[My ISP's] Server responded: HTTP_INTERNAL_SERVER_ERROR
spw
Post by spw »
The client won't connect to 49.49.48.13 with and internal server error. I am on Ubuntu 13.04 64bit. I've tried several hours apart so it isn't a temporary problem. Is there a way of changing the request to HTTPS? My ISP frequently breaks HTTP connections with its transparent proxy. I am a 2GHz Pentium Dual core with 2GB RAM.
It seems my ISP's transparent proxy is breaking it, as I keep on getting "Failure to connect to web server", which is an error from the proxy, which I cannot turn off.
11:08:24:************************* Folding@home Client *************************
11:08:24:    Website: http://folding.stanford.edu/
11:08:24:  Copyright: (c) 2009-2013 Stanford University
11:08:24:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:08:24:       Args:
11:08:24:     Config: /storage/FAH/config.xml
11:08:24:******************************** Build ********************************
11:08:24:    Version: 7.3.6
11:08:24:       Date: Feb 18 2013
11:08:24:       Time: 07:24:08
11:08:24:    SVN Rev: 3923
11:08:24:     Branch: fah/trunk/client
11:08:24:   Compiler: GNU 4.4.7
11:08:24:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
11:08:24:             -fno-unsafe-math-optimizations -msse2
11:08:24:   Platform: linux2 3.2.0-1-amd64
11:08:24:       Bits: 64
11:08:24:       Mode: Release
11:08:24:******************************* System ********************************
11:08:24:        CPU: Pentium(R) Dual-Core CPU T4200 @ 2.00GHz
11:08:24:     CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
11:08:24:       CPUs: 2
11:08:24:     Memory: 1.89GiB
11:08:24:Free Memory: 70.03MiB
11:08:24:    Threads: POSIX_THREADS
11:08:24:Has Battery: true
11:08:24: On Battery: false
11:08:24: UTC offset: 8
11:08:24:        PID: 3156
11:08:24:        CWD: /storage/FAH
11:08:24:         OS: Linux 3.8.0-29-generic x86_64
11:08:24:    OS Arch: AMD64
11:08:24:       GPUs: 0
11:08:24:       CUDA: Not detected
11:08:24:***********************************************************************
11:08:24:<config>
11:08:24:  <!-- Folding Slot Configuration -->
11:08:24:  <power v='medium'/>
11:08:24:
11:08:24:  <!-- Folding Slots -->
11:08:24:  <slot id='0' type='CPU'/>
11:08:24:</config>
11:08:24:Trying to access database...
11:08:24:Successfully acquired database lock
11:08:24:Enabled folding slot 00: READY cpu:1
11:08:24:WU00:FS00:Connecting to assign3.stanford.edu:8080
11:08:26:WU00:FS00:News:
11:08:26:WU00:FS00:Assigned to work server 49.49.48.13
11:08:26:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 49.49.48.13
11:08:26:WU00:FS00:Connecting to 49.49.48.13:8080
11:08:57:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
11:08:58:WU00:FS00:Connecting to assign3.stanford.edu:8080
11:08:59:WU00:FS00:News:
11:08:59:WU00:FS00:Assigned to work server 49.49.48.13
11:08:59:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 49.49.48.13
11:08:59:WU00:FS00:Connecting to 49.49.48.13:8080
11:09:29:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
11:09:58:WU00:FS00:Connecting to assign3.stanford.edu:8080
11:09:59:WU00:FS00:News:
11:09:59:WU00:FS00:Assigned to work server 49.49.48.13
11:09:59:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 49.49.48.13
11:09:59:WU00:FS00:Connecting to 49.49.48.13:8080
11:10:29:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
11:11:35:WU00:FS00:Connecting to assign3.stanford.edu:8080
11:11:36:WU00:FS00:News:
11:11:36:WU00:FS00:Assigned to work server 49.49.48.13
11:11:36:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 49.49.48.13
11:11:36:WU00:FS00:Connecting to 49.49.48.13:8080
11:12:07:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
11:14:12:WU00:FS00:Connecting to assign3.stanford.edu:8080
11:14:13:WU00:FS00:News:
11:14:13:WU00:FS00:Assigned to work server 49.49.48.13
11:14:14:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 49.49.48.13
11:14:14:WU00:FS00:Connecting to 49.49.48.13:8080
11:14:44:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
11:18:27:WU00:FS00:Connecting to assign3.stanford.edu:8080
11:18:33:WU00:FS00:News:
11:18:33:WU00:FS00:Assigned to work server 49.49.48.13
11:18:33:WU00:FS00:Requesting new work unit for slot 00: READY cpu:1 from 49.49.48.13
11:18:33:WU00:FS00:Connecting to 49.49.48.13:8080
11:19:05
bollix47
Re: Server responded: HTTP_INTERNAL_SERVER_ERROR
Post by bollix47 »
Welcome to the folding@home support forum spw.
The first thing I would try would be to add your proxy to the client's configuration. Open FAHControl and click on the proxy tab.
Check the Enable Proxy box and insert 49.49.48.13 or the Hostname if the IP is likely to change in the "Hostname or IP" field and click on Save. (You might also have to change the port if your "ISP's transparent proxy" uses a specific port ... possibly 80)
You might have to restart the client after making this type of change.
Basically, the client's communication process works the same as your browser. Check your browser's proxy settings and use the same in the client's proxy settings.
spw
Post by spw »
My ISP intercepts HTTP traffic. I can't disable it and it is on always without an option to turn it off.
49.49.48.13 is the work server which I can't connect to because of my ISP. How can I get FAH to assign me a different server which hopefully my ISP doesn't break?
No, 49.49.48.13 is not a work server at Stanford or any of the other associated research groups at other locations. The servers that are used are listed on the Server Status page, a link to that page is at the top of every forum page. Your connection requests are being redirected by your ISP, contact them for the correct proxy server settings to use. We can help you get those entered into the client.
bollix47
Post by bollix47 »
49.49.48.13 resolves to an ISP provider in Thailand. As Joe has said this is not a folding@home work server.
Re: [My ISP's] Server responded: HTTP_INTERNAL_SERVER_ERROR
Does your government censor the internet? If so, there's nothing we can do about it -- nor should we. You need to follow the laws of your country.
If your country is unfairly blocking FAH, you'll have to convince them of that fact.
