Guide for fan speed control for Nvidia cards in Linux
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
Note: this is for enabling fan control settings in Linux for more than one Nvidia GPU. If you only have one card, then look at viewtopic.php?p=246099#p246099
MSI Afterburner a pretty useful program for Windows, and works well even if you've got more than one graphics card. Since it was one of the main reasons I was still running Windows on my desktop, so I decided to see what was out there for Linux. Turns out that there are multiple guides and tutorials out there, and it's entirely possible to set it up for Linux, at least for Nvidia. I have a GTX 560TI and a GTX 480, so I set mine up around that in Mint 15 (raring package base). If this guide is useful to you, feel free to adapt it to your own setup as needed. Others on FF also have experience doing this sort of thing, so post below if you need.
1) In a fully updated environment, first install the Nvidia drivers. I chose the 310 drivers from the official repos as they seem to work pretty well. The drivers should also come with nvidia-settings, which is GUI for changing these settings. You should be able to modify the /home/.nvidia-settings.rc file manually if your build is headless or if you prefer CLI.
2) Restart.
3) Open nvidia-settings and then save the current configuration to the xorg.conf file. Make a backup of this file just in case things go downhill.
4) Coolbits needs to be enabled for the Nvidia drivers to display the advanced settings. This is really easy to do if you've only got one GPU, (follow this guide by bollix47) but the problem for multiple GPUs is that coolbits requires that an X server be running on each GPU. If you only have a single monitor, you have to trick X/Nvidia into thinking that you've got a second one and you need another X server instance. Fortunately, this is not hard to do. First you need to know how to connect to the other GPU(s). Run the command "lspci | grep VGA" and you should see all the GPUs that are connected to your motherboard. There are three numbers at the beginning of each entry, you'll need those later.
5) Open xorg.conf in your text editor of choice. The filepath is /etc/X11/xorg.conf. Under the ServerLayout section at the top, you'll need to make an entry for every card you have. You should see "Screen 0 "Screen0" 0 0" already listed, so just make another entry. In my case, I put the coordinates at 1600 0 because my actual monitor is 1600 pixels wide. There are likely a number of values that work for this, but that was the one that I went with.
6) Create a Monitor section for the other GPUs. You should already see one listed, so under it you can write
Section "Monitor"
    Identifier     "Monitor1"
    VendorName     "Unknown"
    ModelName      "CRT-0"
    HorizSync       0.0 - 0.0
    VertRefresh     0.0
    Option         "DPMS"
EndSection
for a third card, your third entry should say "Monitor2", etc. Basically you're just defining these Monitor variables that you referenced in the previous step.
7) Still in xorg.conf, create a Device section for all the other GPUs that you have. You should already have one listed, so just copy-paste and use it as a template. Change the BoardName entry accordingly. Use the three numbers you obtained in step 4 here, and apply them to the BusID. Make sure the formatting is good.
8) Ensure that every Device section has an Option with the values "Coolbits" "5". This enables the extra controls in nvidia-settings.
9) Create a second Screen section, using the existing one as a template. Here's my entry, it should work for you:
Section "Screen"
    Identifier     "Screen1"
    Device         "Device1"
    Monitor        "Monitor1"
    DefaultDepth    24
    Option         "ConnectedMonitor" "CRT"
    Option         "Coolbits" "5"
    Option         "Stereo" "0"
    Option         "nvidiaXineramaInfoOrder" "CRT-0"
    Option         "metamodes" "nvidia-auto-select +0+0"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Notice that the Screen section references the Device and Monitor variables, so you'll need to ensure that these all match accordingly.
10) Ensure that every Screen section has a "Coolbits" "5" entry. In the end, your xorg.conf should look very similar to mine: http://pastebin.com/EmCNt5GX
11) Restart.
If all goes well, your desktop should boot properly and under nvidia-settings you should see a fake CRT-0 display under "X Server Display Configuration", along with more than one X Screen listed on the left, and the advanced features such as fan settings under the "Thermal Settings" subsection for each GPU. On my machine, the Cinnamon desktop under Mint 15 didn't like this hack and reverted to Fallback Mode on startup. If anyone encounters this and has figured out how to fix it, please let me know. KDE seems to work fine though, it's easy to switch desktops.
Enjoy!
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
Re: Guide for Nvidia multi-card fan control in Linux
Post by jimerickson »
thank you for posting this Jesse_V!! excellent guide.
bollix47
Post by bollix47 »
Thanks Jesse ... bookmarked for future reference. :wink:
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
Thanks guys. Thanks jimerickson for the help in setting this up in the first place, and to bollix47 for the tips, links, and guide for single-card boxes. :D
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Re: Guide for fan speed control for Nvidia cards in Linux
Post by Jesse_V »
I just confirmed that this works on a fresh install of Mint 15 KDE edition. Last time I just installed KDE as a replacement to Cinnamon, so it's good to know that KDE can handle this hack out of the box. Copy-pasted xorg.conf from the old install, restarted, and was good to go.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
I recently swapped out my 560TI for a 480. I changed the xorg.conf to reflect the name change, but other than that I've left it alone. Yet I'm no longer seeing the thermal settings for the first 480, only for the second one. Is Nvidia getting confused? Should I reinstall the driver?
Edit: reinstalled the driver. Thermal settings are still not showing up.
Might be related to why the new core 17 temp feature only works with one GPU?
The reason is that the Linux version hasn't been updated, it is still on version 0.0.46 (IIRC):
00:59 < bollix47> deleting the core in linux does not get the new core ... just downloads older version again
00:59 < bollix47> location: cores/www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/
01:11 <@proteneer> yes
01:11 <@proteneer> linux hasnt been updated yet
01:11 <@proteneer> (mainly because i accidentally my linux build system)
01:11 <@proteneer> and things like temperature control etc.
01:11 <@proteneer> doesn't do anything new in linux
01:12 < bollix47> k
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
Thanks, but that's not what I'm referring to. I'm not seeing the thermal sensors and fan controls in nvidia-settings. I would have expected them to be there because of the Coolbits setting, which I did not change from when it was working with the 560TI and the 480. Now with two 480s, I simply updated the GPU label in xorg.conf, but nothing else has changed.
For those that have a multi-GPU setup using the same card, what did you do to get Coolbits activated for both?
jimerickson
Jesse_V: did you try changing the board name in xorg.conf or did the pci address change?
Edit: have to go to work right now will be back this evening.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
Jim, nope, I double checked the PCI address. Still same as before.
ChristianVirtual
Post by ChristianVirtual »
here my little success story
on an Asus board with iGPU connected to HDMI as primary/only screen and an GTX 660 Ti headless for folding (driver 319.x)
The following xorg.conf allows me to set the fan speed and fold while using the iGPU to drive the UI. Until now I had only luck with attached screens. What I added is a default screen resolution and skipping the monitor detection based on some hints from other sources.
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 319.49  (buildmeister@swio-display-x64-rhel04-03)  Tu
e Aug 13 20:42:18 PDT 2013
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      1  "Screen1" RightOf "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
EndSection
Section "Monitor"
    VendorName     "Headless"
    ModelName      "CRT1"
    Option         "Enable" "true"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "intel"
    VendorName     "Intel Corporation"
    BoardName      "iGPU"
    BusID          "PCI:0:2:0"
EndSection
Section "Device"
    Identifier     "Device1"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GTX 660 Ti"
    BusID          "PCI:1:0:0"
    Option         "ConnectedMonitor" "CRT-0"
    Option         "UseEDID" "false"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
        Depth       24
        Modes      "1920x1080"
    EndSubSection
EndSection
Section "Screen"
    Device         "Device1"
    Monitor        "Monitor1"
    DefaultDepth    24
        Depth       24
        Modes      "800x600"
    EndSubSection
EndSection
and a little script for the fan (as referred earlier)
nvidia-settings -a [gpu:0]/GPUFanControlState=1
nvidia-settings -a [fan:0]/GPUCurrentFanSpeed=60
The only little downside not yet solved but also not relevant: on my HDMI screen I don't see any Unity UI elements; only a naked desktop; I need to start a terminal with Ctrl-Alt+t which is perfectly fine for a dedicated folding rig; I can even fully start with ssh this way. Happy camper.
Nicolas_orleans
Post by Nicolas_orleans »
Thanks Jesse_V, it works and now both GPUs are correctly cooled !
Full file
# nvidia-xconfig:  version 304.117  (buildmeister@swio-display-x86-rhel47-01)  Tue Nov 26 22:29:40 PST 2013
    Screen      1  "Screen1" 1920 0
EndSection
Section "Files"
EndSection
    Identifier     "Mouse0"
    Driver         "mouse"
EndSection
    Driver         "kbd"
EndSection
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Monitor"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BusID          "PCI:1:0:0"
EndSection
Section "Device"
    Driver         "nvidia"
    BusID          "PCI:2:0:0"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Coolbits" "4"
        Depth       24
    EndSubSection
EndSection
Section "Screen"
    Device         "Device1"
    Monitor        "Monitor1"
    DefaultDepth    24
        Depth       24
    EndSubSection
EndSection
AORUS Elite X AX B650E- Ryzen 9 9950X - Inno3D RTX 5080 - Ubuntu 25.04 - 6.14 kernel - 580.95
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super - Ubuntu 25.04 - 6.14 kernel - 580.95
Bead_Hand
Post by Bead_Hand »
The info in this thread is a tad dated. It's not that it's incorrect, it's just that there is an easier way to configure X to recognize all of your nVidia cards and allow manual fan control. You simply use the nvidia-xconfig command with appropriate parameters, arguments and/or switches on the command line in a terminal. nvidia-xconfig is installed when you install the nVidia driver. I don't know exactly when they began shipping it with the driver but if you have a reasonably recent version of the driver you will definitely have nvidia-xconfig.
The tips/methods/commands below will work if you have just installed Linux and the nVidia drivers for the first time. It should also work if you had a working setup but broke it by changing cards or rearranging cards in your PCIe slots. Unlike that other OS, it's not necessary to do the herky-jerky the way you have to sometimes just to uninstall the driver, config files and registry (gag) entries just to reinstall and get going again.
I use Ubuntu. The stuff below works for me on Ubuntu 12.04 and 14.04. I don't know about 13.04 but probably.
If you have the nVidia driver installed and a card(s) in the slot(s) then open a terminal. On Ubuntu with Unity the easy way to open a terminal is to bring the desktop into focus (click on an open area of the desktop) and type CTRL-ALT-T.
In the terminal, to enable (recognize) all cards present on the mainboard type
nvidia-xconfig --enable-all-gpus
To allow manual fan control on all enabled cards type
nvidia-xconfig --cool-bits=4
Please note that in both of the above commands there is a space character before the "--" sequence. Note also that in the second command there is no space before or after the "=".
The nvidia-xconfig command has a plethora of options. Do man nvidia-xconfig in a terminal to read the user manual.
I have a nifty Python script that monitors the temperature of each of my 3 nVidia cards and increases/decreases each cards fan speed independently as required to keep the temperature at a user selectable target temperature. In practice, due to hysteresis and dynamic load on the GPU, the actual temps hover about 2 degrees Celsius above or below the target. I have my system configured to autostart the script at boot time. Anybody want a copy? Remember it's a Python script therefore you need to install Python to use it. Your distro might have installed Python automatically for you.
Hawkeye
Post by Hawkeye »
Sorry to thread necro, but could I get a copy of your script? I'm having a hard time getting my 2 960s to set at 60% fan. GPU0 does but GPU1 wont.
