tanked a few 2621's
ChewieFL2003
tanked a few 2621's
Post by ChewieFL2003 »
How and where do I post my logfiles for this ? Just want to pass it on. Lost 3 due to a "client-core communication error". 3rd time (i think) it restarted one, message changed to "will use standard loops", it got to step (60), then same error. I rebooted, and it downloaded a Double Gromacs this time, and seems to be doing just fine with it. Not complaining, just wanting someone to look at the file, perhaps I need to change my settings. My config is as follows :
Desktop box :
Athlon FX-55 @ 2.8 (14x200)
MSI Neo 2 Platinum / 2 x 512 Corsair XMS v1.1 2-2-2-5-1T @ 400 Mhz
(oc'd by multi only, prime stable indefinitely tested to 8hrs+)
Running as service, Adv and >5MB flags ON.
Laptop :
Sager 9860 , umm.... P4 Desktop CPU, 3.2 Ghz, and 1gb of some Ram :e) a bit slower @ folding than desktop, but it chews every WU it gets and likes it, so far a 2621, a 2620, and now it is halfway through a p_1168p_1164 ribo frozen thingy.
Side question : How do I shutdown service, without turning off computer (properly) ? I tried just using Task Manager, and closing core as service, and FAH itself started it again. Then I closed FAH, and restarted manually later, got the first error. Manual shutdown again, restarted computer, FAH picked back up, and got comm error again at roughly same step (~20), on third try, it got all the way to 60, then tanked same error, after that I got the Double Gromacs B. Was it the Cores/WU's or my setup ? Should I change my flags to units I am better suited for, or does that even matter ?
-ChewieFL2003
To save space I edited out the 18 download retries with core 7b. replaced downloading entries with string "start download/end download". after I came in and saw the 18th try and waiting, and hard shutdown machine, I simply rebooted, and you'll never guess what happened then, it started crunching away on 7b ??? which was the Double Gromacs B thingy. Also included current log file below prevLog.
--- Opening Log file [May 4 17:41:59]
# Windows Console Edition #####################################################
                       Folding@Home Client Version 5.04beta
                          http://folding.stanford.edu
Launch directory: C:\FAH
Service: C:\FAH\fah504-console
Arguments: -svcstart
Launched as a service.
Entered C:\FAH to do work.
[17:41:59] - Ask before connecting: No
[17:41:59] - User name: ChewieFL2003 (Team 734)
[17:41:59] - User ID: 6FF6E82343A9356F
[17:41:59] - Machine ID: 1
[17:41:59]
[17:41:59] Could not open work queue, generating new queue...
[17:41:59] + Benchmarking ...
[17:42:03] - Preparing to get new work unit...
[17:42:03] + Attempting to get work packet
[17:42:03] - Connecting to assignment server
[17:42:08] - Successful: assigned to (171.64.65.65).
[17:42:08] + News From Folding@Home: Welcome to Folding@Home
[17:42:08] Loaded queue successfully.
[17:42:08] - Couldn't send HTTP request to server
[17:42:08]   (Got status 503)
[17:42:08] + Could not connect to Work Server
[17:42:08] - Error: Attempt #1  to get work failed, and no other work to do.
             Waiting before retry.
[17:42:17] + Attempting to get work packet
[17:42:17] - Connecting to assignment server
[17:42:17] - Successful: assigned to (171.64.65.65).
[17:42:17] + News From Folding@Home: Welcome to Folding@Home
[17:42:17] Loaded queue successfully.
[17:42:18] - Couldn't send HTTP request to server
[17:42:18]   (Got status 503)
[17:42:18] + Could not connect to Work Server
[17:42:18] - Error: Attempt #2  to get work failed, and no other work to do.
[17:42:31] + Attempting to get work packet
[17:42:31] - Connecting to assignment server
[17:42:31] - Successful: assigned to (171.64.65.65).
[17:42:31] + News From Folding@Home: Welcome to Folding@Home
[17:42:32] Loaded queue successfully.
[17:42:49] + Closed connections
[17:42:49]
[17:42:49] + Processing work unit
[17:42:49] Core required: FahCore_78.exe
[17:42:49] Core not found.
[17:42:49] - Core is not present or corrupted.
[17:42:49] - Attempting to download new core...
[17:42:49] + Downloading new core: FahCore_78.exe
[17:42:50] start download/end download
[17:42:52] Verifying core Core_78.fah...
[17:42:52] Signature is VALID
[17:42:52]
[17:42:52] Trying to unzip core FahCore_78.exe
[17:42:52] Decompressed FahCore_78.exe (2338816 bytes) successfully
[17:42:52] + Core successfully engaged
[17:42:57]
[17:42:57] + Processing work unit
[17:42:57] Core required: FahCore_78.exe
[17:42:57] Core found.
[17:42:57] Working on Unit 01 [May 4 17:42:57]
[17:42:57] + Working ...
[17:42:57]
[17:42:57] *------------------------------*
[17:42:57] Folding@Home Gromacs Core
[17:42:57] Version 1.90 (March 8, 2006)
[17:42:57]
[17:42:57] Preparing to commence simulation
[17:42:57] - Looking at optimizations...
[17:42:57] - Created dyn
[17:42:57] - Files status OK
[17:43:01] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[17:43:01] - Starting from initial work packet
[17:43:01]
[17:43:01] Project: 2621 (Run 4, Clone 87, Gen 16)
[17:43:01]
[17:43:01] Assembly optimizations on if available.
[17:43:01] Entering M.D.
[17:43:08] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[17:43:08]
[17:43:08] Writing local files
[17:43:12] Extra SSE boost OK.
[17:43:12] Writing local files
[17:43:12] Completed 0 out of 125000 steps  (0)
[17:53:27] Writing local files
[17:53:27] Completed 1250 out of 125000 steps  (1)
[18:04:48] Writing local files
[18:04:48] Completed 2500 out of 125000 steps  (2)
[18:15:00] Writing local files
[18:15:00] Completed 3750 out of 125000 steps  (3)
[18:25:42] Writing local files
[18:25:42] Completed 5000 out of 125000 steps  (4)
[18:36:06] Writing local files
[18:36:06] Completed 6250 out of 125000 steps  (5)
[18:45:49] Writing local files
[18:45:49] Completed 7500 out of 125000 steps  (6)
[18:55:20] Writing local files
[18:55:20] Completed 8750 out of 125000 steps  (7)
[19:04:51] Writing local files
[19:04:51] Completed 10000 out of 125000 steps  (8)
[19:14:21] Writing local files
[19:14:22] Completed 11250 out of 125000 steps  (9)
[19:23:52] Writing local files
[19:23:52] Completed 12500 out of 125000 steps  (10)
[19:33:22] Writing local files
[19:33:23] Completed 13750 out of 125000 steps  (11)
[19:42:53] Writing local files
[19:42:53] Completed 15000 out of 125000 steps  (12)
[19:52:23] Writing local files
[19:52:24] Completed 16250 out of 125000 steps  (13)
[20:01:54] Writing local files
[20:01:54] Completed 17500 out of 125000 steps  (14)
[20:11:24] Writing local files
[20:11:24] Completed 18750 out of 125000 steps  (15)
[20:22:16] Writing local files
[20:22:17] Completed 20000 out of 125000 steps  (16)
[20:33:57] Writing local files
[20:33:57] Completed 21250 out of 125000 steps  (17)
[20:46:13] Writing local files
[20:46:13] Completed 22500 out of 125000 steps  (18)
[20:56:41] Writing local files
[20:56:41] Completed 23750 out of 125000 steps  (19)
[21:06:12] Writing local files
[21:06:12] Completed 25000 out of 125000 steps  (20)
[21:15:43] Writing local files
[21:15:43] Completed 26250 out of 125000 steps  (21)
[21:25:14] Writing local files
[21:25:14] Completed 27500 out of 125000 steps  (22)
[21:34:51] Writing local files
[21:34:51] Completed 28750 out of 125000 steps  (23)
[21:44:26] Writing local files
[21:44:26] Completed 30000 out of 125000 steps  (24)
[21:54:04] Writing local files
[21:54:05] Completed 31250 out of 125000 steps  (25)
[22:03:35] Writing local files
[22:03:35] Completed 32500 out of 125000 steps  (26)
[22:13:06] Writing local files
[22:13:06] Completed 33750 out of 125000 steps  (27)
[22:22:37] Writing local files
[22:22:37] Completed 35000 out of 125000 steps  (28)
[22:32:07] Writing local files
[22:32:07] Completed 36250 out of 125000 steps  (29)
[22:41:38] Writing local files
[22:41:38] Completed 37500 out of 125000 steps  (30)
[22:51:08] Writing local files
[22:51:09] Completed 38750 out of 125000 steps  (31)
[23:00:39] Writing local files
[23:00:39] Completed 40000 out of 125000 steps  (32)
[23:10:10] Writing local files
[23:10:10] Completed 41250 out of 125000 steps  (33)
[23:19:40] Writing local files
[23:19:41] Completed 42500 out of 125000 steps  (34)
[23:29:11] Writing local files
[23:29:11] Completed 43750 out of 125000 steps  (35)
[23:38:42] Writing local files
[23:38:42] Completed 45000 out of 125000 steps  (36)
[23:49:11] Writing local files
[23:49:11] Completed 46250 out of 125000 steps  (37)
[23:59:43] Writing local files
[23:59:44] Completed 47500 out of 125000 steps  (38)
[00:10:05] Writing local files
[00:10:05] Completed 48750 out of 125000 steps  (39)
[00:20:10] Writing local files
[00:20:10] Completed 50000 out of 125000 steps  (40)
[00:29:44] Writing local files
[00:29:44] Completed 51250 out of 125000 steps  (41)
[00:39:18] Writing local files
[00:39:18] Completed 52500 out of 125000 steps  (42)
[00:49:22] Writing local files
[00:49:22] Completed 53750 out of 125000 steps  (43)
[00:59:25] Writing local files
[00:59:25] Completed 55000 out of 125000 steps  (44)
[01:08:58] Writing local files
[01:08:58] Completed 56250 out of 125000 steps  (45)
[01:18:31] Writing local files
[01:18:31] Completed 57500 out of 125000 steps  (46)
[01:28:04] Writing local files
[01:28:04] Completed 58750 out of 125000 steps  (47)
[01:37:37] Writing local files
[01:37:37] Completed 60000 out of 125000 steps  (48)
[01:47:10] Writing local files
[01:47:10] Completed 61250 out of 125000 steps  (49)
[01:56:43] Writing local files
[01:56:43] Completed 62500 out of 125000 steps  (50)
[02:06:16] Writing local files
[02:06:16] Completed 63750 out of 125000 steps  (51)
[02:15:49] Writing local files
[02:15:49] Completed 65000 out of 125000 steps  (52)
[02:25:22] Writing local files
[02:25:22] Completed 66250 out of 125000 steps  (53)
[02:34:55] Writing local files
[02:34:56] Completed 67500 out of 125000 steps  (54)
[02:44:29] Writing local files
[02:44:29] Completed 68750 out of 125000 steps  (55)
[02:54:02] Writing local files
[02:54:02] Completed 70000 out of 125000 steps  (56)
[03:03:35] Writing local files
[03:03:35] Completed 71250 out of 125000 steps  (57)
[03:13:08] Writing local files
[03:13:09] Completed 72500 out of 125000 steps  (58)
[03:22:42] Writing local files
[03:22:42] Completed 73750 out of 125000 steps  (59)
[03:32:17] Writing local files
[03:32:17] Completed 75000 out of 125000 steps  (60)
[03:33:29]
[03:33:29] Folding@home Core Shutdown: INTERRUPTED
[03:33:31] CoreStatus = 66 (102)
[03:33:31] + Shutdown requested by user. Exiting.
Folding@Home Client Shutdown.
--- Opening Log file [May 5 12:26:13]
[12:26:13] - Ask before connecting: No
[12:26:13] - User name: ChewieFL2003 (Team 734)
[12:26:13] - User ID: 6FF6E82343A9356F
[12:26:13] - Machine ID: 1
[12:26:13]
[12:26:14] Loaded queue successfully.
[12:26:14] + Benchmarking ...
[12:26:17]
[12:26:17] + Processing work unit
[12:26:17] Core required: FahCore_78.exe
[12:26:17] Core found.
[12:26:18] Working on Unit 01 [May 5 12:26:18]
[12:26:18] + Working ...
[12:26:19]
[12:26:19] *------------------------------*
[12:26:19] Folding@Home Gromacs Core
[12:26:19] Version 1.90 (March 8, 2006)
[12:26:19]
[12:26:19] Preparing to commence simulation
[12:26:19] - Looking at optimizations...
[12:26:19] - Files status OK
[12:26:23] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[12:26:24]
[12:26:24] Project: 2621 (Run 4, Clone 87, Gen 16)
[12:26:24]
[12:26:24] Assembly optimizations on if available.
[12:26:24] Entering M.D.
[12:26:45] (Starting from checkpoint)
[12:26:45] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[12:26:45]
[12:26:45] Writing local files
[12:26:45] Completed 75000 out of 125000 steps  (60)
[12:26:49] Extra SSE boost OK.
[12:37:40] Writing local files
[12:37:40] Completed 76250 out of 125000 steps  (61)
[12:47:45] Writing local files
[12:47:45] Completed 77500 out of 125000 steps  (62)
[12:57:19] Writing local files
[12:57:19] Completed 78750 out of 125000 steps  (63)
[13:06:57] Writing local files
[13:06:57] Completed 80000 out of 125000 steps  (64)
[13:17:57] Writing local files
[13:17:57] Completed 81250 out of 125000 steps  (65)
[13:22:48] CoreStatus = 1 (1)
[13:22:48] Client-core communications error: ERROR 0x1
[13:22:48] Deleting current work unit & continuing...
[13:23:08] - Preparing to get new work unit...
[13:23:08] + Attempting to get work packet
[13:23:08] - Connecting to assignment server
[13:23:09] - Successful: assigned to (171.64.65.65).
[13:23:09] + News From Folding@Home: Welcome to Folding@Home
[13:23:09] Loaded queue successfully.
[13:23:09] - Couldn't send HTTP request to server
[13:23:09]   (Got status 503)
[13:23:09] + Could not connect to Work Server
[13:23:09] - Error: Attempt #1  to get work failed, and no other work to do.
[13:23:17] + Attempting to get work packet
[13:23:17] - Connecting to assignment server
[13:23:18] - Successful: assigned to (171.64.65.65).
[13:23:18] + News From Folding@Home: Welcome to Folding@Home
[13:23:18] Loaded queue successfully.
[13:23:31] + Closed connections
[13:23:36]
[13:23:36] + Processing work unit
[13:23:36] Core required: FahCore_78.exe
[13:23:36] Core found.
[13:23:36] Working on Unit 02 [May 5 13:23:36]
[13:23:36] + Working ...
[13:23:36]
[13:23:36] *------------------------------*
[13:23:36] Folding@Home Gromacs Core
[13:23:36] Version 1.90 (March 8, 2006)
[13:23:36]
[13:23:36] Preparing to commence simulation
[13:23:36] - Looking at optimizations...
[13:23:36] - Created dyn
[13:23:36] - Files status OK
[13:23:40] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[13:23:41] - Starting from initial work packet
[13:23:41]
[13:23:41] Project: 2621 (Run 4, Clone 87, Gen 16)
[13:23:41]
[13:23:41] Assembly optimizations on if available.
[13:23:41] Entering M.D.
[13:23:48] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[13:23:48]
[13:23:48] Writing local files
[13:23:52] Extra SSE boost OK.
[13:23:52] Writing local files
[13:23:52] Completed 0 out of 125000 steps  (0)
[13:24:58] CoreStatus = 1 (1)
[13:24:58] Client-core communications error: ERROR 0x1
[13:24:58] Deleting current work unit & continuing...
--- Opening Log file [May 5 13:30:16]
Executable: C:\FAH\FAH504-Console.exe
[13:30:16] - Ask before connecting: No
[13:30:16] - User name: ChewieFL2003 (Team 734)
[13:30:16] - User ID: 6FF6E82343A9356F
[13:30:16] - Machine ID: 1
[13:30:16]
[13:30:16] Loaded queue successfully.
[13:30:16] + Benchmarking ...
[13:30:20]
[13:30:20] + Processing work unit
[13:30:20] Core required: FahCore_78.exe
[13:30:20] Core found.
[13:30:20] Working on Unit 02 [May 5 13:30:20]
[13:30:20] + Working ...
[13:30:20]
[13:30:20] *------------------------------*
[13:30:20] Folding@Home Gromacs Core
[13:30:20] Version 1.90 (March 8, 2006)
[13:30:20]
[13:30:20] Preparing to commence simulation
[13:30:20] - Ensuring status. Please wait.
[13:30:37] - Looking at optimizations...
[13:30:37] - Working with standard loops on this execution.
[13:30:37] - Previous termination of core was improper.
[13:30:37] - Files status OK
[13:30:41] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[13:30:41]
[13:30:41] Project: 2621 (Run 4, Clone 87, Gen 16)
[13:30:41]
[13:30:42] Entering M.D.
[13:31:03] (Starting from checkpoint)
[13:31:03] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[13:31:03]
[13:31:03] Writing local files
[13:31:07] Writing local files
[13:31:07] Completed 0 out of 125000 steps  (0)
[13:45:23] Writing local files
[13:45:23] Completed 1250 out of 125000 steps  (1)
[13:59:39] Writing local files
[13:59:39] Completed 2500 out of 125000 steps  (2)
[14:14:12] Writing local files
[14:14:13] Completed 3750 out of 125000 steps  (3)
[14:29:02] Writing local files
[14:29:03] Completed 5000 out of 125000 steps  (4)
--- Opening Log file [May 5 14:34:52]
[14:34:52] - Ask before connecting: No
[14:34:52] - User name: ChewieFL2003 (Team 734)
[14:34:52] - User ID: 6FF6E82343A9356F
[14:34:52] - Machine ID: 1
[14:34:52]
[14:34:52] Loaded queue successfully.
[14:34:52] + Benchmarking ...
[14:34:56]
[14:34:56] + Processing work unit
[14:34:56] Core required: FahCore_78.exe
[14:34:56] Core found.
[14:34:56] Working on Unit 02 [May 5 14:34:56]
[14:34:56] + Working ...
[14:34:57]
[14:34:57] *------------------------------*
[14:34:57] Folding@Home Gromacs Core
[14:34:57] Version 1.90 (March 8, 2006)
[14:34:57]
[14:34:57] Preparing to commence simulation
[14:34:57] - Looking at optimizations...
[14:34:57] - Working with standard loops on this execution.
[14:34:58] - Files status OK
[14:35:17] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[14:35:18]
[14:35:18] Project: 2621 (Run 4, Clone 87, Gen 16)
[14:35:18]
[14:35:19] Entering M.D.
[14:35:42]  from checkpoint)
[14:35:42] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[14:35:42]
[14:35:42] Writing lWriting locCompletedCompleted 5000 out of 125000 steps  (4)
[14:35:50]  boost OK.
[14:35:51] Size of work/wudata_02.bed not what saved.
[14:35:51]
[14:35:51] Folding@home Core Shutdown: FILE_IO_ERROR
[14:35:55] CoreStatus = 75 (117)
[14:35:55] Error opening or reading from a file.
[14:35:55] Deleting current work unit & continuing...
[14:36:03] - Preparing to get new work unit...
[14:36:03] + Attempting to get work packet
[14:36:03] - Connecting to assignment server
[14:36:03] - Successful: assigned to (171.64.65.65).
[14:36:03] + News From Folding@Home: Welcome to Folding@Home
[14:36:04] Loaded queue successfully.
[14:36:14] + Closed connections
[14:36:19]
[14:36:19] + Processing work unit
[14:36:19] Core required: FahCore_78.exe
[14:36:19] Core found.
[14:36:19] Working on Unit 03 [May 5 14:36:19]
[14:36:19] + Working ...
[14:36:20]
[14:36:20] *------------------------------*
[14:36:20] Folding@Home Gromacs Core
[14:36:20] Version 1.90 (March 8, 2006)
[14:36:20]
[14:36:20] Preparing to commence simulation
[14:36:20] - Looking at optimizations...
[14:36:20] - Created dyn
[14:36:20] - Files status OK
[14:36:28] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[14:36:29] - Starting from initial work packet
[14:36:31]
[14:36:31] Project: 2621 (Run 4, Clone 87, Gen 16)
[14:36:31]
[14:36:42] Assembly optimizations on if available.
[14:36:42] Entering M.D.
[14:36:51] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[14:36:51]
[14:36:51] Writing local files
[14:36:59] Extra SSE boost OK.
[14:37:00] Writing local files
[14:37:01] Completed 0 out of 125000 steps  (0)
--- Opening Log file [May 5 14:38:13]
Executable: fah504-console
Arguments: -configonly
[14:38:13] - Ask before connecting: No
[14:38:13] - User name: ChewieFL2003 (Team 734)
[14:38:13] - User ID: 6FF6E82343A9356F
[14:38:13] - Machine ID: 1
[14:38:13]
[14:38:13] Configuring Folding@Home...
[14:38:38] - Ask before connecting: No
[14:38:38] - User name: ChewieFL2003 (Team 734)
[14:38:38] - User ID: 6FF6E82343A9356F
[14:38:38] - Machine ID: 1
[14:38:38]
[14:38:38] -configonly flag given, so exiting.
--- Opening Log file [May 5 14:41:05]
[14:41:05] - Ask before connecting: No
[14:41:05] - User name: ChewieFL2003 (Team 734)
[14:41:05] - User ID: 6FF6E82343A9356F
[14:41:05] - Machine ID: 1
[14:41:05]
[14:41:05] Loaded queue successfully.
[14:41:05] + Benchmarking ...
[14:41:09] - Preparing to get new work unit...
[14:41:09] + Attempting to get work packet
[14:41:09] - Connecting to assignment server
[14:41:14] - Successful: assigned to (171.64.65.65).
[14:41:14] + News From Folding@Home: Welcome to Folding@Home
[14:41:14] Loaded queue successfully.
[14:41:23] + Closed connections
[14:41:23]
[14:41:23] + Processing work unit
[14:41:23] Core required: FahCore_78.exe
[14:41:23] Core found.
[14:41:23] Working on Unit 03 [May 5 14:41:23]
[14:41:23] + Working ...
[14:41:23]
[14:41:23] *------------------------------*
[14:41:23] Folding@Home Gromacs Core
[14:41:23] Version 1.90 (March 8, 2006)
[14:41:23]
[14:41:23] Preparing to commence simulation
[14:41:23] - Ensuring status. Please wait.
[14:41:40] - Looking at optimizations...
[14:41:40] - Working with standard loops on this execution.
[14:41:40] - Previous termination of core was improper.
[14:41:40] - Files status OK
[14:41:44] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[14:41:45]
[14:41:45] Project: 2621 (Run 4, Clone 87, Gen 16)
[14:41:45]
[14:41:45] Entering M.D.
[14:42:06] (Starting from checkpoint)
[14:42:06] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[14:42:06]
[14:42:06] Writing local files
[14:42:10] Writing local files
[14:42:10] Completed 0 out of 125000 steps  (0)
[14:57:22] Writing local files
[14:57:22] Completed 1250 out of 125000 steps  (1)
[15:13:06] Writing local files
[15:13:06] Completed 2500 out of 125000 steps  (2)
[15:27:23] Writing local files
[15:27:23] Completed 3750 out of 125000 steps  (3)
[15:41:36] Writing local files
[15:41:36] Completed 5000 out of 125000 steps  (4)
[15:55:49] Writing local files
[15:55:49] Completed 6250 out of 125000 steps  (5)
[16:10:03] Writing local files
[16:10:03] Completed 7500 out of 125000 steps  (6)
[16:24:16] Writing local files
[16:24:16] Completed 8750 out of 125000 steps  (7)
[16:38:28] Writing local files
[16:38:29] Completed 10000 out of 125000 steps  (8)
[16:52:41] Writing local files
[16:52:41] Completed 11250 out of 125000 steps  (9)
[17:06:54] Writing local files
[17:06:54] Completed 12500 out of 125000 steps  (10)
[17:21:07] Writing local files
[17:21:07] Completed 13750 out of 125000 steps  (11)
[17:35:20] Writing local files
[17:35:21] Completed 15000 out of 125000 steps  (12)
[17:49:33] Writing local files
[17:49:33] Completed 16250 out of 125000 steps  (13)
[18:03:46] Writing local files
[18:03:47] Completed 17500 out of 125000 steps  (14)
[18:18:00] Writing local files
[18:18:00] Completed 18750 out of 125000 steps  (15)
[18:32:13] Writing local files
[18:32:13] Completed 20000 out of 125000 steps  (16)
[18:46:26] Writing local files
[18:46:26] Completed 21250 out of 125000 steps  (17)
[19:00:39] Writing local files
[19:00:39] Completed 22500 out of 125000 steps  (18)
[19:14:52] Writing local files
[19:14:52] Completed 23750 out of 125000 steps  (19)
[19:29:05] Writing local files
[19:29:05] Completed 25000 out of 125000 steps  (20)
[19:44:26] Writing local files
[19:44:26] Completed 26250 out of 125000 steps  (21)
[19:58:39] Writing local files
[19:58:39] Completed 27500 out of 125000 steps  (22)
[20:12:52] Writing local files
[20:12:52] Completed 28750 out of 125000 steps  (23)
[20:27:05] Writing local files
[20:27:05] Completed 30000 out of 125000 steps  (24)
[20:41:26] Writing local files
[20:41:26] Completed 31250 out of 125000 steps  (25)
[20:54:55] CoreStatus = 1 (1)
[20:54:55] Client-core communications error: ERROR 0x1
[20:54:55] Deleting current work unit & continuing...
--- Opening Log file [May 5 20:59:10]
[20:59:10] - Ask before connecting: No
[20:59:10] - User name: ChewieFL2003 (Team 734)
[20:59:10] - User ID: 6FF6E82343A9356F
[20:59:10] - Machine ID: 1
[20:59:10]
[20:59:10] Loaded queue successfully.
[20:59:10] + Benchmarking ...
[20:59:14]
[20:59:14] + Processing work unit
[20:59:14] Core required: FahCore_78.exe
[20:59:14] Core found.
[20:59:14] Working on Unit 03 [May 5 20:59:14]
[20:59:14] + Working ...
[20:59:16]
[20:59:16] *------------------------------*
[20:59:16] Folding@Home Gromacs Core
[20:59:16] Version 1.90 (March 8, 2006)
[20:59:16]
[20:59:16] Preparing to commence simulation
[20:59:16] - Looking at optimizations...
[20:59:17] - Created dyn
[20:59:17] - Files status OK
[20:59:17]
[20:59:17] Folding@home Core Shutdown: MISSING_WORK_FILES
[20:59:21] CoreStatus = 74 (116)
[20:59:21] The core could not find the work files specified. Removing from queue
[20:59:21] Deleting current work unit & continuing...
[20:59:25] - Preparing to get new work unit...
[20:59:25] + Attempting to get work packet
[20:59:25] - Connecting to assignment server
[20:59:28] - Successful: assigned to (171.64.122.88).
[20:59:28] + News From Folding@Home: Welcome to Folding@Home
[20:59:29] Loaded queue successfully.
[20:59:30] + Closed connections
[20:59:35]
[20:59:35] + Processing work unit
[20:59:35] Core required: FahCore_7b.exe
[20:59:35] Core not found.
[20:59:35] - Core is not present or corrupted.
[20:59:35] - Attempting to download new core...
[20:59:35] + Downloading new core: FahCore_7b.exe
[20:59:36] start download/end download
[20:59:38] Verifying core Core_7b.fah...
[20:59:38] Signature is VALID
[20:59:38]
[20:59:38] Trying to unzip core FahCore_7b.exe
[20:59:38] UnzipCore: Couldn't v3Decompress
[20:59:38] + Error: Could not extract core
[20:59:38] + Core download error (#2), waiting before retry...
[20:59:51] + Downloading new core: FahCore_7b.exe
[20:59:52] start download/end download
[20:59:52] Verifying core Core_7b.fah...
[20:59:52] Signature is VALID
[20:59:52]
[20:59:52] Trying to unzip core FahCore_7b.exe
[20:59:52] - Couldn't open file FahCore_7b.exe
[20:59:52] + Error: Could not extract core
[20:59:52] + Core download error (#3), waiting before retry...
[21:00:03] + Downloading new core: FahCore_7b.exe
[21:00:03] start download/end download
[21:00:05] Verifying core Core_7b.fah...
[21:00:05] Signature is VALID
[21:00:05]
[21:00:05] Trying to unzip core FahCore_7b.exe
[21:00:05] - Couldn't open file FahCore_7b.exe
[21:00:05] + Error: Could not extract core
[21:00:05] + Core download error (#4), waiting before retry...
[21:00:36] + Downloading new core: FahCore_7b.exe
[21:00:37] start download/end download
[21:00:39] Verifying core Core_7b.fah...
[21:00:39] Signature is VALID
[21:00:39]
[21:00:39] Trying to unzip core FahCore_7b.exe
[21:00:39] - Couldn't open file FahCore_7b.exe
[21:00:39] + Error: Could not extract core
[21:00:39] + Core download error (#5), waiting before retry...
[21:01:32] + Downloading new core: FahCore_7b.exe
[21:01:33] start download/end download
[21:01:34] Verifying core Core_7b.fah...
[21:01:34] Signature is VALID
[21:01:34]
[21:01:34] Trying to unzip core FahCore_7b.exe
[21:01:34] - Couldn't open file FahCore_7b.exe
[21:01:34] + Error: Could not extract core
[21:01:34] + Core download error (#6), waiting before retry...
[21:03:00] + Downloading new core: FahCore_7b.exe
[21:03:01] start download/end download
[21:03:03] Verifying core Core_7b.fah...
[21:03:03] Signature is VALID
[21:03:03]
[21:03:03] Trying to unzip core FahCore_7b.exe
[21:03:03] - Couldn't open file FahCore_7b.exe
[21:03:03] + Error: Could not extract core
[21:03:03] + Core download error (#7), waiting before retry...
[21:05:49] + Downloading new core: FahCore_7b.exe
[21:05:49] +start download/end download
[21:05:51] Verifying core Core_7b.fah...
[21:05:51] Signature is VALID
[21:05:51]
[21:05:51] Trying to unzip core FahCore_7b.exe
[21:05:51] - Couldn't open file FahCore_7b.exe
[21:05:51] + Error: Could not extract core
[21:05:51] + Core download error (#8), waiting before retry...
[21:11:15] + Downloading new core: FahCore_7b.exe
[21:11:16] start download/end download
[21:11:17] Verifying core Core_7b.fah...
[21:11:17] Signature is VALID
[21:11:17]
[21:11:17] Trying to unzip core FahCore_7b.exe
[21:11:17] - Couldn't open file FahCore_7b.exe
[21:11:17] + Error: Could not extract core
[21:11:17] + Core download error (#9), waiting before retry...
[21:22:05] + Downloading new core: FahCore_7b.exe
[21:22:06] start download/end download
[21:22:07] Verifying core Core_7b.fah...
[21:22:07] Signature is VALID
[21:22:07]
[21:22:07] Trying to unzip core FahCore_7b.exe
[21:22:07] - Couldn't open file FahCore_7b.exe
[21:22:07] + Error: Could not extract core
[21:22:07] + Core download error (#10), waiting before retry...
[21:43:39] + Downloading new core: FahCore_7b.exe
[21:43:40] start download/end download
[21:43:41] Verifying core Core_7b.fah...
[21:43:41] Signature is VALID
[21:43:41]
[21:43:41] Trying to unzip core FahCore_7b.exe
[21:43:41] - Couldn't open file FahCore_7b.exe
[21:43:41] + Error: Could not extract core
[21:43:41] + Core download error (#11), waiting before retry...
[22:26:25] + Downloading new core: FahCore_7b.exe
[22:26:25] start download/end download
[22:26:26] Verifying core Core_7b.fah...
[22:26:26] Signature is VALID
[22:26:26]
[22:26:26] Trying to unzip core FahCore_7b.exe
[22:26:26] - Couldn't open file FahCore_7b.exe
[22:26:26] + Error: Could not extract core
[22:26:26] + Core download error (#12), waiting before retry...
[23:14:37] + Downloading new core: FahCore_7b.exe
[23:14:37] start download/end download
[23:14:38] Verifying core Core_7b.fah...
[23:14:38] Signature is VALID
[23:14:38]
[23:14:38] Trying to unzip core FahCore_7b.exe
[23:14:38] - Couldn't open file FahCore_7b.exe
[23:14:38] + Error: Could not extract core
[23:14:38] + Core download error (#13), waiting before retry...
[00:02:51] + Downloading new core: FahCore_7b.exe
[00:02:52] start download/end download
[00:02:53] Verifying core Core_7b.fah...
[00:02:53] Signature is VALID
[00:02:53]
[00:02:53] Trying to unzip core FahCore_7b.exe
[00:02:53] - Couldn't open file FahCore_7b.exe
[00:02:53] + Error: Could not extract core
[00:02:53] + Core download error (#14), waiting before retry...
[00:51:04] + Downloading new core: FahCore_7b.exe
[00:51:05] start download/end download
[00:51:06] Verifying core Core_7b.fah...
[00:51:06] Signature is VALID
[00:51:06]
[00:51:06] Trying to unzip core FahCore_7b.exe
[00:51:06] - Couldn't open file FahCore_7b.exe
[00:51:06] + Error: Could not extract core
[00:51:06] + Core download error (#15), waiting before retry...
[01:39:17] + Downloading new core: FahCore_7b.exe
[01:39:19] start download/end download
[01:39:20] Verifying core Core_7b.fah...
[01:39:20] Signature is VALID
[01:39:20]
[01:39:20] Trying to unzip core FahCore_7b.exe
[01:39:20] - Couldn't open file FahCore_7b.exe
[01:39:20] + Error: Could not extract core
[01:39:20] + Core download error (#16), waiting before retry...
[02:27:21] + Downloading new core: FahCore_7b.exe
[02:27:22] start download/end download
[02:27:23] Verifying core Core_7b.fah...
[02:27:23] Signature is VALID
[02:27:23]
[02:27:23] Trying to unzip core FahCore_7b.exe
[02:27:23] - Couldn't open file FahCore_7b.exe
[02:27:23] + Error: Could not extract core
[02:27:23] + Core download error (#17), waiting before retry...
[03:15:33] + Downloading new core: FahCore_7b.exe
[03:15:33] start download/end download
[03:15:34] Verifying core Core_7b.fah...
[03:15:34] Signature is VALID
[03:15:34]
[03:15:34] Trying to unzip core FahCore_7b.exe
[03:15:34] - Couldn't open file FahCore_7b.exe
[03:15:34] + Error: Could not extract core
[03:15:34] + Core download error (#18), waiting before retry...
--- Opening Log file [May 6 03:46:36]
[03:46:36] - Ask before connecting: No
[03:46:36] - User name: ChewieFL2003 (Team 734)
[03:46:36] - User ID: 6FF6E82343A9356F
[03:46:36] - Machine ID: 1
[03:46:36]
[03:46:37] Loaded queue successfully.
[03:46:37] + Benchmarking ...
[03:46:40]
[03:46:40] + Processing work unit
[03:46:40] Core required: FahCore_7b.exe
[03:46:40] Core found.
[03:46:41] Working on Unit 04 [May 6 03:46:41]
[03:46:41] + Working ...
[03:46:43]
[03:46:43] *------------------------------*
[03:46:43] Folding@Home Double Gromacs Core B
[03:46:43] Version 1.04 (Fri Aug 10 16:46:39 PDT 2007)
[03:46:43]
[03:46:43] Preparing to commence simulation
[03:46:43] - Files status OK
[03:46:43] - Expanded 344849 -> 1202041 (decompressed 348.5 percent)
[03:46:43]
[03:46:43] Project: 3907 (Run 3898, Clone 4, Gen 6)
[03:46:43]
[03:46:43] Assembly optimizations on if available.
[03:46:43] Entering M.D.
[03:46:49] Will resume from checkpoint file
[03:46:49] Working on Lig in water
[03:46:49] Completed 0 out of 500000 steps  (0)
[03:46:49] Extra SSE2 boost OK
[03:46:49] Resuming from checkpoint
[03:46:49] Verified work/wudata_04.log
[03:46:49] Verified work/wudata_04.edr
[03:46:49] Verified work/wudata_04.xvg
[03:46:49] Verified work/wudata_04.trr
[03:46:49] Verified work/wudata_04.xtc
[03:54:09] Completed 5000 out of 500000 steps  (1)
[04:01:22] Completed 10000 out of 500000 steps  (2)
[04:08:33] Completed 15000 out of 500000 steps  (3)
[04:15:41] Completed 20000 out of 500000 steps  (4)
[04:22:52] Completed 25000 out of 500000 steps  (5)
[04:30:06] Completed 30000 out of 500000 steps  (6)
[04:37:18] Completed 35000 out of 500000 steps  (7)
[04:44:30] Completed 40000 out of 500000 steps  (8)
[04:51:43] Completed 45000 out of 500000 steps  (9)
[04:58:55] Completed 50000 out of 500000 steps  (10)
[05:06:05] Completed 55000 out of 500000 steps  (11)
[05:13:16] Completed 60000 out of 500000 steps  (12)
[05:20:26] Completed 65000 out of 500000 steps  (13)
[05:27:38] Completed 70000 out of 500000 steps  (14)
[05:34:50] Completed 75000 out of 500000 steps  (15)
[05:42:02] Completed 80000 out of 500000 steps  (16)
[05:49:13] Completed 85000 out of 500000 steps  (17)
[05:56:23] Completed 90000 out of 500000 steps  (18)
[06:03:32] Completed 95000 out of 500000 steps  (19)
[06:10:39] Completed 100000 out of 500000 steps  (20)
[06:17:48] Completed 105000 out of 500000 steps  (21)
[06:24:57] Completed 110000 out of 500000 steps  (22)
[06:32:05] Completed 115000 out of 500000 steps  (23)
[06:39:14] Completed 120000 out of 500000 steps  (24)
[06:46:21] Completed 125000 out of 500000 steps  (25)
[06:53:33] Completed 130000 out of 500000 steps  (26)
[07:00:43] Completed 135000 out of 500000 steps  (27)
[07:07:54] Completed 140000 out of 500000 steps  (28)
[07:15:06] Completed 145000 out of 500000 steps  (29)
[07:22:16] Completed 150000 out of 500000 steps  (30)
[07:29:25] Completed 155000 out of 500000 steps  (31)
[07:36:34] Completed 160000 out of 500000 steps  (32)
[07:43:45] Completed 165000 out of 500000 steps  (33)
[07:50:53] Completed 170000 out of 500000 steps  (34)
[07:58:00] Completed 175000 out of 500000 steps  (35)
[08:05:09] Completed 180000 out of 500000 steps  (36)
[08:12:19] Completed 185000 out of 500000 steps  (37)
[08:19:28] Completed 190000 out of 500000 steps  (38)
[08:26:38] Completed 195000 out of 500000 steps  (39)
[08:33:53] Completed 200000 out of 500000 steps  (40)
[08:41:06] Completed 205000 out of 500000 steps  (41)
[08:48:17] Completed 210000 out of 500000 steps  (42)
[08:55:31] Completed 215000 out of 500000 steps  (43)
[09:02:42] Completed 220000 out of 500000 steps  (44)
[09:09:50] Completed 225000 out of 500000 steps  (45)
[09:17:01] Completed 230000 out of 500000 steps  (46)
[09:24:09] Completed 235000 out of 500000 steps  (47)
[09:31:21] Completed 240000 out of 500000 steps  (48)
[09:38:34] Completed 245000 out of 500000 steps  (49)
[09:45:47] Completed 250000 out of 500000 steps  (50)
[09:53:01] Completed 255000 out of 500000 steps  (51)
[10:00:13] Completed 260000 out of 500000 steps  (52)
[10:07:27] Completed 265000 out of 500000 steps  (53)
[10:14:40] Completed 270000 out of 500000 steps  (54)
[10:21:55] Completed 275000 out of 500000 steps  (55)
[10:29:09] Completed 280000 out of 500000 steps  (56)
[10:36:21] Completed 285000 out of 500000 steps  (57)
[10:43:32] Completed 290000 out of 500000 steps  (58)
[10:50:45] Completed 295000 out of 500000 steps  (59)
[10:57:55] Completed 300000 out of 500000 steps  (60)
[11:05:02] Completed 305000 out of 500000 steps  (61)
[11:12:12] Completed 310000 out of 500000 steps  (62)
[11:19:23] Completed 315000 out of 500000 steps  (63)
[11:26:36] Completed 320000 out of 500000 steps  (64)
[11:33:45] Completed 325000 out of 500000 steps  (65)
[11:40:58] Completed 330000 out of 500000 steps  (66)
[11:48:10] Completed 335000 out of 500000 steps  (67)
[11:55:20] Completed 340000 out of 500000 steps  (68)
[12:02:31] Completed 345000 out of 500000 steps  (69)
[12:09:43] Completed 350000 out of 500000 steps  (70)
[12:16:52] Completed 355000 out of 500000 steps  (71)
[12:24:01] Completed 360000 out of 500000 steps  (72)
[12:31:12] Completed 365000 out of 500000 steps  (73)
[12:38:21] Completed 370000 out of 500000 steps  (74)
[12:45:32] Completed 375000 out of 500000 steps  (75)
[12:52:44] Completed 380000 out of 500000 steps  (76)
[12:59:58] Completed 385000 out of 500000 steps  (77)
[13:07:11] Completed 390000 out of 500000 steps  (78)
[13:14:25] Completed 395000 out of 500000 steps  (79)
[13:21:37] Completed 400000 out of 500000 steps  (80)
[13:28:46] Completed 405000 out of 500000 steps  (81)
[13:35:54] Completed 410000 out of 500000 steps  (82)
[13:43:03] Completed 415000 out of 500000 steps  (83)
[13:50:12] Completed 420000 out of 500000 steps  (84)
[13:57:23] Completed 425000 out of 500000 steps  (85)
[14:04:35] Completed 430000 out of 500000 steps  (86)
[14:11:46] Completed 435000 out of 500000 steps  (87)
[14:18:59] Completed 440000 out of 500000 steps  (88)
[14:26:16] Completed 445000 out of 500000 steps  (89)
[14:33:52] Completed 450000 out of 500000 steps  (90)
[14:41:14] Completed 455000 out of 500000 steps  (91)
[14:49:37] Completed 460000 out of 500000 steps  (92)
[14:57:52] Completed 465000 out of 500000 steps  (93)
[15:06:43] Completed 470000 out of 500000 steps  (94)
[15:15:32] Completed 475000 out of 500000 steps  (95)
[15:24:05] Completed 480000 out of 500000 steps  (96)
[15:32:17] Completed 485000 out of 500000 steps  (97)
[15:40:56] Completed 490000 out of 500000 steps  (98)
[15:48:59] Completed 495000 out of 500000 steps  (99)
[15:57:39] Completed 500000 out of 500000 steps  (100)
[15:58:40]
[15:58:40] Finished Work Unit:
[15:58:40] - Reading up to 7920684 from "work/wudata_04.trr": Read 7920684
[15:58:40] - Reading up to 1144360 from "work/wudata_04.xtc": Read 1144360
[15:58:40] logfile size: 26949
[15:58:40] Leaving Run
[15:58:44] - Writing 11579613 bytes of core data to disk...
[15:58:49] Done: 11579101 -> 9575713 (compressed to 82.6 percent)
[15:58:49]   ... Done.
[15:58:49] - Shutting down core
[15:58:49]
[15:58:49] Folding@home Core Shutdown: FINISHED_UNIT
[15:58:51] CoreStatus = 64 (100)
[15:58:51] Sending work to server
[15:58:51] + Attempting to send results
[16:01:38] + Results successfully sent
[16:01:38] Thank you for your contribution to Folding@Home.
[16:01:38] + Starting local stats count at 1
[16:01:42] - Preparing to get new work unit...
[16:01:42] + Attempting to get work packet
[16:01:42] - Connecting to assignment server
[16:01:42] - Successful: assigned to (171.64.65.65).
[16:01:42] + News From Folding@Home: Welcome to Folding@Home
[16:01:42] Loaded queue successfully.
[16:01:52] + Closed connections
[16:01:52]
[16:01:52] + Processing work unit
[16:01:52] Core required: FahCore_78.exe
[16:01:52] Core found.
[16:01:52] Working on Unit 05 [May 6 16:01:52]
[16:01:52] + Working ...
[16:01:53]
[16:01:53] *------------------------------*
[16:01:53] Folding@Home Gromacs Core
[16:01:53] Version 1.90 (March 8, 2006)
[16:01:53]
[16:01:53] Preparing to commence simulation
[16:01:53] - Looking at optimizations...
[16:01:53] - Created dyn
[16:01:53] - Files status OK
[16:01:57] - Expanded 3639016 -> 18751629 (decompressed 515.2 percent)
[16:01:57] - Starting from initial work packet
[16:01:57]
[16:01:57] Project: 2621 (Run 4, Clone 87, Gen 16)
[16:01:57]
[16:01:57] Assembly optimizations on if available.
[16:01:57] Entering M.D.
[16:02:04] Protein: p2621_p1475_tet1_03_1 t= 20000.00000
[16:02:04]
[16:02:04] Writing local files
[16:02:09] Extra SSE boost OK.
[16:02:10] Writing local files
[16:02:10] Completed 0 out of 125000 steps  (0)
[16:13:42] Writing local files
[16:13:43] Completed 1250 out of 125000 steps  (1)
[16:25:34] Writing local files
[16:25:34] Completed 2500 out of 125000 steps  (2)
[16:36:54] Writing local files
[16:36:55] Completed 3750 out of 125000 steps  (3)
[16:47:59] Writing local files
[16:47:59] Completed 5000 out of 125000 steps  (4)
[16:59:29] Writing local files
[16:59:29] Completed 6250 out of 125000 steps  (5)
[17:09:57] Writing local files
[17:09:58] Completed 7500 out of 125000 steps  (6)
[17:19:45] Writing local files
[17:19:45] Completed 8750 out of 125000 steps  (7)
Hope this is usefull info, Chewie.
Re: tanked a few 2621's
ChewieFL2003 wrote:Side question : How do I shutdown service, without turning off computer (properly) ?
Open Services Manager (services.msc), find the FAH service, and select Stop.
P.S : prime stable is NOT fah stable (and often not stable at all) ... if you want a test close to FAH code, use this one viewtopic.php?f=14&t=430
