This is after I restarted FAHControl to try to get it to try to upload again.
*********************** Log Started 2013-10-03T14:45:15Z ***********************
14:45:15:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:114 clone:0 gen:188 core:0x17 unit:0x000000dd028c126651a63fcb4af7124c
14:45:15:WU03:FS02:Uploading 72.13MiB to 171.64.65.69
14:45:15:WU03:FS02:Connecting to 171.64.65.69:8080
14:45:15:WARNING:WU03:FS02:Exception: Failed to send results to work server: Transfer failed
14:45:15:WU03:FS02:Trying to send results to collection server
14:45:15:WU03:FS02:Uploading 72.13MiB to 171.65.103.160
14:45:15:WU03:FS02:Connecting to 171.65.103.160:8080
14:45:16:ERROR:WU03:FS02:Exception: Transfer failed
14:45:16:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:114 clone:0 gen:188 core:0x17 unit:0x000000dd028c126651a63fcb4af7124c
14:45:16:WU03:FS02:Uploading 72.13MiB to 171.64.65.69
14:45:16:WU03:FS02:Connecting to 171.64.65.69:8080
14:45:16:WARNING:WU03:FS02:Exception: Failed to send results to work server: Transfer failed
14:45:16:WU03:FS02:Trying to send results to collection server
14:45:16:WU03:FS02:Uploading 72.13MiB to 171.65.103.160
14:45:16:WU03:FS02:Connecting to 171.65.103.160:8080
14:46:16:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:114 clone:0 gen:188 core:0x17 unit:0x000000dd028c126651a63fcb4af7124c
14:46:16:WU03:FS02:Uploading 72.13MiB to 171.64.65.69
14:46:16:WU03:FS02:Connecting to 171.64.65.69:8080
14:46:16:WARNING:WU03:FS02:Exception: Failed to send results to work server: Transfer failed
14:46:16:WU03:FS02:Trying to send results to collection server
14:46:16:WU03:FS02:Uploading 72.13MiB to 171.65.103.160
14:46:16:WU03:FS02:Connecting to 171.65.103.160:8080
14:46:16:ERROR:WU03:FS02:Exception: Transfer failed
14:47:53:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:114 clone:0 gen:188 core:0x17 unit:0x000000dd028c126651a63fcb4af7124c
14:47:53:WU03:FS02:Uploading 72.13MiB to 171.64.65.69
14:47:53:WU03:FS02:Connecting to 171.64.65.69:8080
14:47:53:WARNING:WU03:FS02:Exception: Failed to send results to work server: Transfer failed
14:47:53:WU03:FS02:Trying to send results to collection server
14:47:53:WU03:FS02:Uploading 72.13MiB to 171.65.103.160
14:47:53:WU03:FS02:Connecting to 171.65.103.160:8080
14:47:54:ERROR:WU03:FS02:Exception: Transfer failed
14:50:30:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:114 clone:0 gen:188 core:0x17 unit:0x000000dd028c126651a63fcb4af7124c
14:50:30:WU03:FS02:Uploading 72.13MiB to 171.64.65.69
14:50:30:WU03:FS02:Connecting to 171.64.65.69:8080
14:50:31:WARNING:WU03:FS02:Exception: Failed to send results to work server: Transfer failed
14:50:31:WU03:FS02:Trying to send results to collection server
14:50:31:WU03:FS02:Uploading 72.13MiB to 171.65.103.160
14:50:31:WU03:FS02:Connecting to 171.65.103.160:8080
14:50:31:ERROR:WU03:FS02:Exception: Transfer failedCode: Select all
14:45:15:************************* Folding@home Client *************************
14:45:15: Website: http://folding.stanford.edu/
14:45:15: Copyright: (c) 2009-2012 Stanford University
14:45:15: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:45:15: Args: --lifeline 12048 --command-port=36330
14:45:15: Config: C:/ProgramData/FAHClient/config.xml
14:45:15:******************************** Build ********************************
14:45:15: Version: 7.2.9
14:45:15: Date: Oct 3 2012
14:45:15: Time: 18:05:48
14:45:15: SVN Rev: 3578
14:45:15: Branch: fah/trunk/client
14:45:15: Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:45:15: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:45:15: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:45:15: Platform: win32 XP
14:45:15: Bits: 32
14:45:15: Mode: Release
14:45:15:******************************* System ********************************
14:45:15: CPU: Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz
14:45:15: CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
14:45:15: CPUs: 12
14:45:15: Memory: 11.99GiB
14:45:15: Free Memory: 9.23GiB
14:45:15: Threads: WINDOWS_THREADS
14:45:15: On Battery: false
14:45:15: UTC offset: -4
14:45:15: PID: 5720
14:45:15: CWD: C:/ProgramData/FAHClient
14:45:15: OS: Windows 7 Ultimate
14:45:15: OS Arch: AMD64
14:45:15: GPUs: 4
14:45:15: GPU 0: NVIDIA:2 GF110 [Geforce GTX 590]
14:45:15: GPU 1: NVIDIA:2 GF110 [Geforce GTX 590]
14:45:15: GPU 2: NVIDIA:2 GF110 [Geforce GTX 590]
14:45:15: GPU 3: NVIDIA:2 GF110 [Geforce GTX 590]
14:45:15: CUDA: 2.0
14:45:15: CUDA Driver: 5050
14:45:15:Win32 Service: false
14:45:15:***********************************************************************
14:45:15:<config>
14:45:15: <service-description v='Folding@home Client'/>
14:45:15: <service-restart v='true'/>
14:45:15: <service-restart-delay v='5000'/>
14:45:15:
14:45:15: <!-- Client Control -->
14:45:15: <cycle-rate v='4'/>
14:45:15: <cycles v='-1'/>
14:45:15: <data-directory v='.'/>
14:45:15: <disable-project-lookup v='false'/>
14:45:15: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
14:45:15: <exit-when-done v='false'/>
14:45:15: <threads v='4'/>
14:45:15:
14:45:15: <!-- Configuration -->
14:45:15: <config-rotate v='true'/>
14:45:15: <config-rotate-dir v='configs'/>
14:45:15: <config-rotate-max v='16'/>
14:45:15:
14:45:15: <!-- Debugging -->
14:45:15: <assignment-servers>
14:45:15: assign3.stanford.edu:8080 assign4.stanford.edu:80
14:45:15: </assignment-servers>
14:45:15: <capture-directory v='capture'/>
14:45:15: <capture-sockets v='false'/>
14:45:15: <debug-sockets v='false'/>
14:45:15: <exception-locations v='true'/>
14:45:15: <gpu-assignment-servers>
14:45:15: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
14:45:15: </gpu-assignment-servers>
14:45:15: <stack-traces v='false'/>
14:45:15:
14:45:15: <!-- Error Handling -->
14:45:15: <max-slot-errors v='5'/>
14:45:15: <max-unit-errors v='5'/>
14:45:15:
14:45:15: <!-- FahCore Control -->
14:45:15: <checkpoint v='10'/>
14:45:15: <core-dir v='cores'/>
14:45:15: <core-priority v='idle'/>
14:45:15: <cpu-affinity v='false'/>
14:45:15: <cpu-usage v='100'/>
14:45:15: <no-assembly v='false'/>
14:45:15:
14:45:15: <!-- Folding Slot Configuration -->
14:45:15: <cause-pref v='ANY'/>
14:45:15: <client-subtype v='STDCLI'/>
14:45:15: <client-type v='normal'/>
14:45:15: <cpu-species v='X86_PENTIUM_II'/>
14:45:15: <cpu-type v='AMD64'/>
14:45:15: <cpus v='-1'/>
14:45:15: <cuda-index v='0'/>
14:45:15: <gpu v='true'/>
14:45:15: <gpu-usage v='100'/>
14:45:15: <max-packet-size v='normal'/>
14:45:15: <opencl-index v='0'/>
14:45:15: <os-species v='UNKNOWN'/>
14:45:15: <os-type v='WIN32'/>
14:45:15: <project-key v='0'/>
14:45:15: <smp v='true'/>
14:45:15:
14:45:15: <!-- Logging -->
14:45:15: <log v='log.txt'/>
14:45:15: <log-color v='false'/>
14:45:15: <log-crlf v='true'/>
14:45:15: <log-date v='false'/>
14:45:15: <log-date-periodically v='21600'/>
14:45:15: <log-debug v='true'/>
14:45:15: <log-domain v='false'/>
14:45:15: <log-header v='true'/>
14:45:15: <log-level v='true'/>
14:45:15: <log-no-info-header v='true'/>
14:45:15: <log-redirect v='false'/>
14:45:15: <log-rotate v='true'/>
14:45:15: <log-rotate-dir v='logs'/>
14:45:15: <log-rotate-max v='16'/>
14:45:15: <log-short-level v='false'/>
14:45:15: <log-simple-domains v='true'/>
14:45:15: <log-thread-id v='false'/>
14:45:15: <log-thread-prefix v='true'/>
14:45:15: <log-time v='true'/>
14:45:15: <log-to-screen v='true'/>
14:45:15: <log-truncate v='false'/>
14:45:15: <verbosity v='5'/>
14:45:15:
14:45:15: <!-- Network -->
14:45:15: <proxy v=':8080'/>
14:45:15: <proxy-enable v='false'/>
14:45:15: <proxy-pass v=''/>
14:45:15: <proxy-user v=''/>
14:45:15:
14:45:15: <!-- Process Control -->
14:45:15: <child v='false'/>
14:45:15: <daemon v='false'/>
14:45:15: <pid v='false'/>
14:45:15: <pid-file v='Folding@home Client.pid'/>
14:45:15: <respawn v='false'/>
14:45:15: <service v='false'/>
14:45:15:
14:45:15: <!-- Remote Command Server -->
14:45:15: <command-address v='0.0.0.0'/>
14:45:15: <command-allow v='127.0.0.1'/>
14:45:15: <command-allow-no-pass v='127.0.0.1'/>
14:45:15: <command-deny v='0.0.0.0/0'/>
14:45:15: <command-deny-no-pass v='0.0.0.0/0'/>
14:45:15: <command-port v='36330'/>
14:45:15:
14:45:15: <!-- Slot Control -->
14:45:15: <max-shutdown-wait v='60'/>
14:45:15: <pause-on-battery v='false'/>
14:45:15: <pause-on-start v='false'/>
14:45:15:
14:45:15: <!-- User Information -->
14:45:15: <machine-id v='0'/>
14:45:15: <passkey v='********************************'/>
14:45:15: <team v='111065'/>
14:45:15: <user v='rjbelans'/>
14:45:15:
14:45:15: <!-- Work Unit Control -->
14:45:15: <dump-after-deadline v='true'/>
14:45:15: <max-queue v='16'/>
14:45:15: <max-units v='0'/>
14:45:15: <next-unit-percentage v='99'/>
14:45:15:
14:45:15: <!-- Folding Slots -->
14:45:15: <slot id='0' type='GPU'>
14:45:15: <client-type v='advanced'/>
14:45:15: <next-unit-percentage v='100'/>
14:45:15: </slot>
14:45:15: <slot id='2' type='GPU'>
14:45:15: </slot>
14:45:15: <slot id='3' type='GPU'>
14:45:15: </slot>
14:45:15: <slot id='1' type='GPU'>
14:45:15: </slot>
14:45:15: <slot id='4' type='SMP'>
14:45:15: <cpus v='6'/>
14:45:15: </slot>
14:45:15:</config>After some searching of the old log, I found this too.
22:22:08:WU03:FS02:0x17:Completed 1525000 out of 2500000 steps (61%)
22:30:54:WU03:FS02:0x17:Completed 1550000 out of 2500000 steps (62%)
22:31:56:WU03:FS02:0x17:Bad State detected... attempting to resume from last good checkpoint
22:40:42:WU03:FS02:0x17:Completed 1525000 out of 2500000 steps (61%)
22:49:27:WU03:FS02:0x17:Completed 1550000 out of 2500000 steps (62%)
22:50:29:WU03:FS02:0x17:Bad State detected... attempting to resume from last good checkpoint
22:59:15:WU03:FS02:0x17:Completed 1525000 out of 2500000 steps (61%)
23:08:01:WU03:FS02:0x17:Completed 1550000 out of 2500000 steps (62%)
23:09:03:WU03:FS02:0x17:Bad State detected... attempting to resume from last good checkpoint
23:09:03:WU03:FS02:0x17:Max number of retries reached. Aborting.
23:09:03:WU03:FS02:0x17:ERROR:exception: Max Retries Reached
23:09:03:WU03:FS02:0x17:Saving result file logfile_01.txt
23:09:03:WU03:FS02:0x17:Saving result file badStateCheckpoint_18467
23:09:05:WU03:FS02:0x17:Saving result file badStateCheckpoint_41
23:09:07:WU03:FS02:0x17:Saving result file badStateCheckpoint_6334
23:09:09:WU03:FS02:0x17:Saving result file badStateForceGroup0_18467Core.xml
23:09:12:WU03:FS02:0x17:Saving result file badStateForceGroup0_18467Ref.xml
23:09:15:WU03:FS02:0x17:Saving result file badStateForceGroup0_41Core.xml
23:09:18:WU03:FS02:0x17:Saving result file badStateForceGroup0_41Ref.xml
23:09:21:WU03:FS02:0x17:Saving result file badStateForceGroup0_6334Core.xml
23:09:25:WU03:FS02:0x17:Saving result file badStateForceGroup0_6334Ref.xml
23:09:28:WU03:FS02:0x17:Saving result file badStateForceGroup1_18467Core.xml
23:09:30:WU03:FS02:0x17:Saving result file badStateForceGroup1_18467Ref.xml
23:09:33:WU03:FS02:0x17:Saving result file badStateForceGroup1_41Core.xml
23:09:35:WU03:FS02:0x17:Saving result file badStateForceGroup1_41Ref.xml
23:09:37:WU03:FS02:0x17:Saving result file badStateForceGroup1_6334Core.xml
23:09:40:WU03:FS02:0x17:Saving result file badStateForceGroup1_6334Ref.xml
23:09:42:WU03:FS02:0x17:Saving result file badStateForceGroup2_18467Core.xml
23:09:44:WU03:FS02:0x17:Saving result file badStateForceGroup2_18467Ref.xml
23:09:46:WU03:FS02:0x17:Saving result file badStateForceGroup2_41Core.xml
23:09:49:WU03:FS02:0x17:Saving result file badStateForceGroup2_41Ref.xml
23:09:51:WU03:FS02:0x17:Saving result file badStateForceGroup2_6334Core.xml
23:09:53:WU03:FS02:0x17:Saving result file badStateForceGroup2_6334Ref.xml
23:09:55:WU03:FS02:0x17:Saving result file log.txt
23:09:55:WU03:FS02:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
23:09:56:WARNING:WU03:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
23:09:56:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:8900 run:114 clone:0 gen:188 core:0x17 unit:0x000000dd028c126651a63fcb4af7124c
