Passkey ineffective
Passkey ineffective
I've tried using my passkey to differentiate my folding from that of an inactive user, and contribute my points to my team, but this seems to have Norma worked. Please help.
Re: Passkey ineffective
Please post the beginning of your log including the system information and the configuration settings. We can take a look and see if a problem there can be spotted.
As for points, they are reported first by username and then team. The passkey would allow you to distinguish which points you contributed individually on the official stats site, but at this time that is not usable for team reports if the username is the same.
Ah. I'll post when I'm home from work. That said, it it possible to change my username and keep my points and progress?
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Unfortunately, no. I think you'd also need to qualify a new passkey for a new username.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
P5-133XL
Machine #2:
Machine 3:
Points always stay with the original team, username, and passkey they were folded with. That being said, you can search the individual stats for a username and get all the teams that that username has folded with and the subtotals for each team and totals all teams, or if you search for a passkey you get everything that has used that specific passkey.
Nope. You can use any name with your one passkey. NO new passkey needed. ONE passkey is the recommendation. However, each name will need to complete 10 QRB eligible work units to start getting the bonus.Napoleon wrote:Unfortunately, no. I think you'd also need to qualify a new passkey for a new username.
*********************** Log Started 2013-08-29T23:57:44Z ***********************
23:57:44:************************* Folding@home Client *************************
23:57:44: Website: http://folding.stanford.edu/
23:57:44: Copyright: (c) 2009-2013 Stanford University
23:57:44: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:57:44: Args: --open-web-control
23:57:44: Config: C:/Users/Faucett/AppData/Roaming/FAHClient/config.xml
23:57:44:******************************** Build ********************************
23:57:44: Version: 7.3.6
23:57:44: Date: Feb 18 2013
23:57:44: Time: 15:25:17
23:57:44: SVN Rev: 3923
23:57:44: Branch: fah/trunk/client
23:57:44: Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:57:44: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:57:44: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:57:44: Platform: win32 XP
23:57:44: Bits: 32
23:57:44: Mode: Release
23:57:44:******************************* System ********************************
23:57:44: CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
23:57:44: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
23:57:44: CPUs: 4
23:57:44: Memory: 15.96GiB
23:57:44: Free Memory: 13.83GiB
23:57:44: Threads: WINDOWS_THREADS
23:57:44: Has Battery: false
23:57:44: On Battery: false
23:57:44: UTC offset: -5
23:57:44: PID: 3452
23:57:44: CWD: C:/Users/Faucett/AppData/Roaming/FAHClient
23:57:44: OS: Microsoft Windows XP Service Pack 3
23:57:44: OS Arch: AMD64
23:57:44: GPUs: 1
23:57:44: GPU 0: NVIDIA:3 GK106 [GeForce GTX 650 Ti]
23:57:44: CUDA: 3.0
23:57:44: CUDA Driver: 5050
23:57:44:Win32 Service: false
23:57:44:***********************************************************************
23:57:44:<config>
23:57:44: <!-- Network -->
23:57:44: <proxy v=':8080'/>
23:57:44:
23:57:44: <!-- User Information -->
23:57:44: <passkey v='********************************'/>
23:57:44: <team v='225053'/>
23:57:44: <user v='Sethdude'/>
23:57:44:-
I have looked into this a bit, your username with the passkey will qualify for the QRB once one more eligible WU is successfully returned. Your individual stats are being updated and credited to your team. However they are not showing up on the team statistics page. That appears to be a problem with the official team stats that has been reported for other teams since the server move Monday. Hopefully this will get cleared up soon.
The Pande Group is aware of the problem with the team stats. In the meantime, EOC seems to be updating although they're always a few hours behind.
As of now it looks like PG has fixed the team statistics. The official statistics site shows an update time of today and does list your contribution, http://fah-web.stanford.edu/cgi-bin/mai ... num=225053.
