Previously I used to fold but the majority of it was using V6, and without a GPU. Now, I have a laptop with adequate cooling that I would like to begin folding on, getting myself and my team back into the game a bit more while helping science.
My CPU seems to be doing just fine. My GPU on the other hand is at ready, and by looking at the logs, is not folding because it cannot retrieve a WU. Is there a proper fix to correct this? I am pretty sure that my GPU is supported, as I have checked the previously posted whitelist.
Any help would be much appreciated, and thank you in advance!
*********************** Log Started 2013-07-12T19:30:50Z ***********************
19:30:50:************************* Folding@home Client *************************
19:30:50: Website: http://folding.stanford.edu/
19:30:50: Copyright: (c) 2009-2013 Stanford University
19:30:50: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:30:50: Args: --open-web-control
19:30:50: Config: C:/Users/Brentt/AppData/Roaming/FAHClient/config.xml
19:30:50:******************************** Build ********************************
19:30:50: Version: 7.3.6
19:30:50: Date: Feb 18 2013
19:30:50: Time: 15:25:17
19:30:50: SVN Rev: 3923
19:30:50: Branch: fah/trunk/client
19:30:50: Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:30:50: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:30:50: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:30:50: Platform: win32 XP
19:30:50: Bits: 32
19:30:50: Mode: Release
19:30:50:******************************* System ********************************
19:30:50: CPU: AMD A8-4500M APU with Radeon(tm) HD Graphics
19:30:50: CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
19:30:50: CPUs: 4
19:30:50: Memory: 3.45GiB
19:30:50: Free Memory: 1.15GiB
19:30:50: Threads: WINDOWS_THREADS
19:30:50: Has Battery: true
19:30:50: On Battery: false
19:30:50: UTC offset: -4
19:30:50: PID: 6588
19:30:50: CWD: C:/Users/Brentt/AppData/Roaming/FAHClient
19:30:50: OS: Windows 8
19:30:50: OS Arch: AMD64
19:30:50: GPUs: 1
19:30:50: GPU 0: ATI:5 Trinity [Radeon HD 7640G]
19:30:50: CUDA: Not detected
19:30:50:Win32 Service: false
19:30:50:***********************************************************************
19:30:51:<config>
19:30:51: <!-- Folding Slot Configuration -->
19:30:51: <power v='full'/>
19:30:51:
19:30:51: <!-- Network -->
19:30:51: <proxy v=':8080'/>
19:30:51:
19:30:51: <!-- User Information -->
19:30:51: <passkey v='********************************'/>
19:30:51: <team v='12772'/>
19:30:51: <user v='gebraset'/>
19:30:51:
19:30:51: <!-- Folding Slots -->
19:30:51: <slot id='0' type='GPU'/>
19:30:51: <slot id='1' type='CPU'/>
19:30:51:</config>
19:30:51:Connecting to assign-GPU.stanford.edu:80
19:30:51:Connecting to assign-GPU.stanford.edu:8080
19:30:52:Read GPUs.txt
19:30:52:Trying to access database...
19:30:52:Successfully acquired database lock
19:30:52:Enabled folding slot 00: READY gpu:0:Trinity [Radeon HD 7640G]
19:30:52:Enabled folding slot 01: READY cpu:3
19:30:52:WU00:FS01:Starting
19:30:52:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Brentt/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 6588 -checkpoint 15 -np 3
19:30:52:WU00:FS01:Started FahCore on PID 5652
19:30:52:WU00:FS01:Core PID:5244
19:30:52:WU00:FS01:FahCore 0xa4 started
19:30:53:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
19:30:53:WU00:FS01:0xa4:
19:30:53:WU00:FS01:0xa4:*------------------------------*
19:30:53:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
19:30:53:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
19:30:53:WU00:FS01:0xa4:Preparing to commence simulation
19:30:53:WU00:FS01:0xa4:- Looking at optimizations...
19:30:53:WU00:FS01:0xa4:- Files status OK
19:30:54:WU00:FS01:0xa4:- Expanded 1117638 -> 3125912 (decompressed 279.6 percent)
19:30:54:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1117638 data_size=3125912, decompressed_data_size=3125912 diff=0
19:30:54:WU00:FS01:0xa4:- Digital signature verified
19:30:54:WU00:FS01:0xa4:Project: 8703 (Run 507, Clone 0, Gen 5)
19:30:54:WU00:FS01:0xa4:Assembly optimizations on if available.
19:30:54:WU00:FS01:0xa4:Entering M.D.
19:30:54:WU01:FS00:News: Welcome to Folding@Home
19:30:54:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:30:54:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
19:30:56:WU01:FS00:News: Welcome to Folding@Home
19:30:56:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:30:56:ERROR:WU01:FS00:Exception: Could not get an assignment
19:30:56:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
19:30:57:WU01:FS00:News: Welcome to Folding@Home
19:30:57:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:30:57:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
19:30:58:WU01:FS00:News: Welcome to Folding@Home
19:30:58:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:30:58:ERROR:WU01:FS00:Exception: Could not get an assignment
19:31:00:WU00:FS01:0xa4:Using Gromacs checkpoints
19:31:00:WU00:FS01:0xa4:Mapping NT from 3 to 3
19:31:01:14:127.0.0.1:New Web connection
19:31:01:WU00:FS01:0xa4:Resuming from checkpoint
19:31:01:WU00:FS01:0xa4:Verified 00/wudata_01.log
19:31:01:WU00:FS01:0xa4:Verified 00/wudata_01.trr
19:31:01:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
19:31:01:WU00:FS01:0xa4:Verified 00/wudata_01.edr
19:31:02:WU00:FS01:0xa4:Completed 7630 out of 1500000 steps (0%)
19:31:56:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
19:31:57:WU01:FS00:News: Welcome to Folding@Home
19:31:57:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:31:57:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
19:31:57:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:31:57:ERROR:WU01:FS00:Exception: Could not get an assignment
19:32:24:Saving configuration to config.xml
19:32:24:<config>
19:32:24: <!-- Folding Slot Configuration -->
19:32:24: <power v='full'/>
19:32:24:
19:32:24: <!-- Network -->
19:32:24: <proxy v=':8080'/>
19:32:24:
19:32:24: <!-- User Information -->
19:32:24: <passkey v='********************************'/>
19:32:24: <team v='12772'/>
19:32:24: <user v='gebraset'/>
19:32:24:
19:32:24: <!-- Folding Slots -->
19:32:24: <slot id='0' type='GPU'/>
19:32:24: <slot id='1' type='CPU'/>
19:32:24:</config>
19:33:34:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
19:33:34:WU01:FS00:News: Welcome to Folding@Home
19:33:34:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:33:34:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
19:33:34:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:33:34:ERROR:WU01:FS00:Exception: Could not get an assignment
19:36:11:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
19:36:11:WU01:FS00:News: Welcome to Folding@Home
19:36:11:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:80': Empty work server assignment
19:36:11:WU01:FS00:Connecting to assign-GPU.stanford.edu:8080
19:36:11:WARNING:WU01:FS00:Failed to get assignment from 'assign-GPU.stanford.edu:8080': Empty work server assignment
19:36:11:ERROR:WU01:FS00:Exception: Could not get an assignment
