Radeon HD7770
Radeon HD7770
I know this thread is a year old, but my 7770 is making no progress although it says it is running. Can anyone help with this or should this be posted elsewhere?
Mod edit: Moved post to more appropriate forum
Re: Radeon HD7770
Welcome to the forum.
First, could you post your folding log file? Please include the beginning section with version and system information as well as the folding configuration. Also, what version of the Catalyst drivers do you have installed on the system.
One other thing to mention, the default settings of version 7.3.6 of F@H only uses the GPU for folding when the system is idle. With Windows that would be either when the FAH screensaver activates or when the system shuts down the screen. Putting the slider to Full will start GPU folding even when the system is not idle, but you may experience some lag in displaying other events on the screen.
Re: Radeon HD7770
Thanks for the reply.
I am using FAH version 7.3.6 and the slider is always on "full".
I can't figure out how to post a screen shot
so...
The log file:
********************** Log Started 2013-09-12T20:15:51Z ***********************
20:15:52:WU00:FS00:Starting
20:15:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI ... ore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 2492 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:15:52:WU00:FS00:Started FahCore on PID 3056
20:15:52:WU00:FS00:Core PID:1236
20:15:52:WU00:FS00:FahCore 0x16 started
20:15:52:WU00:FS00:0x16:
20:15:52:WU00:FS00:0x16:*------------------------------*
20:15:52:WU00:FS00:0x16:Folding@Home GPU Core
20:15:52:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
20:15:52:WU00:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
20:15:52:WU00:FS00:0x16:Build host: user-f6d030f24f
20:15:52:WU00:FS00:0x16:Board Type: AMD/OpenCL
20:15:52:WU00:FS00:0x16:Core : x=16
20:15:52:WU00:FS00:0x16: Window's signal control handler registered.
20:15:52:WU00:FS00:0x16:Preparing to commence simulation
20:15:52:WU00:FS00:0x16:- Ensuring status. Please wait.
20:16:01:WU00:FS00:0x16:- Looking at optimizations...
20:16:01:WU00:FS00:0x16:- Working with standard loops on this execution.
20:16:01:WU00:FS00:0x16:- Previous termination of core was improper.
20:16:01:WU00:FS00:0x16:- Files status OK
20:16:01:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:16:01:WU00:FS00:0x16:- Expanded 44817 -> 171163 (decompressed 381.9 percent)
20:16:01:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=44817 data_size=171163, decompressed_data_size=171163 diff=0
20:16:01:WU00:FS00:0x16:- Digital signature verified
20:16:01:WU00:FS00:0x16:Project: 11292 (Run 11, Clone 116, Gen 8)
20:16:01:WU00:FS00:0x16:Entering M.D.
20:16:03:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr: 3967943916 2644945059 343900979 820153727 2131957849
20:16:03:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
20:16:03:WU00:FS00:0x16:Client config unavailable.
20:16:04:WU00:FS00:0x16:Starting GUI
the Catalyst driver version is:
12.104-130328a-159787C-ATI
Thanks for your time!
The log file:
Re: Radeon HD7770
That appears to be catalyst v13.4, which is new enough to be supported by fah.
What does the log say after this...
Please also post the info from the *** System *** section.
Re: Radeon HD7770
The log has nothing else in it.
I can't copy/paste from the "system, info"tab and don't know how to post a screen shot.
Re: Radeon HD7770
Have a look at this post to see how to get the log in FAHControl to show your System Info and Config areas.
Re: Radeon HD7770
Just above the log file there are some check boxe filters: "slot", "unit" "warning and errors"
I had the "slot" box checked to see just slot 00, my GPU. When I unchecked it I got what you wanted. I thought you meant the TABS above that: "status" "system info" and "log"
I was referring to this "system info" tab when I said I can't cut/paste from it.
Anyway, my log with requested info:
*********************** Log Started 2013-09-12T20:15:51Z ***********************
20:15:51:************************* Folding@home Client *************************
20:15:51: Website: http://folding.stanford.edu/
20:15:51: Copyright: (c) 2009-2013 Stanford University
20:15:51: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:15:51: Args:
20:15:51: Config: C:/ProgramData/FAHClient/config.xml
20:15:51:******************************** Build ********************************
20:15:51: Version: 7.3.6
20:15:51: Date: Feb 18 2013
20:15:51: Time: 15:25:17
20:15:51: SVN Rev: 3923
20:15:51: Branch: fah/trunk/client
20:15:51: Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:15:51: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:15:51: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:15:51: Platform: win32 XP
20:15:51: Bits: 32
20:15:51: Mode: Release
20:15:51:******************************* System ********************************
20:15:51: CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
20:15:51: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
20:15:51: CPUs: 8
20:15:51: Memory: 15.89GiB
20:15:51: Free Memory: 14.70GiB
20:15:51: Threads: WINDOWS_THREADS
20:15:51: Has Battery: false
20:15:51: On Battery: false
20:15:51: UTC offset: -4
20:15:51: PID: 2492
20:15:51: CWD: C:/ProgramData/FAHClient
20:15:51: OS: Windows 7 Professional
20:15:51: OS Arch: AMD64
20:15:51: GPUs: 1
20:15:51: GPU 0: ATI:5 R575A [AMD Radeon HD7700 Series]
20:15:51: CUDA: Not detected
20:15:51:Win32 Service: false
20:15:51:***********************************************************************
20:15:51:<config>
20:15:51: <!-- Folding Slot Configuration -->
20:15:51: <power v='full'/>
20:15:51:
20:15:51: <!-- Network -->
20:15:51: <proxy v=':8080'/>
20:15:51:
20:15:51: <!-- User Information -->
20:15:51: <passkey v='********************************'/>
20:15:51: <team v='12772'/>
20:15:51: <user v='ivangela'/>
20:15:51:
20:15:51: <!-- Folding Slots -->
20:15:51: <slot id='1' type='CPU'>
20:15:51: <cpus v='-1'/>
20:15:51: </slot>
20:15:51: <slot id='0' type='GPU'/>
20:15:51:</config>
20:15:51:Trying to access database...
20:15:52:Successfully acquired database lock
20:15:52:Enabled folding slot
20:15:52:ERROR:Exception: Option 'gpu-index' has no default and is not set.
20:15:52:Enabled folding slot 00: READY gpu:0:R575A [AMD Radeon HD7700 Series]
20:15:52:WARNING:WU01:Slot ID 1 no longer exists and there are no other matching slots, dumping
20:15:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 2492 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:15:52:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:8567 run:1 clone:0 gen:7 core:0xa3 unit:0x000000550a3b1e5952278a04c93146ee
20:15:52:WU01:FS01:Connecting to 128.143.231.202:8080
20:15:52:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:15:53:WARNING:WU01:FS01:Exception: Failed to send results to work server: Failed to connect to 128.143.231.202:80: A socket operation was attempted to an unreachable network.
20:15:53:WU01:FS01:Trying to send results to collection server
20:15:53:WU01:FS01:Connecting to 128.143.199.97:8080
20:15:53:WARNING:WU01:FS01:WorkServer connection failed on port 8080 trying 80
20:15:53:ERROR:WU01:FS01:Exception: Failed to connect to 128.143.199.97:80: A socket operation was attempted to an unreachable network.
20:15:53:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:8567 run:1 clone:0 gen:7 core:0xa3 unit:0x000000550a3b1e5952278a04c93146ee
20:15:53:WU01:Connecting to 128.143.231.202:8080
20:15:53:WARNING:WU01:WorkServer connection failed on port 8080 trying 80
20:15:53:WARNING:WU01:Exception: Failed to send results to work server: Failed to connect to 128.143.231.202:80: A socket operation was attempted to an unreachable network.
20:15:53:WU01:Trying to send results to collection server
20:15:53:WU01:Connecting to 128.143.199.97:8080
20:15:54:ERROR:WU01:Exception: Failed to connect to 128.143.199.97:80: A socket operation was attempted to an unreachable network.
20:16:04:WU00:FS00:0x16:Starting GUI Server
20:16:53:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:8567 run:1 clone:0 gen:7 core:0xa3 unit:0x000000550a3b1e5952278a04c93146ee
20:16:53:WU01:Connecting to 128.143.231.202:8080
20:16:53:WARNING:WU01:WorkServer connection failed on port 8080 trying 80
20:16:53:WARNING:WU01:Exception: Failed to send results to work server: Failed to connect to 128.143.231.202:80: A socket operation was attempted to an unreachable host.
20:16:53:WU01:Trying to send results to collection server
20:16:53:WU01:Connecting to 128.143.199.97:8080
20:16:53:ERROR:WU01:Exception: Failed to connect to 128.143.199.97:80: A socket operation was attempted to an unreachable host.
20:18:31:WU01:Sending unit results: id:01 state:SEND error:DUMPED project:8567 run:1 clone:0 gen:7 core:0xa3 unit:0x000000550a3b1e5952278a04c93146ee
20:18:31:WU01:Connecting to 128.143.231.202:8080
20:18:31:WU01:Server responded WORK_ACK (400)
20:18:31:WU01:Cleaning up
20:19:17:Adding folding slot 01: READY cpu:7
20:19:17:Removing old file 'configs/config-20130825-204035.xml'
20:19:17:Saving configuration to config.xml
20:19:17:<config>
20:19:17: <!-- Folding Slot Configuration -->
20:19:17: <power v='full'/>
20:19:17:
20:19:17: <!-- Network -->
20:19:17: <proxy v=':8080'/>
20:19:17:
20:19:17: <!-- User Information -->
20:19:17: <passkey v='********************************'/>
20:19:17: <team v='12772'/>
20:19:17: <user v='ivangela'/>
20:19:17:
20:19:17: <!-- Folding Slots -->
20:19:17: <slot id='0' type='GPU'/>
20:19:17: <slot id='1' type='CPU'>
20:19:17: <cpus v='-1'/>
20:19:17: </slot>
20:19:17:</config>
20:19:17:WU01:FS01:Connecting to assign3.stanford.edu:8080
20:19:18:WU01:FS01:News: Welcome to Folding@Home
20:19:18:WU01:FS01:Assigned to work server 128.143.231.202
20:19:18:WU01:FS01:Requesting new work unit for slot 01: READY cpu:7 from 128.143.231.202
20:19:18:WU01:FS01:Connecting to 128.143.231.202:8080
20:19:19:WU01:FS01:Downloading 3.64MiB
20:19:25:WU01:FS01:Download 77.34%
20:19:26:WU01:FS01:Download complete
20:19:26:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:6098 run:8 clone:17 gen:493 core:0xa3 unit:0x0000026c0a3b1e594e91df80aca48cb1
20:19:26:WU01:FS01:Starting
20:19:26:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 01 -suffix 01 -version 703 -lifeline 2492 -checkpoint 15 -np 7
20:19:26:WU01:FS01:Started FahCore on PID 3348
20:19:26:WU01:FS01:Core PID:2148
20:19:26:WU01:FS01:FahCore 0xa3 started
20:19:27:WU01:FS01:0xa3:
20:19:27:WU01:FS01:0xa3:*------------------------------*
20:19:27:WU01:FS01:0xa3:Folding@Home Gromacs SMP Core
20:19:27:WU01:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
20:19:27:WU01:FS01:0xa3:Preparing to commence simulation
20:19:27:WU01:FS01:0xa3:- Looking at optimizations...
20:19:27:WU01:FS01:0xa3:- Created dyn
20:19:27:WU01:FS01:0xa3:- Files status OK
20:19:27:WU01:FS01:0xa3:- Expanded 3812688 -> 4136808 (decompressed 108.5 percent)
20:19:27:WU01:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3812688 data_size=4136808, decompressed_data_size=4136808 diff=0
20:19:27:WU01:FS01:0xa3:- Digital signature verified
20:19:27:WU01:FS01:0xa3:Project: 6098 (Run 8, Clone 17, Gen 493)
20:19:27:WU01:FS01:0xa3:Assembly optimizations on if available.
20:19:27:WU01:FS01:0xa3:Entering M.D.
20:19:33:WU01:FS01:0xa3:Mapping NT from 7 to 7
20:19:33:WU01:FS01:0xa3:Completed 0 out of 500000 steps (0%)
20:28:55:WU01:FS01:0xa3:Completed 5000 out of 500000 steps (1%)
20:38:02:WU01:FS01:0xa3:Completed 10000 out of 500000 steps (2%)
20:46:59:WU01:FS01:0xa3:Completed 15000 out of 500000 steps (3%)
20:55:45:WU01:FS01:0xa3:Completed 20000 out of 500000 steps (4%)
21:04:32:WU01:FS01:0xa3:Completed 25000 out of 500000 steps (5%)
21:13:21:WU01:FS01:0xa3:Completed 30000 out of 500000 steps (6%)
21:22:08:WU01:FS01:0xa3:Completed 35000 out of 500000 steps (7%)
21:30:54:WU01:FS01:0xa3:Completed 40000 out of 500000 steps (8%)
21:39:38:WU01:FS01:0xa3:Completed 45000 out of 500000 steps (9%)
21:48:31:WU01:FS01:0xa3:Completed 50000 out of 500000 steps (10%)
21:57:09:WU01:FS01:0xa3:Completed 55000 out of 500000 steps (11%)
22:05:45:WU01:FS01:0xa3:Completed 60000 out of 500000 steps (12%)
22:14:20:WU01:FS01:0xa3:Completed 65000 out of 500000 steps (13%)
22:22:59:WU01:FS01:0xa3:Completed 70000 out of 500000 steps (14%)
22:31:36:WU01:FS01:0xa3:Completed 75000 out of 500000 steps (15%)
22:40:12:WU01:FS01:0xa3:Completed 80000 out of 500000 steps (16%)
22:48:49:WU01:FS01:0xa3:Completed 85000 out of 500000 steps (17%)
22:57:27:WU01:FS01:0xa3:Completed 90000 out of 500000 steps (18%)
23:06:05:WU01:FS01:0xa3:Completed 95000 out of 500000 steps (19%)
23:14:44:WU01:FS01:0xa3:Completed 100000 out of 500000 steps (20%)
23:23:21:WU01:FS01:0xa3:Completed 105000 out of 500000 steps (21%)
23:32:02:WU01:FS01:0xa3:Completed 110000 out of 500000 steps (22%)
23:40:39:WU01:FS01:0xa3:Completed 115000 out of 500000 steps (23%)
23:49:18:WU01:FS01:0xa3:Completed 120000 out of 500000 steps (24%)
23:57:57:WU01:FS01:0xa3:Completed 125000 out of 500000 steps (25%)
00:06:35:WU01:FS01:0xa3:Completed 130000 out of 500000 steps (26%)
00:15:19:WU01:FS01:0xa3:Completed 135000 out of 500000 steps (27%)
00:24:42:WU01:FS01:0xa3:Completed 140000 out of 500000 steps (28%)-
Re: Radeon HD7770
The latest version of Catalyst known to work well with Core_16 GPU projects is 12.8. Persons have managed to get newer versions to work by using custom installs of the newer driver and using the older OpenCL support from 12.8. There are discussions of that in the forum for Problems with AMD / ATI Drivers. Without the custom install, some versions later than 12.8 have been reported to run slowly using only a fraction of the GPU power or not work at all.
An alternative to processing Core_16 WU's is to add the parameter client-type advanced to your GPU folding slot. This may get you some recently moved from beta status Core_17 WU's. There are only a few projects so far using that core so far, and they also are requested by systems with nVidia cards, so using the advanced setting is no guarantee of getting Core_17 WU's. But they usually work better with the newer Catalyst driver installation.
Re: Radeon HD7770
@Joe: So you think this is an AMD driver issue and if I rolled back my drivers to 12.8 it would work?
I don't know how to do any of the other stuff involving custom installs and modifying OpenCL, but I might be able to figure out a driver rollback, lol
Thanks
Thanks
P5-133XL
Machine #2:
Machine 3:
Re: Radeon HD7770
To save a lot of heartache before rolling back your drivers, use a driver cleaner before installing the new older driver. Many people before you have had problems GPU folding when they didn't. Without the driver cleaner, you end up with mixed file versions typically messing up OpenCL which is required for folding with AMD GPU's.
Re: Radeon HD7770
The other thing to watch is the minimum version of Catalyst required for your GPU. As a more recent model, the HD 7770 may require a newer version than 12.8.
Re: Radeon HD7770
20:15:52:WU00:FS00:StartingI also notice that slot 0 is after slot 1 in the configuration. That's unusual but shouldn't cause any errors unless you try to fix it.
Re: Radeon HD7770
@ Joe, I'm not sure what the minimum version of Catalyst is, but I'll see what I can dredge up.
@ Bruce, I have uninstalled and installed the GPU slot numerous times. Before I plan on doing the driver "update", I will actually uninstall and then reinstall FAH.
On that note, I was once able to get the GPU to fold by going under the configure tab>>advanced>>clicking :disable highly optimized code" and clicking "try to lock cores to a specific CPU"
It worked for one work unit then the CPU also wouldn't download a WU, so I got rid of that.
The other option I thought of is on my HTPC I have an older version of FAH that has no problems folding the GPU but that's an Nvidea card.
Re: Radeon HD7770
The setting for optimized code is essentially non-functional. It only applies to FahCore_78 so it doesn't matter what you set it to.
I've heard recently that locking cores to a specific CPU doesn't work either but it's certain that any changes it might make will be minimal.
Neither of these settings have anything to do with the assignment of new WUs. That leaves "we don't know" as the only logical explanation for the troubles you had downloading a new WU.
Re: Radeon HD7770
OK, so I uninstalled my CCC.
I reinstalled Catalyst version 12.8
I then unistalled FAH and reinstalled it hoping it would autodetect my GPU but it detected 2 CPUs instead, so I deleted slot 01 and added my GPU while only allowing the CPU 7 threads, leaving one for GPU.
It started folding and then said FAILED.
I deleted the slot and re-added it again and it started folding then FAILED again!
Attached is the log:
Mod edit: Added Code tags for you, please read this posting on how to post a log.
23:45:02:Adding folding slot 01: READY gpu:0:R575A [AMD Radeon HD7700 Series]
23:45:02:FS00:Shutting core down
23:45:02:Saving configuration to config.xml
23:45:02:<config>
23:45:02: <!-- Folding Core -->
23:45:02: <checkpoint v='30'/>
23:45:02:
23:45:02: <!-- Folding Slot Configuration -->
23:45:02: <power v='full'/>
23:45:02:
23:45:02: <!-- Network -->
23:45:02: <proxy v=':8080'/>
23:45:02:
23:45:02: <!-- User Information -->
23:45:02: <passkey v='********************************'/>
23:45:02: <team v='12772'/>
23:45:02: <user v='ivangela'/>
23:45:02:
23:45:02: <!-- Folding Slots -->
23:45:02: <slot id='0' type='CPU'/>
23:45:02: <slot id='1' type='GPU'/>
23:45:02:</config>
23:45:02:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
23:45:03:WU02:FS01:News: Welcome to Folding@Home
23:45:03:WU02:FS01:Assigned to work server 171.67.108.44
23:45:03:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:R575A [AMD Radeon HD7700 Series] from 171.67.108.44
23:45:03:WU02:FS01:Connecting to 171.67.108.44:8080
23:45:03:WU02:FS01:Downloading 44.31KiB
23:45:04:WU02:FS01:Download complete
23:45:04:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11292 run:15 clone:132 gen:19 core:0x16 unit:0x0000003a6652edbc4d62a445920156a9
23:45:04:WU02:FS01:Starting
23:45:04:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Pinsky Inc/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe" -dir 02 -suffix 01 -version 703 -lifeline 1084 -checkpoint 30 -gpu 0 -gpu-vendor ati
23:45:04:WU02:FS01:Started FahCore on PID 1908
23:45:04:WU02:FS01:Core PID:2464
23:45:04:WU02:FS01:FahCore 0x16 started
23:45:04:WU02:FS01:0x16:
23:45:04:WU02:FS01:0x16:*------------------------------*
23:45:04:WU02:FS01:0x16:Folding@Home GPU Core
23:45:04:WU02:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
23:45:04:WU02:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
23:45:04:WU02:FS01:0x16:Build host: user-f6d030f24f
23:45:04:WU02:FS01:0x16:Board Type: AMD/OpenCL
23:45:04:WU02:FS01:0x16:Core : x=16
23:45:04:WU02:FS01:0x16: Window's signal control handler registered.
23:45:04:WU02:FS01:0x16:Preparing to commence simulation
23:45:04:WU02:FS01:0x16:- Looking at optimizations...
23:45:04:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:45:04:WU02:FS01:0x16:- Created dyn
23:45:04:WU02:FS01:0x16:- Files status OK
23:45:04:WU02:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:45:04:WU02:FS01:0x16:- Expanded 44864 -> 171163 (decompressed 381.5 percent)
23:45:04:WU02:FS01:0x16:Called DecompressByteArray: compressed_data_size=44864 data_size=171163, decompressed_data_size=171163 diff=0
23:45:04:WU02:FS01:0x16:- Digital signature verified
23:45:04:WU02:FS01:0x16:Project: 11292 (Run 15, Clone 132, Gen 19)
23:45:04:WU02:FS01:0x16:Assembly optimizations on if available.
23:45:04:WU02:FS01:0x16:Entering M.D.
23:45:06:WU02:FS01:0x16:Tpr hash 02/wudata_01.tpr: 2207043755 316921312 3346864564 3364213212 2123555125
23:45:06:WU02:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
23:45:06:WU02:FS01:0x16:Client config unavailable.
23:45:06:WU02:FS01:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
23:45:06:WU02:FS01:0x16:Going to send back what have done -- stepsTotalG=0
23:45:06:WU02:FS01:0x16:Work fraction=0.0000 steps=0.
23:45:06:WU02:FS01:0x16:Starting GUI Server
23:45:10:WU02:FS01:0x16:logfile size=7229 infoLength=7229 edr=0 trr=23
23:45:10:WU02:FS01:0x16:+ Opened results file
23:45:10:WU02:FS01:0x16:- Writing 7765 bytes of core data to disk...
23:45:10:WU02:FS01:0x16:Done: 7253 -> 2512 (compressed to 34.6 percent)
23:45:10:WU02:FS01:0x16: ... Done.
23:45:10:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:45:10:WU02:FS01:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
23:45:10:WARNING:WU02:FS01:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
23:45:10:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11292 run:15 clone:132 gen:19 core:0x16 unit:0x0000003a6652edbc4d62a445920156a9
23:45:10:WU02:FS01:Uploading 2.95KiB to 171.67.108.44
23:45:10:WU02:FS01:Connecting to 171.67.108.44:8080
23:45:10:WU00:FS00:Starting
23:45:10:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Pinsky Inc/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 703 -lifeline 1084 -checkpoint 30 -np 7
23:45:10:WU00:FS00:Started FahCore on PID 2064
23:45:10:WU00:FS00:Core PID:2860
23:45:10:WU00:FS00:FahCore 0xa3 started
23:45:10:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:45:10:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
23:45:10:WU02:FS01:Upload complete
23:45:10:WU02:FS01:Server responded WORK_ACK (400)
23:45:10:WU02:FS01:Cleaning up
23:45:11:WU00:FS00:0xa3:
23:45:11:WU00:FS00:0xa3:*------------------------------*
23:45:11:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
23:45:11:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
23:45:11:WU00:FS00:0xa3:Preparing to commence simulation
23:45:11:WU00:FS00:0xa3:- Looking at optimizations...
23:45:11:WU00:FS00:0xa3:- Files status OK
23:45:11:WU00:FS00:0xa3:- Expanded 3846061 -> 4375408 (decompressed 113.7 percent)
23:45:11:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3846061 data_size=4375408, decompressed_data_size=4375408 diff=0
23:45:11:WU00:FS00:0xa3:- Digital signature verified
23:45:11:WU00:FS00:0xa3:Project: 8579 (Run 0, Clone 9, Gen 211)
23:45:11:WU00:FS00:0xa3:Assembly optimizations on if available.
23:45:11:WU00:FS00:0xa3:Entering M.D.
23:45:11:WU03:FS01:News: Welcome to Folding@Home
23:45:11:WU03:FS01:Assigned to work server 171.67.108.44
23:45:11:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:R575A [AMD Radeon HD7700 Series] from 171.67.108.44
23:45:11:WU03:FS01:Connecting to 171.67.108.44:8080
23:45:11:WU03:FS01:Downloading 44.44KiB
23:45:12:WU03:FS01:Download complete
23:45:12:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11293 run:10 clone:85 gen:46 core:0x16 unit:0x000000456652edbc4d9257c36e70cef1
23:45:12:WU03:FS01:Starting
23:45:12:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Pinsky Inc/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe" -dir 03 -suffix 01 -version 703 -lifeline 1084 -checkpoint 30 -gpu 0 -gpu-vendor ati
23:45:12:WU03:FS01:Started FahCore on PID 3980
23:45:12:WU03:FS01:Core PID:2468
23:45:12:WU03:FS01:FahCore 0x16 started
23:45:12:WU03:FS01:0x16:
23:45:12:WU03:FS01:0x16:*------------------------------*
23:45:12:WU03:FS01:0x16:Folding@Home GPU Core
23:45:12:WU03:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
23:45:12:WU03:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
23:45:12:WU03:FS01:0x16:Build host: user-f6d030f24f
23:45:12:WU03:FS01:0x16:Board Type: AMD/OpenCL
23:45:12:WU03:FS01:0x16:Core : x=16
23:45:12:WU03:FS01:0x16: Window's signal control handler registered.
23:45:12:WU03:FS01:0x16:Preparing to commence simulation
23:45:12:WU03:FS01:0x16:- Looking at optimizations...
23:45:12:WU03:FS01:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
23:45:12:WU03:FS01:0x16:- Created dyn
23:45:12:WU03:FS01:0x16:- Files status OK
23:45:12:WU03:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:45:12:WU03:FS01:0x16:- Expanded 44996 -> 171163 (decompressed 380.3 percent)
23:45:12:WU03:FS01:0x16:Called DecompressByteArray: compressed_data_size=44996 data_size=171163, decompressed_data_size=171163 diff=0
23:45:12:WU03:FS01:0x16:- Digital signature verified
23:45:12:WU03:FS01:0x16:Project: 11293 (Run 10, Clone 85, Gen 46)
23:45:12:WU03:FS01:0x16:Assembly optimizations on if available.
23:45:12:WU03:FS01:0x16:Entering M.D.
23:45:14:WU03:FS01:0x16:Tpr hash 03/wudata_01.tpr: 2150590678 161986115 803704064 1948300495 3461268692
23:45:14:WU03:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
23:45:14:WU03:FS01:0x16:Client config unavailable.
23:45:14:WU03:FS01:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
23:45:14:WU03:FS01:0x16:Going to send back what have done -- stepsTotalG=0
23:45:14:WU03:FS01:0x16:Work fraction=0.0000 steps=0.
23:45:14:WU03:FS01:0x16:Starting GUI Server
23:45:17:WU00:FS00:0xa3:Mapping NT from 7 to 7
23:45:17:WU00:FS00:0xa3:Completed 0 out of 500000 steps (0%)
23:45:18:WU03:FS01:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
23:45:18:WU03:FS01:0x16:+ Opened results file
23:45:18:WU03:FS01:0x16:- Writing 7757 bytes of core data to disk...
23:45:18:WU03:FS01:0x16:Done: 7245 -> 2511 (compressed to 34.6 percent)
23:45:18:WU03:FS01:0x16: ... Done.
23:45:18:WU03:FS01:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
23:45:18:WU03:FS01:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
23:45:18:WARNING:WU03:FS01:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
23:45:18:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:11293 run:10 clone:85 gen:46 core:0x16 unit:0x000000456652edbc4d9257c36e70cef1
23:45:18:WU03:FS01:Uploading 2.95KiB to 171.67.108.44
23:45:18:WU03:FS01:Connecting to 171.67.108.44:8080
23:45:19:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
23:45:19:WU03:FS01:Upload complete
23:45:19:WU03:FS01:Server responded WORK_ACK (400)
23:45:19:WU03:FS01:Cleaning up
23:45:19:WU02:FS01:News: Welcome to Folding@Home
23:45:19:WU02:FS01:Assigned to work server 171.67.108.44
23:45:19:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:R575A [AMD Radeon HD7700 Series] from 171.67.108.44
23:45:19:WU02:FS01:Connecting to 171.67.108.44:8080
23:45:20:WU02:FS01:Downloading 44.67KiB
23:45:20:WU02:FS01:Download complete
23:45:20:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:11 clone:85 gen:46 core:0x16 unit:0x000000466652edbc4d9257faa48dd9c8
23:45:20:WU02:FS01:Starting
23:45:20:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Pinsky Inc/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe" -dir 02 -suffix 01 -version 703 -lifeline 1084 -checkpoint 30 -gpu 0 -gpu-vendor ati
23:45:20:WU02:FS01:Started FahCore on PID 2280
23:45:20:WU02:FS01:Core PID:3252
23:45:20:WU02:FS01:FahCore 0x16 started
23:45:21:WU02:FS01:0x16:
23:45:21:WU02:FS01:0x16:*------------------------------*
23:45:21:WU02:FS01:0x16:Folding@Home GPU Core
23:45:21:WU02:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
23:45:21:WU02:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
23:45:21:WU02:FS01:0x16:Build host: user-f6d030f24f
23:45:21:WU02:FS01:0x16:Board Type: AMD/OpenCL
23:45:21:WU02:FS01:0x16:Core : x=16
23:45:21:WU02:FS01:0x16: Window's signal control handler registered.
23:45:21:WU02:FS01:0x16:Preparing to commence simulation
23:45:21:WU02:FS01:0x16:- Looking at optimizations...
23:45:21:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:45:21:WU02:FS01:0x16:- Created dyn
23:45:21:WU02:FS01:0x16:- Files status OK
23:45:21:WU02:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:45:21:WU02:FS01:0x16:- Expanded 45228 -> 171163 (decompressed 378.4 percent)
23:45:21:WU02:FS01:0x16:Called DecompressByteArray: compressed_data_size=45228 data_size=171163, decompressed_data_size=171163 diff=0
23:45:21:WU02:FS01:0x16:- Digital signature verified
23:45:21:WU02:FS01:0x16:Project: 11293 (Run 11, Clone 85, Gen 46)
23:45:21:WU02:FS01:0x16:Assembly optimizations on if available.
23:45:21:WU02:FS01:0x16:Entering M.D.
23:45:22:WU02:FS01:0x16:Tpr hash 02/wudata_01.tpr: 3641819732 4130679753 2134117480 2835076195 3164400615
23:45:22:WU02:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
23:45:22:WU02:FS01:0x16:Client config unavailable.
23:45:22:WU02:FS01:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
23:45:22:WU02:FS01:0x16:Going to send back what have done -- stepsTotalG=0
23:45:22:WU02:FS01:0x16:Work fraction=0.0000 steps=0.
23:45:23:WU02:FS01:0x16:Starting GUI Server
23:45:26:WU02:FS01:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
23:45:26:WU02:FS01:0x16:+ Opened results file
23:45:26:WU02:FS01:0x16:- Writing 7757 bytes of core data to disk...
23:45:26:WU02:FS01:0x16:Done: 7245 -> 2510 (compressed to 34.6 percent)
23:45:26:WU02:FS01:0x16: ... Done.
23:45:26:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:45:26:WU02:FS01:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
23:45:27:WARNING:WU02:FS01:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
23:45:27:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11293 run:11 clone:85 gen:46 core:0x16 unit:0x000000466652edbc4d9257faa48dd9c8
23:45:27:WU02:FS01:Uploading 2.95KiB to 171.67.108.44
23:45:27:WU02:FS01:Connecting to 171.67.108.44:8080
23:45:27:WU03:FS01:Connecting to assign-GPU.stanford.edu:80
23:45:27:WU02:FS01:Upload complete
23:45:27:WU02:FS01:Server responded WORK_ACK (400)
23:45:27:WU02:FS01:Cleaning up
23:45:28:WU03:FS01:News: Welcome to Folding@Home
23:45:28:WU03:FS01:Assigned to work server 171.67.108.44
23:45:28:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:R575A [AMD Radeon HD7700 Series] from 171.67.108.44
23:45:28:WU03:FS01:Connecting to 171.67.108.44:8080
23:45:28:WU03:FS01:Downloading 44.34KiB
23:45:29:WU03:FS01:Download complete
23:45:29:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11293 run:12 clone:85 gen:46 core:0x16 unit:0x000000536652edbc4d92582e7271d814
23:45:29:WU03:FS01:Starting
23:45:29:WU03:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Pinsky Inc/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe" -dir 03 -suffix 01 -version 703 -lifeline 1084 -checkpoint 30 -gpu 0 -gpu-vendor ati
23:45:29:WU03:FS01:Started FahCore on PID 960
23:45:29:WU03:FS01:Core PID:2036
23:45:29:WU03:FS01:FahCore 0x16 started
23:45:29:WU03:FS01:0x16:
23:45:29:WU03:FS01:0x16:*------------------------------*
23:45:29:WU03:FS01:0x16:Folding@Home GPU Core
23:45:29:WU03:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
23:45:29:WU03:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
23:45:29:WU03:FS01:0x16:Build host: user-f6d030f24f
23:45:29:WU03:FS01:0x16:Board Type: AMD/OpenCL
23:45:29:WU03:FS01:0x16:Core : x=16
23:45:29:WU03:FS01:0x16: Window's signal control handler registered.
23:45:29:WU03:FS01:0x16:Preparing to commence simulation
23:45:29:WU03:FS01:0x16:- Looking at optimizations...
23:45:29:WU03:FS01:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
23:45:29:WU03:FS01:0x16:- Created dyn
23:45:29:WU03:FS01:0x16:- Files status OK
23:45:29:WU03:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:45:29:WU03:FS01:0x16:- Expanded 44889 -> 171163 (decompressed 381.3 percent)
23:45:29:WU03:FS01:0x16:Called DecompressByteArray: compressed_data_size=44889 data_size=171163, decompressed_data_size=171163 diff=0
23:45:29:WU03:FS01:0x16:- Digital signature verified
23:45:29:WU03:FS01:0x16:Project: 11293 (Run 12, Clone 85, Gen 46)
23:45:29:WU03:FS01:0x16:Assembly optimizations on if available.
23:45:29:WU03:FS01:0x16:Entering M.D.
23:45:31:WU03:FS01:0x16:Tpr hash 03/wudata_01.tpr: 2713543331 1063099581 1987952533 3108072492 2590813687
23:45:31:WU03:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
23:45:31:WU03:FS01:0x16:Client config unavailable.
23:45:31:WU03:FS01:0x16:Starting GUI Server
23:45:31:WU03:FS01:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
23:45:31:WU03:FS01:0x16:Going to send back what have done -- stepsTotalG=0
23:45:31:WU03:FS01:0x16:Work fraction=0.0000 steps=0.
23:45:35:WU03:FS01:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
23:45:35:WU03:FS01:0x16:+ Opened results file
23:45:35:WU03:FS01:0x16:- Writing 7757 bytes of core data to disk...
23:45:35:WU03:FS01:0x16:Done: 7245 -> 2506 (compressed to 34.5 percent)
23:45:35:WU03:FS01:0x16: ... Done.
23:45:35:WU03:FS01:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
23:45:35:WU03:FS01:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
23:45:36:WARNING:WU03:FS01:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
23:45:36:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:11293 run:12 clone:85 gen:46 core:0x16 unit:0x000000536652edbc4d92582e7271d814
23:45:36:WU03:FS01:Uploading 2.95KiB to 171.67.108.44
23:45:36:WU03:FS01:Connecting to 171.67.108.44:8080
23:45:36:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
23:45:36:WU03:FS01:Upload complete
23:45:36:WU03:FS01:Server responded WORK_ACK (400)
23:45:36:WU03:FS01:Cleaning up
23:45:36:WU02:FS01:News: Welcome to Folding@Home
23:45:36:WU02:FS01:Assigned to work server 171.67.108.44
23:45:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:R575A [AMD Radeon HD7700 Series] from 171.67.108.44
23:45:36:WU02:FS01:Connecting to 171.67.108.44:8080
23:45:37:WU02:FS01:Downloading 44.55KiB
23:45:37:WU02:FS01:Download complete
23:45:37:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:13 clone:85 gen:46 core:0x16 unit:0x000000466652edbc4d92586024f5f27e
23:45:37:WU02:FS01:Starting
23:45:37:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/Pinsky Inc/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe" -dir 02 -suffix 01 -version 703 -lifeline 1084 -checkpoint 30 -gpu 0 -gpu-vendor ati
23:45:37:WU02:FS01:Started FahCore on PID 260
23:45:37:WU02:FS01:Core PID:3012
23:45:37:WU02:FS01:FahCore 0x16 started
23:45:38:WU02:FS01:0x16:
23:45:38:WU02:FS01:0x16:*------------------------------*
23:45:38:WU02:FS01:0x16:Folding@Home GPU Core
23:45:38:WU02:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
23:45:38:WU02:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
23:45:38:WU02:FS01:0x16:Build host: user-f6d030f24f
23:45:38:WU02:FS01:0x16:Board Type: AMD/OpenCL
23:45:38:WU02:FS01:0x16:Core : x=16
23:45:38:WU02:FS01:0x16: Window's signal control handler registered.
23:45:38:WU02:FS01:0x16:Preparing to commence simulation
23:45:38:WU02:FS01:0x16:- Looking at optimizations...
23:45:38:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:45:38:WU02:FS01:0x16:- Created dyn
23:45:38:WU02:FS01:0x16:- Files status OK
23:45:38:WU02:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
23:45:38:WU02:FS01:0x16:- Expanded 45110 -> 171163 (decompressed 379.4 percent)
23:45:38:WU02:FS01:0x16:Called DecompressByteArray: compressed_data_size=45110 data_size=171163, decompressed_data_size=171163 diff=0
23:45:38:WU02:FS01:0x16:- Digital signature verified
23:45:38:WU02:FS01:0x16:Project: 11293 (Run 13, Clone 85, Gen 46)
23:45:38:WU02:FS01:0x16:Assembly optimizations on if available.
23:45:38:WU02:FS01:0x16:Entering M.D.
23:45:40:WU02:FS01:0x16:Tpr hash 02/wudata_01.tpr: 108242883 2375434093 973921648 2586089999 1941489539
23:45:40:WU02:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
23:45:40:WU02:FS01:0x16:Client config unavailable.
23:45:40:WU02:FS01:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
23:45:40:WU02:FS01:0x16:Going to send back what have done -- stepsTotalG=0
23:45:40:WU02:FS01:0x16:Work fraction=0.0000 steps=0.
23:45:40:WU02:FS01:0x16:Starting GUI Server
23:45:44:WU02:FS01:0x16:logfile size=7221 infoLength=7221 edr=0 trr=23
23:45:44:WU02:FS01:0x16:+ Opened results file
23:45:44:WU02:FS01:0x16:- Writing 7757 bytes of core data to disk...
23:45:44:WU02:FS01:0x16:Done: 7245 -> 2508 (compressed to 34.6 percent)
23:45:44:WU02:FS01:0x16: ... Done.
23:45:44:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
23:45:44:WU02:FS01:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
23:45:44:WARNING:WU02:FS01:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
23:45:44:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11293 run:13 clone:85 gen:46 core:0x16 unit:0x000000466652edbc4d92586024f5f27e
23:45:44:WU02:FS01:Uploading 2.95KiB to 171.67.108.44
23:45:44:WU02:FS01:Connecting to 171.67.108.44:8080
23:45:44:WU02:FS01:Upload complete
23:45:44:WU02:FS01:Server responded WORK_ACK (400)
23:45:44:WU02:FS01:Cleaning up
