Having failed errors on 8900 projects.
StitchExperimen
Post by StitchExperimen »
Right now I have one 8900 that is running in Slot 1 at 7.5%.
I went and did a days worth of SETI for an upcoming race in a month and now am back doing FAH. I was running on 1 660 Ti because of heat and now installed a window air conditioner and started up the other card again. The fails started as best as I can tell before the work unit was started in the progress meter. This computer is used by a different person and had installed a McAfee scan program which I uninstalled. Virus scanning is by Norton Suite. There have been a few updates to Nvidia's G-Force Experience game tuning software but there are no games on the machine, also drivers 320.49 on the 13th. Adobe Flash player on the 16th. PDF-Xchange 3 on the 16th.
In the past I have had no errors from the GPUs.
Machine is Win7 Pro
8 GB 2166 memory
Win 7 SP1 + updates
two Nvidia Galaxy 660 Ti
3770K @ 4.5
closed loop water cooling
MB ASRock OC Formula
*********************** Log Started 2013-07-19T12:01:56Z ***********************
12:01:56:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
12:01:57:WU01:FS00:News: Welcome to Folding@Home
12:01:57:WU01:FS00:Assigned to work server 171.64.65.69
12:01:57:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:01:57:WU01:FS00:Connecting to 171.64.65.69:8080
12:01:57:WU01:FS00:Downloading 4.18MiB
12:01:59:WU01:FS00:Download complete
12:01:59:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:263 clone:1 gen:47 core:0x17 unit:0x00000037028c126651a661179511818a
12:01:59:WU01:FS00:Starting
12:01:59:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:02:05:WU01:FS00:Started FahCore on PID 3968
12:02:12:WU01:FS00:Core PID:6084
12:02:12:WU01:FS00:FahCore 0x17 started
12:02:25:WU01:FS00:0x17:*********************** Log Started 2013-07-19T12:02:25Z ***********************
12:02:25:WU01:FS00:0x17:Project: 8900 (Run 263, Clone 1, Gen 47)
12:02:25:WU01:FS00:0x17:Unit: 0x00000037028c126651a661179511818a
12:02:25:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:02:25:WU01:FS00:0x17:Machine: 0
12:02:25:WU01:FS00:0x17:Reading tar file state.xml
12:02:26:WU01:FS00:0x17:Reading tar file system.xml
12:02:26:WU01:FS00:0x17:Reading tar file integrator.xml
12:02:26:WU01:FS00:0x17:Reading tar file core.xml
12:02:26:WU01:FS00:0x17:Digital signatures verified
12:03:45:WU01:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:03:45:WU01:FS00:0x17:Saving result file logfile_01.txt
12:03:45:WU01:FS00:0x17:Saving result file log.txt
12:03:45:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:03:46:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:03:46:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:263 clone:1 gen:47 core:0x17 unit:0x00000037028c126651a661179511818a
12:03:46:WU01:FS00:Uploading 2.53KiB to 171.64.65.69
12:03:46:WU01:FS00:Connecting to 171.64.65.69:8080
12:03:46:WU01:FS00:Upload complete
12:03:46:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:03:47:WU01:FS00:Server responded WORK_ACK (400)
12:03:47:WU01:FS00:Cleaning up
12:03:47:WU02:FS00:News: Welcome to Folding@Home
12:03:47:WU02:FS00:Assigned to work server 171.64.65.69
12:03:47:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:03:47:WU02:FS00:Connecting to 171.64.65.69:8080
12:03:48:WU02:FS00:Downloading 4.18MiB
12:03:49:WU02:FS00:Download complete
12:03:50:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:99 clone:0 gen:75 core:0x17 unit:0x00000062028c126651a63c742ff73399
12:03:50:WU02:FS00:Starting
12:03:50:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:03:50:WU02:FS00:Started FahCore on PID 5524
12:03:50:WU02:FS00:Core PID:1784
12:03:50:WU02:FS00:FahCore 0x17 started
12:03:50:WU02:FS00:0x17:*********************** Log Started 2013-07-19T12:03:50Z ***********************
12:03:50:WU02:FS00:0x17:Project: 8900 (Run 99, Clone 0, Gen 75)
12:03:50:WU02:FS00:0x17:Unit: 0x00000062028c126651a63c742ff73399
12:03:50:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:03:50:WU02:FS00:0x17:Machine: 0
12:03:50:WU02:FS00:0x17:Reading tar file state.xml
12:03:51:WU02:FS00:0x17:Reading tar file system.xml
12:03:51:WU02:FS00:0x17:Reading tar file integrator.xml
12:03:51:WU02:FS00:0x17:Reading tar file core.xml
12:03:51:WU02:FS00:0x17:Digital signatures verified
12:05:03:WU02:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:05:03:WU02:FS00:0x17:Saving result file logfile_01.txt
12:05:03:WU02:FS00:0x17:Saving result file log.txt
12:05:03:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:05:03:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:05:03:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:99 clone:0 gen:75 core:0x17 unit:0x00000062028c126651a63c742ff73399
12:05:03:WU02:FS00:Uploading 2.54KiB to 171.64.65.69
12:05:03:WU02:FS00:Connecting to 171.64.65.69:8080
12:05:03:WU02:FS00:Upload complete
12:05:03:WU02:FS00:Server responded WORK_ACK (400)
12:05:03:WU02:FS00:Cleaning up
12:05:03:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
12:05:04:WU01:FS00:News: Welcome to Folding@Home
12:05:04:WU01:FS00:Assigned to work server 171.64.65.69
12:05:04:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:05:04:WU01:FS00:Connecting to 171.64.65.69:8080
12:05:04:WU01:FS00:Downloading 4.18MiB
12:05:06:WU01:FS00:Download complete
12:05:06:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:276 clone:1 gen:76 core:0x17 unit:0x00000060028c126651a663fcdf17eeb1
12:05:06:WU01:FS00:Starting
12:05:06:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:05:06:WU01:FS00:Started FahCore on PID 2336
12:05:06:WU01:FS00:Core PID:3008
12:05:06:WU01:FS00:FahCore 0x17 started
12:05:07:WU01:FS00:0x17:*********************** Log Started 2013-07-19T12:05:06Z ***********************
12:05:07:WU01:FS00:0x17:Project: 8900 (Run 276, Clone 1, Gen 76)
12:05:07:WU01:FS00:0x17:Unit: 0x00000060028c126651a663fcdf17eeb1
12:05:07:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:05:07:WU01:FS00:0x17:Machine: 0
12:05:07:WU01:FS00:0x17:Reading tar file state.xml
12:05:07:WU01:FS00:0x17:Reading tar file system.xml
12:05:07:WU01:FS00:0x17:Reading tar file integrator.xml
12:05:07:WU01:FS00:0x17:Reading tar file core.xml
12:05:07:WU01:FS00:0x17:Digital signatures verified
12:06:18:WU01:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:06:18:WU01:FS00:0x17:Saving result file logfile_01.txt
12:06:18:WU01:FS00:0x17:Saving result file log.txt
12:06:18:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:06:19:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:06:19:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:276 clone:1 gen:76 core:0x17 unit:0x00000060028c126651a663fcdf17eeb1
12:06:19:WU01:FS00:Uploading 2.54KiB to 171.64.65.69
12:06:19:WU01:FS00:Connecting to 171.64.65.69:8080
12:06:19:WU01:FS00:Upload complete
12:06:19:WU01:FS00:Server responded WORK_ACK (400)
12:06:19:WU01:FS00:Cleaning up
12:06:19:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:06:19:WU02:FS00:News: Welcome to Folding@Home
12:06:19:WU02:FS00:Assigned to work server 171.64.65.69
12:06:19:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:06:19:WU02:FS00:Connecting to 171.64.65.69:8080
12:06:19:WU02:FS00:Downloading 4.17MiB
12:06:21:WU02:FS00:Download complete
12:06:21:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:193 clone:0 gen:63 core:0x17 unit:0x00000054028c126651a65175100b8b16
12:06:21:WU02:FS00:Starting
12:06:21:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:06:21:WU02:FS00:Started FahCore on PID 4304
12:06:21:WU02:FS00:Core PID:1696
12:06:21:WU02:FS00:FahCore 0x17 started
12:06:22:WU02:FS00:0x17:*********************** Log Started 2013-07-19T12:06:21Z ***********************
12:06:22:WU02:FS00:0x17:Project: 8900 (Run 193, Clone 0, Gen 63)
12:06:22:WU02:FS00:0x17:Unit: 0x00000054028c126651a65175100b8b16
12:06:22:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:06:22:WU02:FS00:0x17:Machine: 0
12:06:22:WU02:FS00:0x17:Reading tar file state.xml
12:06:22:WU02:FS00:0x17:Reading tar file system.xml
12:06:22:WU02:FS00:0x17:Reading tar file integrator.xml
12:06:22:WU02:FS00:0x17:Reading tar file core.xml
12:06:22:WU02:FS00:0x17:Digital signatures verified
12:07:33:WU02:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:07:33:WU02:FS00:0x17:Saving result file logfile_01.txt
12:07:33:WU02:FS00:0x17:Saving result file log.txt
12:07:33:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:07:34:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:07:34:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:193 clone:0 gen:63 core:0x17 unit:0x00000054028c126651a65175100b8b16
12:07:34:WU02:FS00:Uploading 2.54KiB to 171.64.65.69
12:07:34:WU02:FS00:Connecting to 171.64.65.69:8080
12:07:34:WU02:FS00:Upload complete
12:07:34:WU02:FS00:Server responded WORK_ACK (400)
12:07:34:WU02:FS00:Cleaning up
12:07:34:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
12:07:34:WU01:FS00:News: Welcome to Folding@Home
12:07:34:WU01:FS00:Assigned to work server 171.64.65.69
12:07:34:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:07:34:WU01:FS00:Connecting to 171.64.65.69:8080
12:07:34:WU01:FS00:Downloading 4.18MiB
12:07:36:WU01:FS00:Download complete
12:07:36:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:35 clone:0 gen:54 core:0x17 unit:0x00000049028c1266519a66c7dd86ab82
12:07:36:WU01:FS00:Starting
12:07:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:07:36:WU01:FS00:Started FahCore on PID 5004
12:07:36:WU01:FS00:Core PID:5860
12:07:36:WU01:FS00:FahCore 0x17 started
12:07:37:WU01:FS00:0x17:*********************** Log Started 2013-07-19T12:07:36Z ***********************
12:07:37:WU01:FS00:0x17:Project: 8900 (Run 35, Clone 0, Gen 54)
12:07:37:WU01:FS00:0x17:Unit: 0x00000049028c1266519a66c7dd86ab82
12:07:37:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:07:37:WU01:FS00:0x17:Machine: 0
12:07:37:WU01:FS00:0x17:Reading tar file state.xml
12:07:37:WU01:FS00:0x17:Reading tar file system.xml
12:07:37:WU01:FS00:0x17:Reading tar file integrator.xml
12:07:37:WU01:FS00:0x17:Reading tar file core.xml
12:07:37:WU01:FS00:0x17:Digital signatures verified
12:08:48:WU01:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:08:48:WU01:FS00:0x17:Saving result file logfile_01.txt
12:08:48:WU01:FS00:0x17:Saving result file log.txt
12:08:48:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:08:49:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:08:49:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:35 clone:0 gen:54 core:0x17 unit:0x00000049028c1266519a66c7dd86ab82
12:08:49:WU01:FS00:Uploading 2.54KiB to 171.64.65.69
12:08:49:WU01:FS00:Connecting to 171.64.65.69:8080
12:08:49:WU01:FS00:Upload complete
12:08:49:WU01:FS00:Server responded WORK_ACK (400)
12:08:49:WU01:FS00:Cleaning up
Bruce G.
More code failed again
12:09:21:WU00:FS01:0x17:Completed 25000 out of 2500000 steps (1%)
12:14:32:WU00:FS01:0x17:Completed 50000 out of 2500000 steps (2%)
12:19:54:WU00:FS01:0x17:Completed 75000 out of 2500000 steps (3%)
12:25:08:WU00:FS01:0x17:Completed 100000 out of 2500000 steps (4%)
12:30:31:WU00:FS01:0x17:Completed 125000 out of 2500000 steps (5%)
12:35:43:WU00:FS01:0x17:Completed 150000 out of 2500000 steps (6%)
12:41:05:WU00:FS01:0x17:Completed 175000 out of 2500000 steps (7%)
12:46:18:WU00:FS01:0x17:Completed 200000 out of 2500000 steps (8%)
12:48:07:FS00:Finishing
12:48:40:FS00:Paused
12:49:11:FS00:Unpaused
12:49:11:FS00:Finishing
12:49:16:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
12:49:17:WU01:FS00:News: Welcome to Folding@Home
12:49:17:WU01:FS00:Assigned to work server 171.64.65.69
12:49:17:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:49:17:WU01:FS00:Connecting to 171.64.65.69:8080
12:49:17:WU01:FS00:Downloading 4.18MiB
12:49:19:WU01:FS00:Download complete
12:49:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:671 clone:1 gen:83 core:0x17 unit:0x00000063028c126651a6bbe342e4ed14
12:49:19:WU01:FS00:Starting
12:49:19:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:49:19:WU01:FS00:Started FahCore on PID 1448
12:49:19:WU01:FS00:Core PID:5232
12:49:19:WU01:FS00:FahCore 0x17 started
12:49:19:WU01:FS00:0x17:*********************** Log Started 2013-07-19T12:49:19Z ***********************
12:49:19:WU01:FS00:0x17:Project: 8900 (Run 671, Clone 1, Gen 83)
12:49:19:WU01:FS00:0x17:Unit: 0x00000063028c126651a6bbe342e4ed14
12:49:19:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:49:19:WU01:FS00:0x17:Machine: 0
12:49:19:WU01:FS00:0x17:Reading tar file state.xml
12:49:20:WU01:FS00:0x17:Reading tar file system.xml
12:49:20:WU01:FS00:0x17:Reading tar file integrator.xml
12:49:20:WU01:FS00:0x17:Reading tar file core.xml
12:49:20:WU01:FS00:0x17:Digital signatures verified
12:50:30:WU01:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:50:30:WU01:FS00:0x17:Saving result file logfile_01.txt
12:50:30:WU01:FS00:0x17:Saving result file log.txt
12:50:30:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:50:30:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:50:30:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:671 clone:1 gen:83 core:0x17 unit:0x00000063028c126651a6bbe342e4ed14
12:50:30:WU01:FS00:Uploading 2.54KiB to 171.64.65.69
12:50:30:WU01:FS00:Connecting to 171.64.65.69:8080
12:50:30:WU01:FS00:Upload complete
12:50:30:WU01:FS00:Server responded WORK_ACK (400)
12:50:30:WU01:FS00:Cleaning up
12:50:31:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:50:31:WU02:FS00:News: Welcome to Folding@Home
12:50:31:WU02:FS00:Assigned to work server 171.64.65.69
12:50:31:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:50:31:WU02:FS00:Connecting to 171.64.65.69:8080
12:50:31:WU02:FS00:Downloading 4.17MiB
12:50:33:WU02:FS00:Download complete
12:50:33:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:305 clone:1 gen:73 core:0x17 unit:0x0000005f028c126651a66a7433e010a6
12:50:33:WU02:FS00:Starting
12:50:33:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:50:33:WU02:FS00:Started FahCore on PID 2800
12:50:33:WU02:FS00:Core PID:5156
12:50:33:WU02:FS00:FahCore 0x17 started
12:50:33:WU02:FS00:0x17:*********************** Log Started 2013-07-19T12:50:33Z ***********************
12:50:33:WU02:FS00:0x17:Project: 8900 (Run 305, Clone 1, Gen 73)
12:50:33:WU02:FS00:0x17:Unit: 0x0000005f028c126651a66a7433e010a6
12:50:33:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:50:33:WU02:FS00:0x17:Machine: 0
12:50:33:WU02:FS00:0x17:Reading tar file state.xml
12:50:34:WU02:FS00:0x17:Reading tar file system.xml
12:50:34:WU02:FS00:0x17:Reading tar file integrator.xml
12:50:34:WU02:FS00:0x17:Reading tar file core.xml
12:50:34:WU02:FS00:0x17:Digital signatures verified
12:51:37:WU00:FS01:0x17:Completed 225000 out of 2500000 steps (9%)
12:51:44:WU02:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:51:44:WU02:FS00:0x17:Saving result file logfile_01.txt
12:51:44:WU02:FS00:0x17:Saving result file log.txt
12:51:44:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:51:44:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:51:44:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:305 clone:1 gen:73 core:0x17 unit:0x0000005f028c126651a66a7433e010a6
12:51:44:WU02:FS00:Uploading 2.54KiB to 171.64.65.69
12:51:44:WU02:FS00:Connecting to 171.64.65.69:8080
12:51:44:WU02:FS00:Upload complete
12:51:44:WU02:FS00:Server responded WORK_ACK (400)
12:51:44:WU02:FS00:Cleaning up
12:51:44:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
12:51:45:WU01:FS00:News: Welcome to Folding@Home
12:51:45:WU01:FS00:Assigned to work server 171.64.65.69
12:51:45:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:51:45:WU01:FS00:Connecting to 171.64.65.69:8080
12:51:45:WU01:FS00:Downloading 4.17MiB
12:51:47:WU01:FS00:Download complete
12:51:47:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:21 clone:1 gen:92 core:0x17 unit:0x00000076028c1266519a63b0f35896b5
12:51:47:WU01:FS00:Starting
12:51:47:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:51:47:WU01:FS00:Started FahCore on PID 2984
12:51:47:WU01:FS00:Core PID:1868
12:51:47:WU01:FS00:FahCore 0x17 started
12:51:47:WU01:FS00:0x17:*********************** Log Started 2013-07-19T12:51:47Z ***********************
12:51:47:WU01:FS00:0x17:Project: 8900 (Run 21, Clone 1, Gen 92)
12:51:47:WU01:FS00:0x17:Unit: 0x00000076028c1266519a63b0f35896b5
12:51:47:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:51:47:WU01:FS00:0x17:Machine: 0
12:51:47:WU01:FS00:0x17:Reading tar file state.xml
12:51:48:WU01:FS00:0x17:Reading tar file system.xml
12:51:48:WU01:FS00:0x17:Reading tar file integrator.xml
12:51:48:WU01:FS00:0x17:Reading tar file core.xml
12:51:48:WU01:FS00:0x17:Digital signatures verified
12:52:58:WU01:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:52:58:WU01:FS00:0x17:Saving result file logfile_01.txt
12:52:58:WU01:FS00:0x17:Saving result file log.txt
12:52:58:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:52:58:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:52:58:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:21 clone:1 gen:92 core:0x17 unit:0x00000076028c1266519a63b0f35896b5
12:52:58:WU01:FS00:Uploading 2.53KiB to 171.64.65.69
12:52:58:WU01:FS00:Connecting to 171.64.65.69:8080
12:52:58:WU01:FS00:Upload complete
12:52:58:WU01:FS00:Server responded WORK_ACK (400)
12:52:58:WU01:FS00:Cleaning up
12:52:59:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:52:59:WU02:FS00:News: Welcome to Folding@Home
12:52:59:WU02:FS00:Assigned to work server 171.64.65.69
12:52:59:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:52:59:WU02:FS00:Connecting to 171.64.65.69:8080
12:52:59:WU02:FS00:Downloading 4.17MiB
12:53:01:WU02:FS00:Download complete
12:53:01:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:12 clone:1 gen:64 core:0x17 unit:0x00000058028c1266519a61b27add38ea
12:53:01:WU02:FS00:Starting
12:53:01:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:53:01:WU02:FS00:Started FahCore on PID 4952
12:53:01:WU02:FS00:Core PID:2724
12:53:01:WU02:FS00:FahCore 0x17 started
12:53:01:WU02:FS00:0x17:*********************** Log Started 2013-07-19T12:53:01Z ***********************
12:53:01:WU02:FS00:0x17:Project: 8900 (Run 12, Clone 1, Gen 64)
12:53:01:WU02:FS00:0x17:Unit: 0x00000058028c1266519a61b27add38ea
12:53:01:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:53:01:WU02:FS00:0x17:Machine: 0
12:53:01:WU02:FS00:0x17:Reading tar file state.xml
12:53:02:WU02:FS00:0x17:Reading tar file system.xml
12:53:02:WU02:FS00:0x17:Reading tar file integrator.xml
12:53:02:WU02:FS00:0x17:Reading tar file core.xml
12:53:02:WU02:FS00:0x17:Digital signatures verified
12:54:12:WU02:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:54:12:WU02:FS00:0x17:Saving result file logfile_01.txt
12:54:12:WU02:FS00:0x17:Saving result file log.txt
12:54:12:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:54:12:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:54:12:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:12 clone:1 gen:64 core:0x17 unit:0x00000058028c1266519a61b27add38ea
12:54:12:WU02:FS00:Uploading 2.54KiB to 171.64.65.69
12:54:12:WU02:FS00:Connecting to 171.64.65.69:8080
12:54:13:WU02:FS00:Upload complete
12:54:13:WU02:FS00:Server responded WORK_ACK (400)
12:54:13:WU02:FS00:Cleaning up
12:54:13:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
12:54:13:WU01:FS00:News: Welcome to Folding@Home
12:54:13:WU01:FS00:Assigned to work server 171.64.65.69
12:54:13:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:GK104 [GeForce GTX 660 Ti] from 171.64.65.69
12:54:13:WU01:FS00:Connecting to 171.64.65.69:8080
12:54:13:WU01:FS00:Downloading 4.18MiB
12:54:15:WU01:FS00:Download complete
12:54:15:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:758 clone:0 gen:57 core:0x17 unit:0x00000052028c126651a6cf3ad448de52
12:54:15:WU01:FS00:Starting
12:54:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4284 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
12:54:15:WU01:FS00:Started FahCore on PID 4272
12:54:15:WU01:FS00:Core PID:5728
12:54:15:WU01:FS00:FahCore 0x17 started
12:54:16:WU01:FS00:0x17:*********************** Log Started 2013-07-19T12:54:15Z ***********************
12:54:16:WU01:FS00:0x17:Project: 8900 (Run 758, Clone 0, Gen 57)
12:54:16:WU01:FS00:0x17:Unit: 0x00000052028c126651a6cf3ad448de52
12:54:16:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:54:16:WU01:FS00:0x17:Machine: 0
12:54:16:WU01:FS00:0x17:Reading tar file state.xml
12:54:16:WU01:FS00:0x17:Reading tar file system.xml
12:54:16:WU01:FS00:0x17:Reading tar file integrator.xml
12:54:16:WU01:FS00:0x17:Reading tar file core.xml
12:54:16:WU01:FS00:0x17:Digital signatures verified
12:55:26:WU01:FS00:0x17:ERROR:exception: Error invoking kernel updateBsplines: clEnqueueNDRangeKernel (-4)
12:55:26:WU01:FS00:0x17:Saving result file logfile_01.txt
12:55:26:WU01:FS00:0x17:Saving result file log.txt
12:55:26:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
12:55:27:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
12:55:27:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:758 clone:0 gen:57 core:0x17 unit:0x00000052028c126651a6cf3ad448de52
12:55:27:WU01:FS00:Uploading 2.54KiB to 171.64.65.69
12:55:27:WU01:FS00:Connecting to 171.64.65.69:8080
12:55:27:WU01:FS00:Upload complete
12:55:27:WU01:FS00:Server responded WORK_ACK (400)
12:55:27:WU01:FS00:Cleaning up
folding_hoomer
Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300
Re: Having failed errors on 8900 projects.
Post by folding_hoomer »
While one GTX660Ti is folding without any issue i think failure of the second one is a consequence of overclocking - so set the frequencies to stock and try again.
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
Core_17 is very sensitive to OC'ing (much more than previous GPU cores) so just don't, or be prepared to spend a lot of time trying to find it limits.
If you are overclocking and encountering failures, please safe a copy of the WU, disconnect from the internet and perform your testing since we don't encourage testing with live WUs as you can cause unnecessary delay to the Project as the WUs are reissued and processed multiple times.
Other pointers to help you troubleshoot:
Did you do a clean installation of the latest WHQL Drivers?
Have you tried to downloading a new copy of FahCore (once the GPU has finished the WU, exit the client, delete the FahCore folder and restart the Client)?
Have you excluded FahCore from Norton scanning?
Are there any anomalies in the GPU frequencies (check by using MSI Afterburner or EVGA Precision X, etc)?
StitchExperimen
I wrote comments to each suggestion and the forum ate the work. <sigh>
StitchExperimen
I have a work unit that appears to not upload due to errors.
I have a work unit that is not uploading.
I have looked in the wu file in the ProgramData and found this.
This is on a HD 7950
The wu it is processing now has no errors.
The card is not o/c.
I did shut down the computer for some maintenance though now that I think about it.
*********************** Log Started 2013-07-18T03:48:53Z ***********************
Project: 8900 (Run 177, Clone 1, Gen 80)
Unit: 0x00000064028c126651a64de8c52f5593
Machine: 0
  Found a checkpoint file
Completed 1800000 out of 2500000 steps (72%)
Completed 1825000 out of 2500000 steps (73%)
Completed 1850000 out of 2500000 steps (74%)
Completed 1875000 out of 2500000 steps (75%)
Completed 1900000 out of 2500000 steps (76%)
Completed 1925000 out of 2500000 steps (77%)
Completed 1950000 out of 2500000 steps (78%)
Completed 1975000 out of 2500000 steps (79%)
Completed 2000000 out of 2500000 steps (80%)
Completed 2025000 out of 2500000 steps (81%)
Completed 2050000 out of 2500000 steps (82%)
Completed 2075000 out of 2500000 steps (83%)
Completed 2100000 out of 2500000 steps (84%)
Completed 2125000 out of 2500000 steps (85%)
Completed 2150000 out of 2500000 steps (86%)
Completed 2175000 out of 2500000 steps (87%)
Completed 2200000 out of 2500000 steps (88%)
Completed 2225000 out of 2500000 steps (89%)
Completed 2250000 out of 2500000 steps (90%)
Bad State detected... attempting to resume from last good checkpoint
Completed 2275000 out of 2500000 steps (91%)
Completed 2300000 out of 2500000 steps (92%)
Completed 2325000 out of 2500000 steps (93%)
Completed 2350000 out of 2500000 steps (94%)
Completed 2375000 out of 2500000 steps (95%)
Completed 2400000 out of 2500000 steps (96%)
Completed 2425000 out of 2500000 steps (97%)
Completed 2450000 out of 2500000 steps (98%)
Max number of retries reached. Aborting.
ERROR:exception: Max Retries Reached
Saving result file badStateCheckpoint_18467
Saving result file badStateCheckpoint_41
Saving result file badStateCheckpoint_6334
Saving result file badStateForceGroup0_18467Core.xml
Saving result file badStateForceGroup0_18467Ref.xml
Saving result file badStateForceGroup0_41Core.xml
Saving result file badStateForceGroup0_41Ref.xml
Saving result file badStateForceGroup0_6334Core.xml
Saving result file badStateForceGroup0_6334Ref.xml
Saving result file badStateForceGroup1_18467Core.xml
Saving result file badStateForceGroup1_18467Ref.xml
Saving result file badStateForceGroup1_41Core.xml
Saving result file badStateForceGroup1_41Ref.xml
Saving result file badStateForceGroup1_6334Core.xml
Saving result file badStateForceGroup1_6334Ref.xml
Saving result file badStateForceGroup2_18467Core.xml
Saving result file badStateForceGroup2_18467Ref.xml
Saving result file badStateForceGroup2_41Core.xml
Saving result file badStateForceGroup2_41Ref.xml
Saving result file badStateForceGroup2_6334Core.xml
Saving result file badStateForceGroup2_6334Ref.xml
Here is the latest log on the file from a restart of the computer.
*********************** Log Started 2013-07-19T20:25:49Z ***********************
20:25:49:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:25:49:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:25:49:WU00:FS00:Connecting to 171.64.65.69:8080
20:25:50:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:25:50:WU00:FS00:Trying to send results to collection server
20:25:50:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:25:50:WU00:FS00:Connecting to 171.65.103.160:8080
20:25:51:ERROR:WU00:FS00:Exception: Transfer failed
20:25:51:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:25:51:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:25:51:WU00:FS00:Connecting to 171.64.65.69:8080
20:25:51:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:25:51:WU00:FS00:Trying to send results to collection server
20:25:51:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:25:51:WU00:FS00:Connecting to 171.65.103.160:8080
20:25:52:ERROR:WU00:FS00:Exception: Transfer failed
20:26:51:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:26:51:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:26:51:WU00:FS00:Connecting to 171.64.65.69:8080
20:26:51:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:26:51:WU00:FS00:Trying to send results to collection server
20:26:51:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:26:51:WU00:FS00:Connecting to 171.65.103.160:8080
20:26:51:ERROR:WU00:FS00:Exception: Transfer failed
20:28:28:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:28:28:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:28:28:WU00:FS00:Connecting to 171.64.65.69:8080
20:28:28:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:28:28:WU00:FS00:Trying to send results to collection server
20:28:28:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:28:28:WU00:FS00:Connecting to 171.65.103.160:8080
20:28:28:ERROR:WU00:FS00:Exception: Transfer failed
20:31:05:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:31:05:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:31:05:WU00:FS00:Connecting to 171.64.65.69:8080
20:31:05:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:31:05:WU00:FS00:Trying to send results to collection server
20:31:05:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:31:05:WU00:FS00:Connecting to 171.65.103.160:8080
20:31:06:ERROR:WU00:FS00:Exception: Transfer failed
20:35:20:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:35:20:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:35:20:WU00:FS00:Connecting to 171.64.65.69:8080
20:35:20:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:35:20:WU00:FS00:Trying to send results to collection server
20:35:20:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:35:20:WU00:FS00:Connecting to 171.65.103.160:8080
20:35:20:ERROR:WU00:FS00:Exception: Transfer failed
20:42:11:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:42:11:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:42:11:WU00:FS00:Connecting to 171.64.65.69:8080
20:42:11:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:42:11:WU00:FS00:Trying to send results to collection server
20:42:11:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:42:11:WU00:FS00:Connecting to 171.65.103.160:8080
20:42:11:ERROR:WU00:FS00:Exception: Transfer failed
20:53:16:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
20:53:16:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
20:53:16:WU00:FS00:Connecting to 171.64.65.69:8080
20:53:17:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
20:53:17:WU00:FS00:Trying to send results to collection server
20:53:17:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
20:53:17:WU00:FS00:Connecting to 171.65.103.160:8080
20:53:17:ERROR:WU00:FS00:Exception: Transfer failed
21:11:13:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
21:11:13:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
21:11:13:WU00:FS00:Connecting to 171.64.65.69:8080
21:11:13:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
21:11:13:WU00:FS00:Trying to send results to collection server
21:11:13:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
21:11:13:WU00:FS00:Connecting to 171.65.103.160:8080
21:11:14:ERROR:WU00:FS00:Exception: Transfer failed
21:40:15:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
21:40:15:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
21:40:15:WU00:FS00:Connecting to 171.64.65.69:8080
21:40:16:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
21:40:16:WU00:FS00:Trying to send results to collection server
21:40:16:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
21:40:16:WU00:FS00:Connecting to 171.65.103.160:8080
21:40:16:ERROR:WU00:FS00:Exception: Transfer failed
22:27:14:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
22:27:14:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
22:27:14:WU00:FS00:Connecting to 171.64.65.69:8080
22:27:14:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
22:27:14:WU00:FS00:Trying to send results to collection server
22:27:14:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
22:27:14:WU00:FS00:Connecting to 171.65.103.160:8080
22:27:15:ERROR:WU00:FS00:Exception: Transfer failed
23:43:15:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
23:43:15:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
23:43:15:WU00:FS00:Connecting to 171.64.65.69:8080
23:43:15:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
23:43:15:WU00:FS00:Trying to send results to collection server
23:43:15:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
23:43:15:WU00:FS00:Connecting to 171.65.103.160:8080
23:43:15:ERROR:WU00:FS00:Exception: Transfer failed
01:46:15:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
01:46:15:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
01:46:15:WU00:FS00:Connecting to 171.64.65.69:8080
01:46:15:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
01:46:15:WU00:FS00:Trying to send results to collection server
01:46:15:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
01:46:15:WU00:FS00:Connecting to 171.65.103.160:8080
01:46:15:ERROR:WU00:FS00:Exception: Transfer failed
******************************* Date: 2013-07-20 *******************************
05:05:12:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
05:05:12:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
05:05:12:WU00:FS00:Connecting to 171.64.65.69:8080
05:05:12:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:05:12:WU00:FS00:Trying to send results to collection server
05:05:12:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
05:05:12:WU00:FS00:Connecting to 171.65.103.160:8080
05:05:13:ERROR:WU00:FS00:Exception: Transfer failed
05:06:49:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
05:06:49:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
05:06:49:WU00:FS00:Connecting to 171.64.65.69:8080
05:06:49:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:06:49:WU00:FS00:Trying to send results to collection server
05:06:49:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
05:06:49:WU00:FS00:Connecting to 171.65.103.160:8080
05:06:50:ERROR:WU00:FS00:Exception: Transfer failed
05:09:26:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
05:09:26:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
05:09:26:WU00:FS00:Connecting to 171.64.65.69:8080
05:09:27:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:09:27:WU00:FS00:Trying to send results to collection server
05:09:27:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
05:09:27:WU00:FS00:Connecting to 171.65.103.160:8080
05:09:27:ERROR:WU00:FS00:Exception: Transfer failed
05:13:41:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
05:13:41:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
05:13:41:WU00:FS00:Connecting to 171.64.65.69:8080
05:13:41:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:13:41:WU00:FS00:Trying to send results to collection server
05:13:41:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
05:13:41:WU00:FS00:Connecting to 171.65.103.160:8080
05:13:41:ERROR:WU00:FS00:Exception: Transfer failed
05:20:32:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
05:20:32:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
05:20:32:WU00:FS00:Connecting to 171.64.65.69:8080
05:20:32:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:20:32:WU00:FS00:Trying to send results to collection server
05:20:32:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
05:20:32:WU00:FS00:Connecting to 171.65.103.160:8080
05:20:33:ERROR:WU00:FS00:Exception: Transfer failed
05:31:38:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
05:31:38:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
05:31:38:WU00:FS00:Connecting to 171.64.65.69:8080
05:31:38:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:31:38:WU00:FS00:Trying to send results to collection server
05:31:38:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
05:31:38:WU00:FS00:Connecting to 171.65.103.160:8080
05:31:38:ERROR:WU00:FS00:Exception: Transfer failed
05:49:34:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
05:49:34:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
05:49:34:WU00:FS00:Connecting to 171.64.65.69:8080
05:49:35:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
05:49:35:WU00:FS00:Trying to send results to collection server
05:49:35:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
05:49:35:WU00:FS00:Connecting to 171.65.103.160:8080
05:49:35:ERROR:WU00:FS00:Exception: Transfer failed
06:18:37:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
06:18:37:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
06:18:37:WU00:FS00:Connecting to 171.64.65.69:8080
06:18:37:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
06:18:37:WU00:FS00:Trying to send results to collection server
06:18:37:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
06:18:37:WU00:FS00:Connecting to 171.65.103.160:8080
06:18:37:ERROR:WU00:FS00:Exception: Transfer failed
07:05:35:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
07:05:35:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
07:05:35:WU00:FS00:Connecting to 171.64.65.69:8080
07:05:36:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
07:05:36:WU00:FS00:Trying to send results to collection server
07:05:36:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
07:05:36:WU00:FS00:Connecting to 171.65.103.160:8080
07:05:36:ERROR:WU00:FS00:Exception: Transfer failed
08:21:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
08:21:36:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
08:21:36:WU00:FS00:Connecting to 171.64.65.69:8080
08:21:36:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
08:21:36:WU00:FS00:Trying to send results to collection server
08:21:36:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
08:21:36:WU00:FS00:Connecting to 171.65.103.160:8080
08:21:37:ERROR:WU00:FS00:Exception: Transfer failed
10:24:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
10:24:36:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
10:24:36:WU00:FS00:Connecting to 171.64.65.69:8080
10:24:36:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
10:24:36:WU00:FS00:Trying to send results to collection server
10:24:36:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
10:24:36:WU00:FS00:Connecting to 171.65.103.160:8080
10:24:36:ERROR:WU00:FS00:Exception: Transfer failed
13:43:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
13:43:36:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
13:43:36:WU00:FS00:Connecting to 171.64.65.69:8080
13:43:36:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
13:43:36:WU00:FS00:Trying to send results to collection server
13:43:36:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
13:43:36:WU00:FS00:Connecting to 171.65.103.160:8080
13:43:36:ERROR:WU00:FS00:Exception: Transfer failed
19:05:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80 core:0x17 unit:0x00000064028c126651a64de8c52f5593
19:05:36:WU00:FS00:Uploading 51.79MiB to 171.64.65.69
19:05:36:WU00:FS00:Connecting to 171.64.65.69:8080
19:05:36:WARNING:WU00:FS00:Exception: Failed to send results to work server: Transfer failed
19:05:36:WU00:FS00:Trying to send results to collection server
19:05:36:WU00:FS00:Uploading 51.79MiB to 171.65.103.160
19:05:36:WU00:FS00:Connecting to 171.65.103.160:8080
19:05:36:ERROR:WU00:FS00:Exception: Transfer failed
EDIT by Mod: Two similar projects merged.
StitchExperimen
This computer seems to be working fine after all the advice on 8900 projects.
Re: I have a work unit that appears to not upload due to err
Can you please post the section of the log with your system configuration, fah configuration and from the instance the WU was downloaded? My theory as to why it won't upload is that the wuresult is rather huge, 51.79MiB. Am not sure as to why that is hence am asking for the aforementioned information. Do note that I have notified the appropriate personnel regarding this matter.
StitchExperimen
What else do I need to send? if anything?
20:25:49:************************* Folding@home Client *************************
20:25:49:      Website: http://folding.stanford.edu/
20:25:49:    Copyright: (c) 2009-2013 Stanford University
20:25:49:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:25:49:         Args:
20:25:49:       Config: C:/ProgramData/FAHClient/config.xml
20:25:49:******************************** Build ********************************
20:25:49:      Version: 7.3.6
20:25:49:         Date: Feb 18 2013
20:25:49:         Time: 15:25:17
20:25:49:      SVN Rev: 3923
20:25:49:       Branch: fah/trunk/client
20:25:49:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
20:25:49:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
20:25:49:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
20:25:49:     Platform: win32 XP
20:25:49:         Bits: 32
20:25:49:         Mode: Release
20:25:49:******************************* System ********************************
20:25:49:          CPU:
20:25:49:       CPU ID: GenuineIntel Family 6 Model 45 Stepping 2
20:25:49:         CPUs: 16
20:25:49:       Memory: 15.95GiB
20:25:49:  Free Memory: 13.98GiB
20:25:49:      Threads: WINDOWS_THREADS
20:25:49:  Has Battery: false
20:25:49:   On Battery: false
20:25:49:   UTC offset: -6
20:25:49:          PID: 4292
20:25:49:          CWD: C:/ProgramData/FAHClient
20:25:49:           OS: Windows 7 Professional
20:25:49:      OS Arch: AMD64
20:25:49:         GPUs: 1
20:25:49:        GPU 0: ATI:5 Tahiti PRO [Radeon HD 7950]
20:25:49:         CUDA: Not detected
20:25:49:Win32 Service: false
20:25:49:***********************************************************************
20:25:49:<config>
20:25:49:  <!-- Folding Slot Configuration -->
20:25:49:  <power v='full'/>
20:25:49:
20:25:49:  <!-- Network -->
20:25:49:  <proxy v=':8080'/>
20:25:49:
20:25:49:  <!-- Remote Command Server -->
20:25:49:  <password v='*********'/>
20:25:49:
20:25:49:  <!-- User Information -->
20:25:49:  <passkey v='********************************'/>
20:25:49:  <team v='198'/>
20:25:49:  <user v='StitchExperimen'/>
20:25:49:
20:25:49:  <!-- Folding Slots -->
20:25:49:  <slot id='0' type='GPU'>
20:25:49:    <client-type v='advanced'/>
20:25:49:    <cuda-index v='0'/>
20:25:49:  </slot>
20:25:49:</config>
20:25:49:Trying to access database...
20:25:49:Successfully acquired database lock
20:25:49:Enabled folding slot 00: READY gpu:0:Tahiti PRO [Radeon HD 7950]
20:25:49:WU02:FS00:Starting
20:25:49:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4292 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:25:49:WU02:FS00:Started FahCore on PID 5532
20:25:49:WU02:FS00:Core PID:5548
20:25:49:WU02:FS00:FahCore 0x17 started
20:25:50:WU02:FS00:0x17:*********************** Log Started 2013-07-19T20:25:49Z ***********************
20:25:50:WU02:FS00:0x17:Project: 8900 (Run 592, Clone 1, Gen 69)
20:25:50:WU02:FS00:0x17:Unit: 0x0000004e028c126651a6aa54890d5f85
20:25:50:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
20:25:50:WU02:FS00:0x17:Machine: 0
20:25:50:WU02:FS00:0x17:Digital signatures verified
20:25:50:WU02:FS00:0x17:  Found a checkpoint file
20:28:21:WU02:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
20:37:25:WU02:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
20:46:07:WU02:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
20:55:27:WU02:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
21:04:30:WU02:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
21:05:21:WU02:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
21:13:56:WU02:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
21:26:20:WU02:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
21:27:37:WU02:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
21:36:20:WU02:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
22:03:12:WU02:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
22:05:19:WU02:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
22:05:19:WU02:FS00:0x17:Max number of retries reached. Aborting.
22:05:19:WU02:FS00:0x17:ERROR:exception: Max Retries Reached
22:05:19:WU02:FS00:0x17:Saving result file logfile_01.txt
22:05:19:WU02:FS00:0x17:Saving result file badStateCheckpoint_41
22:05:20:WU02:FS00:0x17:Saving result file badStateCheckpoint_6334
22:05:22:WU02:FS00:0x17:Saving result file badStateForceGroup0_18467Core.xml
22:05:24:WU02:FS00:0x17:Saving result file badStateForceGroup0_18467Ref.xml
22:05:26:WU02:FS00:0x17:Saving result file badStateForceGroup0_41Core.xml
22:05:28:WU02:FS00:0x17:Saving result file badStateForceGroup0_41Ref.xml
22:05:30:WU02:FS00:0x17:Saving result file badStateForceGroup0_6334Core.xml
22:05:32:WU02:FS00:0x17:Saving result file badStateForceGroup0_6334Ref.xml
22:05:34:WU02:FS00:0x17:Saving result file badStateForceGroup1_18467Core.xml
22:05:36:WU02:FS00:0x17:Saving result file badStateForceGroup1_18467Ref.xml
22:05:38:WU02:FS00:0x17:Saving result file badStateForceGroup1_41Core.xml
22:05:40:WU02:FS00:0x17:Saving result file badStateForceGroup1_41Ref.xml
22:05:42:WU02:FS00:0x17:Saving result file badStateForceGroup1_6334Core.xml
22:05:44:WU02:FS00:0x17:Saving result file badStateForceGroup1_6334Ref.xml
22:05:46:WU02:FS00:0x17:Saving result file badStateForceGroup2_41Core.xml
22:05:48:WU02:FS00:0x17:Saving result file badStateForceGroup2_41Ref.xml
22:05:50:WU02:FS00:0x17:Saving result file badStateForceGroup2_6334Core.xml
22:05:52:WU02:FS00:0x17:Saving result file badStateForceGroup2_6334Ref.xml
22:05:54:WU02:FS00:0x17:Saving result file log.txt
22:05:54:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
22:05:55:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
22:05:55:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:592 clone:1 gen:69 core:0x17 unit:0x0000004e028c126651a6aa54890d5f85
22:05:55:WU02:FS00:Uploading 27.60MiB to 171.64.65.69
22:05:55:WU02:FS00:Connecting to 171.64.65.69:8080
22:05:55:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
22:05:55:WU01:FS00:News: Welcome to Folding@Home
22:05:55:WU01:FS00:Assigned to work server 171.64.65.69
22:05:55:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti PRO [Radeon HD 7950] from 171.64.65.69
22:05:55:WU01:FS00:Connecting to 171.64.65.69:8080
22:05:56:WU01:FS00:Downloading 4.18MiB
22:05:57:WU01:FS00:Download complete
22:05:58:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:184 clone:0 gen:66 core:0x17 unit:0x0000004f028c126651a64f715a58e534
22:05:58:WU01:FS00:Starting
22:05:58:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4292 -checkpoint 15 -gpu 0 -gpu-vendor ati
22:05:58:WU01:FS00:Started FahCore on PID 4288
22:05:58:WU01:FS00:Core PID:8484
22:05:58:WU01:FS00:FahCore 0x17 started
22:05:58:WU01:FS00:0x17:*********************** Log Started 2013-07-19T22:05:58Z ***********************
22:05:58:WU01:FS00:0x17:Project: 8900 (Run 184, Clone 0, Gen 66)
22:05:58:WU01:FS00:0x17:Unit: 0x0000004f028c126651a64f715a58e534
22:05:58:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
22:05:58:WU01:FS00:0x17:Machine: 0
22:05:58:WU01:FS00:0x17:Reading tar file state.xml
22:05:59:WU01:FS00:0x17:Reading tar file system.xml
22:05:59:WU01:FS00:0x17:Reading tar file integrator.xml
22:05:59:WU01:FS00:0x17:Reading tar file core.xml
22:05:59:WU01:FS00:0x17:Digital signatures verified
22:06:01:WU02:FS00:Upload 3.85%
22:06:07:WU02:FS00:Upload 7.70%
22:06:13:WU02:FS00:Upload 11.55%
22:06:19:WU02:FS00:Upload 15.17%
22:06:25:WU02:FS00:Upload 19.02%
22:06:31:WU02:FS00:Upload 22.65%
22:06:37:WU02:FS00:Upload 26.50%
22:06:43:WU02:FS00:Upload 30.35%
22:06:49:WU02:FS00:Upload 34.20%
22:06:55:WU02:FS00:Upload 37.82%
22:07:01:WU02:FS00:Upload 41.67%
22:07:07:WU02:FS00:Upload 45.30%
22:07:13:WU02:FS00:Upload 49.15%
22:07:19:WU02:FS00:Upload 53.00%
22:07:25:WU02:FS00:Upload 56.62%
22:07:31:WU02:FS00:Upload 60.47%
22:07:37:WU02:FS00:Upload 64.09%
22:07:43:WU02:FS00:Upload 67.94%
22:07:49:WU02:FS00:Upload 71.57%
22:07:55:WU02:FS00:Upload 75.42%
22:08:01:WU02:FS00:Upload 79.27%
22:08:07:WU02:FS00:Upload 82.89%
22:08:13:WU02:FS00:Upload 86.74%
22:08:19:WU02:FS00:Upload 90.37%
22:08:25:WU02:FS00:Upload 94.22%
22:08:29:WU01:FS00:0x17:Completed 0 out of 2500000 steps (0%)
22:08:31:WU02:FS00:Upload 98.07%
22:08:34:WU02:FS00:Upload complete
22:08:34:WU02:FS00:Server responded WORK_ACK (400)
22:08:34:WU02:FS00:Cleaning up
22:17:33:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
22:41:55:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
22:44:03:WU01:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
23:06:55:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
23:35:06:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
23:37:13:WU01:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
23:45:56:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
23:54:59:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
00:04:15:WU01:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
00:25:48:WU01:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
00:27:55:WU01:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
00:27:55:WU01:FS00:0x17:Max number of retries reached. Aborting.
00:27:55:WU01:FS00:0x17:ERROR:exception: Max Retries Reached
00:27:55:WU01:FS00:0x17:Saving result file logfile_01.txt
00:27:55:WU01:FS00:0x17:Saving result file badStateCheckpoint_18467
00:27:57:WU01:FS00:0x17:Saving result file badStateCheckpoint_41
00:27:58:WU01:FS00:0x17:Saving result file badStateCheckpoint_6334
00:28:00:WU01:FS00:0x17:Saving result file badStateForceGroup0_18467Core.xml
00:28:03:WU01:FS00:0x17:Saving result file badStateForceGroup0_18467Ref.xml
00:28:05:WU01:FS00:0x17:Saving result file badStateForceGroup0_41Core.xml
00:28:07:WU01:FS00:0x17:Saving result file badStateForceGroup0_41Ref.xml
00:28:09:WU01:FS00:0x17:Saving result file badStateForceGroup0_6334Core.xml
00:28:11:WU01:FS00:0x17:Saving result file badStateForceGroup0_6334Ref.xml
00:28:13:WU01:FS00:0x17:Saving result file badStateForceGroup1_18467Core.xml
00:28:15:WU01:FS00:0x17:Saving result file badStateForceGroup1_18467Ref.xml
00:28:18:WU01:FS00:0x17:Saving result file badStateForceGroup1_41Core.xml
00:28:20:WU01:FS00:0x17:Saving result file badStateForceGroup1_41Ref.xml
00:28:22:WU01:FS00:0x17:Saving result file badStateForceGroup1_6334Core.xml
00:28:24:WU01:FS00:0x17:Saving result file badStateForceGroup1_6334Ref.xml
00:28:26:WU01:FS00:0x17:Saving result file badStateForceGroup2_18467Core.xml
00:28:29:WU01:FS00:0x17:Saving result file badStateForceGroup2_18467Ref.xml
00:28:31:WU01:FS00:0x17:Saving result file badStateForceGroup2_41Core.xml
00:28:33:WU01:FS00:0x17:Saving result file badStateForceGroup2_41Ref.xml
00:28:35:WU01:FS00:0x17:Saving result file badStateForceGroup2_6334Core.xml
00:28:37:WU01:FS00:0x17:Saving result file badStateForceGroup2_6334Ref.xml
00:28:39:WU01:FS00:0x17:Saving result file log.txt
00:28:40:WU01:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
00:28:40:WARNING:WU01:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
00:28:40:WU01:FS00:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:184 clone:0 gen:66 core:0x17 unit:0x0000004f028c126651a64f715a58e534
00:28:40:WU01:FS00:Uploading 10.49MiB to 171.64.65.69
00:28:40:WU01:FS00:Connecting to 171.64.65.69:8080
00:28:40:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
00:28:41:WU02:FS00:News: Welcome to Folding@Home
00:28:41:WU02:FS00:Assigned to work server 171.64.65.69
00:28:41:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti PRO [Radeon HD 7950] from 171.64.65.69
00:28:41:WU02:FS00:Connecting to 171.64.65.69:8080
00:28:41:WU02:FS00:Downloading 4.18MiB
00:28:43:WU02:FS00:Download complete
00:28:43:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:676 clone:0 gen:52 core:0x17 unit:0x00000046028c126651a6bcfac98032fb
00:28:43:WU02:FS00:Starting
00:28:43:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4292 -checkpoint 15 -gpu 0 -gpu-vendor ati
00:28:43:WU02:FS00:Started FahCore on PID 4232
00:28:43:WU02:FS00:Core PID:5952
00:28:43:WU02:FS00:FahCore 0x17 started
00:28:44:WU02:FS00:0x17:*********************** Log Started 2013-07-20T00:28:43Z ***********************
00:28:44:WU02:FS00:0x17:Project: 8900 (Run 676, Clone 0, Gen 52)
00:28:44:WU02:FS00:0x17:Unit: 0x00000046028c126651a6bcfac98032fb
00:28:44:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
00:28:44:WU02:FS00:0x17:Machine: 0
00:28:44:WU02:FS00:0x17:Reading tar file state.xml
00:28:44:WU02:FS00:0x17:Reading tar file system.xml
00:28:45:WU02:FS00:0x17:Reading tar file integrator.xml
00:28:45:WU02:FS00:0x17:Reading tar file core.xml
00:28:45:WU02:FS00:0x17:Digital signatures verified
00:28:46:WU01:FS00:Upload 8.94%
00:28:52:WU01:FS00:Upload 18.47%
00:28:58:WU01:FS00:Upload 28.60%
00:29:04:WU01:FS00:Upload 38.13%
00:29:10:WU01:FS00:Upload 47.67%
00:29:16:WU01:FS00:Upload 57.80%
00:29:22:WU01:FS00:Upload 67.33%
00:29:28:WU01:FS00:Upload 76.86%
00:29:34:WU01:FS00:Upload 85.80%
00:29:40:WU01:FS00:Upload 95.93%
00:29:43:WU01:FS00:Upload complete
00:29:43:WU01:FS00:Server responded WORK_ACK (400)
00:29:43:WU01:FS00:Cleaning up
00:31:13:WU02:FS00:0x17:Completed 0 out of 2500000 steps (0%)
00:39:43:WU02:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
00:48:05:WU02:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
00:56:50:WU02:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
01:05:06:WU02:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
01:13:30:WU02:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
01:21:37:WU02:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
01:22:27:WU02:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
01:30:43:WU02:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
01:39:02:WU02:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
01:39:52:WU02:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
01:48:14:WU02:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
01:56:36:WU02:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
02:05:02:WU02:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
02:23:17:WU02:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
02:24:34:WU02:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
02:24:34:WU02:FS00:0x17:Max number of retries reached. Aborting.
02:24:34:WU02:FS00:0x17:ERROR:exception: Max Retries Reached
02:24:34:WU02:FS00:0x17:Saving result file logfile_01.txt
02:24:34:WU02:FS00:0x17:Saving result file badStateCheckpoint_18467
02:24:35:WU02:FS00:0x17:Saving result file badStateCheckpoint_41
02:24:37:WU02:FS00:0x17:Saving result file badStateForceGroup0_18467Core.xml
02:24:39:WU02:FS00:0x17:Saving result file badStateForceGroup0_18467Ref.xml
02:24:41:WU02:FS00:0x17:Saving result file badStateForceGroup0_41Core.xml
02:24:44:WU02:FS00:0x17:Saving result file badStateForceGroup0_41Ref.xml
02:24:46:WU02:FS00:0x17:Saving result file badStateForceGroup0_6334Core.xml
02:24:48:WU02:FS00:0x17:Saving result file badStateForceGroup0_6334Ref.xml
02:24:50:WU02:FS00:0x17:Saving result file badStateForceGroup1_18467Core.xml
02:24:53:WU02:FS00:0x17:Saving result file badStateForceGroup1_18467Ref.xml
02:24:55:WU02:FS00:0x17:Saving result file badStateForceGroup1_41Core.xml
02:24:57:WU02:FS00:0x17:Saving result file badStateForceGroup1_41Ref.xml
02:24:59:WU02:FS00:0x17:Saving result file badStateForceGroup1_6334Core.xml
02:25:01:WU02:FS00:0x17:Saving result file badStateForceGroup1_6334Ref.xml
02:25:03:WU02:FS00:0x17:Saving result file badStateForceGroup2_18467Core.xml
02:25:06:WU02:FS00:0x17:Saving result file badStateForceGroup2_18467Ref.xml
02:25:08:WU02:FS00:0x17:Saving result file badStateForceGroup2_41Core.xml
02:25:10:WU02:FS00:0x17:Saving result file badStateForceGroup2_41Ref.xml
02:25:12:WU02:FS00:0x17:Saving result file log.txt
02:25:12:WU02:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
02:25:12:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
02:25:12:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:8900 run:676 clone:0 gen:52 core:0x17 unit:0x00000046028c126651a6bcfac98032fb
02:25:12:WU02:FS00:Uploading 48.27MiB to 171.64.65.69
02:25:12:WU02:FS00:Connecting to 171.64.65.69:8080
02:25:12:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
02:25:13:WU01:FS00:News: Welcome to Folding@Home
02:25:13:WU01:FS00:Assigned to work server 171.64.65.69
02:25:13:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Tahiti PRO [Radeon HD 7950] from 171.64.65.69
02:25:13:WU01:FS00:Connecting to 171.64.65.69:8080
02:25:13:WU01:FS00:Downloading 4.17MiB
02:25:15:WU01:FS00:Download complete
02:25:15:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:35 clone:6 gen:81 core:0x17 unit:0x00000067028c1266519a66e991743e81
02:25:15:WU01:FS00:Starting
02:25:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4292 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:25:15:WU01:FS00:Started FahCore on PID 8516
02:25:15:WU01:FS00:Core PID:4920
02:25:15:WU01:FS00:FahCore 0x17 started
02:25:15:WU01:FS00:0x17:*********************** Log Started 2013-07-20T02:25:15Z ***********************
02:25:15:WU01:FS00:0x17:Project: 8900 (Run 35, Clone 6, Gen 81)
02:25:15:WU01:FS00:0x17:Unit: 0x00000067028c1266519a66e991743e81
02:25:15:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
02:25:15:WU01:FS00:0x17:Machine: 0
02:25:15:WU01:FS00:0x17:Reading tar file state.xml
02:25:16:WU01:FS00:0x17:Reading tar file system.xml
02:25:16:WU01:FS00:0x17:Reading tar file integrator.xml
02:25:16:WU01:FS00:0x17:Reading tar file core.xml
02:25:16:WU01:FS00:0x17:Digital signatures verified
02:25:18:WU02:FS00:Upload 2.07%
02:25:24:WU02:FS00:Upload 4.14%
02:25:30:WU02:FS00:Upload 6.22%
02:25:36:WU02:FS00:Upload 8.29%
02:25:42:WU02:FS00:Upload 10.36%
02:25:48:WU02:FS00:Upload 12.56%
02:25:54:WU02:FS00:Upload 14.63%
02:26:00:WU02:FS00:Upload 16.83%
02:26:06:WU02:FS00:Upload 18.90%
02:26:12:WU02:FS00:Upload 20.98%
02:26:18:WU02:FS00:Upload 23.05%
02:26:24:WU02:FS00:Upload 25.12%
02:26:30:WU02:FS00:Upload 27.32%
02:26:36:WU02:FS00:Upload 29.39%
02:26:42:WU02:FS00:Upload 31.46%
02:26:48:WU02:FS00:Upload 33.54%
02:26:54:WU02:FS00:Upload 35.61%
02:27:00:WU02:FS00:Upload 37.81%
02:27:06:WU02:FS00:Upload 39.88%
02:27:12:WU02:FS00:Upload 42.08%
02:27:18:WU02:FS00:Upload 44.15%
02:27:24:WU02:FS00:Upload 46.10%
02:27:30:WU02:FS00:Upload 48.30%
02:27:36:WU02:FS00:Upload 50.37%
02:27:42:WU02:FS00:Upload 52.57%
02:27:45:WU01:FS00:0x17:Completed 0 out of 2500000 steps (0%)
02:27:48:WU02:FS00:Upload 54.64%
02:27:54:WU02:FS00:Upload 56.71%
02:28:00:WU02:FS00:Upload 58.79%
02:28:06:WU02:FS00:Upload 60.99%
02:28:12:WU02:FS00:Upload 63.06%
02:28:18:WU02:FS00:Upload 65.26%
02:28:24:WU02:FS00:Upload 67.46%
02:28:30:WU02:FS00:Upload 69.53%
02:28:36:WU02:FS00:Upload 71.73%
02:28:42:WU02:FS00:Upload 73.81%
02:28:48:WU02:FS00:Upload 76.01%
02:28:54:WU02:FS00:Upload 78.08%
02:29:00:WU02:FS00:Upload 80.28%
02:29:06:WU02:FS00:Upload 82.35%
02:29:12:WU02:FS00:Upload 84.42%
02:29:18:WU02:FS00:Upload 86.63%
02:29:24:WU02:FS00:Upload 88.70%
02:29:30:WU02:FS00:Upload 90.90%
02:29:36:WU02:FS00:Upload 92.97%
02:29:42:WU02:FS00:Upload 95.04%
02:29:48:WU02:FS00:Upload 97.11%
02:29:54:WU02:FS00:Upload 99.19%
02:29:56:WU02:FS00:Upload complete
02:29:57:WU02:FS00:Server responded WORK_ACK (400)
02:29:57:WU02:FS00:Cleaning up
02:36:42:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
02:45:12:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
02:53:55:WU01:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
03:02:17:WU01:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
03:11:06:WU01:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
03:19:49:WU01:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
03:28:48:WU01:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
03:44:16:FS00:Paused
03:44:16:FS00:Shutting core down
03:44:16:WU01:FS00:0x17:WARNING:Console control signal 1 on PID 4920
03:44:16:WU01:FS00:0x17:Exiting, please wait. . .
03:44:18:WU01:FS00:0x17:Lost lifeline PID 8516, exiting
03:44:18:WU01:FS00:0x17:ERROR:103: Lost client lifeline
03:44:18:WU01:FS00:0x17:Folding@home Core Shutdown: CLIENT_DIED
03:44:18:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
05:05:12:FS00:Unpaused
05:05:12:WU01:FS00:Starting
05:05:12:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4292 -checkpoint 15 -gpu 0 -gpu-vendor ati
05:05:12:WU01:FS00:Started FahCore on PID 7608
05:05:12:WU01:FS00:Core PID:6072
05:05:12:WU01:FS00:FahCore 0x17 started
05:05:13:WU01:FS00:0x17:*********************** Log Started 2013-07-20T05:05:13Z ***********************
05:05:13:WU01:FS00:0x17:Project: 8900 (Run 35, Clone 6, Gen 81)
05:05:13:WU01:FS00:0x17:Unit: 0x00000067028c1266519a66e991743e81
05:05:13:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
05:05:13:WU01:FS00:0x17:Machine: 0
05:05:13:WU01:FS00:0x17:Digital signatures verified
05:05:13:WU01:FS00:0x17:  Found a checkpoint file
05:07:42:WU01:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
05:23:34:WU01:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
05:49:45:WU01:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
05:51:02:WU01:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
05:59:37:WU01:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
06:08:00:WU01:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
06:16:38:WU01:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
06:22:41:WU01:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
06:28:42:WU01:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
06:33:34:WU01:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
06:38:42:WU01:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
06:43:33:WU01:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
06:48:17:WU01:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
06:52:31:WU01:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
06:53:22:WU01:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
06:57:38:WU01:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
07:01:55:WU01:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
07:06:13:WU01:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
07:10:14:WU01:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
07:14:33:WU01:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
07:18:34:WU01:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
07:22:52:WU01:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
07:26:52:WU01:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
07:31:10:WU01:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
07:35:11:WU01:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
07:39:30:WU01:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
07:43:30:WU01:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
07:47:49:WU01:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
07:51:50:WU01:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
07:56:09:WU01:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
08:00:10:WU01:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
08:04:28:WU01:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
08:08:27:WU01:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
08:12:43:WU01:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
08:16:43:WU01:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
08:21:00:WU01:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
08:24:59:WU01:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
08:29:14:WU01:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
08:33:13:WU01:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
08:37:29:WU01:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
08:41:27:WU01:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
08:45:42:WU01:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
08:49:37:WU01:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
08:53:52:WU01:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
08:57:51:WU01:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
09:02:04:WU01:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
09:06:03:WU01:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
09:10:19:WU01:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
09:14:18:WU01:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
09:18:35:WU01:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
09:22:35:WU01:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
09:26:50:WU01:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
09:30:49:WU01:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
09:35:05:WU01:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
09:39:05:WU01:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
09:43:23:WU01:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
09:47:22:WU01:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
09:51:39:WU01:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
09:55:38:WU01:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
09:59:56:WU01:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
10:03:56:WU01:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
10:08:13:WU01:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
10:12:13:WU01:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
10:16:32:WU01:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
10:20:33:WU01:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
10:24:52:WU01:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
10:28:53:WU01:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
10:33:10:WU01:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
10:37:11:WU01:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
10:41:30:WU01:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
10:45:30:WU01:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
10:49:49:WU01:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
10:53:50:WU01:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
10:58:07:WU01:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
11:02:07:WU01:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
11:06:25:WU01:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
11:10:25:WU01:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
11:14:43:WU01:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
11:18:43:WU01:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
11:23:02:WU01:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
11:27:03:WU01:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
11:31:22:WU01:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
11:35:23:WU01:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
11:39:41:WU01:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
11:43:42:WU01:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
11:48:01:WU01:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
11:52:02:WU01:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
11:56:20:WU01:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
12:00:21:WU01:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
12:04:40:WU01:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
12:08:42:WU01:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
12:13:00:WU01:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
12:17:02:WU01:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
12:21:22:WU01:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
12:25:24:WU01:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
12:29:42:WU01:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
12:33:44:WU01:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
12:38:03:WU01:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
12:42:05:WU01:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
12:42:06:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
12:42:06:WU02:FS00:News: Welcome to Folding@Home
12:42:06:WU02:FS00:Assigned to work server 171.64.65.69
12:42:06:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti PRO [Radeon HD 7950] from 171.64.65.69
12:42:06:WU02:FS00:Connecting to 171.64.65.69:8080
12:42:06:WU02:FS00:Downloading 4.18MiB
12:42:08:WU02:FS00:Download complete
12:42:08:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:8900 run:115 clone:1 gen:47 core:0x17 unit:0x00000042028c126651a6400afb8069bf
12:46:24:WU01:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
12:50:24:WU01:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
12:50:42:WU01:FS00:0x17:Saving result file logfile_01.txt
12:50:42:WU01:FS00:0x17:Saving result file badStateCheckpoint_18467
12:50:43:WU01:FS00:0x17:Saving result file badStateForceGroup0_18467Core.xml
12:50:45:WU01:FS00:0x17:Saving result file badStateForceGroup0_18467Ref.xml
12:50:47:WU01:FS00:0x17:Saving result file badStateForceGroup0_41Core.xml
12:50:49:WU01:FS00:0x17:Saving result file badStateForceGroup0_41Ref.xml
12:50:51:WU01:FS00:0x17:Saving result file badStateForceGroup1_18467Core.xml
12:50:53:WU01:FS00:0x17:Saving result file badStateForceGroup1_18467Ref.xml
12:50:55:WU01:FS00:0x17:Saving result file badStateForceGroup1_41Core.xml
12:50:57:WU01:FS00:0x17:Saving result file badStateForceGroup1_41Ref.xml
12:50:59:WU01:FS00:0x17:Saving result file badStateForceGroup2_18467Core.xml
12:51:01:WU01:FS00:0x17:Saving result file badStateForceGroup2_18467Ref.xml
12:51:03:WU01:FS00:0x17:Saving result file checkpointState.xml
12:51:04:WU01:FS00:0x17:Saving result file checkpt.crc
12:51:04:WU01:FS00:0x17:Saving result file log.txt
12:51:04:WU01:FS00:0x17:Saving result file positions.xtc
12:51:07:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:51:07:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8900 run:35 clone:6 gen:81 core:0x17 unit:0x00000067028c1266519a66e991743e81
12:51:07:WU01:FS00:Uploading 37.11MiB to 171.64.65.69
12:51:07:WU01:FS00:Connecting to 171.64.65.69:8080
12:51:07:WU02:FS00:Starting
12:51:07:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 02 -suffix 01 -version 703 -lifeline 4292 -checkpoint 15 -gpu 0 -gpu-vendor ati
12:51:07:WU02:FS00:Started FahCore on PID 5220
12:51:07:WU02:FS00:Core PID:7332
12:51:07:WU02:FS00:FahCore 0x17 started
12:51:07:WU02:FS00:0x17:*********************** Log Started 2013-07-20T12:51:07Z ***********************
12:51:07:WU02:FS00:0x17:Project: 8900 (Run 115, Clone 1, Gen 47)
12:51:07:WU02:FS00:0x17:Unit: 0x00000042028c126651a6400afb8069bf
12:51:07:WU02:FS00:0x17:CPU: 0x00000000000000000000000000000000
12:51:07:WU02:FS00:0x17:Machine: 0
12:51:07:WU02:FS00:0x17:Reading tar file state.xml
12:51:08:WU02:FS00:0x17:Reading tar file system.xml
12:51:08:WU02:FS00:0x17:Reading tar file integrator.xml
12:51:08:WU02:FS00:0x17:Reading tar file core.xml
12:51:08:WU02:FS00:0x17:Digital signatures verified
12:51:13:WU01:FS00:Upload 3.54%
12:51:19:WU01:FS00:Upload 6.40%
12:51:25:WU01:FS00:Upload 9.26%
12:51:31:WU01:FS00:Upload 12.13%
12:51:37:WU01:FS00:Upload 14.82%
12:51:43:WU01:FS00:Upload 17.68%
12:51:49:WU01:FS00:Upload 20.55%
12:51:55:WU01:FS00:Upload 23.41%
12:52:01:WU01:FS00:Upload 26.27%
12:52:07:WU01:FS00:Upload 29.13%
12:52:13:WU01:FS00:Upload 32.00%
12:52:19:WU01:FS00:Upload 34.69%
12:52:25:WU01:FS00:Upload 37.55%
12:52:31:WU01:FS00:Upload 40.42%
12:52:37:WU01:FS00:Upload 43.28%
12:52:43:WU01:FS00:Upload 46.14%
12:52:49:WU01:FS00:Upload 49.01%
12:52:55:WU01:FS00:Upload 51.87%
12:53:01:WU01:FS00:Upload 54.73%
12:53:07:WU01:FS00:Upload 57.59%
12:53:13:WU01:FS00:Upload 60.46%
12:53:19:WU01:FS00:Upload 63.15%
12:53:25:WU01:FS00:Upload 66.01%
12:53:31:WU01:FS00:Upload 68.88%
12:53:37:WU02:FS00:0x17:Completed 0 out of 2500000 steps (0%)
12:53:37:WU01:FS00:Upload 71.74%
12:53:43:WU01:FS00:Upload 74.60%
12:53:49:WU01:FS00:Upload 77.47%
12:53:55:WU01:FS00:Upload 80.33%
12:54:01:WU01:FS00:Upload 83.19%
12:54:07:WU01:FS00:Upload 85.89%
12:54:13:WU01:FS00:Upload 88.75%
12:54:19:WU01:FS00:Upload 91.61%
12:54:25:WU01:FS00:Upload 94.47%
12:54:31:WU01:FS00:Upload 97.17%
12:54:52:WU01:FS00:Upload complete
12:54:52:WU01:FS00:Server responded WORK_ACK (400)
12:54:52:WU01:FS00:Final credit estimate, 23311.00 points
12:54:52:WU01:FS00:Cleaning up
12:57:55:WU02:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
13:01:58:WU02:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
13:06:19:WU02:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
13:10:22:WU02:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
13:14:43:WU02:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
13:18:46:WU02:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
13:23:06:WU02:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
13:27:10:WU02:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
13:31:30:WU02:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
13:35:33:WU02:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
13:39:53:WU02:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
13:43:55:WU02:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
13:48:15:WU02:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
13:52:18:WU02:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
13:56:38:WU02:FS00:0x17:Completed 375000 out of 2500000 steps (15%)
14:00:40:WU02:FS00:0x17:Completed 400000 out of 2500000 steps (16%)
14:05:01:WU02:FS00:0x17:Completed 425000 out of 2500000 steps (17%)
14:09:04:WU02:FS00:0x17:Completed 450000 out of 2500000 steps (18%)
14:13:24:WU02:FS00:0x17:Completed 475000 out of 2500000 steps (19%)
14:17:27:WU02:FS00:0x17:Completed 500000 out of 2500000 steps (20%)
14:21:48:WU02:FS00:0x17:Completed 525000 out of 2500000 steps (21%)
14:25:50:WU02:FS00:0x17:Completed 550000 out of 2500000 steps (22%)
14:30:11:WU02:FS00:0x17:Completed 575000 out of 2500000 steps (23%)
14:34:14:WU02:FS00:0x17:Completed 600000 out of 2500000 steps (24%)
14:38:34:WU02:FS00:0x17:Completed 625000 out of 2500000 steps (25%)
14:42:37:WU02:FS00:0x17:Completed 650000 out of 2500000 steps (26%)
14:46:58:WU02:FS00:0x17:Completed 675000 out of 2500000 steps (27%)
14:51:01:WU02:FS00:0x17:Completed 700000 out of 2500000 steps (28%)
14:55:22:WU02:FS00:0x17:Completed 725000 out of 2500000 steps (29%)
14:59:25:WU02:FS00:0x17:Completed 750000 out of 2500000 steps (30%)
15:03:45:WU02:FS00:0x17:Completed 775000 out of 2500000 steps (31%)
15:07:48:WU02:FS00:0x17:Completed 800000 out of 2500000 steps (32%)
15:12:09:WU02:FS00:0x17:Completed 825000 out of 2500000 steps (33%)
15:16:12:WU02:FS00:0x17:Completed 850000 out of 2500000 steps (34%)
15:20:32:WU02:FS00:0x17:Completed 875000 out of 2500000 steps (35%)
15:24:34:WU02:FS00:0x17:Completed 900000 out of 2500000 steps (36%)
15:28:55:WU02:FS00:0x17:Completed 925000 out of 2500000 steps (37%)
15:32:57:WU02:FS00:0x17:Completed 950000 out of 2500000 steps (38%)
15:37:17:WU02:FS00:0x17:Completed 975000 out of 2500000 steps (39%)
15:41:20:WU02:FS00:0x17:Completed 1000000 out of 2500000 steps (40%)
15:45:40:WU02:FS00:0x17:Completed 1025000 out of 2500000 steps (41%)
15:49:41:WU02:FS00:0x17:Completed 1050000 out of 2500000 steps (42%)
15:54:01:WU02:FS00:0x17:Completed 1075000 out of 2500000 steps (43%)
15:58:03:WU02:FS00:0x17:Completed 1100000 out of 2500000 steps (44%)
16:02:23:WU02:FS00:0x17:Completed 1125000 out of 2500000 steps (45%)
16:06:26:WU02:FS00:0x17:Completed 1150000 out of 2500000 steps (46%)
16:10:46:WU02:FS00:0x17:Completed 1175000 out of 2500000 steps (47%)
16:14:49:WU02:FS00:0x17:Completed 1200000 out of 2500000 steps (48%)
16:19:09:WU02:FS00:0x17:Completed 1225000 out of 2500000 steps (49%)
16:23:11:WU02:FS00:0x17:Completed 1250000 out of 2500000 steps (50%)
16:27:31:WU02:FS00:0x17:Completed 1275000 out of 2500000 steps (51%)
16:31:34:WU02:FS00:0x17:Completed 1300000 out of 2500000 steps (52%)
16:35:54:WU02:FS00:0x17:Completed 1325000 out of 2500000 steps (53%)
16:39:57:WU02:FS00:0x17:Completed 1350000 out of 2500000 steps (54%)
16:44:16:WU02:FS00:0x17:Completed 1375000 out of 2500000 steps (55%)
16:48:19:WU02:FS00:0x17:Completed 1400000 out of 2500000 steps (56%)
16:52:39:WU02:FS00:0x17:Completed 1425000 out of 2500000 steps (57%)
16:56:42:WU02:FS00:0x17:Completed 1450000 out of 2500000 steps (58%)
17:01:02:WU02:FS00:0x17:Completed 1475000 out of 2500000 steps (59%)
17:05:04:WU02:FS00:0x17:Completed 1500000 out of 2500000 steps (60%)
17:09:24:WU02:FS00:0x17:Completed 1525000 out of 2500000 steps (61%)
17:13:25:WU02:FS00:0x17:Completed 1550000 out of 2500000 steps (62%)
17:17:45:WU02:FS00:0x17:Completed 1575000 out of 2500000 steps (63%)
17:21:48:WU02:FS00:0x17:Completed 1600000 out of 2500000 steps (64%)
17:26:07:WU02:FS00:0x17:Completed 1625000 out of 2500000 steps (65%)
17:30:09:WU02:FS00:0x17:Completed 1650000 out of 2500000 steps (66%)
17:34:28:WU02:FS00:0x17:Completed 1675000 out of 2500000 steps (67%)
17:38:30:WU02:FS00:0x17:Completed 1700000 out of 2500000 steps (68%)
17:42:50:WU02:FS00:0x17:Completed 1725000 out of 2500000 steps (69%)
17:46:52:WU02:FS00:0x17:Completed 1750000 out of 2500000 steps (70%)
17:51:12:WU02:FS00:0x17:Completed 1775000 out of 2500000 steps (71%)
17:55:15:WU02:FS00:0x17:Completed 1800000 out of 2500000 steps (72%)
17:59:34:WU02:FS00:0x17:Completed 1825000 out of 2500000 steps (73%)
18:03:37:WU02:FS00:0x17:Completed 1850000 out of 2500000 steps (74%)
18:07:55:WU02:FS00:0x17:Completed 1875000 out of 2500000 steps (75%)
18:11:57:WU02:FS00:0x17:Completed 1900000 out of 2500000 steps (76%)
18:16:15:WU02:FS00:0x17:Completed 1925000 out of 2500000 steps (77%)
18:20:16:WU02:FS00:0x17:Completed 1950000 out of 2500000 steps (78%)
18:24:35:WU02:FS00:0x17:Completed 1975000 out of 2500000 steps (79%)
18:28:36:WU02:FS00:0x17:Completed 2000000 out of 2500000 steps (80%)
18:32:55:WU02:FS00:0x17:Completed 2025000 out of 2500000 steps (81%)
18:36:57:WU02:FS00:0x17:Completed 2050000 out of 2500000 steps (82%)
18:41:16:WU02:FS00:0x17:Completed 2075000 out of 2500000 steps (83%)
18:45:18:WU02:FS00:0x17:Completed 2100000 out of 2500000 steps (84%)
18:49:37:WU02:FS00:0x17:Completed 2125000 out of 2500000 steps (85%)
18:53:39:WU02:FS00:0x17:Completed 2150000 out of 2500000 steps (86%)
18:57:58:WU02:FS00:0x17:Completed 2175000 out of 2500000 steps (87%)
19:01:59:WU02:FS00:0x17:Completed 2200000 out of 2500000 steps (88%)
19:06:18:WU02:FS00:0x17:Completed 2225000 out of 2500000 steps (89%)
19:10:20:WU02:FS00:0x17:Completed 2250000 out of 2500000 steps (90%)
19:14:39:WU02:FS00:0x17:Completed 2275000 out of 2500000 steps (91%)
19:18:42:WU02:FS00:0x17:Completed 2300000 out of 2500000 steps (92%)
19:23:02:WU02:FS00:0x17:Completed 2325000 out of 2500000 steps (93%)
19:27:03:WU02:FS00:0x17:Completed 2350000 out of 2500000 steps (94%)
19:31:22:WU02:FS00:0x17:Completed 2375000 out of 2500000 steps (95%)
19:35:22:WU02:FS00:0x17:Completed 2400000 out of 2500000 steps (96%)
19:39:40:WU02:FS00:0x17:Completed 2425000 out of 2500000 steps (97%)
19:43:41:WU02:FS00:0x17:Completed 2450000 out of 2500000 steps (98%)
19:43:42:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
19:43:42:WU01:FS00:News: Welcome to Folding@Home
19:43:42:WU01:FS00:Assigned to work server 171.64.65.69
19:43:42:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:Tahiti PRO [Radeon HD 7950] from 171.64.65.69
19:43:42:WU01:FS00:Connecting to 171.64.65.69:8080
19:43:43:WU01:FS00:Downloading 4.17MiB
19:43:44:WU01:FS00:Download complete
19:43:45:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:364 clone:0 gen:74 core:0x17 unit:0x0000005f028c126651a6778af24dfd85
19:48:00:WU02:FS00:0x17:Completed 2475000 out of 2500000 steps (99%)
19:52:01:WU02:FS00:0x17:Completed 2500000 out of 2500000 steps (100%)
19:52:18:WU02:FS00:0x17:Saving result file logfile_01.txt
19:52:18:WU02:FS00:0x17:Saving result file checkpointState.xml
19:52:20:WU02:FS00:0x17:Saving result file checkpt.crc
19:52:20:WU02:FS00:0x17:Saving result file log.txt
19:52:20:WU02:FS00:0x17:Saving result file positions.xtc
19:52:22:WU02:FS00:0x17:Folding@home Core Shutdown: FINISHED_UNIT
19:52:22:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:52:22:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:8900 run:115 clone:1 gen:47 core:0x17 unit:0x00000042028c126651a6400afb8069bf
19:52:22:WU02:FS00:Uploading 12.96MiB to 171.64.65.69
19:52:22:WU02:FS00:Connecting to 171.64.65.69:8080
19:52:22:WU01:FS00:Starting
19:52:22:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 01 -suffix 01 -version 703 -lifeline 4292 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:52:23:WU01:FS00:Started FahCore on PID 7340
19:52:23:WU01:FS00:Core PID:9620
19:52:23:WU01:FS00:FahCore 0x17 started
19:52:23:WU01:FS00:0x17:*********************** Log Started 2013-07-20T19:52:23Z ***********************
19:52:23:WU01:FS00:0x17:Project: 8900 (Run 364, Clone 0, Gen 74)
19:52:23:WU01:FS00:0x17:Unit: 0x0000005f028c126651a6778af24dfd85
19:52:23:WU01:FS00:0x17:CPU: 0x00000000000000000000000000000000
19:52:23:WU01:FS00:0x17:Machine: 0
19:52:23:WU01:FS00:0x17:Reading tar file state.xml
19:52:24:WU01:FS00:0x17:Reading tar file system.xml
19:52:24:WU01:FS00:0x17:Reading tar file integrator.xml
19:52:24:WU01:FS00:0x17:Reading tar file core.xml
19:52:24:WU01:FS00:0x17:Digital signatures verified
19:52:28:WU02:FS00:Upload 7.23%
19:52:34:WU02:FS00:Upload 14.95%
19:52:40:WU02:FS00:Upload 23.14%
19:52:46:WU02:FS00:Upload 31.34%
19:52:52:WU02:FS00:Upload 39.05%
19:52:58:WU02:FS00:Upload 47.25%
19:53:04:WU02:FS00:Upload 54.97%
19:53:10:WU02:FS00:Upload 63.16%
19:53:16:WU02:FS00:Upload 70.88%
19:53:22:WU02:FS00:Upload 79.07%
19:53:28:WU02:FS00:Upload 86.79%
19:53:34:WU02:FS00:Upload 94.50%
19:53:45:WU02:FS00:Upload complete
19:53:46:WU02:FS00:Server responded WORK_ACK (400)
19:53:46:WU02:FS00:Final credit estimate, 28154.00 points
19:53:46:WU02:FS00:Cleaning up
19:54:52:WU01:FS00:0x17:Completed 0 out of 2500000 steps (0%)
19:59:09:WU01:FS00:0x17:Completed 25000 out of 2500000 steps (1%)
20:03:11:WU01:FS00:0x17:Completed 50000 out of 2500000 steps (2%)
20:07:30:WU01:FS00:0x17:Completed 75000 out of 2500000 steps (3%)
20:11:32:WU01:FS00:0x17:Completed 100000 out of 2500000 steps (4%)
20:15:51:WU01:FS00:0x17:Completed 125000 out of 2500000 steps (5%)
20:19:53:WU01:FS00:0x17:Completed 150000 out of 2500000 steps (6%)
20:24:12:WU01:FS00:0x17:Completed 175000 out of 2500000 steps (7%)
20:28:13:WU01:FS00:0x17:Completed 200000 out of 2500000 steps (8%)
20:32:33:WU01:FS00:0x17:Completed 225000 out of 2500000 steps (9%)
20:36:35:WU01:FS00:0x17:Completed 250000 out of 2500000 steps (10%)
20:40:54:WU01:FS00:0x17:Completed 275000 out of 2500000 steps (11%)
20:44:56:WU01:FS00:0x17:Completed 300000 out of 2500000 steps (12%)
20:49:15:WU01:FS00:0x17:Completed 325000 out of 2500000 steps (13%)
20:53:18:WU01:FS00:0x17:Completed 350000 out of 2500000 steps (14%)
Truncated due to 60000 character limit
WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:177 clone:1 gen:80. This message indicates that there was some kind of an error when processing WU 0 on slot 0 and the client is attempting to upload a report indicating that the WU was Faulty. That report has not been accepted by either the server 171.64.65.69 or by the collection server 171.65.103.160 as indicated by the message Transfer failed
The client downloaded a new wu, project:8900 run:592 clone:1 gen:69, calling it WU 2, to be processed in slot 0. It also failed with the messages 22:05:19:WU02:FS00:0x17:Bad State detected... attempting to resume from last good checkpoint
generating a second FAULTY WU report after completing 24% of the processing.
The report for WU 2 was accepted by the server at 22:08:34:WU02:FS00:Server responded WORK_ACK (400)
Since it had an error, you received partial credit for it:
Hi StitchExperimen (team 198),
Your WU (P8900 R592 C1 G69) was added to the stats database on 2013-07-19 16:00:20 for 1440 points of credi
t.
The WU was assigned to someone else who completed it successfully:
Hi xxxxx (team xxxx),
Your WU (P8900 R592 C1 G69) was added to the stats database on 2013-07-20 00:00:11 for 25644 points of credit
Subsequent WUs have been assigned and seem to be failing quite consistently. That's most likely due to overclocking though it can also be due to overheating or a power supply that can't provide enough 12v current to run the GPU reliably. I suggest you reduce the clock rate of you GPU and see if you can find a spot where it's stable.
Re: Having failed errors on 8900 projects.
And in general we don't need to see the entire log file, just the config section and the section showing the errors. All those completed frames could be snipped out to better show the more related info.
StitchExperimen
Post by StitchExperimen »
Okay, also my bad, card was o/c to 1200 in Catalyst Control Center, it's now at 950, power supply is digital switching 1200 watt. Temp is 59c. So these last 2 weren't problems.
jrheuwing
Post by jrheuwing »
Unfortunately i have the same problem with this type of WU. The problems started last week and a reinstall of the software didn't fix the problem. Cause there is no OC function on the laptop and it runs on stock speed that can not be the problem. The laptop has run for months with F@H without a problem but since the server maintenance the problem started. When folding a SMP WU the client didn't gave a error message and finished the WU before the deadline.
Is it possible to get other WU than the 8900's. As far as i can see only those WU gave problems with the AMD GPU.
Below some lines from the log file.
*********************** Log Started 2013-09-02T14:23:46Z ***********************
14:23:46:******************************** Build ********************************
14:23:46:      Version: 7.3.6
14:23:46:         Date: Feb 18 2013
14:23:46:         Time: 15:25:17
14:23:46:      SVN Rev: 3923
14:23:46:       Branch: fah/trunk/client
14:23:46:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:23:46:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:23:46:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
14:23:46:     Platform: win32 XP
14:23:46:         Bits: 32
14:23:46:         Mode: Release
14:23:46:******************************* System ********************************
14:23:46:          CPU: AMD A6-4400M APU with Radeon(tm) HD Graphics
14:23:46:       CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
14:23:46:         CPUs: 2
14:23:46:       Memory: 3.46GiB
14:23:46:  Free Memory: 2.42GiB
14:23:46:      Threads: WINDOWS_THREADS
14:23:46:  Has Battery: true
14:23:46:   On Battery: false
14:23:46:   UTC offset: 2
14:23:46:          PID: 4004
14:23:46:          CWD: C:/Users/Jeroen/AppData/Roaming/FAHClient
14:23:46:           OS: Windows 8
14:23:46:      OS Arch: AMD64
14:23:46:         GPUs: 1
14:23:46:        GPU 0: ATI:5 Trinity [Radeon HD 7520G]
14:23:46:         CUDA: Not detected
14:23:46:Win32 Service: false
14:23:46:***********************************************************************
14:23:46:Trying to access database...
14:23:46:Successfully acquired database lock
14:23:46:Enabled folding slot 00: PAUSED gpu:0:Trinity [Radeon HD 7520G] (paused)
14:25:52:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:25:52:WU00:FS00:News: Welcome to Folding@Home
14:25:52:WU00:FS00:Assigned to work server 171.64.65.69
14:25:52:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Trinity [Radeon HD 7520G] from 171.64.65.69
14:25:52:WU00:FS00:Connecting to 171.64.65.69:8080
14:25:53:WU00:FS00:Downloading 4.18MiB
14:25:59:WU00:FS00:Download 40.41%
14:26:05:WU00:FS00:Download 91.30%
14:26:05:WU00:FS00:Download complete
14:26:05:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8900 run:631 clone:0 gen:104 core:0x17 unit:0x00000088028c126651a6b2f7ec13a226
14:26:06:WU00:FS00:Starting
14:26:06:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Jeroen/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_17.fah/FahCore_17.exe -dir 00 -suffix 01 -version 703 -lifeline 4004 -checkpoint 15 -gpu 0 -gpu-vendor ati
14:26:06:WU00:FS00:Started FahCore on PID 6048
14:26:07:WU00:FS00:Core PID:6068
14:26:07:WU00:FS00:FahCore 0x17 started
14:26:08:WU00:FS00:0x17:*********************** Log Started 2013-09-02T14:26:08Z ***********************
14:26:08:WU00:FS00:0x17:Project: 8900 (Run 631, Clone 0, Gen 104)
14:26:08:WU00:FS00:0x17:Unit: 0x00000088028c126651a6b2f7ec13a226
14:26:08:WU00:FS00:0x17:CPU: 0x00000000000000000000000000000000
14:26:08:WU00:FS00:0x17:Machine: 0
14:26:08:WU00:FS00:0x17:Reading tar file state.xml
14:26:09:WU00:FS00:0x17:Reading tar file system.xml
14:26:10:WU00:FS00:0x17:Reading tar file integrator.xml
14:26:10:WU00:FS00:0x17:Reading tar file core.xml
14:26:10:WU00:FS00:0x17:Digital signatures verified
14:26:36:WU00:FS00:0x17:ERROR:Win32: 0xc0000005: Exception access violation
14:26:36:WU00:FS00:0x17:Saving result file logfile_01.txt
14:26:36:WU00:FS00:0x17:Saving result file log.txt
14:26:36:WU00:FS00:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
14:26:36:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:26:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:8900 run:631 clone:0 gen:104 core:0x17 unit:0x00000088028c126651a6b2f7ec13a226
14:26:36:WU00:FS00:Uploading 2.29KiB to 171.64.65.69
14:26:36:WU00:FS00:Connecting to 171.64.65.69:8080
14:26:36:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
14:26:36:WU00:FS00:Upload complete
14:26:36:WU00:FS00:Server responded WORK_ACK (400)
14:26:36:WU00:FS00:Cleaning up
PS. Sorry for my bad English. It is not my native languages
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
jrheuwing, there have been other reports of that error, what it is caused by, and what can be done about it. See for example viewtopic.php?f=66&t=23868&p=239216#p239212
Might be an OpenCL error.
Project:8900 run:631 clone:0 gen:104 has two failure reports in the database so far and no successes. So it might be a bad WU, I will mark this for followup.
The folding configuration was not listed in the log, did you edit it out? That is useful information for troubleshooting a problem. Also, what version of Catalyst is installed on the system. For Core_17 recent versions are recommended, 13.4 is most recent non-beta installation.
