can't connect 155.247.166.219
hisui
Post by hisui »
ping is ok,but can't connect via 8080 port in browser,unable to upload finished wu to that server,can't access via ssh and other proxy as well.
Upload go on for a while but always stuck at 99%
Pinging 155.247.166.219 with 32 bytes of data:
Reply from 155.247.166.219: bytes=32 time=241ms TTL=45
Reply from 155.247.166.219: bytes=32 time=239ms TTL=45
Reply from 155.247.166.219: bytes=32 time=298ms TTL=45
Reply from 155.247.166.219: bytes=32 time=252ms TTL=45
*********************** Log Started 2013-11-04T04:46:45Z ***********************
04:46:45:************************* Folding@home Client *************************
04:46:45:      Website: http://folding.stanford.edu/
04:46:45:    Copyright: (c) 2009-2012 Stanford University
04:46:45:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:46:45:         Args: --lifeline 1724 --command-port=36330
04:46:45:       Config: E:/FAHCdata/config.xml
04:46:45:******************************** Build ********************************
04:46:45:      Version: 7.2.9
04:46:45:         Date: Oct 3 2012
04:46:45:         Time: 18:05:48
04:46:45:      SVN Rev: 3578
04:46:45:       Branch: fah/trunk/client
04:46:45:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:46:45:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:46:45:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:46:45:     Platform: win32 XP
04:46:45:         Bits: 32
04:46:45:         Mode: Release
04:46:45:******************************* System ********************************
04:46:45:          CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
04:46:45:       CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
04:46:45:         CPUs: 4
04:46:45:       Memory: 3.93GiB
04:46:45:  Free Memory: 3.01GiB
04:46:45:      Threads: WINDOWS_THREADS
04:46:45:   On Battery: false
04:46:45:   UTC offset: 8
04:46:45:          PID: 5768
04:46:45:          CWD: E:/FAHCdata
04:46:45:           OS: Microsoft Windows Server 2003 Service Pack 2
04:46:45:      OS Arch: X86
04:46:45:         GPUs: 1
04:46:45:        GPU 0: NVIDIA:1 G98 [GeForce 9300 GE]
04:46:45:         CUDA: Not detected
04:46:45:Win32 Service: false
04:46:45:***********************************************************************
04:46:45:<config>
04:46:45:  <!-- Network -->
04:46:45:  <proxy v='210.101.131.231:8080'/>
04:46:45:
04:46:45:  <!-- User Information -->
04:46:45:  <passkey v='********************************'/>
04:46:45:  <user v='Hisui'/>
04:46:45:
04:46:45:  <!-- Folding Slots -->
04:46:45:  <slot id='0' type='SMP'>
04:46:45:    <cpus v='2'/>
04:46:45:  </slot>
04:46:45:</config>
04:46:45:Trying to access database...
04:46:45:Successfully acquired database lock
04:46:45:Enabled folding slot 00: READY smp:2
04:46:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:6362 run:4 clone:77 gen:4 core:0xa4 unit:0x000000050002894b52668b1fdce6b31e
04:46:45:WU00:FS00:Uploading 844.22KiB to 155.247.166.219
04:46:45:WU01:FS00:Starting
04:46:45:WU00:FS00:Connecting to 155.247.166.219:8080
04:46:45:WU01:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe E:/FAHCdata/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 702 -lifeline 5768 -checkpoint 15 -np 2
04:46:45:WU01:FS00:Started FahCore on PID 4336
04:46:45:WU01:FS00:Core PID:5536
04:46:45:WU01:FS00:FahCore 0xa4 started
04:46:46:WU01:FS00:0xa4:
04:46:46:WU01:FS00:0xa4:*------------------------------*
04:46:46:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
04:46:46:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
04:46:46:WU01:FS00:0xa4:Preparing to commence simulation
04:46:46:WU01:FS00:0xa4:- Ensuring status. Please wait.
04:46:49:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
04:46:55:WU01:FS00:0xa4:- Looking at optimizations...
04:46:55:WU01:FS00:0xa4:- Working with standard loops on this execution.
04:46:55:WU01:FS00:0xa4:- Previous termination of core was improper.
04:46:55:WU01:FS00:0xa4:- Files status OK
04:46:55:WU01:FS00:0xa4:- Expanded 2053920 -> 5365960 (decompressed 261.2 percent)
04:46:55:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=2053920 data_size=5365960, decompressed_data_size=5365960 diff=0
04:46:55:WU01:FS00:0xa4:- Digital signature verified
04:46:55:WU01:FS00:0xa4:Project: 7808 (Run 9, Clone 164, Gen 79)
04:46:55:WU01:FS00:0xa4:Entering M.D.
04:47:01:WU01:FS00:0xa4:Using Gromacs checkpoints
04:47:02:WU01:FS00:0xa4:Mapping NT from 2 to 2
04:47:02:WU01:FS00:0xa4:Resuming from checkpoint
04:47:02:WU01:FS00:0xa4:Verified 01/wudata_01.log
04:47:02:WU01:FS00:0xa4:Verified 01/wudata_01.trr
04:47:02:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
04:47:02:WU01:FS00:0xa4:Verified 01/wudata_01.edr
04:47:02:WU01:FS00:0xa4:Completed 29120 out of 1500000 steps  (1%)
04:47:04:WU00:FS00:Upload 7.58%
04:47:11:WU00:FS00:Upload 22.74%
04:47:17:WU00:FS00:Upload 30.32%
04:47:23:WU00:FS00:Upload 37.90%
04:47:30:WU00:FS00:Upload 53.07%
04:47:40:WU00:FS00:Upload 68.23%
04:47:49:WU00:FS00:Upload 83.39%
04:48:01:WU00:FS00:Upload 98.55%
04:48:52:WU01:FS00:0xa4:Completed 30000 out of 1500000 steps  (2%)
05:19:50:WU01:FS00:0xa4:Completed 45000 out of 1500000 steps  (3%)
05:50:37:WU01:FS00:0xa4:Completed 60000 out of 1500000 steps  (4%)
06:21:26:WU01:FS00:0xa4:Completed 75000 out of 1500000 steps  (5%)
06:52:07:WU01:FS00:0xa4:Completed 90000 out of 1500000 steps  (6%)
07:22:47:WU01:FS00:0xa4:Completed 105000 out of 1500000 steps  (7%)
07:53:28:WU01:FS00:0xa4:Completed 120000 out of 1500000 steps  (8%)
08:24:09:WU01:FS00:0xa4:Completed 135000 out of 1500000 steps  (9%)
08:54:54:WU01:FS00:0xa4:Completed 150000 out of 1500000 steps  (10%)
09:25:42:WU01:FS00:0xa4:Completed 165000 out of 1500000 steps  (11%)
09:56:33:WU01:FS00:0xa4:Completed 180000 out of 1500000 steps  (12%)
bollix47
Re: can't connect 155.247.166.219
Post by bollix47 »
Thank you for your report.
According to the Server Status page both the cpu load and the net load are somewhat high. PG has been notified but because of the early hour there I doubt they will be able to investigate for at least a few hours.
vvoelz
Pande Group Member
Post by vvoelz »
Thanks for the report. We have found the problem: a full disk on that server. I have taken vav3 (155.247.166.219) down to migrate to a RAID disk with plenty of space. This may take an hour or two, but it will be back up by today. In the meantime, the collection server (vav4) should be collecting returned WUs.
Thanks for your patience and understanding,
Vince
vvoelz
Pande Group Member
Post by vvoelz »
vav3 (155.247.166.219) is back up, and running well. It will take ~20 min for the assignment server to acknowlegde it but then should be available for new assignments. Please let me know if there are any more problems. --VInce
