tucker9
Posts: 6 Joined: Thu Jul 11, 2013 4:40 pm
Post
by tucker9 » Sat Jul 20, 2013 9:01 pm
I am new here and want to use my GPU only. My CPU is running BOINC for World Community Grid. Is this possible? It seems everything works and my status shows RUNNING, but my progress stays at 0.00%.
20:54:26:Adding folding slot 00: PAUSED gpu:0:Barts PRO [ATI Radeon HD 6800 Series] (paused)
20:54:26:Removing old file 'configs/config-20130715-230047.xml'
20:54:26:Saving configuration to config.xml
20:54:26:<config>
20:54:26: <!-- Folding Slot Configuration -->
20:54:26: <power v='full'/>
20:54:26:
20:54:26: <!-- Network -->
20:54:26: <proxy v=':8080'/>
20:54:26:
20:54:26: <!-- User Information -->
20:54:26: <passkey v='********************************'/>
20:54:26:
20:54:26: <!-- Folding Slots -->
20:54:26: <slot id='0' type='GPU'/>
20:54:26:</config>
20:54:26:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
20:54:27:WU00:FS00:News: Welcome to Folding@Home
20:54:27:WU00:FS00:Assigned to work server 171.67.108.44
20:54:27:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Barts PRO [ATI Radeon HD 6800 Series] from 171.67.108.44
20:54:27:WU00:FS00:Connecting to 171.67.108.44:8080
20:54:27:WU00:FS00:Downloading 44.49KiB
20:54:28:WU00:FS00:Download complete
20:54:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11293 run:30 clone:369 gen:43 core:0x16 unit:0x000000496652edbc4d94bb319da9d6f7
20:54:28:WU00:FS00:Starting
20:54:28:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 00 -suffix 01 -version 703 -lifeline 6032 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:54:28:WU00:FS00:Started FahCore on PID 17784
20:54:28:WU00:FS00:Core PID:8236
20:54:28:WU00:FS00:FahCore 0x16 started
20:54:28:WU00:FS00:0x16:
20:54:28:WU00:FS00:0x16:*------------------------------*
20:54:28:WU00:FS00:0x16:Folding@Home GPU Core
20:54:28:WU00:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
20:54:28:WU00:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
20:54:28:WU00:FS00:0x16:Build host: user-f6d030f24f
20:54:28:WU00:FS00:0x16:Board Type: AMD/OpenCL
20:54:28:WU00:FS00:0x16:Core : x=16
20:54:28:WU00:FS00:0x16: Window's signal control handler registered.
20:54:28:WU00:FS00:0x16:Preparing to commence simulation
20:54:28:WU00:FS00:0x16:- Looking at optimizations...
20:54:28:WU00:FS00:0x16:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
20:54:28:WU00:FS00:0x16:- Created dyn
20:54:28:WU00:FS00:0x16:- Files status OK
20:54:28:WU00:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:54:28:WU00:FS00:0x16:- Expanded 45049 -> 171163 (decompressed 379.9 percent)
20:54:28:WU00:FS00:0x16:Called DecompressByteArray: compressed_data_size=45049 data_size=171163, decompressed_data_size=171163 diff=0
20:54:28:WU00:FS00:0x16:- Digital signature verified
20:54:28:WU00:FS00:0x16:Project: 11293 (Run 30, Clone 369, Gen 43)
20:54:28:WU00:FS00:0x16:Assembly optimizations on if available.
20:54:28:WU00:FS00:0x16:Entering M.D.
20:54:30:WU00:FS00:0x16:Tpr hash 00/wudata_01.tpr: 8816592 3125653773 1486065052 1079093897 222841049
20:54:30:WU00:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
20:54:30:WU00:FS00:0x16:Client config unavailable.
20:54:30:WU00:FS00:0x16:Starting GUI Server
StitchExperimen
Posts: 37 Joined: Thu Jul 04, 2013 9:29 pm
Post
by StitchExperimen » Sat Jul 20, 2013 9:46 pm
I'm new at this also but either in Web Control or advanced you have to set the power bar to "Full" to get the GPU to work.
Also I would suggest (from my experience) that you free up one core for AMD GPU's and depending on the Nvidia card 1 or 2. Let testing be your guide.
Also stop the project and restart it sometimes I have found the data did then start to flow for the project from the server. In advanced mode on the upper bar highlight it then right click on it and then hit pause and wait then after a several seconds press fold. Then check your log and see if data starts to flow in 30 seconds or so.
The other Bruce
Posts: 20824 Joined: Thu Nov 29, 2007 10:13 pm
Post
by bruce » Sat Jul 20, 2013 11:11 pm
tucker9 wrote: I am new here and want to use my GPU only. My CPU is running BOINC for World Community Grid. Is this possible? It seems everything works and my status shows RUNNING, but my progress stays at 0.00%.
Yes, it's certainly possible. (Though IMHO
FAH will make better use of your CPU that WCG) it's certainly your choice to make. BOINC shouldn't interfere with FAH as long as you tell BOINC not to use one of the CPUs. The primary issue is that by default, the GPU is designed to work like a screensaver without any video; it will only use the GPU when your mouse and keyboard are idle for a period of time. This was done because GPUs have no priority settings so FAH was able to put enough work through the GPU that video was slowed down on some GPUs. In most cases, this doesn't happen, but Stanford didn't want people quitting because they noticed screen lag. Personally, I've never noticed it with my GPUs.
This also can be your choice. FULL should run the GPU constantly; MEDIUM should run the GPU only when the computer is idle.
Posts: 6986 Joined: Wed Dec 23, 2009 9:33 am
Hardware configuration: V7.6.21 -> Multi-purpose 24/7 Windows 10 64-bit CPU:2/3/4/6 -> Intel i7-6700K GPU:1 -> Nvidia GTX 1080 Ti § Retired: 2x Nvidia GTX 1070 Nvidia GTX 675M Nvidia GTX 660 Ti Nvidia GTX 650 SC Nvidia GTX 260 896 MB SOC Nvidia 9600GT 1 GB OC Nvidia 9500M GS Nvidia 8800GTS 320 MB Intel Core i7-860 Intel Core i7-3840QM Intel i3-3240 Intel Core 2 Duo E8200 Intel Core 2 Duo E6550 Intel Core 2 Duo T8300 Intel Pentium E5500 Intel Pentium E5400
Post
by PantherX » Sun Jul 21, 2013 12:34 am
Welcome to the F@H Forum tucker9,
According to the F@H log, it seems that you have a passkey but not a username? Did you intentionally remove it (it is fine if you did) or have you not configured it? Moreover, if you want to use the latest AMD WHQL Drivers and make the most use of your GPU, I would suggest that you configure your Client to advanced to get FahCore_17 WUs which nets a higher PPD when compared to FahCore_16 WUs that you are currently folding. You can achieve that by:
Open Advanced Control (AKA FAHControl) -> Configure -> Slots Tab -> GPU -> Under the Extra slot Options, enter the following:
Value: advanced
Do note that once you have configured your client to advanced, it will increase the probability of you being assigned FahCore_17 WUs but doesn't guarantee it. Do note that if you don't want to configure your GPU Slot for advanced, it too is fine since eventually, the Project will be released to the general public.
tucker9
Post
by tucker9 » Mon Jul 22, 2013 12:13 am
I do not have any CPU slots, however I did try using a CPU slot and the WU on the CPU slot ran, but the WU on the GPU stayed at 0.00%. My status always says RUNNING when the power is set to FULL, but it never progresses past 0.00%. I never entered a username because it was not required. I have started and stopped it several times as well as deleting the GPU slot and re-adding it. It has sat for several days at 0.00%.
Posts: 10179 Joined: Thu Nov 29, 2007 4:30 pm
Post
by 7im » Mon Jul 22, 2013 12:16 am
Is the GPU overclocked?
Post
by PantherX » Mon Jul 22, 2013 12:35 am
If you are using the latest WHQL Drivers (higher than 12.8), then that might be an issue since there are reports that FahCore_16 doesn't function very well with the newer WHQL Drivers. If you have a reason to use the latest drivers, I would suggest that you remove the GPU Slot, and when you add it, make sure that you configure it for advanced WUs as I have stated previously. Hopefully, you will be assigned a FahCore_17 WU that will fold on your system. If you have any issues, please post here and include the fah log.
tucker9
Post
by tucker9 » Wed Jul 24, 2013 3:06 am
Thank you PantherX for the advice, sorry I did not reply sooner. I tried that and it did not help, I am still stuck at 0.00%. And yes, 7im, I guess my GPU is factory overclocked to 790MHz so I changed it to the lowest setting 600 MHz. Still no progress.
Here is my log:
02:55:32:Adding folding slot 00: PAUSED gpu:0:Barts PRO [ATI Radeon HD 6800 Series] (paused)
02:55:32:Removing old file 'configs/config-20130719-001425.xml'
02:55:32:Saving configuration to config.xml
02:55:32:<config>
02:55:32: <!-- Folding Slot Configuration -->
02:55:32: <power v='full'/>
02:55:32:
02:55:32: <!-- Network -->
02:55:32: <proxy v=':8080'/>
02:55:32:
02:55:32: <!-- User Information -->
02:55:32: <passkey v='********************************'/>
02:55:32: <user v='tucker9'/>
02:55:32:
02:55:32: <!-- Folding Slots -->
02:55:32: <slot id='0' type='GPU'>
02:55:32: <client-type v='advanced'/>
02:55:32: </slot>
02:55:32:</config>
02:55:33:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
02:55:33:WU00:FS00:News: Welcome to Folding@Home
02:55:33:WU00:FS00:Assigned to work server 171.64.65.69
02:55:33:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Barts PRO [ATI Radeon HD 6800 Series] from 171.64.65.69
02:55:33:WU00:FS00:Connecting to 171.64.65.69:8080
02:55:33:WU00:FS00:Downloading 4.17MiB
02:55:39:WU00:FS00:Download 56.91%
02:55:46:WU00:FS00:Download 71.89%
02:55:52:WU00:FS00:Download 92.85%
02:55:53:WU00:FS00:Download complete
02:55:53:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:331 clone:1 gen:70 core:0x17 unit:0x0000005a028c126651a6703b9b424e30
02:55:53:WU00:FS00:Starting
02:55:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 4864 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:55:53:WU00:FS00:Started FahCore on PID 4920
02:55:53:WU00:FS00:Core PID:9588
02:55:53:WU00:FS00:FahCore 0x17 started
02:55:54:WU00:FS00:0x17:*********************** Log Started 2013-07-24T02:55:53Z ***********************
02:55:54:WU00:FS00:0x17:Project: 8900 (Run 331, Clone 1, Gen 70)
02:55:54:WU00:FS00:0x17:Unit: 0x0000005a028c126651a6703b9b424e30
02:55:54:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:55:54:WU00:FS00:0x17:Machine: 0
02:55:54:WU00:FS00:0x17:Reading tar file state.xml
02:55:54:WU00:FS00:0x17:Reading tar file system.xml
02:55:55:WU00:FS00:0x17:Reading tar file integrator.xml
02:55:55:WU00:FS00:0x17:Reading tar file core.xml
02:55:55:WU00:FS00:0x17:Digital signatures verified
02:58:32:WU00:FS00:0x17:ERROR:exception: clSetKernelArg
02:58:32:WU00:FS00:0x17:Saving result file logfile_01.txt
02:58:32:WU00:FS00:0x17:Saving result file log.txt
02:58:32:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
02:58:32:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:58:32:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:331 clone:1 gen:70 core:0x17 unit:0x0000005a028c126651a6703b9b424e30
02:58:32:WU00:FS00:Uploading 2.40KiB to 171.64.65.69
02:58:32:WU00:FS00:Connecting to 171.64.65.69:8080
02:58:32:WU00:FS00:Upload complete
02:58:32:WU00:FS00:Server responded WORK_ACK (400)
02:58:32:WU00:FS00:Cleaning up
02:58:32:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
02:58:32:WU01:FS00:News: Welcome to Folding@Home
02:58:32:WU01:FS00:Assigned to work server 171.64.65.69
02:58:32:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Barts PRO [ATI Radeon HD 6800 Series] from 171.64.65.69
02:58:32:WU01:FS00:Connecting to 171.64.65.69:8080
02:58:33:WU01:FS00:Downloading 4.18MiB
02:58:39:WU01:FS00:Download 14.97%
02:58:45:WU01:FS00:Download 47.90%
02:58:51:WU01:FS00:Download 83.83%
02:58:51:WU01:FS00:Download complete
02:58:51:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:940 clone:0 gen:66 core:0x17 unit:0x00000057028c126651a6f7b8fbf98ab2
02:58:51:WU01:FS00:Starting
02:58:51:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4864 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:58:51:WU01:FS00:Started FahCore on PID 10212
02:58:51:WU01:FS00:Core PID:3748
02:58:51:WU01:FS00:FahCore 0x17 started
02:58:52:WU01:FS00:0x17:*********************** Log Started 2013-07-24T02:58:51Z ***********************
02:58:52:WU01:FS00:0x17:Project: 8900 (Run 940, Clone 0, Gen 66)
02:58:52:WU01:FS00:0x17:Unit: 0x00000057028c126651a6f7b8fbf98ab2
02:58:52:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:58:52:WU01:FS00:0x17:Machine: 0
02:58:52:WU01:FS00:0x17:Reading tar file state.xml
02:58:52:WU01:FS00:0x17:Reading tar file system.xml
02:58:53:WU01:FS00:0x17:Reading tar file integrator.xml
02:58:53:WU01:FS00:0x17:Reading tar file core.xml
02:58:53:WU01:FS00:0x17:Digital signatures verified
03:01:24:WU01:FS00:0x17:ERROR:exception: clSetKernelArg
03:01:24:WU01:FS00:0x17:Saving result file logfile_01.txt
03:01:24:WU01:FS00:0x17:Saving result file log.txt
03:01:24:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
03:01:24:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:01:24:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:940 clone:0 gen:66 core:0x17 unit:0x00000057028c126651a6f7b8fbf98ab2
03:01:24:WU01:FS00:Uploading 2.40KiB to 171.64.65.69
03:01:24:WU01:FS00:Connecting to 171.64.65.69:8080
03:01:25:WU01:FS00:Upload complete
03:01:25:WU01:FS00:Server responded WORK_ACK (400)
03:01:25:WU01:FS00:Cleaning up
03:01:25:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
03:01:25:WU00:FS00:News: Welcome to Folding@Home
03:01:25:WU00:FS00:Assigned to work server 171.64.65.69
03:01:25:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Barts PRO [ATI Radeon HD 6800 Series] from 171.64.65.69
03:01:25:WU00:FS00:Connecting to 171.64.65.69:8080
03:01:25:WU00:FS00:Downloading 4.18MiB
03:01:31:WU00:FS00:Download 32.93%
03:01:37:WU00:FS00:Download 55.39%
03:01:43:WU00:FS00:Download 73.35%
03:01:47:WU00:FS00:Download complete
03:01:47:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:540 clone:1 gen:66 core:0x17 unit:0x0000004e028c126651a69ece5763e274
03:01:47:WU00:FS00:Starting
03:01:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 4864 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:01:47:WU00:FS00:Started FahCore on PID 3160
03:01:47:WU00:FS00:Core PID:8644
03:01:47:WU00:FS00:FahCore 0x17 started
03:01:48:WU00:FS00:0x17:*********************** Log Started 2013-07-24T03:01:48Z ***********************
03:01:48:WU00:FS00:0x17:Project: 8900 (Run 540, Clone 1, Gen 66)
03:01:48:WU00:FS00:0x17:Unit: 0x0000004e028c126651a69ece5763e274
03:01:48:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:01:48:WU00:FS00:0x17:Machine: 0
03:01:48:WU00:FS00:0x17:Reading tar file state.xml
03:01:49:WU00:FS00:0x17:Reading tar file system.xml
03:01:49:WU00:FS00:0x17:Reading tar file integrator.xml
03:01:49:WU00:FS00:0x17:Reading tar file core.xml
03:01:49:WU00:FS00:0x17:Digital signatures verified
03:04:18:WU00:FS00:0x17:ERROR:exception: clSetKernelArg
03:04:18:WU00:FS00:0x17:Saving result file logfile_01.txt
03:04:18:WU00:FS00:0x17:Saving result file log.txt
03:04:18:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
03:04:18:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:04:18:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:540 clone:1 gen:66 core:0x17 unit:0x0000004e028c126651a69ece5763e274
03:04:18:WU00:FS00:Uploading 2.40KiB to 171.64.65.69
03:04:18:WU00:FS00:Connecting to 171.64.65.69:8080
03:04:19:WU00:FS00:Upload complete
03:04:19:WU00:FS00:Server responded WORK_ACK (400)
03:04:19:WU00:FS00:Cleaning up
03:04:19:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
03:04:19:WU01:FS00:News: Welcome to Folding@Home
03:04:19:WU01:FS00:Assigned to work server 171.64.65.69
03:04:19:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Barts PRO [ATI Radeon HD 6800 Series] from 171.64.65.69
03:04:19:WU01:FS00:Connecting to 171.64.65.69:8080
03:04:20:WU01:FS00:Downloading 4.17MiB
03:04:26:WU01:FS00:Download 22.46%
03:04:32:WU01:FS00:Download 47.91%
03:04:38:WU01:FS00:Download 73.37%
03:04:44:WU01:FS00:Download 92.83%
03:04:45:WU01:FS00:Download complete
03:04:45:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:19 clone:1 gen:87 core:0x17 unit:0x0000006e028c1266519a633e9d06d95c
03:04:45:WU01:FS00:Starting
03:04:45:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4864 -checkpoint 15 -gpu 0 -gpu-vendor ati
03:04:45:WU01:FS00:Started FahCore on PID 9420
03:04:45:WU01:FS00:Core PID:3760
03:04:45:WU01:FS00:FahCore 0x17 started
03:04:46:WU01:FS00:0x17:*********************** Log Started 2013-07-24T03:04:45Z ***********************
03:04:46:WU01:FS00:0x17:Project: 8900 (Run 19, Clone 1, Gen 87)
03:04:46:WU01:FS00:0x17:Unit: 0x0000006e028c1266519a633e9d06d95c
03:04:46:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
03:04:46:WU01:FS00:0x17:Machine: 0
03:04:46:WU01:FS00:0x17:Reading tar file state.xml
03:04:46:WU01:FS00:0x17:Reading tar file system.xml
03:04:47:WU01:FS00:0x17:Reading tar file integrator.xml
03:04:47:WU01:FS00:0x17:Reading tar file core.xml
03:04:47:WU01:FS00:0x17:Digital signatures verified
P5-133XL
Posts: 2948 Joined: Sun Dec 02, 2007 4:36 am
Hardware configuration: Machine #1: Intel Q9450; 2x2GB=8GB Ram; Gigabyte GA-X48-DS4 Motherboard; PC Power and Cooling Q750 PS; 2x GTX 460; Windows Server 2008 X64 (SP1). Machine #2: Intel Q6600; 2x2GB=4GB Ram; Gigabyte GA-X48-DS4 Motherboard; PC Power and Cooling Q750 PS; 2x GTX 460 video card; Windows 7 X64. Machine 3: Dell Dimension 8400, 3.2GHz P4 4x512GB Ram, Video card GTX 460, Windows 7 X32 I am currently folding just on the 5x GTX 460's for aprox. 70K PPD
Post
by P5-133XL » Wed Jul 24, 2013 3:35 am
You say that your CPU is dedicated to BOINC (which is fine) but Nvidia GPU's need at least one full CPU core available to run p8900's (Core_17). I do not know if you are running an Nvidia GPU nor do I know if you have given the GPU client access to a full CPU core but that could be a reason why the GPU client stays at 0%. You may want to suspend BOINC processing (for at least an hour) to see if that has any effect.
tucker9
Post
by tucker9 » Wed Jul 24, 2013 2:38 pm
I am now seeing an error: :ERROR:exception: clSetKernelArg.
Log:
14:26:53: <!-- Folding Slots -->
14:26:53: <slot id='0' type='GPU'>
14:26:53: <client-type v='advanced'/>
14:26:53: </slot>
14:26:53:</config>
14:26:53:Trying to access database...
14:26:53:Successfully acquired database lock
14:26:53:Enabled folding slot 00: READY gpu:0:Barts PRO [ATI Radeon HD 6800 Series]
14:26:53:WU01:FS00:Starting
14:26:53:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4896 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:26:53:WU01:FS00:Started FahCore on PID 5304
14:26:53:WU01:FS00:Core PID:5336
14:26:53:WU01:FS00:FahCore 0x17 started
14:26:54:WU01:FS00:0x17:*********************** Log Started 2013-07-24T14:26:53Z ***********************
14:26:54:WU01:FS00:0x17:Project: 8900 (Run 711, Clone 0, Gen 90)
14:26:54:WU01:FS00:0x17:Unit: 0x00000073028c126651a6c4c153223013
14:26:54:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
14:26:54:WU01:FS00:0x17:Machine: 0
14:26:54:WU01:FS00:0x17:Reading tar file state.xml
14:26:55:WU01:FS00:0x17:Reading tar file system.xml
14:26:55:WU01:FS00:0x17:Reading tar file integrator.xml
14:26:55:WU01:FS00:0x17:Reading tar file core.xml
14:26:55:WU01:FS00:0x17:Digital signatures verified
14:28:27:WU01:FS00:0x17:ERROR:exception: clSetKernelArg
14:28:27:WU01:FS00:0x17:Saving result file logfile_01.txt
14:28:27:WU01:FS00:0x17:Saving result file log.txt
14:28:27:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
14:28:27:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:28:27:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:711 clone:0 gen:90 core:0x17 unit:0x00000073028c126651a6c4c153223013
14:28:27:WU01:FS00:Uploading 2.74KiB to 171.64.65.69
14:28:27:WU01:FS00:Connecting to 171.64.65.69:8080
14:28:28:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:28:28:WU00:FS00:News: Welcome to Folding@Home
14:28:28:WU00:FS00:Assigned to work server 171.64.65.69
14:28:28:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Barts PRO [ATI Radeon HD 6800 Series] from 171.64.65.69
14:28:28:WU00:FS00:Connecting to 171.64.65.69:8080
14:28:28:WU01:FS00:Upload complete
14:28:29:WU01:FS00:Server responded WORK_ACK (400)
14:28:29:WU01:FS00:Cleaning up
14:28:29:WU00:FS00:Downloading 4.18MiB
14:28:31:WU00:FS00:Download complete
14:28:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:20 clone:2 gen:69 core:0x17 unit:0x00000056028c1266519a637d0dd44c5d
14:28:31:WU00:FS00:Starting
14:28:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Tt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 4896 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:28:31:WU00:FS00:Started FahCore on PID 7000
14:28:31:WU00:FS00:Core PID:7812
14:28:31:WU00:FS00:FahCore 0x17 started
14:28:32:WU00:FS00:0x17:*********************** Log Started 2013-07-24T14:28:31Z ***********************
14:28:32:WU00:FS00:0x17:Project: 8900 (Run 20, Clone 2, Gen 69)
14:28:32:WU00:FS00:0x17:Unit: 0x00000056028c1266519a637d0dd44c5d
14:28:32:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
14:28:32:WU00:FS00:0x17:Machine: 0
14:28:32:WU00:FS00:0x17:Reading tar file state.xml
14:28:32:WU00:FS00:0x17:Reading tar file system.xml
14:28:33:WU00:FS00:0x17:Reading tar file integrator.xml
14:28:33:WU00:FS00:0x17:Reading tar file core.xml
14:28:33:WU00:FS00:0x17:Digital signatures verified
Post
by 7im » Wed Jul 24, 2013 3:12 pm
Need to see the system section of the log please.
tucker9
Post
by tucker9 » Wed Jul 24, 2013 6:00 pm
System section of log:
14:26:53:******************************* System ********************************
14:26:53: CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
14:26:53: CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
14:26:53: CPUs: 8
14:26:53: Memory: 15.88GiB
14:26:53: Free Memory: 14.22GiB
14:26:53: Threads: WINDOWS_THREADS
14:26:53: Has Battery: false
14:26:53: On Battery: false
14:26:53: UTC offset: -5
14:26:53: PID: 4896
14:26:53: CWD: C:/Users/Tt/AppData/Roaming/FAHClient
14:26:53: OS: Windows 7 Professional
14:26:53: OS Arch: AMD64
14:26:53: GPUs: 1
14:26:53: GPU 0: ATI:4 Barts PRO [ATI Radeon HD 6800 Series]
14:26:53: CUDA: Not detected
14:26:53:Win32 Service: false
14:26:53:***********************************************************************
tucker9
Post
by tucker9 » Thu Jul 25, 2013 3:33 am
It's working!!!! I tried various versions of drivers (AMD Catalyst) with FahCore_16 and 17. The combination of AMD Catalyst v13.4 and FahCore_17 did the trick. My card is an ASUS EAH6850 and this version is not on the Asus download website. I hope this helps anyone else who experiences the same problem.
Thanks for all the help!
