Radeon HD6520G (A6-3400M APU)
Lethargic Adventurer
Post by Lethargic Adventurer »
I'm having trouble getting my GPU to run alongside my CPU in F@H. I've tried restarting the client, checked the gpu support list, downloaded and copied the opencl.dll file into both system32 and SysWOW64 folders on Windows 7 Home Premium 64 bit. Uninstalled and reinstalled display drivers for the 6520G, I just don't know what else I can do at this point, so that's what brings me here.
Hardware & Driver Info
Toshiba L755D-S5218
Display Driver Version: 8.911.6.0
System Info
14:46:18:      Version: 7.3.6
14:46:18:         Date: Feb 18 2013
14:46:18:         Time: 15:25:17
14:46:18:      SVN Rev: 3923
14:46:18:       Branch: fah/trunk/client
14:46:18:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:46:18:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:46:18:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:46:18:     Platform: win32 XP
14:46:18:         Bits: 32
14:46:18:         Mode: Release
14:46:18:******************************* System ********************************
14:46:18:          CPU: AMD A6-3400M APU with Radeon(tm) HD Graphics
14:46:18:       CPU ID: AuthenticAMD Family 18 Model 1 Stepping 0
14:46:18:         CPUs: 4
14:46:18:       Memory: 3.48GiB
14:46:18:  Free Memory: 1.71GiB
14:46:18:      Threads: WINDOWS_THREADS
14:46:18:  Has Battery: true
14:46:18:   On Battery: false
14:46:18:   UTC offset: -5
14:46:18:          PID: 8180
14:46:18:          CWD: C:/Users/Marvin/AppData/Roaming/FAHClient
14:46:18:           OS: Windows 7 Home Premium
14:46:18:      OS Arch: AMD64
14:46:18:         GPUs: 1
14:46:18:        GPU 0: ATI:4 BeaverCreek [Radeon HD 6520G]
14:46:18:         CUDA: Not detected
GPU Logs
*********************** Log Started 2013-08-23T14:46:18Z ***********************
14:46:18:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
14:46:19:WU01:FS00:News: Welcome to Folding@Home
14:46:19:WU01:FS00:Assigned to work server 171.67.108.44
14:46:19:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:BeaverCreek [Radeon HD 6520G] from 171.67.108.44
14:46:19:WU01:FS00:Connecting to 171.67.108.44:8080
14:46:19:WU01:FS00:Downloading 44.39KiB
14:46:19:WU01:FS00:Download complete
14:46:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11292 run:11 clone:60 gen:11 core:0x16 unit:0x0000002a6652edbc4d096dc505e3dffa
14:46:19:WU01:FS00:Starting
14:46:19:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Marvin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 8180 -checkpoint 10 -noassembly -gpu 0 -gpu-vendor ati
14:46:19:WU01:FS00:Started FahCore on PID 5332
14:46:19:WU01:FS00:Core PID:9612
14:46:19:WU01:FS00:FahCore 0x16 started
14:46:20:WU01:FS00:0x16:
14:46:20:WU01:FS00:0x16:*------------------------------*
14:46:20:WU01:FS00:0x16:Folding@Home GPU Core
14:46:20:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:46:20:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:46:20:WU01:FS00:0x16:Build host: user-f6d030f24f
14:46:20:WU01:FS00:0x16:Board Type: AMD/OpenCL
14:46:20:WU01:FS00:0x16:Core      : x=16
14:46:20:WU01:FS00:0x16: Window's signal control handler registered.
14:46:20:WU01:FS00:0x16:Preparing to commence simulation
14:46:20:WU01:FS00:0x16:- User disabled assembly optimizations.
14:46:20:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
14:46:20:WU01:FS00:0x16:- Created dyn
14:46:20:WU01:FS00:0x16:- Files status OK
14:46:20:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:46:20:WU01:FS00:0x16:- Expanded 44945 -> 171163 (decompressed 380.8 percent)
14:46:20:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=44945 data_size=171163, decompressed_data_size=171163 diff=0
14:46:20:WU01:FS00:0x16:- Digital signature verified
14:46:20:WU01:FS00:0x16:Project: 11292 (Run 11, Clone 60, Gen 11)
14:46:20:WU01:FS00:0x16:Entering M.D.
14:46:22:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  1407075081 4185556112 3237182479 1157873025 360928581
14:46:22:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:46:22:WU01:FS00:0x16:Client config unavailable.
14:46:22:WU01:FS00:0x16:Finished fah_main
14:46:22:WU01:FS00:0x16:Successful run
14:46:22:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
14:46:22:WU01:FS00:0x16:Starting GUI Server
14:46:32:WU01:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
14:46:32:WU01:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
14:46:32:WU01:FS00:0x16:Allocated 544 bytes for edr file
14:46:32:WU01:FS00:0x16:Read bedfile
14:46:32:WU01:FS00:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
14:46:32:WU01:FS00:0x16:edrfile file hash check failed.
14:46:32:WU01:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
14:46:32:WARNING:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
14:46:32:WARNING:WU01:FS00:Fatal error, dumping
14:46:32:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11292 run:11 clone:60 gen:11 core:0x16 unit:0x0000002a6652edbc4d096dc505e3dffa
14:46:32:WU01:FS00:Connecting to 171.67.108.44:8080
14:46:32:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
14:46:33:WU01:FS00:Server responded WORK_ACK (400)
14:46:33:WU01:FS00:Cleaning up
14:46:33:WU02:FS00:News: Welcome to Folding@Home
14:46:33:WU02:FS00:Assigned to work server 171.67.108.44
14:46:33:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:BeaverCreek [Radeon HD 6520G] from 171.67.108.44
14:46:33:WU02:FS00:Connecting to 171.67.108.44:8080
14:46:34:WU02:FS00:Downloading 44.62KiB
14:46:34:WU02:FS00:Download complete
14:46:35:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:22 clone:210 gen:45 core:0x16 unit:0x000000496652edbc4d94b95a02322af5
14:46:35:WU02:FS00:Starting
14:46:35:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Marvin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 8180 -checkpoint 10 -noassembly -gpu 0 -gpu-vendor ati
14:46:35:WU02:FS00:Started FahCore on PID 7100
14:46:35:WU02:FS00:Core PID:8208
14:46:35:WU02:FS00:FahCore 0x16 started
14:46:35:WU02:FS00:0x16:
14:46:35:WU02:FS00:0x16:*------------------------------*
14:46:35:WU02:FS00:0x16:Folding@Home GPU Core
14:46:35:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:46:35:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:46:35:WU02:FS00:0x16:Build host: user-f6d030f24f
14:46:35:WU02:FS00:0x16:Board Type: AMD/OpenCL
14:46:35:WU02:FS00:0x16:Core      : x=16
14:46:35:WU02:FS00:0x16: Window's signal control handler registered.
14:46:35:WU02:FS00:0x16:Preparing to commence simulation
14:46:35:WU02:FS00:0x16:- User disabled assembly optimizations.
14:46:35:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
14:46:35:WU02:FS00:0x16:- Created dyn
14:46:35:WU02:FS00:0x16:- Files status OK
14:46:35:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:46:35:WU02:FS00:0x16:- Expanded 45178 -> 171163 (decompressed 378.8 percent)
14:46:35:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=45178 data_size=171163, decompressed_data_size=171163 diff=0
14:46:35:WU02:FS00:0x16:- Digital signature verified
14:46:35:WU02:FS00:0x16:Project: 11293 (Run 22, Clone 210, Gen 45)
14:46:35:WU02:FS00:0x16:Entering M.D.
14:46:37:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  3533622630 361629131 71054626 723200560 125123509
14:46:37:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:46:37:WU02:FS00:0x16:Client config unavailable.
14:46:37:WU02:FS00:0x16:Finished fah_main
14:46:37:WU02:FS00:0x16:Successful run
14:46:37:WU02:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
14:46:37:WU02:FS00:0x16:Starting GUI Server
14:46:47:WU02:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
14:46:47:WU02:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<02/wudata_01.trr> Cosm status=0
14:46:47:WU02:FS00:0x16:Allocated 544 bytes for edr file
14:46:47:WU02:FS00:0x16:Read bedfile
14:46:47:WU02:FS00:0x16:- Checksum of file (02/wudata_01.edr) read from disk doesn't match
14:46:47:WU02:FS00:0x16:edrfile file hash check failed.
14:46:47:WU02:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
14:46:47:WARNING:WU02:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
14:46:47:WARNING:WU02:FS00:Fatal error, dumping
14:46:47:WU02:FS00:Sending unit results: id:02 state:SEND error:DUMPED project:11293 run:22 clone:210 gen:45 core:0x16 unit:0x000000496652edbc4d94b95a02322af5
14:46:48:WU02:FS00:Connecting to 171.67.108.44:8080
14:46:48:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
14:46:48:WU02:FS00:Server responded WORK_ACK (400)
14:46:48:WU02:FS00:Cleaning up
14:46:49:WU01:FS00:News: Welcome to Folding@Home
14:46:49:WU01:FS00:Assigned to work server 171.67.108.44
14:46:49:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:BeaverCreek [Radeon HD 6520G] from 171.67.108.44
14:46:49:WU01:FS00:Connecting to 171.67.108.44:8080
14:46:49:WU01:FS00:Downloading 44.63KiB
14:46:49:WU01:FS00:Download complete
14:46:50:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11292 run:14 clone:72 gen:37 core:0x16 unit:0x000001386652edbc4d096dd455775325
14:46:50:WU01:FS00:Starting
14:46:50:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Marvin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 8180 -checkpoint 10 -noassembly -gpu 0 -gpu-vendor ati
14:46:50:WU01:FS00:Started FahCore on PID 6228
14:46:50:WU01:FS00:Core PID:2548
14:46:50:WU01:FS00:FahCore 0x16 started
14:46:50:WU01:FS00:0x16:
14:46:50:WU01:FS00:0x16:*------------------------------*
14:46:50:WU01:FS00:0x16:Folding@Home GPU Core
14:46:50:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:46:50:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:46:50:WU01:FS00:0x16:Build host: user-f6d030f24f
14:46:50:WU01:FS00:0x16:Board Type: AMD/OpenCL
14:46:50:WU01:FS00:0x16:Core      : x=16
14:46:50:WU01:FS00:0x16: Window's signal control handler registered.
14:46:50:WU01:FS00:0x16:Preparing to commence simulation
14:46:50:WU01:FS00:0x16:- User disabled assembly optimizations.
14:46:50:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
14:46:50:WU01:FS00:0x16:- Created dyn
14:46:50:WU01:FS00:0x16:- Files status OK
14:46:50:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:46:50:WU01:FS00:0x16:- Expanded 45189 -> 171163 (decompressed 378.7 percent)
14:46:50:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45189 data_size=171163, decompressed_data_size=171163 diff=0
14:46:50:WU01:FS00:0x16:- Digital signature verified
14:46:50:WU01:FS00:0x16:Project: 11292 (Run 14, Clone 72, Gen 37)
14:46:50:WU01:FS00:0x16:Entering M.D.
14:46:52:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  4059183648 3745406048 1226158181 2798166646 1915244241
14:46:52:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:46:52:WU01:FS00:0x16:Client config unavailable.
14:46:52:WU01:FS00:0x16:Finished fah_main
14:46:52:WU01:FS00:0x16:Successful run
14:46:52:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
14:46:52:WU01:FS00:0x16:Starting GUI Server
14:47:02:WU01:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
14:47:02:WU01:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
14:47:02:WU01:FS00:0x16:Allocated 544 bytes for edr file
14:47:02:WU01:FS00:0x16:Read bedfile
14:47:02:WU01:FS00:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
14:47:02:WU01:FS00:0x16:edrfile file hash check failed.
14:47:02:WU01:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
14:47:02:WARNING:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
14:47:02:WARNING:WU01:FS00:Fatal error, dumping
14:47:03:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11292 run:14 clone:72 gen:37 core:0x16 unit:0x000001386652edbc4d096dd455775325
14:47:03:WU01:FS00:Connecting to 171.67.108.44:8080
14:47:03:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
14:47:03:WU01:FS00:Server responded WORK_ACK (400)
14:47:03:WU01:FS00:Cleaning up
14:47:04:WU02:FS00:News: Welcome to Folding@Home
14:47:04:WU02:FS00:Assigned to work server 171.67.108.44
14:47:04:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:BeaverCreek [Radeon HD 6520G] from 171.67.108.44
14:47:04:WU02:FS00:Connecting to 171.67.108.44:8080
14:47:04:WU02:FS00:Downloading 44.43KiB
14:47:04:WU02:FS00:Download complete
14:47:05:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:23 clone:210 gen:45 core:0x16 unit:0x0000004b6652edbc4d94b98f059f4de0
14:47:05:WU02:FS00:Starting
14:47:05:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Marvin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 8180 -checkpoint 10 -noassembly -gpu 0 -gpu-vendor ati
14:47:05:WU02:FS00:Started FahCore on PID 5824
14:47:05:WU02:FS00:Core PID:5984
14:47:05:WU02:FS00:FahCore 0x16 started
14:47:05:WU02:FS00:0x16:
14:47:05:WU02:FS00:0x16:*------------------------------*
14:47:05:WU02:FS00:0x16:Folding@Home GPU Core
14:47:05:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:47:05:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:47:05:WU02:FS00:0x16:Build host: user-f6d030f24f
14:47:05:WU02:FS00:0x16:Board Type: AMD/OpenCL
14:47:05:WU02:FS00:0x16:Core      : x=16
14:47:05:WU02:FS00:0x16: Window's signal control handler registered.
14:47:05:WU02:FS00:0x16:Preparing to commence simulation
14:47:05:WU02:FS00:0x16:- User disabled assembly optimizations.
14:47:05:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
14:47:05:WU02:FS00:0x16:- Created dyn
14:47:05:WU02:FS00:0x16:- Files status OK
14:47:05:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:47:05:WU02:FS00:0x16:- Expanded 44989 -> 171163 (decompressed 380.4 percent)
14:47:05:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=44989 data_size=171163, decompressed_data_size=171163 diff=0
14:47:05:WU02:FS00:0x16:- Digital signature verified
14:47:05:WU02:FS00:0x16:Project: 11293 (Run 23, Clone 210, Gen 45)
14:47:05:WU02:FS00:0x16:Entering M.D.
14:47:07:WU02:FS00:0x16:Tpr hash 02/wudata_01.tpr:  121071202 3641426954 4126624831 1223079186 3694454945
14:47:07:WU02:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:47:07:WU02:FS00:0x16:Client config unavailable.
14:47:07:WU02:FS00:0x16:Finished fah_main
14:47:07:WU02:FS00:0x16:Successful run
14:47:07:WU02:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
14:47:07:WU02:FS00:0x16:Starting GUI Server
14:47:17:WU02:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
14:47:17:WU02:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<02/wudata_01.trr> Cosm status=0
14:47:17:WU02:FS00:0x16:Allocated 544 bytes for edr file
14:47:17:WU02:FS00:0x16:Read bedfile
14:47:17:WU02:FS00:0x16:- Checksum of file (02/wudata_01.edr) read from disk doesn't match
14:47:17:WU02:FS00:0x16:edrfile file hash check failed.
14:47:17:WU02:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
14:47:17:WARNING:WU02:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
14:47:17:WARNING:WU02:FS00:Fatal error, dumping
14:47:17:WU02:FS00:Sending unit results: id:02 state:SEND error:DUMPED project:11293 run:23 clone:210 gen:45 core:0x16 unit:0x0000004b6652edbc4d94b98f059f4de0
14:47:18:WU02:FS00:Connecting to 171.67.108.44:8080
14:47:18:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
14:47:18:WU02:FS00:Server responded WORK_ACK (400)
14:47:18:WU02:FS00:Cleaning up
14:47:19:WU01:FS00:News: Welcome to Folding@Home
14:47:19:WU01:FS00:Assigned to work server 171.67.108.44
14:47:19:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:BeaverCreek [Radeon HD 6520G] from 171.67.108.44
14:47:19:WU01:FS00:Connecting to 171.67.108.44:8080
14:47:19:WU01:FS00:Downloading 44.60KiB
14:47:20:WU01:FS00:Download complete
14:47:20:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11292 run:13 clone:114 gen:12 core:0x16 unit:0x0000001c6652edbc4d62a437aa49ecd8
14:47:20:WU01:FS00:Starting
14:47:20:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Marvin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 8180 -checkpoint 10 -noassembly -gpu 0 -gpu-vendor ati
14:47:20:WU01:FS00:Started FahCore on PID 9092
14:47:20:WU01:FS00:Core PID:5632
14:47:20:WU01:FS00:FahCore 0x16 started
14:47:21:WU01:FS00:0x16:
14:47:21:WU01:FS00:0x16:*------------------------------*
14:47:21:WU01:FS00:0x16:Folding@Home GPU Core
14:47:21:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
14:47:21:WU01:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
14:47:21:WU01:FS00:0x16:Build host: user-f6d030f24f
14:47:21:WU01:FS00:0x16:Board Type: AMD/OpenCL
14:47:21:WU01:FS00:0x16:Core      : x=16
14:47:21:WU01:FS00:0x16: Window's signal control handler registered.
14:47:21:WU01:FS00:0x16:Preparing to commence simulation
14:47:21:WU01:FS00:0x16:- User disabled assembly optimizations.
14:47:21:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
14:47:21:WU01:FS00:0x16:- Created dyn
14:47:21:WU01:FS00:0x16:- Files status OK
14:47:21:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:47:21:WU01:FS00:0x16:- Expanded 45156 -> 171163 (decompressed 379.0 percent)
14:47:21:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45156 data_size=171163, decompressed_data_size=171163 diff=0
14:47:21:WU01:FS00:0x16:- Digital signature verified
14:47:21:WU01:FS00:0x16:Project: 11292 (Run 13, Clone 114, Gen 12)
14:47:21:WU01:FS00:0x16:Entering M.D.
14:47:22:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr:  3983991503 2510033265 3461184917 4109217219 2473545358
14:47:22:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
14:47:22:WU01:FS00:0x16:Client config unavailable.
14:47:22:WU01:FS00:0x16:Finished fah_main
14:47:22:WU01:FS00:0x16:Successful run
14:47:22:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
14:47:23:WU01:FS00:0x16:Starting GUI Server
14:47:32:WU01:FS00:0x16:Reserved 0 bytes for xtc file; Cosm status=0
14:47:32:WU01:FS00:0x16:Reserved 0 0 786430464 bytes for arc file=<01/wudata_01.trr> Cosm status=0
14:47:32:WU01:FS00:0x16:Allocated 544 bytes for edr file
14:47:32:WU01:FS00:0x16:Read bedfile
14:47:32:WU01:FS00:0x16:- Checksum of file (01/wudata_01.edr) read from disk doesn't match
14:47:32:WU01:FS00:0x16:edrfile file hash check failed.
14:47:32:WU01:FS00:0x16:Folding@home Core Shutdown: FILE_IO_ERROR
14:47:33:WARNING:WU01:FS00:FahCore returned: FILE_IO_ERROR (117 = 0x75)
14:47:33:WARNING:WU01:FS00:Fatal error, dumping
14:47:33:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:11292 run:13 clone:114 gen:12 core:0x16 unit:0x0000001c6652edbc4d62a437aa49ecd8
14:47:33:WU01:FS00:Connecting to 171.67.108.44:8080
14:47:33:WU01:FS00:Server responded WORK_ACK (400)
14:47:34:WU01:FS00:Cleaning up
Re: Radeon HD6520G (A6-3400M APU)
If running a custom driver you likely need to switch to the AMD driver. 12.8 is a good working version.
7im wrote:If running a custom driver you likely need to switch to the AMD driver. 12.8 is a good working version.
Also, you shouldn't have to manually add opencl.dll. Everything you need should come with the drivers. If you happened to pick an obsolete version, it could be contributing to your problem. I'd remove the one you added before installing the correct drivers.
Uninstalling the Toshiba recommended driver and sneaking the Catalyst 12.8 driver helped with getting around the FATAL_IO_ERROR. Now all there is to do is 49,500,000 more steps on Project 11293. I'll update whether the project completes or not in about 28 hours.
Thank you so much.
I wouldn't call getting an updated driver from the hardware manufacturer "sneaking" They made the GPU, after all, and Toshiba got the original driver from them.
I'll clarify what I meant by "sneaking". AMD's display driver support pages lack clear and direct routes to their various display driver versions without the assistance of a Google engine search. For instance if I follow their support pages as stated they direct all Toshiba/Sony VIAO/Panasonic laptop owners to their respected OEM sites and drivers. In addition, their AMD Mobility Driver Verification Tool states I'm running incompatible hardware and directs me back to the laptop OEM who do not provide an adequate driver version. In short, I had to sneak around to find the particular driver version and ignore their warnings of incompatibility.
Back to business, the AMD Catalyst 12.8 driver is working for F@H 7.3.6 on the AMD A6-3400M (Radeon HD 6520G) APU on a Toshiba L755D-S5218 with Windows 7 Home Premium 64 bit. The first project (11293) has been completed with many more to come.
Completion
09:41:27:WU01:FS00:0x16:Completed  49500000 out of 50000000 steps (99%).
09:59:11:WU01:FS00:0x16:Completed  50000000 out of 50000000 steps (100%).
10:00:55:WU01:FS00:0x16:Finished fah_main
10:00:55:WU01:FS00:0x16:Successful run
10:00:55:WU01:FS00:0x16:DynamicWrapper: Finished Work Unit: sleep=10000
10:01:05:WU01:FS00:0x16:Reserved 2441532 bytes for xtc file; Cosm status=0
10:01:05:WU01:FS00:0x16:Allocated 2441532 bytes for xtc file
10:01:05:WU01:FS00:0x16:- Reading up to 2441532 from "01/wudata_01.xtc": Read 2441532
10:01:05:WU01:FS00:0x16:Read 2441532 bytes from xtc file; available packet space=783988932
10:01:05:WU01:FS00:0x16:xtc file hash check passed.
10:01:05:WU01:FS00:0x16:Reserved 75840 75840 783988932 bytes for arc file=<01/wudata_01.trr> Cosm status=0
10:01:05:WU01:FS00:0x16:Allocated 75840 bytes for arc file
10:01:05:WU01:FS00:0x16:- Reading up to 75840 from "01/wudata_01.trr": Read 75840
10:01:05:WU01:FS00:0x16:Read 75840 bytes from arc file; available packet space=783913092
10:01:05:WU01:FS00:0x16:trr file hash check passed.
10:01:05:WU01:FS00:0x16:Allocated 544 bytes for edr file
10:01:05:WU01:FS00:0x16:Read bedfile
10:01:05:WU01:FS00:0x16:edr file hash check passed.
10:01:05:WU01:FS00:0x16:Allocated 120616 bytes for logfile
10:01:05:WU01:FS00:0x16:Read logfile
10:01:05:WU01:FS00:0x16:GuardedRun: success in DynamicWrapper
10:01:05:WU01:FS00:0x16:GuardedRun: done
10:01:05:WU01:FS00:0x16:Run: GuardedRun completed.
10:01:09:WU01:FS00:0x16:+ Opened results file
10:01:09:WU01:FS00:0x16:- Writing 2639044 bytes of core data to disk...
10:01:11:WU01:FS00:0x16:Done: 2638532 -> 2483320 (compressed to 94.1 percent)
10:01:11:WU01:FS00:0x16:  ... Done.
10:01:11:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
10:01:11:WU01:FS00:0x16:Shutting down core
10:01:11:WU01:FS00:0x16:Folding@home Core Shutdown: FINISHED_UNIT
10:01:11:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
10:01:11:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11293 run:18 clone:58 gen:45 core:0x16 unit:0x000000446652edbc4d94b868e7e2476d
10:01:12:WU01:FS00:Uploading 2.37MiB to 171.67.108.44
10:01:12:WU01:FS00:Connecting to 171.67.108.44:8080
10:01:12:WU02:FS00:Starting
10:01:12:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Marvin/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 4516 -checkpoint 7 -gpu 0 -gpu-vendor ati
10:01:12:WU02:FS00:Started FahCore on PID 4692
10:01:12:WU02:FS00:Core PID:4868
10:01:12:WU02:FS00:FahCore 0x16 started
10:01:12:WU02:FS00:0x16:
10:01:12:WU02:FS00:0x16:*------------------------------*
10:01:12:WU02:FS00:0x16:Folding@Home GPU Core
10:01:12:WU02:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
10:01:12:WU02:FS00:0x16:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
10:01:12:WU02:FS00:0x16:Build host: user-f6d030f24f
10:01:12:WU02:FS00:0x16:Board Type: AMD/OpenCL
10:01:12:WU02:FS00:0x16:Core      : x=16
10:01:12:WU02:FS00:0x16: Window's signal control handler registered.
10:01:12:WU02:FS00:0x16:Preparing to commence simulation
10:01:12:WU02:FS00:0x16:- Looking at optimizations...
10:01:12:WU02:FS00:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
10:01:12:WU02:FS00:0x16:- Created dyn
10:01:12:WU02:FS00:0x16:- Files status OK
10:01:12:WU02:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
10:01:12:WU02:FS00:0x16:- Expanded 44958 -> 171163 (decompressed 380.7 percent)
10:01:12:WU02:FS00:0x16:Called DecompressByteArray: compressed_data_size=44958 data_size=171163, decompressed_data_size=171163 diff=0
10:01:12:WU02:FS00:0x16:- Digital signature verified
10:01:12:WU02:FS00:0x16:Project: 11292 (Run 15, Clone 94, Gen 20)
Final note, the Catalyst 12.8 driver works with other functions on the laptop (VGA output, have not tested HDMI output) and sufficient (no noticeable difference) gaming performance. Thank you again for the help and recommendations.
