Team number change
Pearskin
Team number change
Post by Pearskin »
How do I edit my Identity Statistics to reflect a new team number? I am currently team zero (0). I have already created the team but need to update my own status.
bollix47
Re: Team number change
Post by bollix47 »
Assuming you're using v7 - FAHControl (aka Advanced Control) > Configure > Identity - change Team number - click on Save (if you have more than one client then repeat the process for each one)
If you're referring to your existing points they remain with the team for which they were earned but the official stats for your donor id will combine each team's points and display your total points.
