Error (0=0x0) after finishing WU 7811 (0,68,183)
folding_hoomer
Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300
Post by folding_hoomer »
A member of my team got an unexpected error when finishing WU 7811 (0,68,183)
I7 3770@4400MHz, Win7 Home 64Bit, GTX660Ti@1254/1742MHz, client-type=advanced
His OC is running stable within the last weeks, no issue before and after this error.
The Log:
*********************** Log Started 2013-09-03T23:17:59Z ***********************
23:17:59:************************* Folding@home Client *************************
23:17:59: Website: Folding@home
23:17:59: Copyright: (c) 2009-2013 Stanford University
23:17:59: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:17:59: Args:
23:17:59: Config: C:/ProgramData/FAHClient/config.xml
23:17:59:******************************** Build ********************************
23:17:59: Version: 7.3.6
23:17:59: Date: Feb 18 2013
23:17:59: Time: 15:25:17
23:17:59: SVN Rev: 3923
23:17:59: Branch: fah/trunk/client
23:17:59: Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:17:59: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:17:59: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:17:59: Platform: win32 XP
23:17:59: Bits: 32
23:17:59: Mode: Release
23:17:59:******************************* System ********************************
23:17:59: CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
23:17:59: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
23:17:59: CPUs: 8
23:17:59: Memory: 15.94GiB
23:17:59: Free Memory: 14.34GiB
23:17:59: Threads: WINDOWS_THREADS
23:17:59: Has Battery: false
23:17:59: On Battery: false
23:17:59: UTC offset: 2
23:17:59: PID: 4072
23:17:59: CWD: C:/ProgramData/FAHClient
23:17:59: OS: Windows 7 Home Premium
23:17:59: OS Arch: AMD64
23:17:59: GPUs: 1
23:17:59: GPU 0: NVIDIA:3 GK104 [GeForce GTX 660 Ti]
23:17:59: CUDA: 3.0
23:17:59: CUDA Driver: 5050
23:17:59:Win32 Service: false
23:17:59:***************************************** ******************************
05:12:53:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
05:12:54:WU01:FS00:News: Welcome to Folding@Home
05:12:54:WU01:FS00:Assigned to work server 171.64.65.98
05:12:54:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.98
05:12:54:WU01:FS00:Connecting to 171.64.65.98:8080
05:12:56:WU01:FS00:Downloading 1.55MiB
05:13:02:WU01:FS00:Download 100.00%
05:13:02:WU01:FS00:Download complete
05:13:02:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7811 run:0 clone:68 gen:183 core:0x17 unit:0x000000c10a3b1e8651db46cbd8e21a2d
05:13:06:WU01:FS00:Starting
05:13:06:WU01:FS00:Running FahCore: \"C:\\Program Files (x86)\\FAHClient/FAHCoreWrapper.exe\" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/beta/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4072 -checkpoint 3 -gpu 0 -gpu-vendor nvidia -forceasm
05:13:06:WU01:FS00:Started FahCore on PID 6716
05:13:06:WU01:FS00:Core PID:6288
05:13:06:WU01:FS00:FahCore 0x17 started
05:13:06:WU01:FS00:0x17:*********************** Log Started 2013-09-05T05:13:06Z ***********************
05:13:06:WU01:FS00:0x17:Project: 7811 (Run 0, Clone 68, Gen 183)
05:13:06:WU01:FS00:0x17:Unit: 0x000000c10a3b1e8651db46cbd8e21a2d
05:13:06:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
05:13:06:WU01:FS00:0x17:Machine: 0
05:13:06:WU01:FS00:0x17:Reading tar file state.xml
05:13:06:WU01:FS00:0x17:Reading tar file system.xml
05:13:07:WU01:FS00:0x17:Reading tar file integrator.xml
05:13:07:WU01:FS00:0x17:Reading tar file core.xml
05:13:07:WU01:FS00:0x17:Digital signatures verified
05:13:37:WU01:FS00:0x17:Completed 0 out of 2000000 steps (0%)
05:15:21:WU01:FS00:0x17:Completed 20000 out of 2000000 steps (1%)
05:16:58:WU01:FS00:0x17:Completed 40000 out of 2000000 steps (2%)
cut . . .
07:58:50:WU01:FS00:0x17:Completed 1980000 out of 2000000 steps (99%)
08:00:27:WU01:FS00:0x17:Completed 2000000 out of 2000000 steps (100%)
08:00:35:WU01:FS00:0x17:Saving result file logfile_01.txt
08:00:35:WU01:FS00:0x17:Saving result file checkpointState.xml
08:00:36:WU01:FS00:0x17:Saving result file checkpt.crc
08:00:36:WU01:FS00:0x17:Saving result file log.txt
08:00:36:WU01:FS00:0x17:Saving result file positions.xtc
08:00:37:WU01:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
08:00:37:WARNING:WU01:FS00:FahCore returned: FAILED_1 (0 = 0x0)
08:00:37:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:7811 run:0 clone:68 gen:183 core:0x17 unit:0x000000c10a3b1e8651db46cbd8e21a2d
08:00:37:WU01:FS00:Uploading 4.27MiB to 171.64.65.98
08:00:37:WU01:FS00:Connecting to 171.64.65.98:8080
08:00:43:WU01:FS00:Upload 7.32%
08:00:49:WU01:FS00:Upload 17.57%
08:00:55:WU01:FS00:Upload 27.82%
08:01:01:WU01:FS00:Upload 38.08%
08:01:07:WU01:FS00:Upload 49.79%
08:01:13:WU01:FS00:Upload 60.04%
08:01:19:WU01:FS00:Upload 70.29%
08:01:25:WU01:FS00:Upload 80.54%
08:01:31:WU01:FS00:Upload 90.79%
08:01:40:WU01:FS00:Upload complete
08:01:40:WU01:FS00:Server responded WORK_ACK (400)
08:01:40:WU01:FS00:Cleaning up
Please can you check if the server received and accepted the data, too?
Team: 70335
Re: Error (0=0x0) after finishing WU 7811 (0,68,183)
The server reported that the donor had an issue with the WU and thus, no points were awarded:
Hi mattifolder (team 70335),
Your WU (P7811 R0 C68 G183) was added to the stats database on 2013-09-05 02:00:58 for 0 points of credit.
However, the WU was assigned to another donor and was successfully completed:
Your WU (P7811 R0 C68 G183) was added to the stats database on 2013-09-05 04:00:37 for 10223.8 points of credit.
Was there any unusual activity while the WU was finishing, i.e. an AV scan might interfere with the WU wrap-up process.
If not interfered with by AV software or similar problem, then this could be due to the overclock being at the edge of stable and this WU pushed it over the edge. Some error may have been caught by a final validity check during the wrap up of the WU at the end.
folding_hoomer
Optional:
Thanks a lot for your answers - but this error will be a mysterious, because:
FahWiki says, that error-code 0 belongs to Linux, not Windows . . .
cokeman54
Post by cokeman54 »
http://fahwiki.net/index.php/Error_0x0_and_0x1 read the link. Unknown error, could be a lot of things (memory or OC).
When the FahCore finishes and exits normally, it sets a return code of "FINISHED UNIT (100 = 0x64)" and everybody is happy. When a FahCore exits before it finishes the WU, it should set a return code describing the error. If it just stopped running without finishing, it may leave it set at 0x0 or 0x1 which means there is no explanation to why it stopped when it did but it did not finish the WU or at least did not successfully prepare the results for uploading.
