Hello,
I use to fold a lot, then I stopped for some time, when wanting to start again I see F@H has made many updates, ect.
Got the V7 version runs correctly on 3 cores of my 4 core cpu.
When trying to run GPU, I get "Failed to get work assignment".
When doing some search, I see it is told to put advmethods, which I did, no change.
So I go old school, I try V6 version, V5, command versions, and I get this:
[04:28:53] + No appropriate work server was available; will try again in a bit.
[04:28:53] + Couldn't get work instructions.
[04:28:53] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
I have nVIDIA Geforce GT 240 1GB, got 320.49 driver from nVIDIA.
Yes there is CUDA on this GC.
Not a firewall, antivirus, or internet issue.
I would be glad and grateful if someone could help me please, I tried for many hours to make this working, and searching over internet.
Maybe answer is simple, I can't fold anymore with this old card ?
Thanks in advance for support.
Regards,
Raf
Can't get WU {Maintenance}
Machine #2:
Machine 3:
Re: Can't get WU
I need more info. Could you please supply the full log including the system and config portions?
P.S. I could very well simply be that you caught the tail-end of the server maintenance that just occurred:
http://folding.typepad.com/news/2013/08 ... st-26.html
Re: Can't get WU
Thanks for your reply.
Running Windows 7 64, 3 gb ram, Q6600, ect.
Sure, here you go for the log:
And PS: You really think that for the maintenance, seems to be 2 days old ?
*********************** Log Started 2013-08-28T04:02:36Z ***********************
04:02:36:************************* Folding@home Client *************************
04:02:36: Website: http://folding.stanford.edu/
04:02:36: Copyright: (c) 2009-2013 Stanford University
04:02:36: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:02:36: Args: --open-web-control
04:02:36: Config: C:/Folding 0/config.xml
04:02:36:******************************** Build ********************************
04:02:36: Version: 7.3.6
04:02:36: Date: Feb 18 2013
04:02:36: Time: 15:25:17
04:02:36: SVN Rev: 3923
04:02:36: Branch: fah/trunk/client
04:02:36: Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:02:36: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:02:36: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
04:02:36: Platform: win32 XP
04:02:36: Bits: 32
04:02:36: Mode: Release
04:02:36:******************************* System ********************************
04:02:36: CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
04:02:36: CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
04:02:36: CPUs: 4
04:02:36: Memory: 3.00GiB
04:02:36: Free Memory: 1.14GiB
04:02:36: Threads: WINDOWS_THREADS
04:02:36: Has Battery: false
04:02:36: On Battery: false
04:02:36: UTC offset: 2
04:02:36: PID: 5228
04:02:36: CWD: C:/Folding 0
04:02:36: OS: Windows 7 Ultimate
04:02:36: OS Arch: AMD64
04:02:36: GPUs: 1
04:02:36: GPU 0: NVIDIA:1 GT215 [GeForce GT 240]
04:02:36: CUDA: 1.2
04:02:36: CUDA Driver: 5050
04:02:36:Win32 Service: false
04:02:36:***********************************************************************
04:02:36:<config>
04:02:36: <!-- Folding Core -->
04:02:36: <cpu-affinity v='true'/>
04:02:36:
04:02:36: <!-- Folding Slot Configuration -->
04:02:36: <power v='full'/>
04:02:36:
04:02:36: <!-- Network -->
04:02:36: <proxy v=':8080'/>
04:02:36:
04:02:36: <!-- User Information -->
04:02:36: <passkey v='********************************'/>
04:02:36: <team v='35947'/>
04:02:36: <user v='censored'/>
04:02:36:
04:02:36: <!-- Folding Slots -->
04:02:36: <slot id='1' type='CPU'>
04:02:36: <cpus v='3'/>
04:02:36: </slot>
04:02:36: <slot id='0' type='GPU'/>
04:02:36:</config>
04:02:36:Trying to access database...
04:02:36:Successfully acquired database lock
04:02:36:Enabled folding slot 01: READY cpu:3
04:02:36:Enabled folding slot 00: READY gpu:0:GT215 [GeForce GT 240]
04:02:36:WU00:FS01:Starting
04:02:36:WU00:FS01:Running FahCore: "C:\Folding 0\FAHClient/FAHCoreWrapper.exe" "C:/Folding 0/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 703 -lifeline 5228 -checkpoint 15 -np 3
04:02:36:WU00:FS01:Started FahCore on PID 6052
04:02:36:WU00:FS01:Core PID:3864
04:02:36:WU00:FS01:FahCore 0xa4 started
04:02:36:WU00:FS01:0xa4:
04:02:36:WU00:FS01:0xa4:*------------------------------*
04:02:36:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
04:02:36:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:02:36:WU00:FS01:0xa4:Preparing to commence simulation
04:02:36:WU00:FS01:0xa4:- Looking at optimizations...
04:02:36:WU00:FS01:0xa4:- Files status OK
04:02:36:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:02:37:WU00:FS01:0xa4:- Expanded 2053871 -> 5365960 (decompressed 261.2 percent)
04:02:37:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053871 data_size=5365960, decompressed_data_size=5365960 diff=0
04:02:37:WU00:FS01:0xa4:- Digital signature verified
04:02:37:WU00:FS01:0xa4:Project: 7808 (Run 2, Clone 70, Gen 169)
04:02:37:WU00:FS01:0xa4:Assembly optimizations on if available.
04:02:37:WU00:FS01:0xa4:Entering M.D.
04:02:37:WU01:FS00:News: Welcome to Folding@Home
04:02:37:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:02:37:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:02:38:WU01:FS00:News: Welcome to Folding@Home
04:02:38:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:02:38:ERROR:WU01:FS00:Exception: Could not get an assignment
04:02:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:02:39:WU01:FS00:News: Welcome to Folding@Home
04:02:39:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:02:39:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:02:39:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:02:39:ERROR:WU01:FS00:Exception: Could not get an assignment
04:02:42:12:127.0.0.1:New Web connection
04:02:43:WU00:FS01:0xa4:Mapping NT from 3 to 3
04:02:43:WU00:FS01:0xa4:Completed 0 out of 1500000 steps (0%)
04:03:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:03:39:WU01:FS00:News: Welcome to Folding@Home
04:03:39:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:03:39:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:03:40:WU01:FS00:News: Welcome to Folding@Home
04:03:40:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
04:03:40:ERROR:WU01:FS00:Exception: Could not get an assignment
04:04:31:WARNING:Exception: 19:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
04:04:33:WARNING:Exception: 38:127.0.0.1: Send error: 10053: An established connection was aborted by the software in your host machine.
04:05:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
04:05:17:WU01:FS00:News: Welcome to Folding@Home
04:05:17:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
04:05:17:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
04:05:19:WU01:FS00:News: Welcome to Folding@Home
Re: Can't get WU
Hi iraffbe and welcome to the folding@home support forum.
Unfortunately the servers that carry work suitable for your GPU are still DOWN as a result of the move. The staff are working on this problem but until it's fixed there's really nothing you can do but be patient. Your log looks good so as soon as those servers are back up you should receive work. If you prefer not to see the constant attempts in your log you can right click on your GPU slot and select Pause, but you would have to check the Server Status (link at the top of every forum page) and look for the status of servers 171.67.108.11 and 171.67.108.21 to determine when to try again. Once the Connect column says Accepting and the Status Column says full you would again right click on the GPU slot and select Fold.
Re: Can't get WU
Oh so that's the only reason.
Well, that's great news, means I can still help with this GPU, thought it was outdated.
Thanks a lot for the info, hope they get alive soon.
Regards from Belgium,
Raf
Raf
Re: Can't get WU
Yes, your GPU can still contribute but we can't predict for how long.
Please have a look at the folding blog for information about core 11 which is the core your GPU would use:
http://folding.typepad.com/news/2013/08 ... ore78.html
Re: Can't get WU
Okay, well thanks a lot for your help, and the information concerning my GPU.
I got one year to get a good GPU, so it should be OK
I will edit/post when I am able to get a new WU.
Cheers.
Cheers.
