Hi everybody,
I have restarted my folding rig about ten days ago, and i have successfully completed 12 WU under the "prefered time", but I didn't get any bonus points for my last WU.
Yes, i'm a registered user ([INpact]Ellierys) and i have correctly set a Passkey. I have always sent my WU's in time but i never get any bonus points.
This is what my FAH Control says about my last WU sent :
07:51:30:WU01:FS01:0xa3:Project: 8570 (Run 0, Clone 9, Gen 95)
--- 24 hours later ---
07:11:39:WU01:FS01:Upload 18.27%
07:11:45:WU01:FS01:Upload 27.84%
07:11:51:WU01:FS01:Upload 38.28%
07:11:57:WU01:FS01:Upload 47.85%
07:12:03:WU01:FS01:Upload 57.42%
07:12:09:WU01:FS01:Upload 66.99%
07:12:15:WU01:FS01:Upload 76.56%
07:12:21:WU01:FS01:Upload 86.13%
07:12:27:WU01:FS01:Upload 95.69%
07:12:31:WU01:FS01:Upload complete
07:12:31:WU01:FS01:Server responded WORK_ACK (400)
07:12:31:WU01:FS01:Final credit estimate, 9658.00 points
07:12:31:WU01:FS01:Cleaning up
But i got only 1300~ish points awarded for that.
Did i make a mistake somewhere ?
Kind regards, and thanks for your help,
Ellierys
I don't get any bonus points
Re: I don't get any bonus points
Welcome to the folding@home support forum Ellierys.
Without knowing the PRCG numbers we can't look up the work unit you've uploaded in your post. However, I was able to see your latest upload from your GPU and it did receive bonus points:
Hi [INpact]Ellierys (team 51),
Your WU (P8900 R647 C1 G34) was added to the stats database on 2013-07-05 02:00:53 for 13260 points of credit.
It would appear from what we can see that you've only just reached your 10th work unit for bonus qualification. It also looks like you've used different passkeys at various times. Remember, you only need one passkey and it should be used for all your clients.
As long as your work is completed before the preferred timeout you should now receive bonus points for any core_a3, core_a4, core_a5 or core_17 work units provided they are all using a qualified passkey(i.e. the one your GPU is using).
Please let us know if you see different and include the project id (e.g. Project: 8900 Run 647, Clone 1, Gen 34) so we can check the results.
Hi Bollix, and thanks for your quick answer.
About the passkey, I've asked for one the 23 rd of june because i was unable to recover my old passkey in my e-mail folder. Maybe you are talking about this old passkey ? (from 2010 I think)
I have edited my previous post with more information about the WU.
If I understand well, some WU among 12 whom I had handled was not eligible to obtain the bonus ?
So the threshold to gain the bonus is 10 "eligible WU", and not just "10 WU".
Thanks again for your answer, and have a nice day !
Ellierys
Ellierys
Yes, that's probably what I'm seeing. Our look-up tool does not show us what the actual passkey was. When you request a passkey, as long as you use the same username and email address you should get the same passkey.About the passkey, I've asked for one the 23 rd of june because i was unable to recover my old passkey in my e-mail folder. Maybe you are talking about this old passkey ? (from 2010 I think)
Correct.So the threshold to gain the bonus is 10 "eligible WU", and not just "10 WU".
As you've already noticed you did not receive bonus points for the reported work unit:
Your WU (P8570 R0 C9 G95) was added to the stats database on 2013-07-05 01:04:15 for 1674 points of credit.
Please check your next return from that client/slot as future work units should receive bonus points provided you maintain an 80% success rate.
OK, everything is clear now.
Thanks a lot
Thanks a lot
