I've setup a new gaming computer with a gigabyte 7970 and i5-4670k
I've folded succesfully on core 17, but core 16 instantly crashes even on minimum clock speeds.
Here's the log:
*********************** Log Started 2013-09-04T14:12:04Z ***********************
14:12:04:************************* Folding@home Client *************************
14:12:04: Website: http://folding.stanford.edu/
14:12:04: Copyright: (c) 2009-2013 Stanford University
14:12:04: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:12:04: Args: --open-web-control
14:12:04: Config: C:/ProgramData/FAHClient/config.xml
14:12:04:******************************** Build ********************************
14:12:04: Version: 7.3.6
14:12:04: Date: Feb 18 2013
14:12:04: Time: 15:25:17
14:12:04: SVN Rev: 3923
14:12:04: Branch: fah/trunk/client
14:12:04: Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:12:04: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:12:04: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:12:04: Platform: win32 XP
14:12:04: Bits: 32
14:12:04: Mode: Release
14:12:04:******************************* System ********************************
14:12:04: CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
14:12:04: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
14:12:04: CPUs: 4
14:12:04: Memory: 7.89GiB
14:12:04: Free Memory: 6.11GiB
14:12:04: Threads: WINDOWS_THREADS
14:12:04: Has Battery: false
14:12:04: On Battery: false
14:12:04: UTC offset: 2
14:12:04: PID: 2688
14:12:04: CWD: C:/ProgramData/FAHClient
14:12:04: OS: Windows 7 Ultimate
14:12:04: OS Arch: AMD64
14:12:04: GPUs: 1
14:12:04: GPU 0: ATI:5 Tahiti XT [Radeon HD 7970]
14:12:04: CUDA: Not detected
14:12:04:Win32 Service: false
14:12:04:***********************************************************************
14:12:04:<config>
14:12:04: <service-description v='Folding@home Client'/>
14:12:04: <service-restart v='true'/>
14:12:04: <service-restart-delay v='5000'/>
14:12:04:
14:12:04: <!-- Client Control -->
14:12:04: <client-threads v='4'/>
14:12:04: <cycle-rate v='4'/>
14:12:04: <cycles v='-1'/>
14:12:04: <data-directory v='.'/>
14:12:04: <disable-sleep-when-active v='true'/>
14:12:04: <exec-directory v='C:\Program Files (x86)\FAHClient'/>
14:12:04: <exit-when-done v='false'/>
14:12:04: <fold-anon v='false'/>
14:12:04: <open-web-control v='true'/>
14:12:04:
14:12:04: <!-- Configuration -->
14:12:04: <config-rotate v='true'/>
14:12:04: <config-rotate-dir v='configs'/>
14:12:04: <config-rotate-max v='16'/>
14:12:04:
14:12:04: <!-- Debugging -->
14:12:04: <assignment-servers>
14:12:04: assign3.stanford.edu:8080 assign4.stanford.edu:80
14:12:04: </assignment-servers>
14:12:04: <capture-directory v='capture'/>
14:12:04: <capture-on-error v='false'/>
14:12:04: <capture-packets v='false'/>
14:12:04: <capture-requests v='false'/>
14:12:04: <capture-responses v='false'/>
14:12:04: <capture-sockets v='false'/>
14:12:04: <debug-sockets v='false'/>
14:12:04: <exception-locations v='true'/>
14:12:04: <gpu-assignment-servers>
14:12:04: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
14:12:04: </gpu-assignment-servers>
14:12:04: <stack-traces v='false'/>
14:12:04:
14:12:04: <!-- Error Handling -->
14:12:04: <max-slot-errors v='5'/>
14:12:04: <max-unit-errors v='5'/>
14:12:04:
14:12:04: <!-- Folding Core -->
14:12:04: <checkpoint v='15'/>
14:12:04: <core-dir v='cores'/>
14:12:04: <core-priority v='idle'/>
14:12:04: <cpu-affinity v='false'/>
14:12:04: <cpu-usage v='100'/>
14:12:04: <gpu-usage v='100'/>
14:12:04: <no-assembly v='false'/>
14:12:04:
14:12:04: <!-- Folding Slot Configuration -->
14:12:04: <cause v='ANY'/>
14:12:04: <client-subtype v='STDCLI'/>
14:12:04: <client-type v='normal'/>
14:12:04: <cpu-species v='X86_PENTIUM_II'/>
14:12:04: <cpu-type v='AMD64'/>
14:12:04: <cpus v='-1'/>
14:12:04: <cuda-index v='0'/>
14:12:04: <gpu v='true'/>
14:12:04: <max-packet-size v='normal'/>
14:12:04: <opencl-index v='0'/>
14:12:04: <os-species v='UNKNOWN'/>
14:12:04: <os-type v='WIN32'/>
14:12:04: <power v='full'/>
14:12:04: <project-key v='0'/>
14:12:04: <smp v='true'/>
14:12:04:
14:12:04: <!-- HTTP Server -->
14:12:04: <allow v='127.0.0.1'/>
14:12:04: <connection-timeout v='60'/>
14:12:04: <deny v='0/0'/>
14:12:04: <http-addresses v='0:7396'/>
14:12:04: <https-addresses v=''/>
14:12:04: <max-connect-time v='900'/>
14:12:04: <max-connections v='800'/>
14:12:04: <max-request-length v='52428800'/>
14:12:04: <min-connect-time v='300'/>
14:12:04: <threads v='4'/>
14:12:04:
14:12:04: <!-- Logging -->
14:12:04: <log v='log.txt'/>
14:12:04: <log-color v='false'/>
14:12:04: <log-crlf v='true'/>
14:12:04: <log-date v='false'/>
14:12:04: <log-date-periodically v='21600'/>
14:12:04: <log-debug v='true'/>
14:12:04: <log-domain v='false'/>
14:12:04: <log-header v='true'/>
14:12:04: <log-level v='true'/>
14:12:04: <log-no-info-header v='true'/>
14:12:04: <log-redirect v='false'/>
14:12:04: <log-rotate v='true'/>
14:12:04: <log-rotate-dir v='logs'/>
14:12:04: <log-rotate-max v='16'/>
14:12:04: <log-short-level v='false'/>
14:12:04: <log-simple-domains v='true'/>
14:12:04: <log-thread-id v='false'/>
14:12:04: <log-thread-prefix v='true'/>
14:12:04: <log-time v='true'/>
14:12:04: <log-to-screen v='true'/>
14:12:04: <log-truncate v='false'/>
14:12:04: <verbosity v='5'/>
14:12:04:
14:12:04: <!-- Network -->
14:12:04: <proxy v=':8080'/>
14:12:04: <proxy-enable v='false'/>
14:12:04: <proxy-pass v=''/>
14:12:04: <proxy-user v=''/>
14:12:04:
14:12:04: <!-- Process Control -->
14:12:04: <child v='false'/>
14:12:04: <daemon v='false'/>
14:12:04: <pid v='false'/>
14:12:04: <pid-file v='Folding@home Client.pid'/>
14:12:04: <respawn v='false'/>
14:12:04: <service v='false'/>
14:12:04:
14:12:04: <!-- Remote Command Server -->
14:12:04: <command-address v='0.0.0.0'/>
14:12:04: <command-allow-no-pass v='127.0.0.1'/>
14:12:04: <command-deny-no-pass v='0/0'/>
14:12:04: <command-port v='36330'/>
14:12:04:
14:12:04: <!-- Slot Control -->
14:12:04: <idle v='false'/>
14:12:04: <max-shutdown-wait v='60'/>
14:12:04: <pause-on-battery v='true'/>
14:12:04: <pause-on-start v='false'/>
14:12:04:
14:12:04: <!-- User Information -->
14:12:04: <machine-id v='0'/>
14:12:04: <passkey v='********************************'/>
14:12:04: <team v='105987'/>
14:12:04: <user v='bhunt'/>
14:12:04:
14:12:04: <!-- Web Server -->
14:12:04: <session-timeout v='3600'/>
14:12:04: <web-allow v='127.0.0.1'/>
14:12:04: <web-deny v='0/0'/>
14:12:04:
14:12:04: <!-- Work Unit Control -->
14:12:04: <dump-after-deadline v='true'/>
14:12:04: <max-queue v='16'/>
14:12:04: <max-units v='0'/>
14:12:04: <next-unit-percentage v='99'/>
14:12:04:
14:12:04: <!-- Folding Slots -->
14:12:04: <slot id='0' type='GPU'>
14:12:04: <max-packet-size v='big'/>
14:12:04: <next-unit-percentage v='100'/>
14:12:04: </slot>
14:12:04: <slot id='1' type='CPU'>
14:12:04: </slot>
14:12:04:</config>
14:12:04:Trying to access database...
14:12:04:Successfully acquired database lock
14:12:04:Enabled folding slot 00: READY gpu:0:Tahiti XT [Radeon HD 7970]
14:12:04:Enabled folding slot 01: READY cpu:3
14:12:04:Started thread 5 on PID 2688
14:12:04:WU02:FS01:Starting
14:12:04:Started thread 4 on PID 2688
14:12:04:Started thread 6 on PID 2688
14:12:04:Started thread 7 on PID 2688
14:12:04:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe -dir 02 -suffix 01 -version 703 -lifeline 2688 -checkpoint 15 -np 3
14:12:04:WU02:FS01:Started FahCore on PID 2192
14:12:04:Started thread 8 on PID 2688
14:12:04:WU02:FS01:Core PID:5028
14:12:04:WU02:FS01:FahCore 0xa3 started
14:12:04:WU01:FS00:Starting
14:12:04:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 2688 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:12:04:WU01:FS00:Started FahCore on PID 4124
14:12:04:Started thread 9 on PID 2688
14:12:04:WU01:FS00:Core PID:3960
14:12:04:WU01:FS00:FahCore 0x16 started
14:12:05:WU02:FS01:0xa3:
14:12:05:WU02:FS01:0xa3:*------------------------------*
14:12:05:WU02:FS01:0xa3:Folding@Home Gromacs SMP Core
14:12:05:WU02:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
14:12:05:WU02:FS01:0xa3:Preparing to commence simulation
14:12:05:WU02:FS01:0xa3:- Looking at optimizations...
14:12:05:WU02:FS01:0xa3:- Files status OK
14:12:05:WU02:FS01:0xa3:- Expanded 3810721 -> 4169428 (decompressed 109.4 percent)
14:12:05:WU02:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3810721 data_size=4169428, decompressed_data_size=4169428 diff=0
14:12:05:WU02:FS01:0xa3:- Digital signature verified
14:12:05:WU02:FS01:0xa3:Project: 6097 (Run 0, Clone 3, Gen 169)
14:12:05:WU02:FS01:0xa3:Assembly optimizations on if available.
14:12:05:WU02:FS01:0xa3:Entering M.D.
14:12:05:WU01:FS00:0x16:
14:12:05:WU01:FS00:0x16:*------------------------------*
14:12:05:WU01:FS00:0x16:Folding@Home GPU Core
14:12:05:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:12:05:WU01:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:12:05:WU01:FS00:0x16:Build host: user-f6d030f24f
14:12:05:WU01:FS00:0x16:Board Type: AMD/OpenCL
14:12:05:WU01:FS00:0x16:Core : x=16
14:12:05:WU01:FS00:0x16: Window's signal control handler registered.
14:12:05:WU01:FS00:0x16:Preparing to commence simulation
14:12:05:WU01:FS00:0x16:- Ensuring status. Please wait.
14:12:11:WU02:FS01:0xa3:Using Gromacs checkpoints
14:12:11:WU02:FS01:0xa3:Mapping NT from 3 to 3
14:12:11:WU02:FS01:0xa3:Resuming from checkpoint
14:12:11:WU02:FS01:0xa3:Verified 02/wudata_01.log
14:12:11:WU02:FS01:0xa3:Verified 02/wudata_01.trr
14:12:11:WU02:FS01:0xa3:Verified 02/wudata_01.edr
14:12:11:WU02:FS01:0xa3:Completed 5490 out of 500000 steps (1%)
14:12:14:WU01:FS00:0x16:- Looking at optimizations...
14:12:14:WU01:FS00:0x16:- Working with standard loops on this execution.
14:12:14:WU01:FS00:0x16:- Previous termination of core was improper.
14:12:14:WU01:FS00:0x16:- Going to use standard loops.
14:12:14:WU01:FS00:0x16:- Files status OK
14:12:14:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:12:14:WU01:FS00:0x16:- Expanded 45201 -> 171163 (decompressed 378.6 percent)
14:12:14:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45201 data_size=171163, decompressed_data_size=171163 diff=0
14:12:14:WU01:FS00:0x16:- Digital signature verified
14:12:14:WU01:FS00:0x16:Project: 11292 (Run 8, Clone 93, Gen 39)
14:12:14:WU01:FS00:0x16:Entering M.D.
14:12:16:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr: 2561775053 3879319204 1577966071 1030111370 3458052092
14:12:16:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:12:16:WU01:FS00:0x16:Client config unavailable.
14:12:16:WU01:FS00:0x16:Starting GUI Server
14:12:18:Started thread 10 on PID 2688
14:12:21:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:12:21:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)
14:12:22:WU01:FS00:Starting
14:12:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 2688 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:12:22:WU01:FS00:Started FahCore on PID 4396
14:12:22:Started thread 11 on PID 2688
14:12:22:WU01:FS00:Core PID:4476
14:12:22:WU01:FS00:FahCore 0x16 started
14:12:22:WU01:FS00:0x16:
14:12:22:WU01:FS00:0x16:*------------------------------*
14:12:22:WU01:FS00:0x16:Folding@Home GPU Core
14:12:22:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:12:22:WU01:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:12:22:WU01:FS00:0x16:Build host: user-f6d030f24f
14:12:22:WU01:FS00:0x16:Board Type: AMD/OpenCL
14:12:22:WU01:FS00:0x16:Core : x=16
14:12:22:WU01:FS00:0x16: Window's signal control handler registered.
14:12:22:WU01:FS00:0x16:Preparing to commence simulation
14:12:22:WU01:FS00:0x16:- Ensuring status. Please wait.
14:12:31:WU01:FS00:0x16:- Looking at optimizations...
14:12:31:WU01:FS00:0x16:- Working with standard loops on this execution.
14:12:31:WU01:FS00:0x16:- Previous termination of core was improper.
14:12:31:WU01:FS00:0x16:- Going to use standard loops.
14:12:31:WU01:FS00:0x16:- Files status OK
14:12:31:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:12:31:WU01:FS00:0x16:- Expanded 45201 -> 171163 (decompressed 378.6 percent)
14:12:31:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45201 data_size=171163, decompressed_data_size=171163 diff=0
14:12:31:WU01:FS00:0x16:- Digital signature verified
14:12:31:WU01:FS00:0x16:Project: 11292 (Run 8, Clone 93, Gen 39)
14:12:31:WU01:FS00:0x16:Entering M.D.
14:12:33:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr: 2561775053 3879319204 1577966071 1030111370 3458052092
14:12:33:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:12:33:WU01:FS00:0x16:Client config unavailable.
14:12:33:WU01:FS00:0x16:Starting GUI Server
14:12:42:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
14:12:42:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073741819 = 0xc0000005)Have a nice day,
bhunt
