Hello
I cannot start foldin becausse I am getting the following error:
11:00:35:WU00:FS00:Connecting to assign3.stanford.edu:8080
11:00:36:WU00:FS00:News: Welcome to Folding@Home
11:00:36:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment
11:00:36:WU00:FS00:Connecting to assign4.stanford.edu:80
11:00:37:WU00:FS00:News: Welcome to Folding@Home
11:00:37:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment
11:00:37:ERROR:WU00:FS00:Exception: Could not get an assignment
Can I do someething with this in MacOS x 10.6?
Thanks.
Problems at Mac OS X 10.6
Re: Problems at Mac OS X 10.6
Please post the beginning section of your log that contains version and system information as well as the folding configuration. This might be just a temporary lack of work, or a misconfiguration of the folding client. There is not enough information from that short section of log to determine what is going on.
Folding is supported on OSX v10.6 and above, on 64 bit, on Core 2 Duos and above. As Joe said, we need more info. Thanks.
Here's the beginning of the log:
*********************** Log Started 2013-09-10T14:58:55Z ***********************
14:58:55:************************* Folding@home Client *************************
14:58:55: Website: http://folding.stanford.edu/
14:58:55: Copyright: (c) 2009-2013 Stanford University
14:58:55: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:58:55: Args:
14:58:55: Config: /Library/Application Support/FAHClient/config.xml
14:58:55:******************************** Build ********************************
14:58:55: Version: 7.3.6
14:58:55: Date: Feb 18 2013
14:58:55: Time: 15:24:11
14:58:55: SVN Rev: 3923
14:58:55: Branch: fah/trunk/client
14:58:55: Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
14:58:55: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
14:58:55: -fno-unsafe-math-optimizations -msse3 -arch x86_64
14:58:55: -mmacosx-version-min=10.5 -isysroot /Developer/SDKs/MacOSX10.5.sdk
14:58:55: Platform: darwin 10.8.0
14:58:55: Bits: 64
14:58:55: Mode: Release
14:58:55:******************************* System ********************************
14:58:55: CPU: Intel(R) Core(TM)2 Duo CPU P7350 @ 2.00GHz
14:58:55: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
14:58:55: CPUs: 2
14:58:55: Memory: 2.00GiB
14:58:55:Free Memory: 1.31GiB
14:58:55: Threads: POSIX_THREADS
14:58:55:Has Battery: false
14:58:55: On Battery: false
14:58:55: UTC offset: 4
14:58:55: PID: 59
14:58:55: CWD: /Library/Application Support/FAHClient
14:58:55: OS: Darwin 10.8.0 i386
14:58:55: OS Arch: AMD64
14:58:55: GPUs: 1
14:58:55: GPU 0: NVIDIA:1 C79 [GeForce 9400]
14:58:55: CUDA: Not detected
14:58:55:***********************************************************************
14:58:56:<config>
14:58:56: <!-- Network -->
14:58:56: <proxy v=':8080'/>
14:58:56:
14:58:56: <!-- User Information -->
14:58:56: <passkey v='********************************'/>
14:58:56: <user v='ivchencovvl'/>
14:58:56:
14:58:56: <!-- Folding Slots -->
14:58:56: <slot id='0' type='CPU'/>
14:58:56:</config>
14:58:56:Trying to access database...
14:59:05:Successfully acquired database lock
14:59:06:Enabled folding slot 00: READY cpu:1
14:59:08:WU00:FS00:Connecting to assign3.stanford.edu:8080
14:59:09:WU00:FS00:News: Welcome to Folding@Home
14:59:09:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': Empty work server assignment
14:59:09:WU00:FS00:Connecting to assign4.stanford.edu:80
14:59:10:WU00:FS00:News: Welcome to Folding@Home
14:59:10:WARNING:WU00:FS00:Failed to get assignment from 'assign4.stanford.edu:80': Empty work server assignment
14:59:10:ERROR:WU00:FS00:Exception: Could not get an assignment
14:59:10:WU00:FS00:Connecting to assign3.stanford.edu:8080
14:59:11:WU00:FS00:News: Welcome to Folding@Home-
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
I've got no Mac experience, but I'll hazard a guess that you'll have to edit the CPU slot to explicitly use both CPU cores in order to get work. Or move the folding power slider to full.Spider84 wrote: 14:58:56: <!-- Folding Slots -->
14:58:56:</config>
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
Good guess.
In the past there were some projects with core A4 work available for Mac's folding with one core or two, specifically Projects 6338 - 6341. Only 6338 is still listed as active on the Project Summary page, so these might be in short supply for single-core requests. Moving the slider to Full or changing the slot configuration to 2 cores should open up more assignment possibilities. My Core 2 Duo MacBook does regularly get assignments, but I have left its CPU setting at 2 for a while and have not been seeing if it would get single core assignments.
Thanks, it helps.Joe_H wrote:In the past there were some projects with core A4 work available for Mac's folding with one core or two, specifically Projects 6338 - 6341. Only 6338 is still listed as active on the Project Summary page, so these might be in short supply for single-core requests. Moving the slider to Full or changing the slot configuration to 2 cores should open up more assignment possibilities. My Core 2 Duo MacBook does regularly get assignments, but I have left its CPU setting at 2 for a while and have not been seeing if it would get single core assignments.
