Persons more knowledgeable than myself on drivers (i.e., anything > 0) have pointed out that Nvidia is now supporting OpenCL 1.2.
Will that be significant for Folding anytime soon?
https://devtalk.nvidia.com/default/topi ... a-drivers/
http://www.geforce.com/hardware/noteboo ... ifications
Nvidia OpenCL 1.2 support
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Re: Nvidia OpenCL 1.2 support
Well, those are just hardware specs. OpenCL 1.2 spec probably has some minimum requirements about hardware features for it to be called a (true) OpenCL 1.2 capable GPU. But it's the driver which enables the use of those HW features. I'd bet when the OpenCL 1.2 capable drivers are released, they'll still bring OpenCL 1.2 support to old cards, they just emulate missing HW features in the driver.
Think about PhysX, for example. Existing drivers allow you to choose CPU for PhysX, even though the performance will be abysmal. According to rumours, it still isn't multithreaded and only uses x87 instructions for math (no SSE, for example). But hey, you can try it if you like...
Briefly put: still waiting for the driver.
Those HW "specifications" are rather sketchy... for example, look at
http://www.geforce.com/hardware/desktop ... ifications
You don't find anything at all about OpenCL there, any version of it. Does that mean it can't run core_17?
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
No to both questions.
Officially, anything above the 720M supports the OpenCL 1.2 API. I don't think there is an easy way to figure out whether the hardware supports all of the functionality or whether emulation is built into the drivers.
- Hardware configuration: Corsair Obsidian 750D Windows Airflow Edition
Intel Core i9 Extreme 7980XE @ 2.6 GHz (18 cores, 36 threads)
64 GB Corsair Dominator Platinum DDR4 RAM
2x Nvidia Titan RTX (NVLink Enabled) (Nvidia 526.98 Studio Driver)
Asus Rampage VI APEX (BIOS 1401)(Intel X299 Chipset)
Corsair AX1600i Titanium Plus Power Supply
Corsair Neutron NX500 800GB SSD (System Drive)
Seagate SkyHawk 10 TB , 256 MB Cache (Data Drive)
Creative Sound BlasterX AE-5 Plus Pure Edition
Dell UP3218K and Dell U2711
Windows 11 Pro for Workstations 64 Bit (Version 22H2) - Location: Ireland
Agreed.7im wrote:No to both questions.
From reading the following thread on the Nvidia forum, it also appears that they don't support OpenCL 1.2 yet:
https://forums.geforce.com/default/topi ... t-for-fah/
There are related links to further threads on this forum within the above link.
Thanks.
My Folding@Home statistics page:
http://folding.extremeoverclocking.com/ ... =&u=565609
