0% Progress on 6970m
NekoTwilight
Post by NekoTwilight »
Hey guys! Been a *very* long time since I've folded. Just downloaded the v7 client and successfully started folding on my i7. I can't seem to get my 6970m working however. I disabled the cpu slot to make sure it wasn't taking up bandwith the gpu might need. Any suggestions? I've got the latest beta drivers installed. Getting some weird error messages too. Thanks for any help!
*********************** Log Started 2013-11-09T11:07:29Z ***********************
11:07:29:************************* Folding@home Client *************************
11:07:29:      Website: http://folding.stanford.edu/
11:07:29:    Copyright: (c) 2009-2013 Stanford University
11:07:29:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:07:29:         Args: --open-web-control
11:07:29:       Config: C:/Users/Thomas/AppData/Roaming/FAHClient/config.xml
11:07:29:******************************** Build ********************************
11:07:29:      Version: 7.3.6
11:07:29:         Date: Feb 18 2013
11:07:29:         Time: 15:25:17
11:07:29:      SVN Rev: 3923
11:07:29:       Branch: fah/trunk/client
11:07:29:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:07:29:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:07:29:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:07:29:     Platform: win32 XP
11:07:29:         Bits: 32
11:07:29:         Mode: Release
11:07:29:******************************* System ********************************
11:07:29:          CPU: Intel(R) Core(TM) i7-2860QM CPU @ 2.50GHz
11:07:29:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
11:07:29:         CPUs: 8
11:07:29:       Memory: 7.96GiB
11:07:29:  Free Memory: 6.32GiB
11:07:29:      Threads: WINDOWS_THREADS
11:07:29:  Has Battery: true
11:07:29:   On Battery: false
11:07:29:   UTC offset: -8
11:07:29:          PID: 5688
11:07:29:          CWD: C:/Users/Thomas/AppData/Roaming/FAHClient
11:07:29:           OS: Windows 8.1 Pro
11:07:29:      OS Arch: AMD64
11:07:29:         GPUs: 1
11:07:29:        GPU 0: ATI:4 Whistler XT [AMD Radeon HD 6970M]
11:07:29:         CUDA: Not detected
11:07:29:Win32 Service: false
11:07:29:***********************************************************************
11:07:29:<config>
11:07:29:  <!-- Folding Core -->
11:07:29:  <cpu-usage v='65'/>
11:07:29:
11:07:29:  <!-- Folding Slot Configuration -->
11:07:29:  <client-type v='advanced'/>
11:07:29:  <power v='full'/>
11:07:29:
11:07:29:  <!-- Network -->
11:07:29:  <proxy v=':8080'/>
11:07:29:
11:07:29:  <!-- User Information -->
11:07:29:  <passkey v='********************************'/>
11:07:29:  <team v='37726'/>
11:07:29:  <user v='Post-it'/>
11:07:29:
11:07:29:  <!-- Folding Slots -->
11:07:29:  <slot id='0' type='GPU'/>
11:07:29:</config>
11:07:29:Trying to access database...
11:07:29:Successfully acquired database lock
11:07:29:Enabled folding slot 00: READY gpu:0:Whistler XT [AMD Radeon HD 6970M]
11:07:29:WU00:FS00:Starting
11:07:29:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Thomas/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 5688 -checkpoint 15 -gpu 0 -gpu-vendor ati
11:07:29:WU00:FS00:Started FahCore on PID 352
11:07:30:WU00:FS00:Core PID:4076
11:07:30:WU00:FS00:FahCore 0x17 started
11:07:31:WU00:FS00:0x17:*********************** Log Started 2013-11-09T11:07:30Z ***********************
11:07:31:WU00:FS00:0x17:Project: 8900 (Run 488, Clone 5, Gen 0)
11:07:31:WU00:FS00:0x17:Unit: 0x00000002028c126651a6934e57f7a1cf
11:07:31:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
11:07:31:WU00:FS00:0x17:Machine: 0
11:07:31:WU00:FS00:0x17:Digital signatures verified
11:07:31:WU00:FS00:0x17:Folding@home GPU core17
11:07:31:WU00:FS00:0x17:Version 0.0.52
11:07:31:3:127.0.0.1:New Web connection
11:09:54:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
11:09:54:WU00:FS00:0x17:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
11:17:19:WARNING:Exception: 8:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
11:17:26:WARNING:Exception: 12:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
Re: 0% Progress on 6970m
If only folding on the GPU set the CPU usage back to 100.
How much longer did you wait? The client started folding by showing frame 0 completed.
NekoTwilight
Thanks for the response. CPU usage is back at 100% now. I had run it for maybe 40 minutes to an hour before giving up. Might have let it go longer but those messages in the log convinced me something was wrong.
Gonna give it another go.
Welcome to the F@H Forum NekoTwilight,
Please note that the message below indicates that you have closed the Web Control. It is not an error related to folding on your GPU.
Regarding the GPU, you might want to leave it overnight and see if any progress is being made. You may also want to use GPU-Z (http://www.techpowerup.com/downloads/SysInfo/GPU-Z/) to check the load levels on your GPU if required.
