GPU is in the whitelist[solved] white has blacklist in it
Longbowgun
Post by Longbowgun »
I see my GPU in the white list but, I get an error (On client "local" 127.0.0.1:36330: No more GPUs) when trying to add it via the configure/slots (It doesn't add it automatically). I wouldn't have thought it would be in there with how old it is. But, I think it's in there. :e?:
0x1002:0x4c66:::Radeon RV250 [Mobility FireGL 9000]
*********************** Log Started 2013-10-19T02:33:48Z ***********************
02:33:48:************************* Folding@home Client *************************
02:33:48:      Website: http://folding.stanford.edu/
02:33:48:    Copyright: (c) 2009-2013 Stanford University
02:33:48:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:33:48:         Args:
02:33:48:       Config: C:/Documents and Settings/All Users/Application
02:33:48:               Data/FAHClient/config.xml
02:33:48:******************************** Build ********************************
02:33:48:      Version: 7.3.6
02:33:48:         Date: Feb 18 2013
02:33:48:         Time: 15:25:17
02:33:48:      SVN Rev: 3923
02:33:48:       Branch: fah/trunk/client
02:33:48:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:33:48:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:33:48:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:33:48:     Platform: win32 XP
02:33:48:         Bits: 32
02:33:48:         Mode: Release
02:33:48:******************************* System ********************************
02:33:48:          CPU: Intel(R) Pentium(R) M processor 1.80GHz
02:33:48:       CPU ID: GenuineIntel Family 6 Model 13 Stepping 6
02:33:48:         CPUs: 1
02:33:48:       Memory: 2.00GiB
02:33:48:  Free Memory: 1.49GiB
02:33:48:      Threads: WINDOWS_THREADS
02:33:48:  Has Battery: true
02:33:48:   On Battery: false
02:33:48:   UTC offset: -4
02:33:48:          PID: 2692
02:33:48:          CWD: C:/Documents and Settings/All Users/Application Data/FAHClient
02:33:48:           OS: Microsoft Windows XP Service Pack 3
02:33:48:      OS Arch: X86
02:33:48:         GPUs: 1
02:33:48:        GPU 0: UNSUPPORTED: Radeon RV250 [Mobility FireGL 9000]
02:33:48:         CUDA: Not detected
02:33:48:Win32 Service: false
02:33:48:***********************************************************************
02:33:48:<config>
02:33:48:  <!-- Folding Core -->
02:33:48:  <checkpoint v='30'/>
02:33:48:  <core-priority v='low'/>
02:33:48:
02:33:48:  <!-- Folding Slot Configuration -->
02:33:48:  <cause v='CANCER'/>
02:33:48:  <power v='full'/>
02:33:48:
02:33:48:  <!-- Network -->
02:33:48:  <proxy v=':8080'/>
02:33:48:
02:33:48:  <!-- User Information -->
02:33:48:  <passkey v='********************************'/>
02:33:48:  <user v='Longbowgun'/>
02:33:48:
02:33:48:  <!-- Folding Slots -->
02:33:48:  <slot id='0' type='CPU'/>
02:33:48:</config>
02:33:48:Trying to access database...
02:33:48:Successfully acquired database lock
02:33:48:Enabled folding slot 00: READY cpu:1
Mod Edit: Changed List Tags To Code Tags - PantherX
Re: My GPU is in the white list but...
Please note that in your log, this is present:
Unfortunately, your GPU isn't supported by F@H. The Whitelist does contain information that blacklists any unsupported GPUs to avoid any potential issues. Thus, it is more of a greylist than either a whitelist or a blacklist.
The Radeon 9000 is in the GPUs.txt file, but the file is both a white list and a blacklist. It is not supported for folding. The oldest Radeon GPU's supported are from the HD 5000 series. The last projects that could use older cards ran out some time ago. AMD-ATI dropped support for the older GPU programming language and went to OpenCL a couple years ago. F@H made an announcement in the blog at the time that current projects would be finished up, future GPU folding projects for AMD-ATI cards would use OpenCL.
Longbowgun
Thanks! No cpu usability since August... Maybe it'll make a nice clock. :)
prjindigo
Re: GPU is in the whitelist[solved] white has blacklist in i
Post by prjindigo »
(side note, while HD 4000 series cards "support" OCL, their version does not work the same as current driver version, depending on firmware some of the earliest release HD 5000 series cards act like HD 4000 series and won't fold _x16 or _x17)
