CORE_UPDATE question
NookieBandit
Hardware configuration: AMD Opteron 2 x 6274 (32 Cores)
AMD FX-8350 (8 Cores)
Intel i7-4790K (8 Cores)
Intel i7-4771K (8 Cores)
Intel i7-3770K (8 Cores)
Intel i7-3770S (8 Cores)
Intel i7-3930K (12 Cores)
Nvidia GPUs:
GTX 780ti
GTX 780ti
GTX 780ti
GTX 780ti
GTX 780
GTX 690
GTX 690
AMD GPUs:
HD 7970 GBE
HD 7970 GBE
HD 7990
HD 7990
HD 7990
R9 295X2
R9 295X2
R9 295X2
Post by NookieBandit »
I'm running Nvidia and AMD GPUs with mulitple GPUs of the same brand in both systems, using the "advanced" flag. Today, the Nvidia systems and the AMD systems received a "waiting on FahCore Update" on one of the GPU slots, while the rest of the GPUs continue to crunch away. That means the GPUs waiting for the core update will not perform any work. I'm assuming that the rest of the GPUs in each system have to finish their work units before the core will be updated? Is my assumption correct?
bollix47
Re: CORE_UPDATE question
Post by bollix47 »
Yes, the core cannot be updated while it's in use.
NookieBandit
Nvidia GPUs:
GTX 780ti
GTX 780ti
GTX 780ti
GTX 780ti
GTX 780
GTX 690
GTX 690
AMD GPUs:
HD 7970 GBE
HD 7970 GBE
HD 7990
HD 7990
HD 7990
R9 295X2
R9 295X2
R9 295X2
Thank you. I appreciate the quick feedback!
