No problems there, but much to my surprise the WU was credited in the 17:00 (UTC) update run. But only with 783 points, I was expecting 10% more than that
The missing points didn't appear in the 18:00 (UTC) update, could the WU have snuck in somehow before the extra percentage was calculated?
For the sake of 70-odd points I'm not too bothered- if they turn up later that's fine, if they don't I won't lose any sleep over them!
It is possible that when the stat servers were having their issues recently, the 10% A4 bonus was inadvertently dropped. I'll ask...
Stat server wrote:Credit: 783.065 Credit Time: 2013-09-25 10:06:21
Entered into logs at: 2013-09-25 10:04:34
WU assigned to donor at: 2013-09-25 01:56:31
Days taken to complete WU: 0.34
Error code: 0
Hi lbford (team 0),
Your WU (P6360 R6 C32 G37) was added to the stats database on 2013-09-25 10:06:21 for 783.065 points of credit.
7im wrote:You provided no way to make a judgement if that points value was accurate or not. Showing the download time and some frame times would have helped.
08:56:30:WU00:FS00:0xa4:Completed 4950000 out of 5000000 steps (99%)
08:56:31:WU01:FS00:Connecting to assign3.stanford.edu:8080
08:56:32:WU01:FS00:News: Welcome to Folding@Home
08:56:32:WU01:FS00:Assigned to work server 155.247.166.219
08:56:32:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.166.219
08:56:32:WU01:FS00:Connecting to 155.247.166.219:8080
08:56:32:WU01:FS00:Downloading 80.63KiB
08:56:32:WU01:FS00:Download complete
08:56:32:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:6360 run:6 clone:32 gen:37 core:0xa4 unit:0x000000250002894b522e9111075613e0
09:01:26:WU00:FS00:0xa4:Completed 5000000 out of 5000000 steps (100%)
09:01:26:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
09:01:36:WU00:FS00:0xa4:
09:01:36:WU00:FS00:0xa4:Finished Work Unit:
09:01:36:WU00:FS00:0xa4:- Reading up to 826584 from "00/wudata_01.trr": Read 826584
09:01:36:WU00:FS00:0xa4:trr file hash check passed.
09:01:36:WU00:FS00:0xa4:- Reading up to 62220 from "00/wudata_01.xtc": Read 62220
09:01:36:WU00:FS00:0xa4:xtc file hash check passed.
09:01:36:WU00:FS00:0xa4:edr file hash check passed.
09:01:36:WU00:FS00:0xa4:logfile size: 81936
09:01:36:WU00:FS00:0xa4:Leaving Run
09:01:40:WU00:FS00:0xa4:- Writing 1041372 bytes of core data to disk...
09:01:40:WU00:FS00:0xa4:Done: 1040860 -> 864676 (compressed to 83.0 percent)
09:01:40:WU00:FS00:0xa4: ... Done.
09:01:40:WU00:FS00:0xa4:- Shutting down core
09:01:40:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
09:01:41:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
09:01:41:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:6360 run:0 clone:9 gen:42 core:0xa4 unit:0x0000002d0002894b522e90dd96c31563
09:01:41:WU00:FS00:Uploading 844.91KiB to 155.247.166.219
09:01:41:WU00:FS00:Connecting to 155.247.166.219:8080
09:01:41:WU01:FS00:Starting
09:01:41:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 01 -suffix 01 -version 703 -lifeline 53 -checkpoint 15 -np 2
09:01:41:WU01:FS00:Started FahCore on PID 17691
09:01:41:WU01:FS00:Core PID:17694
09:01:41:WU01:FS00:FahCore 0xa4 started
09:01:41:WU01:FS00:0xa4:
09:01:41:WU01:FS00:0xa4:*------------------------------*
09:01:41:WU01:FS00:0xa4:Folding@Home Gromacs Core
09:01:41:WU01:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
09:01:41:WU01:FS00:0xa4:Preparing to commence simulation
09:01:41:WU01:FS00:0xa4:- Looking at optimizations...
09:01:41:WU01:FS00:0xa4:- Created dyn
09:01:41:WU01:FS00:0xa4:- Files status OK
09:01:41:WU01:FS00:0xa4:- Expanded 82049 -> 173488 (decompressed 211.4 percent)
09:01:41:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=82049 data_size=173488, decompressed_data_size=173488 diff=0
09:01:41:WU01:FS00:0xa4:- Digital signature verified
09:01:41:WU01:FS00:0xa4:Project: 6360 (Run 6, Clone 32, Gen 37)
09:01:41:WU01:FS00:0xa4:Assembly optimizations on if available.
09:01:41:WU01:FS00:0xa4:Entering M.D.
09:01:44:WU00:FS00:Upload complete
09:01:44:WU00:FS00:Server responded WORK_ACK (400)
09:01:44:WU00:FS00:Final credit estimate, 779.00 points
09:01:44:WU00:FS00:Cleaning up
09:01:47:WU01:FS00:0xa4:Mapping NT from 2 to 2
09:01:47:WU01:FS00:0xa4:Completed 0 out of 5000000 steps (0%)
09:06:29:WU01:FS00:0xa4:Completed 50000 out of 5000000 steps (1%)
09:11:12:WU01:FS00:0xa4:Completed 100000 out of 5000000 steps (2%)
09:15:54:WU01:FS00:0xa4:Completed 150000 out of 5000000 steps (3%)
09:20:38:WU01:FS00:0xa4:Completed 200000 out of 5000000 steps (4%)
09:25:21:WU01:FS00:0xa4:Completed 250000 out of 5000000 steps (5%)
09:30:05:WU01:FS00:0xa4:Completed 300000 out of 5000000 steps (6%)
09:34:47:WU01:FS00:0xa4:Completed 350000 out of 5000000 steps (7%)
09:39:31:WU01:FS00:0xa4:Completed 400000 out of 5000000 steps (8%)
09:44:14:WU01:FS00:0xa4:Completed 450000 out of 5000000 steps (9%)
15:45:31:WU01:FS00:0xa4:Completed 4200000 out of 5000000 steps (84%)
15:50:23:WU01:FS00:0xa4:Completed 4250000 out of 5000000 steps (85%)
15:55:17:WU01:FS00:0xa4:Completed 4300000 out of 5000000 steps (86%)
16:00:10:WU01:FS00:0xa4:Completed 4350000 out of 5000000 steps (87%)
16:05:05:WU01:FS00:0xa4:Completed 4400000 out of 5000000 steps (88%)
16:10:02:WU01:FS00:0xa4:Completed 4450000 out of 5000000 steps (89%)
16:14:59:WU01:FS00:0xa4:Completed 4500000 out of 5000000 steps (90%)
16:19:59:WU01:FS00:0xa4:Completed 4550000 out of 5000000 steps (91%)
16:24:56:WU01:FS00:0xa4:Completed 4600000 out of 5000000 steps (92%)
16:29:54:WU01:FS00:0xa4:Completed 4650000 out of 5000000 steps (93%)
16:34:53:WU01:FS00:0xa4:Completed 4700000 out of 5000000 steps (94%)
16:39:49:WU01:FS00:0xa4:Completed 4750000 out of 5000000 steps (95%)
16:44:43:WU01:FS00:0xa4:Completed 4800000 out of 5000000 steps (96%)
16:49:37:WU01:FS00:0xa4:Completed 4850000 out of 5000000 steps (97%)
16:54:35:WU01:FS00:0xa4:Completed 4900000 out of 5000000 steps (98%)
16:59:33:WU01:FS00:0xa4:Completed 4950000 out of 5000000 steps (99%)
16:59:34:WU00:FS00:Connecting to assign3.stanford.edu:8080
16:59:35:WU00:FS00:News: Welcome to Folding@Home
16:59:35:WU00:FS00:Assigned to work server 155.247.166.219
16:59:35:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 155.247.166.219
16:59:35:WU00:FS00:Connecting to 155.247.166.219:8080
16:59:35:WU00:FS00:Downloading 80.54KiB
16:59:35:WU00:FS00:Download complete
16:59:35:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:6360 run:4 clone:82 gen:10 core:0xa4 unit:0x0000000b0002894b522e910362c74ef0
17:04:30:WU01:FS00:0xa4:Completed 5000000 out of 5000000 steps (100%)
17:04:30:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
17:04:40:WU01:FS00:0xa4:
17:04:40:WU01:FS00:0xa4:Finished Work Unit:
17:04:40:WU01:FS00:0xa4:- Reading up to 826584 from "01/wudata_01.trr": Read 826584
17:04:40:WU01:FS00:0xa4:trr file hash check passed.
17:04:40:WU01:FS00:0xa4:- Reading up to 62544 from "01/wudata_01.xtc": Read 62544
17:04:40:WU01:FS00:0xa4:xtc file hash check passed.
17:04:40:WU01:FS00:0xa4:edr file hash check passed.
17:04:40:WU01:FS00:0xa4:logfile size: 81932
17:04:40:WU01:FS00:0xa4:Leaving Run
17:04:40:WU01:FS00:0xa4:- Writing 1041692 bytes of core data to disk...
17:04:40:WU01:FS00:0xa4:Done: 1041180 -> 865368 (compressed to 83.1 percent)
17:04:40:WU01:FS00:0xa4: ... Done.
17:04:40:WU01:FS00:0xa4:- Shutting down core
17:04:40:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
17:04:40:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:04:40:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:6360 run:6 clone:32 gen:37 core:0xa4 unit:0x000000250002894b522e9111075613e0
17:04:40:WU01:FS00:Uploading 845.59KiB to 155.247.166.219
17:04:40:WU01:FS00:Connecting to 155.247.166.219:8080
17:04:41:WU00:FS00:Starting
17:04:41:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 00 -suffix 01 -version 703 -lifeline 53 -checkpoint 15 -np 2
17:04:41:WU00:FS00:Started FahCore on PID 18170
17:04:41:WU00:FS00:Core PID:18173
17:04:41:WU00:FS00:FahCore 0xa4 started
17:04:41:WU00:FS00:0xa4:
17:04:41:WU00:FS00:0xa4:*------------------------------*
17:04:41:WU00:FS00:0xa4:Folding@Home Gromacs Core
17:04:41:WU00:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
17:04:41:WU00:FS00:0xa4:Preparing to commence simulation
17:04:41:WU00:FS00:0xa4:- Looking at optimizations...
17:04:41:WU00:FS00:0xa4:- Created dyn
17:04:41:WU00:FS00:0xa4:- Files status OK
17:04:41:WU00:FS00:0xa4:- Expanded 81956 -> 173488 (decompressed 211.6 percent)
17:04:41:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=81956 data_size=173488, decompressed_data_size=173488 diff=0
17:04:41:WU00:FS00:0xa4:- Digital signature verified
17:04:41:WU00:FS00:0xa4:Project: 6360 (Run 4, Clone 82, Gen 10)
17:04:41:WU00:FS00:0xa4:Assembly optimizations on if available.
17:04:41:WU00:FS00:0xa4:Entering M.D.
17:04:44:WU01:FS00:Upload complete
17:04:44:WU01:FS00:Server responded WORK_ACK (400)
17:04:44:WU01:FS00:Final credit estimate, 783.00 points
What is the basis for your estimated 10% difference?
You'll see that the previous WU had a credit estimate of 779, the actual credit was 858, ie 10% higher- I can't find it now but this was stated as one of the benefits of using a passkey and has been applied ever since I got one.
7im wrote:Maybe the 10% is now included in the estimate?
Don't think so- the WU was processed on one of my Core2Duo machines- they've been getting WUs with a base credit of 199, estimated mid-700s and earning in the mid-800s for so long it's getting boring... this one sort of stood out!
P.S. The a4 10% bonus is technically separate from the QRB calculation, and does not require a passkey.
OK, in that case I've probably mis-remembered where I read it when I signed up... which would be a good reason for not being able to find it again!
We found the problem, and have fixed it so that all future WUs will receive the 10% bonus. In fact, the vast majority of WUs were credited correctly. Without evidence that this was a major problem (more than a few WUs) we will not be re-crediting the 10% bonus.
Not sure if that's the page I saw (I don't remember it saying that "Mac OSX: v7 for OSX is still in testing. For a beta copy...", which would have been of interest as I run OS X) but it says the same thing so thanks.
