Unable to uload completed project
Hi, I seem to be having this issue quite often. I look at my status and see a work unit with just seconds left to completion but it will stay that way for days even after rebooting. The one I have stuck now is project 11292 (12,121,2) it has been at 3 seconds for at least 4 days now. I do notice that the upload server is 0.0.0.0 while the work server is listed 171.67.108.44. Is there a way to change the upload server to a valid one if that is the issue. Thanks for any help.
Re: Unable to uload completed project
As always we'll need to see the fah log to troubleshoot the problem.
No. Server addresses are hardcoded for security reasons.
The work server is ALWAYS the first choice for an upload server. 171.67.108.44 is accepting uploads. You didn't tell us what happened when the client tried to upload to the work server but we'll be able to see that in your log.
A collection server is a BACKUP for when the work server can't accept the upload and it will hold the upload and then forward it to the work server when it can. Having a CS set to 0.0.0.0 simply means the backup isn't available.
I am sorry I posted before reading about putting up logs (I hope this isn't a duplicate post because I thought I posted this already). Here is my log but I think I may be too late since this file shows an unknown next upload try. I have had this file sitting in this limbo state for at least 4 days and it doesn't appear that the log has that much data.
16:18:52:************************* Folding@home Client *************************
16:18:52: Website: http://folding.stanford.edu/
16:18:52: Copyright: (c) 2009-2013 Stanford University
16:18:52: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:18:52: Args:
16:18:52: Config: d:/Users/Al/AppData/Roaming/FAHClient/config.xml
16:18:52:******************************** Build ********************************
16:18:52: Version: 7.3.6
16:18:52: Date: Feb 18 2013
16:18:52: Time: 15:25:17
16:18:52: SVN Rev: 3923
16:18:52: Branch: fah/trunk/client
16:18:52: Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:18:52: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:18:52: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:18:52: Platform: win32 XP
16:18:52: Bits: 32
16:18:52: Mode: Release
16:18:52:******************************* System ********************************
16:18:52: CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
16:18:52: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
16:18:52: CPUs: 8
16:18:52: Memory: 11.95GiB
16:18:52: Free Memory: 10.36GiB
16:18:52: Threads: WINDOWS_THREADS
16:18:52: Has Battery: false
16:18:52: On Battery: false
16:18:52: UTC offset: -4
16:18:52: PID: 5568
16:18:52: CWD: d:/Users/Al/AppData/Roaming/FAHClient
16:18:52: OS: Windows 7 Ultimate
16:18:52: OS Arch: AMD64
16:18:52: GPUs: 1
16:18:52: GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
16:18:52: CUDA: Not detected
16:18:52:Win32 Service: false
16:18:52:***********************************************************************
16:18:52:<config>
16:18:52: <!-- Folding Slot Configuration -->
16:18:52: <power v='full'/>
16:18:52:
16:18:52: <!-- User Information -->
16:18:52: <passkey v='********************************'/>
16:18:52: <team v='5'/>
16:18:52: <user v='zoorafa'/>
16:18:52:
16:18:52: <!-- Folding Slots -->
16:18:52: <slot id='0' type='GPU'/>
16:18:52: <slot id='1' type='CPU'/>
16:18:52:</config>
16:18:52:Trying to access database...
16:18:53:Successfully acquired database lock
16:18:53:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
16:18:53:Enabled folding slot 01: READY cpu:7
16:18:54:WU01:FS00:Starting
16:18:54:WU01:FS00:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Al/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 5568 -checkpoint 15 -gpu 0 -gpu-vendor ati
16:18:54:WU01:FS00:Started FahCore on PID 5496
16:18:55:WU01:FS00:Core PID:5520
16:18:55:WU01:FS00:FahCore 0x16 started
16:18:55:WU02:FS01:Starting
16:18:55:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Al/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 703 -lifeline 5568 -checkpoint 15 -np 7
16:18:55:WU02:FS01:Started FahCore on PID 5612
16:18:55:WU01:FS00:0x16:
16:18:55:WU01:FS00:0x16:*------------------------------*
16:18:55:WU01:FS00:0x16:Folding@Home GPU Core
16:18:55:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
16:18:55:WU01:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
16:18:55:WU01:FS00:0x16:Build host: user-f6d030f24f
16:18:55:WU01:FS00:0x16:Board Type: AMD/OpenCL
16:18:55:WU01:FS00:0x16:Core : x=16
16:18:55:WU01:FS00:0x16: Window's signal control handler registered.
16:18:55:WU01:FS00:0x16:Preparing to commence simulation
16:18:55:WU01:FS00:0x16:- Ensuring status. Please wait.
16:18:55:WU02:FS01:Core PID:3492
16:18:55:WU02:FS01:FahCore 0xa4 started
16:18:56:WU02:FS01:0xa4:
16:18:56:WU02:FS01:0xa4:*------------------------------*
16:18:56:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
16:18:56:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
16:18:56:WU02:FS01:0xa4:Preparing to commence simulation
16:18:56:WU02:FS01:0xa4:- Ensuring status. Please wait.
16:19:05:WU01:FS00:0x16:- Looking at optimizations...
16:19:05:WU01:FS00:0x16:- Working with standard loops on this execution.
16:19:05:WU01:FS00:0x16:- Previous termination of core was improper.
16:19:05:WU01:FS00:0x16:- Files status OK
16:19:05:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
16:19:05:WU01:FS00:0x16:- Expanded 44843 -> 171163 (decompressed 381.6 percent)
16:19:05:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=44843 data_size=171163, decompressed_data_size=171163 diff=0
16:19:05:WU01:FS00:0x16:- Digital signature verified
16:19:05:WU01:FS00:0x16:Project: 11292 (Run 12, Clone 121, Gen 2)
16:19:05:WU01:FS00:0x16:Entering M.D.
16:19:05:WU02:FS01:0xa4:- Looking at optimizations...
16:19:05:WU02:FS01:0xa4:- Working with standard loops on this execution.
16:19:05:WU02:FS01:0xa4:- Previous termination of core was improper.
16:19:05:WU02:FS01:0xa4:- Going to use standard loops.
16:19:05:WU02:FS01:0xa4:- Files status OK
16:19:05:WU02:FS01:0xa4:- Expanded 547519 -> 846948 (decompressed 154.6 percent)
16:19:05:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547519 data_size=846948, decompressed_data_size=846948 diff=0
16:19:05:WU02:FS01:0xa4:- Digital signature verified
16:19:05:WU02:FS01:0xa4:Project: 7647 (Run 51, Clone 0, Gen 118)
16:19:05:WU02:FS01:0xa4:Entering M.D.
16:19:07:WU01:FS00:0x16:Will resume from checkpoint file 01/wudata_01.ckp
16:19:07:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr: 654817281 1878190663 2965621558 3962843768 1584205219
16:19:07:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
16:19:07:WU01:FS00:0x16:Client config unavailable.
16:19:07:WU01:FS00:0x16:Starting GUI Server
16:19:09:WU01:FS00:0x16:Resuming from checkpoint
16:19:09:WU01:FS00:0x16:fcCheckPointResume: retreived and current tpr file hash:
16:19:09:WU01:FS00:0x16: 0 654817281 654817281
16:19:09:WU01:FS00:0x16: 1 1878190663 1878190663
16:19:09:WU01:FS00:0x16: 2 2965621558 2965621558
16:19:09:WU01:FS00:0x16: 3 3962843768 3962843768
16:19:09:WU01:FS00:0x16: 4 1584205219 1584205219
16:19:09:WU01:FS00:0x16:fcCheckPointResume: file hashes same.
16:19:09:WU01:FS00:0x16:fcCheckPointResume: state restored.
16:19:09:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
16:19:09:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
16:19:09:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
16:19:09:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
16:19:09:WU01:FS00:0x16:fcCheckPointResume: state restored 2
16:19:09:WU01:FS00:0x16:Resumed from checkpoint
16:19:09:WU01:FS00:0x16:Setting checkpoint frequency: 599999
16:19:09:WU01:FS00:0x16:Completed 1799998 out of 59999992 steps (2%).
16:19:09:WU01:FS00:0x16:Completed 1800000 out of 59999992 steps (3%).
16:19:12:WU02:FS01:0xa4:Using Gromacs checkpoints
16:19:12:WU02:FS01:0xa4:Mapping NT from 7 to 7
16:19:22:WU02:FS01:0xa4:Resuming from checkpoint
16:19:22:WU02:FS01:0xa4:Verified 02/wudata_01.log
16:19:26:WU02:FS01:0xa4:Verified 02/wudata_01.trr
16:19:26:WU02:FS01:0xa4:Verified 02/wudata_01.xtc
16:19:26:WU02:FS01:0xa4:Verified 02/wudata_01.edr
16:19:26:WU02:FS01:0xa4:Completed 2023660 out of 2500000 steps (80%)
16:21:09:WU02:FS01:0xa4:Completed 2025000 out of 2500000 steps (81%)
16:25:30:WU01:FS00:0x16:Completed 2400000 out of 59999992 steps (4%).
16:31:20:WU01:FS00:0x16:Completed 3000000 out of 59999992 steps (5%).
16:39:07:WU01:FS00:0x16:Completed 3600000 out of 59999992 steps (6%).
16:53:14:WU01:FS00:0x16:Completed 4200000 out of 59999992 steps (7%).
17:11:37:WU01:FS00:0x16:Completed 4800000 out of 59999992 steps (8%).
17:20:37:WU01:FS00:0x16:Completed 5400000 out of 59999992 steps (9%).
17:23:56:WU02:FS01:0xa4:Completed 2050000 out of 2500000 steps (82%)
17:26:50:WU01:FS00:0x16:Completed 6000000 out of 59999992 steps (10%).
17:33:01:WU01:FS00:0x16:Completed 6600000 out of 59999992 steps (11%).
17:38:45:WU01:FS00:0x16:Completed 7200000 out of 59999992 steps (12%).
17:44:26:WU01:FS00:0x16:Completed 7799999 out of 59999992 steps (13%).
17:50:07:WU01:FS00:0x16:Completed 8399999 out of 59999992 steps (14%).
17:55:48:WU01:FS00:0x16:Completed 8999999 out of 59999992 steps (15%).
18:01:44:WU01:FS00:0x16:Completed 9599999 out of 59999992 steps (16%).
18:05:15:WU02:FS01:0xa4:Completed 2075000 out of 2500000 steps (83%)
18:07:24:WU01:FS00:0x16:Completed 10199999 out of 59999992 steps (17%).
18:13:08:WU01:FS00:0x16:Completed 10799999 out of 59999992 steps (18%).
18:18:44:WU01:FS00:0x16:Completed 11399999 out of 59999992 steps (19%).
18:24:45:WU01:FS00:0x16:Completed 11999999 out of 59999992 steps (20%).
18:34:56:WU01:FS00:0x16:Completed 12599999 out of 59999992 steps (21%).
18:58:24:WU02:FS01:0xa4:Completed 2100000 out of 2500000 steps (84%)
21:09:09:WU02:FS01:0xa4:Completed 2125000 out of 2500000 steps (85%)
******************************* Date: 2013-09-14 *******************************
23:51:45:WU02:FS01:0xa4:Completed 2150000 out of 2500000 steps (86%)
03:12:38:WU02:FS01:0xa4:Completed 2175000 out of 2500000 steps (87%)
******************************* Date: 2013-09-15 *******************************
07:32:35:WU02:FS01:0xa4:Completed 2200000 out of 2500000 steps (88%)
12:56:47:WU02:FS01:0xa4:Completed 2225000 out of 2500000 steps (89%)
15:24:36:WU02:FS01:0xa4:Completed 2250000 out of 2500000 steps (90%)
15:57:19:WU02:FS01:0xa4:Completed 2275000 out of 2500000 steps (91%)
16:29:02:WU02:FS01:0xa4:Completed 2300000 out of 2500000 steps (92%)
18:10:46:WU02:FS01:0xa4:Completed 2325000 out of 2500000 steps (93%)
19:02:40:WU02:FS01:0xa4:Completed 2350000 out of 2500000 steps (94%)
20:10:24:WU02:FS01:0xa4:Completed 2375000 out of 2500000 steps (95%)
21:30:44:WU02:FS01:0xa4:Completed 2400000 out of 2500000 steps (96%)
21:56:48:WU02:FS01:0xa4:Completed 2425000 out of 2500000 steps (97%)
22:23:53:WU02:FS01:0xa4:Completed 2450000 out of 2500000 steps (98%)
22:23:54:WU00:FS01:Connecting to assign3.stanford.edu:8080
22:23:54:WU00:FS01:News: Welcome to Folding@Home
22:23:54:WU00:FS01:Assigned to work server 171.64.65.101
22:23:54:WU00:FS01:Requesting new work unit for slot 01: RUNNING cpu:7 from 171.64.65.101
22:23:54:WU00:FS01:Connecting to 171.64.65.101:8080
22:23:55:WU00:FS01:Downloading 535.17KiB
22:23:56:WU00:FS01:Download complete
22:23:56:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:7646 run:85 clone:4 gen:93 core:0xa4 unit:0x000000a8664f2dcd4fa7fe0facfe2549
00:39:59:WU02:FS01:0xa4:Completed 2475000 out of 2500000 steps (99%)
02:05:33:WU02:FS01:0xa4:Completed 2500000 out of 2500000 steps (100%)
02:05:38:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:05:48:WU02:FS01:0xa4:
02:05:48:WU02:FS01:0xa4:Finished Work Unit:
02:05:49:WU02:FS01:0xa4:- Reading up to 13372944 from "02/wudata_01.trr": Read 13372944
02:05:49:WU02:FS01:0xa4:trr file hash check passed.
02:05:49:WU02:FS01:0xa4:- Reading up to 1986036 from "02/wudata_01.xtc": Read 1986036
02:05:49:WU02:FS01:0xa4:xtc file hash check passed.
02:05:49:WU02:FS01:0xa4:edr file hash check passed.
02:05:49:WU02:FS01:0xa4:logfile size: 64762
02:05:49:WU02:FS01:0xa4:Leaving Run
02:05:52:WU02:FS01:0xa4:- Writing 15438906 bytes of core data to disk...
02:05:56:WU02:FS01:0xa4:Done: 15438394 -> 14694345 (compressed to 95.1 percent)
02:05:56:WU02:FS01:0xa4: ... Done.
02:06:01:WU02:FS01:0xa4:- Shutting down core
02:06:01:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:06:02:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:06:02:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:7647 run:51 clone:0 gen:118 core:0xa4 unit:0x000000a2664f2dcd4fa7fe4b8029c266
02:06:02:WU02:FS01:Uploading 14.01MiB to 171.64.65.101
02:06:02:WU02:FS01:Connecting to 171.64.65.101:8080
02:06:02:WU00:FS01:Starting
02:06:02:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Al/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 5568 -checkpoint 15 -np 7
02:06:02:WU00:FS01:Started FahCore on PID 4252
02:06:02:WU00:FS01:Core PID:9224
02:06:02:WU00:FS01:FahCore 0xa4 started
02:06:03:WU00:FS01:0xa4:
02:06:03:WU00:FS01:0xa4:*------------------------------*
02:06:03:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
02:06:03:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
02:06:03:WU00:FS01:0xa4:Preparing to commence simulation
02:06:03:WU00:FS01:0xa4:- Looking at optimizations...
02:06:03:WU00:FS01:0xa4:- Created dyn
02:06:03:WU00:FS01:0xa4:- Files status OK
02:06:03:WU00:FS01:0xa4:- Expanded 547499 -> 844688 (decompressed 154.2 percent)
02:06:03:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547499 data_size=844688, decompressed_data_size=844688 diff=0
02:06:03:WU00:FS01:0xa4:- Digital signature verified
02:06:03:WU00:FS01:0xa4:Project: 7646 (Run 85, Clone 4, Gen 93)
02:06:03:WU00:FS01:0xa4:Assembly optimizations on if available.
02:06:03:WU00:FS01:0xa4:Entering M.D.
02:06:08:WU02:FS01:Upload 4.91%
02:06:08:WU00:FS01:0xa4:Mapping NT from 7 to 7
02:06:09:WU00:FS01:0xa4:Completed 0 out of 2500000 steps (0%)
02:06:14:WU02:FS01:Upload 9.81%
02:06:20:WU02:FS01:Upload 15.16%
02:06:26:WU02:FS01:Upload 20.07%
02:06:32:WU02:FS01:Upload 24.97%
02:06:38:WU02:FS01:Upload 29.88%
02:06:44:WU02:FS01:Upload 34.79%
02:06:50:WU02:FS01:Upload 39.69%
02:06:56:WU02:FS01:Upload 44.60%
02:07:02:WU02:FS01:Upload 49.95%
02:07:08:WU02:FS01:Upload 54.86%
02:07:14:WU02:FS01:Upload 59.76%
02:07:20:WU02:FS01:Upload 64.67%
02:07:26:WU02:FS01:Upload 69.57%
02:07:32:WU02:FS01:Upload 74.48%
02:07:38:WU02:FS01:Upload 79.38%
02:07:44:WU02:FS01:Upload 83.84%
02:07:50:WU02:FS01:Upload 88.75%
02:07:56:WU02:FS01:Upload 93.21%
02:08:02:WU02:FS01:Upload 97.67%
02:08:06:WU02:FS01:Upload complete
02:08:06:WU02:FS01:Server responded WORK_ACK (400)
02:08:06:WU02:FS01:Final credit estimate, 8819.00 points
02:08:06:WU02:FS01:Cleaning up
02:52:11:WU00:FS01:0xa4:Completed 25000 out of 2500000 steps (1%)
******************************* Date: 2013-09-16 *******************************
03:34:39:WU00:FS01:0xa4:Completed 50000 out of 2500000 steps (2%)
03:55:10:WU00:FS01:0xa4:Completed 75000 out of 2500000 steps (3%)
04:19:42:WU00:FS01:0xa4:Completed 100000 out of 2500000 steps (4%)
04:47:29:WU00:FS01:0xa4:Completed 125000 out of 2500000 steps (5%)
05:11:20:WU00:FS01:0xa4:Completed 150000 out of 2500000 steps (6%)
05:34:36:WU00:FS01:0xa4:Completed 175000 out of 2500000 steps (7%)
06:00:10:WU00:FS01:0xa4:Completed 200000 out of 2500000 steps (8%)
06:28:53:WU00:FS01:0xa4:Completed 225000 out of 2500000 steps (9%)
06:55:11:WU00:FS01:0xa4:Completed 250000 out of 2500000 steps (10%)
07:21:51:WU00:FS01:0xa4:Completed 275000 out of 2500000 steps (11%)
07:48:40:WU00:FS01:0xa4:Completed 300000 out of 2500000 steps (12%)
08:12:05:WU00:FS01:0xa4:Completed 325000 out of 2500000 steps (13%)
08:37:56:WU00:FS01:0xa4:Completed 350000 out of 2500000 steps (14%)
08:58:34:WU00:FS01:0xa4:Completed 375000 out of 2500000 steps (15%)
09:22:45:WU00:FS01:0xa4:Completed 400000 out of 2500000 steps (16%)
09:46:12:WU00:FS01:0xa4:Completed 425000 out of 2500000 steps (17%)
10:10:16:WU00:FS01:0xa4:Completed 450000 out of 2500000 steps (18%)
10:34:23:WU00:FS01:0xa4:Completed 475000 out of 2500000 steps (19%)
10:59:32:WU00:FS01:0xa4:Completed 500000 out of 2500000 steps (20%)
11:24:10:WU00:FS01:0xa4:Completed 525000 out of 2500000 steps (21%)
11:51:51:WU00:FS01:0xa4:Completed 550000 out of 2500000 steps (22%)
12:23:24:WU00:FS01:0xa4:Completed 575000 out of 2500000 steps (23%)
14:03:39:WU00:FS01:0xa4:Completed 600000 out of 2500000 steps (24%)
16:36:43:WU00:FS01:0xa4:Completed 625000 out of 2500000 steps (25%)
18:49:03:WU00:FS01:0xa4:Completed 650000 out of 2500000 steps (26%)
21:08:57:WU00:FS01:0xa4:Completed 675000 out of 2500000 steps (27%)
23:37:44:WU00:FS01:0xa4:Completed 700000 out of 2500000 steps (28%)
00:59:19:WU00:FS01:0xa4:Completed 725000 out of 2500000 steps (29%)
02:34:36:WU00:FS01:0xa4:Completed 750000 out of 2500000 steps (30%)
******************************* Date: 2013-09-17 *******************************
07:48:58:WU00:FS01:0xa4:Completed 775000 out of 2500000 steps (31%)
12:44:27:WU00:FS01:0xa4:Completed 800000 out of 2500000 steps (32%)
17:49:39:WU00:FS01:0xa4:Completed 825000 out of 2500000 steps (33%)
23:20:21:WU00:FS01:0xa4:Completed 850000 out of 2500000 steps (34%)
******************************* Date: 2013-09-18 *******************************
04:45:00:WU00:FS01:0xa4:Completed 875000 out of 2500000 steps (35%)
10:08:39:WU00:FS01:0xa4:Completed 900000 out of 2500000 steps (36%)
13:05:03:WU00:FS01:0xa4:Completed 925000 out of 2500000 steps (37%)
The GPU was progressing nicely until here:
Check the Windows Event Log for a Driver crash around this time. It may have corrupted to WU. Also, what driver version is installed?
I'm also concerned about why the CPU work unit starts with frame times around 30 minutes, but then later takes as much as 5-6 hours to complete a frame. What else is running and using that much CPU resources?
I have been using beta drivers for about a week now version 13.200.11.0 , I installed these after running driver sweeper due to problems with my PC not waking up and the display just being whiteish when it would come out of standby forcing a hard reboot. I have not had that problem since using these drivers. My event logs do not show anything around that time (I wasn't sure of the day but went back 10 days). If the WU is corrupted can I just scrap it and get another? I have been Folding for years and have never had as many problems since this new video card. Drops in production most likely due to gaming.
Ordinarily we don't recommend beta drivers, but if they work for you, great.
The CPU-based WUs share resources pretty well with foreground activities because modern Operating Systems support CPU priority and other important tools to switch between applications promptly and smoothly. GPU drivers are not that sophisticated, basically processing all work requests as FIFO. Conclusion: A GPU WU will not share resources with a GPU-intensive game so you'll probably end up pausing or finishing a GPU WU before starting the game. [This is not a recommendation ... just something to consider.]
If you're sure you've given the WU a reasonable opportunity to get started processing, the easiest way to get rid of it is to delete the GPU slot and then add a new one. Don't do this unless you have no reasonable alternatives.
I'm confused ..I thought I have a finished WU that just won't upload, don't understand what you mean by "you've given WU reasonable amt of time to get started"
There is a brief cosmetic bug when the GPU client is trying to startup that shows the status bar as 99 percent complete. Normally this goes away in a few seconds. However when a WU is stuck the 99 never clears.
This is part of what Bruce meant. The other part is that your log clearly shows the current GPU WU stopped at 21 percent and cannot seem to startup and continue.
Thanks for the help. I'll give that WU until I get home tonight and if its still there I'll have to kill it. I think I will also pull those beta drivers and install latest released version. My problems with waking up stopped when I installed the beta drivers over the latest ones but I never gave the correct drivers a chance on the new install after running driver sweeper. Hopefully deleting the GPU slot, then doing my driver swap before reinstalling the GPU slot in that order should get me back and running.
Woo hoo looks like it finally cleared..Still going to change video drivers, just not in the middle of a WU. Thanks again.
*********************** Log Started 2013-09-19T03:13:40Z ***********************
03:13:40:************************* Folding@home Client *************************
03:13:40: Website: http://folding.stanford.edu/
03:13:40: Copyright: (c) 2009-2013 Stanford University
03:13:40: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:13:40: Args:
03:13:40: Config: d:/Users/Al/AppData/Roaming/FAHClient/config.xml
03:13:40:******************************** Build ********************************
03:13:40: Version: 7.3.6
03:13:40: Date: Feb 18 2013
03:13:40: Time: 15:25:17
03:13:40: SVN Rev: 3923
03:13:40: Branch: fah/trunk/client
03:13:40: Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:13:40: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:13:40: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:13:40: Platform: win32 XP
03:13:40: Bits: 32
03:13:40: Mode: Release
03:13:40:******************************* System ********************************
03:13:40: CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
03:13:40: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
03:13:40: CPUs: 8
03:13:40: Memory: 11.95GiB
03:13:40: Free Memory: 10.37GiB
03:13:40: Threads: WINDOWS_THREADS
03:13:40: Has Battery: false
03:13:40: On Battery: false
03:13:40: UTC offset: -4
03:13:40: PID: 5548
03:13:40: CWD: d:/Users/Al/AppData/Roaming/FAHClient
03:13:40: OS: Windows 7 Ultimate
03:13:40: OS Arch: AMD64
03:13:40: GPUs: 1
03:13:40: GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
03:13:40: CUDA: Not detected
03:13:40:Win32 Service: false
03:13:40:***********************************************************************
03:13:40:<config>
03:13:40: <!-- Folding Slot Configuration -->
03:13:40: <power v='full'/>
03:13:40:
03:13:40: <!-- User Information -->
03:13:40: <passkey v='********************************'/>
03:13:40: <team v='5'/>
03:13:40: <user v='zoorafa'/>
03:13:40:
03:13:40: <!-- Folding Slots -->
03:13:40: <slot id='0' type='GPU'/>
03:13:40: <slot id='1' type='CPU'/>
03:13:40:</config>
03:13:40:Connecting to assign-GPU.stanford.edu:80
03:13:41:Connecting to assign-GPU.stanford.edu:8080
03:13:41:Read GPUs.txt
03:13:41:Trying to access database...
03:13:44:Successfully acquired database lock
03:13:44:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
03:13:44:Enabled folding slot 01: READY cpu:7
03:13:45:WU00:FS01:Starting
03:13:45:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Al/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 5548 -checkpoint 15 -np 7
03:13:45:WU00:FS01:Started FahCore on PID 1572
03:13:46:WU00:FS01:Core PID:5760
03:13:46:WU00:FS01:FahCore 0xa4 started
03:13:46:WU01:FS00:Starting
03:13:46:WU01:FS00:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Al/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 5548 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:13:46:WU01:FS00:Started FahCore on PID 4288
03:13:46:WU00:FS01:0xa4:
03:13:46:WU00:FS01:0xa4:*------------------------------*
03:13:46:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
03:13:46:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
03:13:46:WU00:FS01:0xa4:Preparing to commence simulation
03:13:46:WU00:FS01:0xa4:- Looking at optimizations...
03:13:46:WU00:FS01:0xa4:- Files status OK
03:13:46:WU00:FS01:0xa4:- Expanded 547499 -> 844688 (decompressed 154.2 percent)
03:13:46:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=547499 data_size=844688, decompressed_data_size=844688 diff=0
03:13:46:WU00:FS01:0xa4:- Digital signature verified
03:13:46:WU00:FS01:0xa4:Project: 7646 (Run 85, Clone 4, Gen 93)
03:13:46:WU00:FS01:0xa4:Assembly optimizations on if available.
03:13:46:WU00:FS01:0xa4:Entering M.D.
03:13:47:WU01:FS00:Core PID:5472
03:13:47:WU01:FS00:FahCore 0x16 started
03:13:47:WU01:FS00:0x16:
03:13:47:WU01:FS00:0x16:*------------------------------*
03:13:47:WU01:FS00:0x16:Folding@Home GPU Core
03:13:47:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
03:13:47:WU01:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
03:13:47:WU01:FS00:0x16:Build host: user-f6d030f24f
03:13:47:WU01:FS00:0x16:Board Type: AMD/OpenCL
03:13:47:WU01:FS00:0x16:Core : x=16
03:13:47:WU01:FS00:0x16: Window's signal control handler registered.
03:13:47:WU01:FS00:0x16:Preparing to commence simulation
03:13:47:WU01:FS00:0x16:- Ensuring status. Please wait.
03:13:53:WU00:FS01:0xa4:Using Gromacs checkpoints
03:13:53:WU00:FS01:0xa4:Mapping NT from 7 to 7
03:13:55:WU00:FS01:0xa4:Resuming from checkpoint
03:13:55:WU00:FS01:0xa4:Verified 00/wudata_01.log
03:13:56:WU01:FS00:0x16:- Looking at optimizations...
03:13:56:WU01:FS00:0x16:- Working with standard loops on this execution.
03:13:56:WU01:FS00:0x16:- Previous termination of core was improper.
03:13:56:WU01:FS00:0x16:- Going to use standard loops.
03:13:56:WU01:FS00:0x16:- Files status OK
03:13:56:WU00:FS01:0xa4:Verified 00/wudata_01.trr
03:13:57:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
03:13:57:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
03:13:57:WU00:FS01:0xa4:Verified 00/wudata_01.edr
03:13:57:WU01:FS00:0x16:- Expanded 44843 -> 171163 (decompressed 381.6 percent)
03:13:57:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=44843 data_size=171163, decompressed_data_size=171163 diff=0
03:13:57:WU01:FS00:0x16:- Digital signature verified
03:13:57:WU01:FS00:0x16:Project: 11292 (Run 12, Clone 121, Gen 2)
03:13:57:WU01:FS00:0x16:Entering M.D.
03:13:57:WU00:FS01:0xa4:Completed 1092880 out of 2500000 steps (43%)
03:13:59:WU01:FS00:0x16:Will resume from checkpoint file 01/wudata_01.ckp
03:13:59:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr: 654817281 1878190663 2965621558 3962843768 1584205219
03:14:00:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
03:14:00:WU01:FS00:0x16:Client config unavailable.
03:14:00:WU01:FS00:0x16:Starting GUI Server
03:14:12:WU01:FS00:0x16:Resuming from checkpoint
03:14:12:WU01:FS00:0x16:fcCheckPointResume: retreived and current tpr file hash:
03:14:12:WU01:FS00:0x16: 0 654817281 654817281
03:14:12:WU01:FS00:0x16: 1 1878190663 1878190663
03:14:12:WU01:FS00:0x16: 2 2965621558 2965621558
03:14:12:WU01:FS00:0x16: 3 3962843768 3962843768
03:14:12:WU01:FS00:0x16: 4 1584205219 1584205219
03:14:12:WU01:FS00:0x16:fcCheckPointResume: file hashes same.
03:14:12:WU01:FS00:0x16:fcCheckPointResume: state restored.
03:14:12:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
03:14:12:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
03:14:12:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
03:14:12:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
03:14:12:WU01:FS00:0x16:fcCheckPointResume: state restored 2
03:14:12:WU01:FS00:0x16:Resumed from checkpoint
03:14:12:WU01:FS00:0x16:Setting checkpoint frequency: 599999
03:14:12:WU01:FS00:0x16:Completed 12599980 out of 59999992 steps (20%).
03:14:12:WU01:FS00:0x16:Completed 12599999 out of 59999992 steps (21%).
03:20:23:WU01:FS00:0x16:Completed 13199999 out of 59999992 steps (22%).
03:21:52:WU00:FS01:0xa4:Completed 1100000 out of 2500000 steps (44%)
03:27:07:WU01:FS00:0x16:Completed 13799999 out of 59999992 steps (23%).
03:33:53:WU01:FS00:0x16:Completed 14399999 out of 59999992 steps (24%).
03:41:02:WU01:FS00:0x16:Completed 14999998 out of 59999992 steps (25%).
03:48:07:WU01:FS00:0x16:Completed 15599998 out of 59999992 steps (26%).
03:48:08:WU00:FS01:0xa4:Completed 1125000 out of 2500000 steps (45%)
03:55:18:WU01:FS00:0x16:Completed 16199998 out of 59999992 steps (27%).
04:02:38:WU01:FS00:0x16:Completed 16799998 out of 59999992 steps (28%).
04:09:31:WU01:FS00:0x16:Completed 17399998 out of 59999992 steps (29%).
04:12:58:WU00:FS01:0xa4:Completed 1150000 out of 2500000 steps (46%)
04:16:22:WU01:FS00:0x16:Completed 17999998 out of 59999992 steps (30%).
04:23:36:WU01:FS00:0x16:Completed 18599998 out of 59999992 steps (31%).
04:31:02:WU01:FS00:0x16:Completed 19199998 out of 59999992 steps (32%).
04:37:59:WU00:FS01:0xa4:Completed 1175000 out of 2500000 steps (47%)
04:38:16:WU01:FS00:0x16:Completed 19799998 out of 59999992 steps (33%).
04:45:28:WU01:FS00:0x16:Completed 20399998 out of 59999992 steps (34%).
04:52:35:WU01:FS00:0x16:Completed 20999998 out of 59999992 steps (35%).
05:00:00:WU01:FS00:0x16:Completed 21599998 out of 59999992 steps (36%).
05:02:57:WU00:FS01:0xa4:Completed 1200000 out of 2500000 steps (48%)
05:07:18:WU01:FS00:0x16:Completed 22199998 out of 59999992 steps (37%).
05:14:37:WU01:FS00:0x16:Completed 22799997 out of 59999992 steps (38%).
05:22:09:WU01:FS00:0x16:Completed 23399997 out of 59999992 steps (39%).
05:27:46:WU00:FS01:0xa4:Completed 1225000 out of 2500000 steps (49%)
05:29:27:WU01:FS00:0x16:Completed 23999997 out of 59999992 steps (40%).
05:36:51:WU01:FS00:0x16:Completed 24599997 out of 59999992 steps (41%).
05:44:11:WU01:FS00:0x16:Completed 25199997 out of 59999992 steps (42%).
05:51:40:WU01:FS00:0x16:Completed 25799997 out of 59999992 steps (43%).
05:52:46:WU00:FS01:0xa4:Completed 1250000 out of 2500000 steps (50%)
05:59:03:WU01:FS00:0x16:Completed 26399997 out of 59999992 steps (44%).
06:06:05:WU01:FS00:0x16:Completed 26999997 out of 59999992 steps (45%).
06:13:25:WU01:FS00:0x16:Completed 27599997 out of 59999992 steps (46%).
06:20:48:WU01:FS00:0x16:Completed 28199997 out of 59999992 steps (47%).
06:26:13:WU00:FS01:0xa4:Completed 1275000 out of 2500000 steps (51%)
06:28:55:WU01:FS00:0x16:Completed 28799997 out of 59999992 steps (48%).
06:35:48:WU01:FS00:0x16:Completed 29399997 out of 59999992 steps (49%).
06:43:29:WU01:FS00:0x16:Completed 29999996 out of 59999992 steps (50%).
06:50:48:WU01:FS00:0x16:Completed 30599996 out of 59999992 steps (51%).
06:59:27:WU01:FS00:0x16:Completed 31199996 out of 59999992 steps (52%).
07:00:26:WU00:FS01:0xa4:Completed 1300000 out of 2500000 steps (52%)
07:06:52:WU01:FS00:0x16:Completed 31799996 out of 59999992 steps (53%).
07:14:05:WU01:FS00:0x16:Completed 32399996 out of 59999992 steps (54%).
07:21:35:WU01:FS00:0x16:Completed 32999996 out of 59999992 steps (55%).
07:29:19:WU01:FS00:0x16:Completed 33599996 out of 59999992 steps (56%).
07:37:00:WU01:FS00:0x16:Completed 34199996 out of 59999992 steps (57%).
07:38:38:WU00:FS01:0xa4:Completed 1325000 out of 2500000 steps (53%)
07:44:05:WU01:FS00:0x16:Completed 34799996 out of 59999992 steps (58%).
07:51:11:WU01:FS00:0x16:Completed 35399996 out of 59999992 steps (59%).
07:58:43:WU01:FS00:0x16:Completed 35999996 out of 59999992 steps (60%).
08:05:57:WU01:FS00:0x16:Completed 36599996 out of 59999992 steps (61%).
08:13:54:WU01:FS00:0x16:Completed 37199996 out of 59999992 steps (62%).
08:15:57:WU00:FS01:0xa4:Completed 1350000 out of 2500000 steps (54%)
08:21:37:WU01:FS00:0x16:Completed 37799995 out of 59999992 steps (63%).
08:29:33:WU01:FS00:0x16:Completed 38399995 out of 59999992 steps (64%).
08:36:57:WU01:FS00:0x16:Completed 38999995 out of 59999992 steps (65%).
08:44:29:WU01:FS00:0x16:Completed 39599995 out of 59999992 steps (66%).
08:52:03:WU00:FS01:0xa4:Completed 1375000 out of 2500000 steps (55%)
08:52:06:WU01:FS00:0x16:Completed 40199995 out of 59999992 steps (67%).
09:00:12:WU01:FS00:0x16:Completed 40799995 out of 59999992 steps (68%).
09:07:36:WU01:FS00:0x16:Completed 41399995 out of 59999992 steps (69%).
******************************* Date: 2013-09-19 *******************************
09:14:53:WU01:FS00:0x16:Completed 41999995 out of 59999992 steps (70%).
09:21:57:WU00:FS01:0xa4:Completed 1400000 out of 2500000 steps (56%)
09:22:37:WU01:FS00:0x16:Completed 42599995 out of 59999992 steps (71%).
09:30:21:WU01:FS00:0x16:Completed 43199995 out of 59999992 steps (72%).
09:37:40:WU01:FS00:0x16:Completed 43799995 out of 59999992 steps (73%).
09:45:04:WU01:FS00:0x16:Completed 44399995 out of 59999992 steps (74%).
09:47:10:WU00:FS01:0xa4:Completed 1425000 out of 2500000 steps (57%)
09:52:25:WU01:FS00:0x16:Completed 44999994 out of 59999992 steps (75%).
10:00:07:WU01:FS00:0x16:Completed 45599994 out of 59999992 steps (76%).
10:07:45:WU01:FS00:0x16:Completed 46199994 out of 59999992 steps (77%).
10:12:21:WU00:FS01:0xa4:Completed 1450000 out of 2500000 steps (58%)
10:15:00:WU01:FS00:0x16:Completed 46799994 out of 59999992 steps (78%).
10:22:05:WU01:FS00:0x16:Completed 47399994 out of 59999992 steps (79%).
10:29:25:WU01:FS00:0x16:Completed 47999994 out of 59999992 steps (80%).
10:36:13:WU01:FS00:0x16:Completed 48599994 out of 59999992 steps (81%).
10:37:38:WU00:FS01:0xa4:Completed 1475000 out of 2500000 steps (59%)
10:43:24:WU01:FS00:0x16:Completed 49199994 out of 59999992 steps (82%).
10:50:19:WU01:FS00:0x16:Completed 49799994 out of 59999992 steps (83%).
10:57:31:WU01:FS00:0x16:Completed 50399994 out of 59999992 steps (84%).
11:02:45:WU00:FS01:0xa4:Completed 1500000 out of 2500000 steps (60%)
11:04:21:WU01:FS00:0x16:Completed 50999994 out of 59999992 steps (85%).
11:11:23:WU01:FS00:0x16:Completed 51599994 out of 59999992 steps (86%).
11:18:19:WU01:FS00:0x16:Completed 52199994 out of 59999992 steps (87%).
11:25:32:WU01:FS00:0x16:Completed 52799993 out of 59999992 steps (88%).
11:28:10:WU00:FS01:0xa4:Completed 1525000 out of 2500000 steps (61%)
11:32:51:WU01:FS00:0x16:Completed 53399993 out of 59999992 steps (89%).
11:39:57:WU01:FS00:0x16:Completed 53999993 out of 59999992 steps (90%).
11:47:29:WU01:FS00:0x16:Completed 54599993 out of 59999992 steps (91%).
11:53:10:WU00:FS01:0xa4:Completed 1550000 out of 2500000 steps (62%)
11:54:53:WU01:FS00:0x16:Completed 55199993 out of 59999992 steps (92%).
12:02:06:WU01:FS00:0x16:Completed 55799993 out of 59999992 steps (93%).
12:09:17:WU01:FS00:0x16:Completed 56399993 out of 59999992 steps (94%).
12:16:44:WU01:FS00:0x16:Completed 56999993 out of 59999992 steps (95%).
12:19:00:WU00:FS01:0xa4:Completed 1575000 out of 2500000 steps (63%)
12:24:06:WU01:FS00:0x16:Completed 57599993 out of 59999992 steps (96%).
12:31:46:WU01:FS00:0x16:Completed 58199993 out of 59999992 steps (97%).
12:39:05:WU01:FS00:0x16:Completed 58799993 out of 59999992 steps (98%).
12:43:56:WU00:FS01:0xa4:Completed 1600000 out of 2500000 steps (64%)
12:46:41:WU01:FS00:0x16:Completed 59399993 out of 59999992 steps (99%).
12:46:42:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:46:42:WU02:FS00:News: Welcome to Folding@Home
12:46:42:WU02:FS00:Assigned to work server 171.67.108.44
12:46:42:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti XT [Radeon HD 7970] from 171.67.108.44
12:46:42:WU02:FS00:Connecting to 171.67.108.44:8080
12:46:43:WU02:FS00:Downloading 44.55KiB
12:46:43:WU02:FS00:Download complete
12:46:43:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:0 clone:176 gen:46 core:0x16 unit:0x000000446652edbc4d9255c72846454d
12:54:02:WU01:FS00:0x16:Completed 59999992 out of 59999992 steps (100%).
12:54:02:WU01:FS00:0x16:Finished fah_main
12:54:02:WU01:FS00:0x16:Successful run
12:54:02:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
12:54:12:WU01:FS00:0x16:Reserved 2924912 bytes for xtc file; Cosm status=0
12:54:12:WU01:FS00:0x16:Allocated 2924912 bytes for xtc file
12:54:12:WU01:FS00:0x16:- Reading up to 2924912 from "01/wudata_01.xtc": Read 2924912
12:54:12:WU01:FS00:0x16:Read 2924912 bytes from xtc file; available packet space=783505552
12:54:12:WU01:FS00:0x16:xtc file hash check passed.
12:54:12:WU01:FS00:0x16:Reserved 75840 75840 783505552 bytes for arc file=<01/wudata_01.trr> Cosm status=0
12:54:12:WU01:FS00:0x16:Allocated 75840 bytes for arc file
12:54:12:WU01:FS00:0x16:- Reading up to 75840 from "01/wudata_01.trr": Read 75840
12:54:12:WU01:FS00:0x16:Read 75840 bytes from arc file; available packet space=783429712
12:54:12:WU01:FS00:0x16:trr file hash check passed.
12:54:12:WU01:FS00:0x16:Allocated 544 bytes for edr file
12:54:12:WU01:FS00:0x16:Read bedfile
12:54:12:WU01:FS00:0x16:edr file hash check passed.
12:54:12:WU01:FS00:0x16:Allocated 139172 bytes for logfile
12:54:12:WU01:FS00:0x16:Read logfile
12:54:12:WU01:FS00:0x16:GuardedRun: success in DynamicWrapper
12:54:12:WU01:FS00:0x16:GuardedRun: done
12:54:12:WU01:FS00:0x16:Run: GuardedRun completed.
12:54:15:WU01:FS00:0x16:+ Opened results file
12:54:15:WU01:FS00:0x16:- Writing 3140980 bytes of core data to disk...
12:54:16:WU01:FS00:0x16:Done: 3140468 -> 2957085 (compressed to 94.1 percent)
12:54:16:WU01:FS00:0x16: ... Done.
12:54:16:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
12:54:17:WU01:FS00:0x16:Shutting down core
12:54:17:WU01:FS00:0x16:Folding@home Core Shutdown: FINISHED_UNIT
12:54:20:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:54:20:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11292 run:12 clone:121 gen:2 core:0x16 unit:0x0000001a6652edbc4d62a43398c6ccad
12:54:20:WU01:FS00:Uploading 2.82MiB to 171.67.108.44
12:54:20:WU02:FS00:Starting
12:54:20:WU01:FS00:Connecting to 171.67.108.44:8080
12:54:20:WU02:FS00:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Al/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 5548 -checkpoint 15 -gpu 0 -gpu-vendor ati
12:54:20:WU02:FS00:Started FahCore on PID 9020
12:54:20:WU02:FS00:Core PID:8824
12:54:20:WU02:FS00:FahCore 0x16 started
12:54:21:WU02:FS00:0x16:
12:54:21:WU02:FS00:0x16:*------------------------------*
12:54:21:WU02:FS00:0x16:Folding@Home GPU Core
12:54:21:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
12:54:21:WU02:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
12:54:21:WU02:FS00:0x16:Build host: user-f6d030f24f
12:54:21:WU02:FS00:0x16:Board Type: AMD/OpenCL
12:54:21:WU02:FS00:0x16:Core : x=16
12:54:21:WU02:FS00:0x16: Window's signal control handler registered.
12:54:21:WU02:FS00:0x16:Preparing to commence simulation
12:54:21:WU02:FS00:0x16:- Looking at optimizations...
12:54:21:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
12:54:21:WU02:FS00:0x16:- Created dyn
12:54:21:WU02:FS00:0x16:- Files status OK
12:54:21:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
12:54:21:WU02:FS00:0x16:- Expanded 45112 -> 171163 (decompressed 379.4 percent)
12:54:21:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=45112 data_size=171163, decompressed_data_size=171163 diff=0
12:54:21:WU02:FS00:0x16:- Digital signature verified
12:54:21:WU02:FS00:0x16:Project: 11293 (Run 0, Clone 176, Gen 46)
12:54:21:WU02:FS00:0x16:Assembly optimizations on if available.
12:54:21:WU02:FS00:0x16:Entering M.D.
12:54:22:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr: 3673310347 168016736 1751743595 1990747502 4086805046
12:54:22:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
12:54:22:WU02:FS00:0x16:Client config unavailable.
12:54:23:WU02:FS00:0x16:Starting GUI Server
12:54:25:WU02:FS00:0x16:Setting checkpoint frequency: 500000
12:54:25:WU02:FS00:0x16:Completed 3 out of 50000000 steps (0%).
12:54:26:WU01:FS00:Upload 22.16%
12:54:32:WU01:FS00:Upload 46.53%
12:54:38:WU01:FS00:Upload 70.91%
12:54:44:WU01:FS00:Upload 97.50%
12:54:45:WU01:FS00:Upload complete
12:54:45:WU01:FS00:Server responded WORK_ACK (400)
12:54:45:WU01:FS00:Final credit estimate, 2224.00 points
12:54:45:WU01:FS00:Cleaning up
13:02:19:WU02:FS00:0x16:Completed 500000 out of 50000000 steps (1%).
13:07:50:WU00:FS01:0xa4:Completed 1625000 out of 2500000 steps (65%)
13:11:01:WU02:FS00:0x16:Completed 1000000 out of 50000000 steps (2%).
13:19:30:WU02:FS00:0x16:Completed 1500000 out of 50000000 steps (3%).
13:27:14:WU02:FS00:0x16:Completed 2000000 out of 50000000 steps (4%).
13:31:08:WU00:FS01:0xa4:Completed 1650000 out of 2500000 steps (66%)
13:35:32:WU02:FS00:0x16:Completed 2500000 out of 50000000 steps (5%).
13:44:05:WU02:FS00:0x16:Completed 3000000 out of 50000000 steps (6%).
13:52:25:WU02:FS00:0x16:Completed 3500000 out of 50000000 steps (7%).
13:54:07:WU00:FS01:0xa4:Completed 1675000 out of 2500000 steps (67%)
14:00:41:WU02:FS00:0x16:Completed 4000000 out of 50000000 steps (8%).
14:09:21:WU02:FS00:0x16:Completed 4500000 out of 50000000 steps (9%).
14:17:18:WU00:FS01:0xa4:Completed 1700000 out of 2500000 steps (68%)
14:17:33:WU02:FS00:0x16:Completed 5000000 out of 50000000 steps (10%).
14:26:13:WU02:FS00:0x16:Completed 5500000 out of 50000000 steps (11%).
14:33:37:WU02:FS00:0x16:Completed 6000000 out of 50000000 steps (12%).
14:40:47:WU00:FS01:0xa4:Completed 1725000 out of 2500000 steps (69%)
14:41:59:WU02:FS00:0x16:Completed 6500000 out of 50000000 steps (13%).
14:50:32:WU02:FS00:0x16:Completed 7000000 out of 50000000 steps (14%).
14:59:28:WU02:FS00:0x16:Completed 7500000 out of 50000000 steps (15%).
15:03:35:WU00:FS01:0xa4:Completed 1750000 out of 2500000 steps (70%)
15:08:04:WU02:FS00:0x16:Completed 8000000 out of 50000000 steps (16%).
15:16:53:WU02:FS00:0x16:Completed 8500000 out of 50000000 steps (17%).
15:26:42:WU02:FS00:0x16:Completed 9000000 out of 50000000 steps (18%).
15:29:10:WU00:FS01:0xa4:Completed 1775000 out of 2500000 steps (71%)
15:35:38:WU02:FS00:0x16:Completed 9500000 out of 50000000 steps (19%).
15:44:19:WU02:FS00:0x16:Completed 10000000 out of 50000000 steps (20%).
15:52:09:WU00:FS01:0xa4:Completed 1800000 out of 2500000 steps (72%)
15:52:52:WU02:FS00:0x16:Completed 10500000 out of 50000000 steps (21%).
16:01:42:WU02:FS00:0x16:Completed 11000000 out of 50000000 steps (22%).
16:10:16:WU02:FS00:0x16:Completed 11500000 out of 50000000 steps (23%).
16:15:37:WU00:FS01:0xa4:Completed 1825000 out of 2500000 steps (73%)
16:18:19:WU02:FS00:0x16:Completed 12000000 out of 50000000 steps (24%).
16:27:08:WU02:FS00:0x16:Completed 12500000 out of 50000000 steps (25%).
16:35:47:WU02:FS00:0x16:Completed 13000000 out of 50000000 steps (26%).
16:38:51:WU00:FS01:0xa4:Completed 1850000 out of 2500000 steps (74%)
16:44:36:WU02:FS00:0x16:Completed 13500000 out of 50000000 steps (27%).
16:53:07:WU02:FS00:0x16:Completed 14000000 out of 50000000 steps (28%).
17:01:42:WU02:FS00:0x16:Completed 14500000 out of 50000000 steps (29%).
17:02:02:WU00:FS01:0xa4:Completed 1875000 out of 2500000 steps (75%)
17:10:36:WU02:FS00:0x16:Completed 15000000 out of 50000000 steps (30%).
17:18:06:WU02:FS00:0x16:Completed 15500000 out of 50000000 steps (31%).
17:25:40:WU00:FS01:0xa4:Completed 1900000 out of 2500000 steps (76%)
17:26:43:WU02:FS00:0x16:Completed 16000000 out of 50000000 steps (32%).
17:35:46:WU02:FS00:0x16:Completed 16500000 out of 50000000 steps (33%).
17:44:52:WU02:FS00:0x16:Completed 17000000 out of 50000000 steps (34%).
17:48:28:WU00:FS01:0xa4:Completed 1925000 out of 2500000 steps (77%)
17:53:05:WU02:FS00:0x16:Completed 17500000 out of 50000000 steps (35%).
18:01:50:WU02:FS00:0x16:Completed 18000000 out of 50000000 steps (36%).
18:10:42:WU02:FS00:0x16:Completed 18500000 out of 50000000 steps (37%).
18:11:33:WU00:FS01:0xa4:Completed 1950000 out of 2500000 steps (78%)
18:19:38:WU02:FS00:0x16:Completed 19000000 out of 50000000 steps (38%).
18:28:17:WU02:FS00:0x16:Completed 19500000 out of 50000000 steps (39%).
18:34:29:WU00:FS01:0xa4:Completed 1975000 out of 2500000 steps (79%)
18:37:19:WU02:FS00:0x16:Completed 20000000 out of 50000000 steps (40%).
18:45:36:WU02:FS00:0x16:Completed 20500000 out of 50000000 steps (41%).
18:54:14:WU02:FS00:0x16:Completed 21000000 out of 50000000 steps (42%).
18:57:30:WU00:FS01:0xa4:Completed 2000000 out of 2500000 steps (80%)
19:02:28:WU02:FS00:0x16:Completed 21500000 out of 50000000 steps (43%).
19:11:14:WU02:FS00:0x16:Completed 22000000 out of 50000000 steps (44%).
19:19:23:WU02:FS00:0x16:Completed 22500000 out of 50000000 steps (45%).
19:20:55:WU00:FS01:0xa4:Completed 2025000 out of 2500000 steps (81%)
19:28:26:WU02:FS00:0x16:Completed 23000000 out of 50000000 steps (46%).
19:36:37:WU02:FS00:0x16:Completed 23500000 out of 50000000 steps (47%).
19:44:11:WU00:FS01:0xa4:Completed 2050000 out of 2500000 steps (82%)
19:44:58:WU02:FS00:0x16:Completed 24000000 out of 50000000 steps (48%).
19:53:12:WU02:FS00:0x16:Completed 24500000 out of 50000000 steps (49%).
20:00:37:WU02:FS00:0x16:Completed 25000000 out of 50000000 steps (50%).
20:07:41:WU00:FS01:0xa4:Completed 2075000 out of 2500000 steps (83%)
20:08:25:WU02:FS00:0x16:Completed 25500000 out of 50000000 steps (51%).
20:16:53:WU02:FS00:0x16:Completed 26000000 out of 50000000 steps (52%).
20:23:42:WU02:FS00:0x16:Completed 26500000 out of 50000000 steps (53%).
20:31:27:WU00:FS01:0xa4:Completed 2100000 out of 2500000 steps (84%)
20:31:55:WU02:FS00:0x16:Completed 27000000 out of 50000000 steps (54%).
20:39:30:WU02:FS00:0x16:Completed 27500000 out of 50000000 steps (55%).
20:47:34:WU02:FS00:0x16:Completed 28000000 out of 50000000 steps (56%).
20:54:56:WU00:FS01:0xa4:Completed 2125000 out of 2500000 steps (85%)
20:55:44:WU02:FS00:0x16:Completed 28500000 out of 50000000 steps (57%).
21:04:01:WU02:FS00:0x16:Completed 29000000 out of 50000000 steps (58%).
21:12:21:WU02:FS00:0x16:Completed 29500000 out of 50000000 steps (59%).
21:17:48:WU00:FS01:0xa4:Completed 2150000 out of 2500000 steps (86%)
21:20:39:WU02:FS00:0x16:Completed 30000000 out of 50000000 steps (60%).
21:28:39:WU02:FS00:0x16:Completed 30500000 out of 50000000 steps (61%).
21:37:09:WU02:FS00:0x16:Completed 31000000 out of 50000000 steps (62%).
21:40:59:WU00:FS01:0xa4:Completed 2175000 out of 2500000 steps (87%)
21:44:51:WU02:FS00:0x16:Completed 31500000 out of 50000000 steps (63%).
21:53:14:WU02:FS00:0x16:Completed 32000000 out of 50000000 steps (64%).
22:01:39:WU02:FS00:0x16:Completed 32500000 out of 50000000 steps (65%).
22:04:04:WU00:FS01:0xa4:Completed 2200000 out of 2500000 steps (88%)
22:10:11:WU02:FS00:0x16:Completed 33000000 out of 50000000 steps (66%).
22:19:00:WU02:FS00:0x16:Completed 33500000 out of 50000000 steps (67%).
22:26:45:WU02:FS00:0x16:Completed 34000000 out of 50000000 steps (68%).
22:27:26:WU00:FS01:0xa4:Completed 2225000 out of 2500000 steps (89%)
22:35:18:WU02:FS00:0x16:Completed 34500000 out of 50000000 steps (69%).
22:43:39:WU02:FS00:0x16:Completed 35000000 out of 50000000 steps (70%).
22:50:36:WU00:FS01:0xa4:Completed 2250000 out of 2500000 steps (90%)
22:52:04:WU02:FS00:0x16:Completed 35500000 out of 50000000 steps (71%).
23:00:05:WU02:FS00:0x16:Completed 36000000 out of 50000000 steps (72%).
23:08:38:WU02:FS00:0x16:Completed 36500000 out of 50000000 steps (73%).
23:14:00:WU00:FS01:0xa4:Completed 2275000 out of 2500000 steps (91%)
23:17:08:WU02:FS00:0x16:Completed 37000000 out of 50000000 steps (74%).
23:25:48:WU02:FS00:0x16:Completed 37500000 out of 50000000 steps (75%).
23:34:21:WU02:FS00:0x16:Completed 38000000 out of 50000000 steps (76%).
23:37:02:WU00:FS01:0xa4:Completed 2300000 out of 2500000 steps (92%)
23:42:53:WU02:FS00:0x16:Completed 38500000 out of 50000000 steps (77%).
23:51:15:WU02:FS00:0x16:Completed 39000000 out of 50000000 steps (78%).
23:59:26:WU02:FS00:0x16:Completed 39500000 out of 50000000 steps (79%).
00:00:29:WU00:FS01:0xa4:Completed 2325000 out of 2500000 steps (93%)
00:08:11:WU02:FS00:0x16:Completed 40000000 out of 50000000 steps (80%).
00:16:40:WU02:FS00:0x16:Completed 40500000 out of 50000000 steps (81%).
00:23:59:WU00:FS01:0xa4:Completed 2350000 out of 2500000 steps (94%)
00:25:08:WU02:FS00:0x16:Completed 41000000 out of 50000000 steps (82%).
00:33:43:WU02:FS00:0x16:Completed 41500000 out of 50000000 steps (83%).
00:42:15:WU02:FS00:0x16:Completed 42000000 out of 50000000 steps (84%).
