Project: 11292 (Run 3, Clone 1, Gen 32) does not send
That work unit has been completed, but it cannot be sent to the work server. This has been going on for hours, and it keeps making attempts. It's just stuck, and it doesn't allow my GPU to receive a new work unit.
Re: Project: 11292 (Run 3, Clone 1, Gen 32) does not send
Help! This has been going on for 5 hours!
Please show us the log with that work unit number. I don't see any WUs on the PSummary page that go above 10504.
The log doesn't say anything about that work unit. It's completely blank. The other work unit (on my CPU) does have a log however.
Previous logs are stored in the Start/All Programs/Fahclient/Data Folder/Logs folder.
Did you install the client more than once -- with different settings? The only thing I can think of is that you've got two installations in different directories. One is running and the other is not.
There once was a Project: 11292 a year or two ago but the WU has long-since expired.
11292 and 11293 are current projects, and the only ones for Core 16. I have a psummary displayed in my browser that is cached from yesterday, both were showing then.
No, I've only installed the client once.
The work unit is still stuck, and it keeps making attempts to be sent. This has been going on for more than 8 hours. What can I do now?
folding_hoomer
- Hardware configuration: Sys 1: I7 2700K@4,4GHz with NH-C14
8GB G.Skill Sniper DDR3 1866MHz CL 9-10-9-28
MSI Z68A-GD65 (G3), various operating systems (WinXP, Ubuntu: 10.4.3 LTS, 12.04.2 LTS)
Optional: GTX560TI 448@stock/OC´d
Sys 2: I7 3930K@4,4GHz with Corsair H110
16GB G.Skill Ripjaws X DDR3 1866MHz CL 9-10-9-28
ASUS Ranpage IV Formula, Ubuntu 10.10
Sys 3 i7 875K@3,826 GHz with Scythe Mine2
MSI P55-GD80, Win7 64Bit Pro
Sapphire Radeon HD5870@1,163V 900/1250MHz
Sapphire Radeon HD7870@1,218V 1200/1300MHz
Sys 4 i7 2600K@4,4GHz with Scythe Mine2
Optional:
ASUS P5Q Pro with Q9550
ASUS P5Q Pro with Q6300 - Location: Bavaria, Germany
The first attempt:
1.Open advanced control and use RMB to click on the folding GPU-slot to pause it.
2. Wait a short time, than restart the GPU-slot - some times it recognizes the finished WU and begin to upload it while downloading a new one.
When nothing happens, pause your CPU-slot, too.
Quit the FAHClient, control (with taskmanager) that everything has ended and start FAHClient by using the Desktop-Icon.
Move slider in advanced control to full, than everything will work fine.
In my experience, pausing a slot doesn't help. You have to stop and restart FAHClient, itself. In many cases, a reboot is the easiest way to accomplish that but it depends on how you've configured your other applications.
Nope, nothing works. I tried both pausing the work unit and restarting the client, and then I also tried to reboot my system. However, nothing. It's stuck at Send, and it keeps making attempts.
Maybe there's a problem with the work server?
I don't see where you posted the log. If the server is down, that would explain why it won't send and why it doesn't appear in psummary but I don't know which servers are involved.
As I said, it's not making a log. I'm trying to check the log for the specific work unit, however all it shows me is a blank page. The log for the work unit my CPU's working on right now is working though.bruce wrote:I don't see where you posted the log. If the server is down, that would explain why it won't send and why it doesn't appear in psummary but I don't know which servers are involved.
In case it helps, the work server is 171.67.108.44 according to the client. Visiting the work server's log, next to project 11292 it says "full". Maybe this means something?
That server has been in Reject off and on for a while now ... it appears to be accepting at the moment so now might be a good time to restart the client. I'm not seeing any evidence of network activity so even though it says it's accepting there may be another problem with this server.
