Project: 8900 (Run 32, Clone 2, Gen 160)
planetclown
Hardware configuration: Ryzen 7 5700x
32GB (2X16GB) DDR4 3200MHz
EVGA RTX 3060 Ti
Post by planetclown »
Folding on Radeon HD 7950 on stock clocks (Sapphire 100352-3L) using client 7.3.6 with advanced flag set. This is my only active folding slot. Got the error "Error creating array interactingTiles: clCreateBuffer (-61)" after 80% completion. This is the first error out of 63 wu's currently in the log file.
Relevant log info...
*********************** Log Started 2013-09-11T15:28:34Z ***********************
15:28:34:************************* Folding@home Client *************************
15:28:34:      Website: http://folding.stanford.edu/
15:28:34:    Copyright: (c) 2009-2013 Stanford University
15:28:34:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:28:34:         Args: --open-web-control
15:28:34:       Config: C:/Users/admin/AppData/Roaming/FAHClient/config.xml
15:28:34:******************************** Build ********************************
15:28:34:      Version: 7.3.6
15:28:34:         Date: Feb 18 2013
15:28:34:         Time: 15:25:17
15:28:34:      SVN Rev: 3923
15:28:34:       Branch: fah/trunk/client
15:28:34:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
15:28:34:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
15:28:34:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
15:28:34:     Platform: win32 XP
15:28:34:         Bits: 32
15:28:34:         Mode: Release
15:28:34:******************************* System ********************************
15:28:34:          CPU: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
15:28:34:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:28:34:         CPUs: 8
15:28:34:       Memory: 7.89GiB
15:28:34:  Free Memory: 5.92GiB
15:28:34:      Threads: WINDOWS_THREADS
15:28:34:  Has Battery: false
15:28:34:   On Battery: false
15:28:34:   UTC offset: -4
15:28:34:          PID: 3744
15:28:34:          CWD: C:/Users/admin/AppData/Roaming/FAHClient
15:28:34:           OS: Windows 7 Home Premium
15:28:34:      OS Arch: AMD64
15:28:34:         GPUs: 1
15:28:34:        GPU 0: ATI:5 Tahiti PRO [Radeon HD 7950]
15:28:34:         CUDA: Not detected
15:28:34:Win32 Service: false
15:28:34:***********************************************************************
15:28:34:<config>
15:28:34:  <!-- Folding Core -->
15:28:34:  <checkpoint v='30'/>
15:28:34:
15:28:34:  <!-- Folding Slot Configuration -->
15:28:34:  <power v='full'/>
15:28:34:
15:28:34:  <!-- Logging -->
15:28:34:  <verbosity v='2'/>
15:28:34:
15:28:34:  <!-- Network -->
15:28:34:  <proxy v=':8080'/>
15:28:34:
15:28:34:  <!-- User Information -->
15:28:34:  <passkey v='********************************'/>
15:28:34:  <team v='111065'/>
15:28:34:  <user v='planetclown'/>
15:28:34:
15:28:34:  <!-- Folding Slots -->
15:28:34:  <slot id='0' type='GPU'>
15:28:34:    <client-type v='advanced'/>
15:28:34:    <pause-on-start v='true'/>
15:28:34:  </slot>
15:28:34:</config>
17:48:41:WU00:FS00:Starting
17:48:42:WU00:FS00:Core PID:8624
17:48:42:WU00:FS00:FahCore 0x17 started
17:48:43:WU00:FS00:0x17:*********************** Log Started 2013-09-26T17:48:43Z ***********************
17:48:43:WU00:FS00:0x17:Project: 8900 (Run 32, Clone 2, Gen 160)
17:48:43:WU00:FS00:0x17:Unit: 0x000000c9028c1266519a6629ad590613
17:48:43:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
17:48:43:WU00:FS00:0x17:Machine: 0
17:48:43:WU00:FS00:0x17:Reading tar file state.xml
17:48:44:WU00:FS00:0x17:Reading tar file system.xml
17:48:44:WU00:FS00:0x17:Reading tar file integrator.xml
17:48:44:WU00:FS00:0x17:Reading tar file core.xml
17:48:44:WU00:FS00:0x17:Digital signatures verified
17:51:38:WU00:FS00:0x17:Completed 0 out of 2500000 steps (0%)
17:56:42:WU00:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
18:01:27:WU00:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
00:22:21:WU00:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
00:27:25:WU00:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
00:32:11:WU00:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
00:33:46:WU00:FS00:0x17:ERROR:exception: Error creating array interactingTiles: clCreateBuffer (-61)
00:33:46:WU00:FS00:0x17:Saving result file logfile_01.txt
00:33:46:WU00:FS00:0x17:Saving result file log.txt
00:33:46:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:33:46:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:33:46:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:32 clone:2 gen:160 core:0x17 unit:0x000000c9028c1266519a6629ad590613
00:33:47:WU00:FS00:Uploading 2.96KiB to 171.64.65.69
00:33:47:WU00:FS00:Upload complete
00:33:47:WU00:FS00:Server responded WORK_ACK (400)
00:33:47:WU00:FS00:Cleaning up
bollix47
Re: Project: 8900 (Run 32, Clone 2, Gen 160)
Post by bollix47 »
Thank you for your report.
Another folder was able to complete the work unit successfully:
Hi **** (team ****),
Your WU (P8900 R32 C2 G160) was added to the stats database on 2013-09-27 03:01:24 for 24978 points of credit.
