I would like to make a suggestion. Maybe we should add a suggestion forum thread. Also, I was wondering why the PC version of the same Mac client control 7.3.6 works differently. For example on the mac, when I have the expert control window open I can click on full, the slider will go to full or go to whatever slider option you pick, but on windows when I start and off and go to full, the slider has to click through every point till it gets to full. Can we fix the slider in the PC version please? Don't you think they should work the same?
Thank you,
Erik
Suggestion
Re: Suggestion
Yes. But the operating systems should all work the same way too, and they do not. That imposes some limitations as to how certain functions can be programmed consistently. This change may be possible, or it may not. Doesn't hurt to ask.
I also see there are some changes coming in the next release of the client from the Bug Trac system that might be related. I created a new ticket anyway. https://fah-web.stanford.edu/projects/F ... icket/1072
P.S. There are several suggestion threads, but mostly for dedicated topics, like the forum, the website, things that don't change much. The clients change too often to have a dedicated thread for those. Pick the client section and version, and post your suggestions there.
