I have CC 7.3.6 installed with a brand new Sapphire HD7970 in a brand new HP Phoenix computer. Everything is up to date.
Expert settings are:
open-web-control true
client-type advanced
Advice?
Questions?
HD 7970 won't load core_17 WUs
folding_hoomer
- Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300 - Location: Bavaria, Germany
Re: HD 7970 won't load core_17 WUs
Without additional info help is not possible.
First Info: Did you move the "Power-Slider" to full?
If yes:
Please post the complete log incl. the initial section and the installed version of Catalyst.
If yes:
*********************** Log Started 2013-09-07T01:47:34Z ***********************
01:47:34:************************* Folding@home Client *************************
01:47:34: Website: http://folding.stanford.edu/
01:47:34: Copyright: (c) 2009-2013 Stanford University
01:47:34: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:47:34: Args: --open-web-control
01:47:34: Config: C:/ProgramData/FAHClient/config.xml
01:47:34:******************************** Build ********************************
01:47:34: Version: 7.3.6
01:47:34: Date: Feb 18 2013
01:47:34: Time: 15:25:17
01:47:34: SVN Rev: 3923
01:47:34: Branch: fah/trunk/client
01:47:34: Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:47:34: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:47:34: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:47:34: Platform: win32 XP
01:47:34: Bits: 32
01:47:34: Mode: Release
01:47:34:******************************* System ********************************
01:47:34: CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
01:47:34: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
01:47:34: CPUs: 8
01:47:34: Memory: 7.96GiB
01:47:34: Free Memory: 5.15GiB
01:47:34: Threads: WINDOWS_THREADS
01:47:34: Has Battery: false
01:47:34: On Battery: false
01:47:34: UTC offset: -4
01:47:34: PID: 1832
01:47:34: CWD: C:/ProgramData/FAHClient
01:47:34: OS: Windows 7 Home Premium
01:47:34: OS Arch: AMD64
01:47:34: GPUs: 1
01:47:34: GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
01:47:34: CUDA: Not detected
01:47:34:Win32 Service: false
01:47:34:***********************************************************************
01:47:34:<config>
01:47:34: <!-- Folding Core -->
01:47:34: <core-priority v='low'/>
01:47:34:
01:47:34: <!-- Folding Slot Configuration -->
01:47:34: <client-type v='advanced'/>
01:47:34: <power v='full'/>
01:47:34:
01:47:34: <!-- Network -->
01:47:34: <proxy v=':8080'/>
01:47:34:
01:47:34: <!-- User Information -->
01:47:34: <passkey v='********************************'/>
01:47:34: <team v='36120'/>
01:47:34: <user v='LonePalm'/>
01:47:34:
01:47:34: <!-- Folding Slots -->
01:47:34: <slot id='0' type='GPU'>
01:47:34: <client-type v='beta'/>
01:47:34: <next-unit-percentage v='100'/>
01:47:34: </slot>
01:47:34: <slot id='1' type='CPU'>
01:47:34: <cpus v='-1'/>
01:47:34: </slot>
01:47:34:</config>
01:47:34:Trying to access database...
01:47:34:Successfully acquired database lock
01:47:34:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
01:47:34:Enabled folding slot 01: READY cpu:7
01:47:35:WU00:FS01:Starting
01:47:35:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 1832 -checkpoint 15 -np 7
01:47:35:WU00:FS01:Started FahCore on PID 6664
01:47:36:WU00:FS01:Core PID:6568
01:47:36:WU00:FS01:FahCore 0xa4 started
01:47:36:WU01:FS00:Starting
01:47:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 1832 -checkpoint 15 -gpu 0 -gpu-vendor ati
01:47:36:WU01:FS00:Started FahCore on PID 4812
01:47:36:WU00:FS01:0xa4:
01:47:36:WU00:FS01:0xa4:*------------------------------*
01:47:36:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
01:47:36:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
01:47:36:WU00:FS01:0xa4:Preparing to commence simulation
01:47:36:WU00:FS01:0xa4:- Ensuring status. Please wait.
01:47:37:WU01:FS00:Core PID:6772
01:47:37:WU01:FS00:FahCore 0x16 started
01:47:37:WU01:FS00:0x16:
01:47:37:WU01:FS00:0x16:*------------------------------*
01:47:37:WU01:FS00:0x16:Folding@Home GPU Core
01:47:37:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
01:47:37:WU01:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
01:47:37:WU01:FS00:0x16:Build host: user-f6d030f24f
01:47:37:WU01:FS00:0x16:Board Type: AMD/OpenCL
01:47:37:WU01:FS00:0x16:Core : x=16
01:47:37:WU01:FS00:0x16: Window's signal control handler registered.
01:47:37:WU01:FS00:0x16:Preparing to commence simulation
01:47:37:WU01:FS00:0x16:- Ensuring status. Please wait.
01:47:37:4:127.0.0.1:New Web connection
01:47:46:WU00:FS01:0xa4:- Looking at optimizations...
01:47:46:WU00:FS01:0xa4:- Working with standard loops on this execution.
01:47:46:WU00:FS01:0xa4:- Previous termination of core was improper.
01:47:46:WU00:FS01:0xa4:- Going to use standard loops.
01:47:46:WU00:FS01:0xa4:- Files status OK
01:47:46:WU00:FS01:0xa4:- Expanded 145892 -> 503128 (decompressed 344.8 percent)
01:47:46:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=145892 data_size=503128, decompressed_data_size=503128 diff=0
01:47:46:WU00:FS01:0xa4:- Digital signature verified
01:47:46:WU00:FS01:0xa4:Project: 7083 (Run 0, Clone 883, Gen 12)
01:47:46:WU00:FS01:0xa4:Entering M.D.
01:47:46:WU01:FS00:0x16:- Looking at optimizations...
01:47:46:WU01:FS00:0x16:- Working with standard loops on this execution.
01:47:46:WU01:FS00:0x16:- Previous termination of core was improper.
01:47:46:WU01:FS00:0x16:- Files status OK
01:47:46:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:47:46:WU01:FS00:0x16:- Expanded 44915 -> 171163 (decompressed 381.0 percent)
01:47:46:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=44915 data_size=171163, decompressed_data_size=171163 diff=0
01:47:46:WU01:FS00:0x16:- Digital signature verified
01:47:46:WU01:FS00:0x16:Project: 11293 (Run 21, Clone 268, Gen 45)
01:47:46:WU01:FS00:0x16:Entering M.D.
01:47:48:WU01:FS00:0x16:Will resume from checkpoint file 01/wudata_01.ckp
01:47:48:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr: 2633031298 4198143489 1632299046 789757347 3557639167
01:47:48:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
01:47:48:WU01:FS00:0x16:Client config unavailable.
01:47:49:WU01:FS00:0x16:Starting GUI Server
01:47:50:WU01:FS00:0x16:Resuming from checkpoint
01:47:50:WU01:FS00:0x16:fcCheckPointResume: retreived and current tpr file hash:
01:47:50:WU01:FS00:0x16: 0 2633031298 2633031298
01:47:50:WU01:FS00:0x16: 1 4198143489 4198143489
01:47:50:WU01:FS00:0x16: 2 1632299046 1632299046
01:47:50:WU01:FS00:0x16: 3 789757347 789757347
01:47:50:WU01:FS00:0x16: 4 3557639167 3557639167
01:47:50:WU01:FS00:0x16:fcCheckPointResume: file hashes same.
01:47:50:WU01:FS00:0x16:fcCheckPointResume: state restored.
01:47:50:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.log Verified 01/wudata_01.log
01:47:50:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.trr Verified 01/wudata_01.trr
01:47:50:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.xtc Verified 01/wudata_01.xtc
01:47:50:WU01:FS00:0x16:fcCheckPointResume: name 01/wudata_01.edr Verified 01/wudata_01.edr
01:47:50:WU01:FS00:0x16:fcCheckPointResume: state restored 2
01:47:50:WU01:FS00:0x16:Resumed from checkpoint
01:47:50:WU01:FS00:0x16:Setting checkpoint frequency: 500000
01:47:50:WU01:FS00:0x16:Completed 500001 out of 50000000 steps (1%).
01:47:52:WU00:FS01:0xa4:Using Gromacs checkpoints
01:47:52:WU00:FS01:0xa4:Mapping NT from 7 to 7
01:47:52:WU00:FS01:0xa4:Resuming from checkpoint
01:47:52:WU00:FS01:0xa4:Verified 00/wudata_01.log
01:47:52:WU00:FS01:0xa4:Verified 00/wudata_01.trr
01:47:52:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
01:47:53:WU00:FS01:0xa4:Verified 00/wudata_01.edr
01:47:53:WU00:FS01:0xa4:Completed 3900001 out of 10000000 steps (39%)Catalyst version 13.4
Mod edit: Added Code tags to log
Setting your client-type to beta or advanced is not a guarantee that you will get a Core_17 WU, only a preference. If there is not one to assign at the time you connect to the servers, then you will get work that is available. In this case you were assigned a WU from Project 11293 that uses Core_16. When it completes you may get another, or get assigned one of the three projects using Core_17.
Also, we do not recommend using the beta flag if you are not a member of the beta testers. Support is only given in the beta forum, posting is limited to members accepted to that sub-forum.
folding_hoomer
Optional:
Open beta means: client-type=advanced
But - like Joe_H said:
If there are no WU´s ATM using Core17 you will get a Core16-WU which has the same state.
PG does not run open beta's of folding cores or new projects, but does post it publicly so anyone logged into the forum can read the posts. Currently Core_17 and three projects have moved to advanced which is an intermediate status between beta and full assignment to any folder. That might be considered an open beta, but it is a separate status.
PG has done open beta with the folding client itself during the development of the V7 client. That is a separate testing from that for the cores and projects.
Further information on the Beta Team and testing can be found in this post.
There are three different things that must be tested, The client (updated rarely), each FahCore (also updated rarely, but more often than the client), and each Project (and new projects can appear at any time). Normally, each one moves progressively toward full release, but occasionally problems are discovered AFTER a move and additional testing and possible revisions can be required so things can move back to a previous status.LonePalm wrote:I though core_17 was now in open beta.
FahCore_17 seems to be (almost) ready for release to Full FAH but I'm not sure about the Projects that are available for folding. Perhaps the issue is a difference between Implicit and explicit solvent models though I'm not sure how we know which a particular project is.
