Using the latest client for Windows, I find my PPD is all over the place. One moment it is 1000 PPD, 5 mins later it is up past 3,000 PPD and then everywhere in between. This is after 65% of the WU is done.
Why so inaccurate?
Why is PPD so inaccurate?
Re: Why is PPD so inaccurate?
To calculate PPD, you must predict the future. How quickly will your system complete the current projects?
Computing an AVERAGE frame time will allow FAH to ASSUME that it has measured FAH's progress over a long enough time period to project that progress will continue to be made at the current rate. It cannot know if you're running something else which is slowing FAH down briefly or if you're going to start something soon which will. Changes like that are unpredictable. Then, too, how long does it have to measure progress to get a good average? One frame of each WU? Three frames of each WU? When did the WU start and has it progressed at exactly the same rate since then or did you just make a change of some kind? How much of that time has been spend in a PAUSED state?
If you can predict what the average PPD is going to be better than FAH is doing, please tell us how to do it.
- Hardware configuration: Full Time:
2x NVidia GTX 980
1x NVidia GTX 780 Ti
2x 3GHz Core i5 PC (Linux)
3.2GHz Core i5 PC (Linux)
3.2GHz Core i5 iMac
2.8GHz Core i5 iMac
2.16GHz Core 2 Duo iMac
2GHz Core 2 Duo MacBook
1.6GHz Core 2 Duo Acer laptop - Location: Near Oxford, United Kingdom
Or, as bollix47 says, use HFM… it's a lot closer than FAHControl !codysluder wrote: If you can predict what the average PPD is going to be better than FAH is doing, please tell us how to do it.
The worst WUs for me seem to be the 900x projects- they vary by a factor of about 2 between alternate frames (with nothing else running!) with FAH, pretty steady (and close) with HFM.
