I installed the available debian package and set the load to 'full'. Here is what I see now. Can someone confirm I am pushing as much power out of this thing as I possibly can?
It's OK. This is all my equipment. My company. My datacenter. And power isn't an issue. There is plenty of that too. Any recommendations to fine tune my system for max output so I can apply it to the rest of the boxes?k1wi wrote:ekiro - personal servers or servers (work or otherwise) that you have access/control of? It's a common first question, as if they aren't personal servers then as per the EULA you need to get permission of the owners/business to run FAH on them (ideally in writing).
It would probably be useful to keep an eye on power usage, as depending on hosting (i.e. in-house or off-site), they an add up quite quickly in a datacentre environment...
Also, you can see the attached image by visiting: http://i.imgur.com/nyRXej7.pngZagen30 wrote:Whatever you linked to didn't show up, probably because there are restrictions on new users to combat spammers.
If possible, paste the contents of the log file in code tags, which you can find in the Full Editor. Make sure to include the System section at the top of the log.
*********************** Log Started 2013-10-28T21:38:45Z ***********************
21:38:45:************************* Folding@home Client *************************
21:38:45: Website: http://folding.stanford.edu/
21:38:45: Copyright: (c) 2009-2013 Stanford University
21:38:45: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:38:45: Args: --child --lifeline 17868 /etc/fahclient/config.xml --run-as
21:38:45: fahclient --pid-file=/var/run/fahclient.pid --daemon
21:38:45: Config: /etc/fahclient/config.xml
21:38:45:******************************** Build ********************************
21:38:45: Version: 7.3.6
21:38:45: Date: Feb 18 2013
21:38:45: Time: 07:24:08
21:38:45: SVN Rev: 3923
21:38:45: Branch: fah/trunk/client
21:38:45: Compiler: GNU 4.4.7
21:38:45: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
21:38:45: -fno-unsafe-math-optimizations -msse2
21:38:45: Platform: linux2 3.2.0-1-amd64
21:38:45: Bits: 64
21:38:45: Mode: Release
21:38:45:******************************* System ********************************
21:38:45: CPU: Intel(R) Xeon(R) CPU E5-2650 0 @ 2.00GHz
21:38:45: CPU ID: GenuineIntel Family 6 Model 45 Stepping 7
21:38:45: CPUs: 32
21:38:45: Memory: 63.02GiB
21:38:45:Free Memory: 250.01MiB
21:38:45: Threads: POSIX_THREADS
21:38:45:Has Battery: false
21:38:45: On Battery: false
21:38:45: UTC offset: -7
21:38:45: PID: 17874
21:38:45: CWD: /var/lib/fahclient
21:38:45: OS: Linux 3.2.0-4-amd64 x86_64
21:38:45: OS Arch: AMD64
21:38:45: GPUs: 0
21:38:45: CUDA: Not detected
21:38:45:***********************************************************************
21:38:45:<config>
21:38:45: <!-- Client Control -->
21:38:45: <fold-anon v='true'/>
21:38:45:
21:38:45: <!-- Folding Slot Configuration -->
21:38:45: <power v='full'/>
21:38:45:
21:38:45: <!-- User Information -->
21:38:45: <passkey v='********************************'/>
21:38:45: <user v='Ekiro_Starkana'/>
21:38:45:
21:38:45: <!-- Folding Slots -->
21:38:45:</config>
21:38:45:Switching to user fahclient
21:38:45:Trying to access database...
21:38:45:Successfully acquired database lock
21:38:45:FS00:Set client configured
21:38:45:Enabled folding slot 00: READY cpu:32
21:38:45:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:38:46:WU00:FS00:Connecting to assign3.stanford.edu:8080
21:38:46:WU00:FS00:News: Welcome to Folding@Home
21:38:46:WU00:FS00:Assigned to work server 128.143.231.202
21:38:46:WU00:FS00:Requesting new work unit for slot 00: READY cpu:32 from 128.143.231.202
21:38:46:WU00:FS00:Connecting to 128.143.231.202:8080
21:38:48:WU00:FS00:Downloading 3.67MiB
21:38:49:WU00:FS00:Download complete
21:38:49:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8585 run:1 clone:5 gen:71 core:0xa3 unit:0x0000025b0a3b1e5952288a23cefb225d
21:38:49:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Linux/AMD64/Core_a3.fah
21:38:49:WU00:FS00:Connecting to www.stanford.edu:80
21:38:49:WU00:FS00:FahCore a3: Downloading 2.56MiB
21:38:54:WU00:FS00:FahCore a3: Download complete
21:38:54:WU00:FS00:Valid core signature
21:38:54:WU00:FS00:Unpacked 5.98MiB to cores/www.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3
21:38:54:WU00:FS00:Starting
21:38:54:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 00 -suffi$
21:38:54:WU00:FS00:Started FahCore on PID 17891
21:38:54:WU00:FS00:Core PID:17895
21:38:54:WU00:FS00:FahCore 0xa3 started
21:38:54:WU00:FS00:0xa3:
21:38:54:WU00:FS00:0xa3:*------------------------------*
21:38:54:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
21:38:54:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
21:38:54:WU00:FS00:0xa3:Preparing to commence simulation
21:38:54:WU00:FS00:0xa3:- Looking at optimizations...
21:38:54:WU00:FS00:0xa3:- Created dyn
21:38:54:WU00:FS00:0xa3:- Files status OK
21:38:54:WU00:FS00:0xa3:- Expanded 3851666 -> 4394668 (decompressed 114.0 percent)
21:38:54:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3851666 data_size=4394668, decompressed_data_size=4394668 diff=0
21:38:54:WU00:FS00:0xa3:- Digital signature verified
21:38:54:WU00:FS00:0xa3:Project: 8585 (Run 1, Clone 5, Gen 71)
21:38:54:WU00:FS00:0xa3:Assembly optimizations on if available.
21:38:54:WU00:FS00:0xa3:Entering M.D.
21:39:00:WU00:FS00:0xa3:Mapping NT from 32 to 32
21:39:01:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
21:43:19:WU00:FS00:0xa3:Completed 5000 out of 500000 steps (1%)
21:47:44:WU00:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
21:51:51:WU00:FS00:0xa3:Completed 15000 out of 500000 steps (3%)
21:56:02:WU00:FS00:0xa3:Completed 20000 out of 500000 steps (4%)
22:00:00:WU00:FS00:0xa3:Completed 25000 out of 500000 steps (5%)
22:04:06:WU00:FS00:0xa3:Completed 30000 out of 500000 steps (6%)
22:08:04:WU00:FS00:0xa3:Completed 35000 out of 500000 steps (7%)
22:12:00:WU00:FS00:0xa3:Completed 40000 out of 500000 steps (8%)
22:15:56:WU00:FS00:0xa3:Completed 45000 out of 500000 steps (9%)
22:19:50:WU00:FS00:0xa3:Completed 50000 out of 500000 steps (10%)
22:23:47:WU00:FS00:0xa3:Completed 55000 out of 500000 steps (11%)
22:27:41:WU00:FS00:0xa3:Completed 60000 out of 500000 steps (12%)
22:31:41:WU00:FS00:0xa3:Completed 65000 out of 500000 steps (13%)
22:35:37:WU00:FS00:0xa3:Completed 70000 out of 500000 steps (14%)
22:39:35:WU00:FS00:0xa3:Completed 75000 out of 500000 steps (15%)
22:43:35:WU00:FS00:0xa3:Completed 80000 out of 500000 steps (16%)What you think of NVIDIA's Tesla line (K20?). I see we have 4 of those in storage.k1wi wrote:In terms of value for money, you're going to get better bang for your buck going with 'regular' GeForce GPUs - the benefits associated with Quadros (i.e. DP compute) don't really apply for F@H at the present time.
The quick return bonus (QRB) rewards faster GPUs in an exponential manner, but this is often offset by the increasing cost of GPUs. I'm not up to date with the 700 series, so someone else might be able to let you know where the sweet spot currently is.
