:30:WU03:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
17:27:59:WU01:FS02:0x17:Completed 125000 out of 2500000 steps (5%)
17:28:34:WU00:FS03:0x15:Completed   2800000 out of 40000000 steps (7%).
17:31:22:WU02:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
17:31:30:WU03:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
17:31:56:WU01:FS02:0x17:Completed 150000 out of 2500000 steps (6%)
17:32:10:WU00:FS03:0x15:Completed   3200000 out of 40000000 steps (8%).
Re: Bad GPU's ?
So individually everything works but when all of them are operating at the same time, you have problems? The points very strongly to inadequate 12v power being supplied to the collection. Note that only the 12v rails really count and if your power supply has plenty of 5v and not enough 12v current, that's bad.
P5-133XL
Machine #2:
Machine 3:
Re: Bad GPU's ?
Post by P5-133XL »
Also monitor temps on all GPU's. It is quite possible for insufficient case air-flow causing a card to get hot producing failure but only if the cards near it are operating too.
