alex@kubuntu:~/.FAHClient$ optirun -vv FAHClient
[5725279.593434] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[5725279.594035] [WARN]Could not open configuration file: /etc/bumblebee/bumblebee.conf
[5725279.594054] [WARN]Using default configuration
[5725279.594364] [DEBUG]optirun version 3.2.1 starting...
[5725279.594398] [DEBUG]Active configuration:
[5725279.594409] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[5725279.594420] [DEBUG] X display: :8
[5725279.594429] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-304:/usr/lib32/nvidia-304
[5725279.594439] [DEBUG] Socket path: /var/run/bumblebee.socket
[5725279.594449] [DEBUG] Accel/display bridge: auto
[5725279.594458] [DEBUG] VGL Compression: proxy
[5725279.594468] [DEBUG] VGLrun extra options:
[5725279.594477] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[5725279.594546] [DEBUG]Using auto-detected bridge virtualgl
[5725280.167356] [INFO]Response: Yes. X is active.
[5725280.167404] [INFO]Running application using virtualgl.
[5725280.167659] [DEBUG]Process vglrun started, PID 15107.
18:09:21:INFO(1):Read GPUs.txt
0:18:09:21:I1:Application:********************** Folding@home Client **********************
0:18:09:21:I1:Application: Website: http://folding.stanford.edu/
0:18:09:21:I1:Application: Copyright: (c) 2009-2013 Stanford University
0:18:09:21:I1:Application: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
0:18:09:21:I1:Application: Args:
0:18:09:21:I1:Application: Config: /home/alex/.FAHClient/config.xml
0:18:09:21:I1:Application:***************************** Build *****************************
0:18:09:21:I1:Application: Version: 7.3.6
0:18:09:21:I1:Application: Date: Feb 18 2013
0:18:09:21:I1:Application: Time: 07:24:08
0:18:09:21:I1:Application: SVN Rev: 3923
0:18:09:21:I1:Application: Branch: fah/trunk/client
0:18:09:21:I1:Application: Compiler: GNU 4.4.7
0:18:09:21:I1:Application: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
0:18:09:21:I1:Application: -fno-unsafe-math-optimizations -msse2
0:18:09:21:I1:Application: Platform: linux2 3.2.0-1-amd64
0:18:09:21:I1:Application: Bits: 64
0:18:09:21:I1:Application: Mode: Release
0:18:09:21:I1:Application:**************************** System *****************************
0:18:09:21:I1:Application: CPU: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz
0:18:09:21:I1:Application: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
0:18:09:21:I1:Application: CPUs: 8
0:18:09:21:I1:Application: Memory: 15.56GiB
0:18:09:21:I1:Application:Free Memory: 657.57MiB
0:18:09:21:I1:Application: Threads: POSIX_THREADS
0:18:09:21:I1:Application:Has Battery: true
0:18:09:21:I1:Application: On Battery: false
0:18:09:21:I1:Application: UTC offset: -7
0:18:09:21:I1:Application: PID: 15107
0:18:09:21:I1:Application: CWD: /home/alex/.FAHClient
0:18:09:21:I1:Application: OS: Linux 3.8.0-19-generic x86_64
0:18:09:21:I1:Application: OS Arch: AMD64
0:18:09:21:I1:Application: GPUs: 1
0:18:09:21:I1:Application: GPU 0: NVIDIA:2 GF114 [GeForce GTX 675M]
0:18:09:21:I1:Application: CUDA: 2.1
0:18:09:21:I1:Application:CUDA Driver: 5000
0:18:09:21:I1:Application:*****************************************************************
1:18:09:21:I5:Thread:Started thread 1 on PID 15107
0:18:09:21:I2:Application:<config>
0:18:09:21:I2:Application: <!-- Client Control -->
0:18:09:21:I2:Application: <client-threads v='4'/>
0:18:09:21:I2:Application: <cycle-rate v='4'/>
0:18:09:21:I2:Application: <cycles v='-1'/>
0:18:09:21:I2:Application: <data-directory v='.'/>
0:18:09:21:I2:Application: <disable-sleep-when-active v='true'/>
0:18:09:21:I2:Application: <exec-directory v='/usr/bin'/>
0:18:09:21:I2:Application: <exit-when-done v='false'/>
0:18:09:21:I2:Application: <fold-anon v='false'/>
0:18:09:21:I2:Application: <idle-seconds v='300'/>
0:18:09:21:I2:Application: <open-web-control v='false'/>
0:18:09:21:I2:Application: <!-- Configuration -->
0:18:09:21:I2:Application: <config-rotate v='true'/>
0:18:09:21:I2:Application: <config-rotate-dir v='configs'/>
0:18:09:21:I2:Application: <config-rotate-max v='1000000'/>
0:18:09:21:I2:Application: <!-- Debugging -->
0:18:09:21:I2:Application: <assignment-servers>
0:18:09:21:I2:Application: assign3.stanford.edu:8080 assign4.stanford.edu:80
0:18:09:21:I2:Application: </assignment-servers>
0:18:09:21:I2:Application: <capture-directory v='capture'/>
0:18:09:21:I2:Application: <capture-on-error v='false'/>
0:18:09:21:I2:Application: <capture-packets v='false'/>
0:18:09:21:I2:Application: <capture-requests v='false'/>
0:18:09:21:I2:Application: <capture-responses v='false'/>
0:18:09:21:I2:Application: <capture-sockets v='false'/>
0:18:09:21:I2:Application: <debug-sockets v='false'/>
0:18:09:21:I2:Application: <exception-locations v='true'/>
0:18:09:21:I2:Application: <gpu-assignment-servers>
0:18:09:21:I2:Application: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
0:18:09:21:I2:Application: </gpu-assignment-servers>
0:18:09:21:I2:Application: <stack-traces v='false'/>
0:18:09:21:I2:Application: <!-- Error Handling -->
0:18:09:21:I2:Application: <max-slot-errors v='5'/>
0:18:09:21:I2:Application: <max-unit-errors v='5'/>
0:18:09:21:I2:Application: <!-- Folding Core -->
0:18:09:21:I2:Application: <checkpoint v='30'/>
0:18:09:21:I2:Application: <core-dir v='cores'/>
0:18:09:21:I2:Application: <core-priority v='idle'/>
0:18:09:21:I2:Application: <cpu-affinity v='true'/>
0:18:09:21:I2:Application: <cpu-usage v='100'/>
0:18:09:21:I2:Application: <gpu-usage v='100'/>
0:18:09:21:I2:Application: <no-assembly v='false'/>
0:18:09:21:I2:Application: <!-- Folding Slot Configuration -->
0:18:09:21:I2:Application: <cause v='CANCER'/>
0:18:09:21:I2:Application: <client-subtype v='LINUX'/>
0:18:09:21:I2:Application: <client-type v='advanced'/>
0:18:09:21:I2:Application: <cpu-species v='X86_PENTIUM_II'/>
0:18:09:21:I2:Application: <cpu-type v='AMD64'/>
0:18:09:21:I2:Application: <cpus v='-1'/>
0:18:09:21:I2:Application: <cuda-index v='0'/>
0:18:09:21:I2:Application: <extra-core-args v='-verbose'/>
0:18:09:21:I2:Application: <gpu v='false'/>
0:18:09:21:I2:Application: <max-packet-size v='big'/>
0:18:09:21:I2:Application: <opencl-index v='0'/>
0:18:09:21:I2:Application: <os-species v='UNKNOWN'/>
0:18:09:21:I2:Application: <os-type v='LINUX'/>
0:18:09:21:I2:Application: <power v='full'/>
0:18:09:21:I2:Application: <project-key v='0'/>
0:18:09:21:I2:Application: <smp v='true'/>
0:18:09:21:I2:Application: <!-- HTTP Server -->
0:18:09:21:I2:Application: <allow v='127.0.0.1 192.168.1.0/24'/>
0:18:09:21:I2:Application: <connection-timeout v='60'/>
0:18:09:21:I2:Application: <deny v='0/0'/>
0:18:09:21:I2:Application: <http-addresses v='0:7396'/>
0:18:09:21:I2:Application: <https-addresses v=''/>
0:18:09:21:I2:Application: <max-connect-time v='900'/>
0:18:09:21:I2:Application: <max-connections v='800'/>
0:18:09:21:I2:Application: <max-request-length v='52428800'/>
0:18:09:21:I2:Application: <min-connect-time v='300'/>
0:18:09:21:I2:Application: <threads v='8'/>
0:18:09:21:I2:Application: <!-- Logging -->
0:18:09:21:I2:Application: <log v='log.txt'/>
0:18:09:21:I2:Application: <log-color v='true'/>
0:18:09:21:I2:Application: <log-crlf v='false'/>
0:18:09:21:I2:Application: <log-date v='false'/>
0:18:09:21:I2:Application: <log-date-periodically v='21600'/>
0:18:09:21:I2:Application: <log-debug v='true'/>
0:18:09:21:I2:Application: <log-domain v='true'/>
0:18:09:21:I2:Application: <log-header v='true'/>
0:18:09:21:I2:Application: <log-level v='true'/>
0:18:09:21:I2:Application: <log-no-info-header v='true'/>
0:18:09:21:I2:Application: <log-redirect v='false'/>
0:18:09:21:I2:Application: <log-rotate v='true'/>
0:18:09:21:I2:Application: <log-rotate-dir v='logs'/>
0:18:09:21:I2:Application: <log-rotate-max v='1000000'/>
0:18:09:21:I2:Application: <log-short-level v='true'/>
0:18:09:21:I2:Application: <log-simple-domains v='true'/>
0:18:09:21:I2:Application: <log-thread-id v='true'/>
0:18:09:21:I2:Application: <log-thread-prefix v='true'/>
0:18:09:21:I2:Application: <log-time v='true'/>
0:18:09:21:I2:Application: <log-to-screen v='true'/>
0:18:09:21:I2:Application: <log-truncate v='false'/>
0:18:09:21:I2:Application: <verbosity v='5'/>
0:18:09:21:I2:Application: <!-- Network -->
0:18:09:21:I2:Application: <proxy v=':8080'/>
0:18:09:21:I2:Application: <proxy-enable v='false'/>
0:18:09:21:I2:Application: <proxy-pass v=''/>
0:18:09:21:I2:Application: <proxy-user v=''/>
0:18:09:21:I2:Application: <!-- Process Control -->
0:18:09:21:I2:Application: <child v='false'/>
0:18:09:21:I2:Application: <daemon v='false'/>
0:18:09:21:I2:Application: <pid v='false'/>
0:18:09:21:I2:Application: <pid-file v='Folding@home Client.pid'/>
0:18:09:21:I2:Application: <respawn v='false'/>
0:18:09:21:I2:Application: <service v='false'/>
0:18:09:21:I2:Application: <!-- Remote Command Server -->
0:18:09:21:I2:Application: <command-address v='0.0.0.0'/>
0:18:09:21:I2:Application: <command-allow-no-pass v='127.0.0.1'/>
0:18:09:21:I2:Application: <command-deny-no-pass v='0/0'/>
0:18:09:21:I2:Application: <command-port v='36330'/>
0:18:09:21:I2:Application: <password v='**********'/>
0:18:09:21:I2:Application: <!-- Slot Control -->
0:18:09:21:I2:Application: <idle v='false'/>
0:18:09:21:I2:Application: <max-shutdown-wait v='60'/>
0:18:09:21:I2:Application: <pause-on-battery v='false'/>
0:18:09:21:I2:Application: <pause-on-start v='false'/>
0:18:09:21:I2:Application: <!-- User Information -->
0:18:09:21:I2:Application: <machine-id v='0'/>
0:18:09:21:I2:Application: <passkey v='********************************'/>
0:18:09:21:I2:Application: <team v='0'/>
0:18:09:21:I2:Application: <user v='Stonecold1995'/>
0:18:09:21:I2:Application: <!-- Web Server -->
0:18:09:21:I2:Application: <session-timeout v='3600'/>
0:18:09:21:I2:Application: <web-allow v='127.0.0.1'/>
0:18:09:21:I2:Application: <web-deny v='0/0'/>
0:18:09:21:I2:Application: <!-- Work Unit Control -->
0:18:09:21:I2:Application: <dump-after-deadline v='true'/>
0:18:09:21:I2:Application: <max-queue v='16'/>
0:18:09:21:I2:Application: <max-units v='0'/>
0:18:09:21:I2:Application: <next-unit-percentage v='100'/>
0:18:09:21:I2:Application: <!-- Folding Slots -->
0:18:09:21:I2:Application: <slot id='0' type='CPU'>
0:18:09:21:I2:Application: <cpus v='6'/>
0:18:09:21:I2:Application: </slot>
0:18:09:21:I2:Application: <slot id='1' type='GPU'/>
0:18:09:21:I2:Application:</config>
0:18:09:21:I1:ClientDB:Trying to access database...
0:18:09:21:I3:ClientDB:Successfully acquired database lock
0:18:09:21:I1:SlotManager:Enabled folding slot 00: READY cpu:6
0:18:09:21:I1:SlotManager:Enabled folding slot 01: READY gpu:0:GF114 [GeForce GTX 675M]
5:18:09:21:I5:Thread:Started thread 5 on PID 15107
6:18:09:21:I5:Thread:Started thread 6 on PID 15107
5:18:09:21:I1:Unit:WU00:FS00:Starting
7:18:09:21:I5:Thread:Started thread 7 on PID 15107
8:18:09:21:I5:Thread:Started thread 8 on PID 15107
5:18:09:21:I3:LegacyCoreInstance:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/alex/.FAHClient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 703 -lifeline 15107 -checkpoint 30 -np 6 -verbose
5:18:09:21:I3:LegacyCoreInstance:WU00:FS00:Started FahCore on PID 15123
9:18:09:21:I5:Thread:Started thread 9 on PID 15107
5:18:09:21:I1:LegacyCoreInstance:WU00:FS00:Core PID:15127
5:18:09:21:I1:Unit:WU00:FS00:FahCore 0xa4 started
5:18:09:21:I1:CoreInterface:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah
5:18:09:21:I3:SocketDefaultImpl:WU01:FS01:Connecting to www.stanford.edu:80
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:*------------------------------*
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:Preparing to commence simulation
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:- Looking at optimizations...
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:- Files status OK
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:- Expanded 1168531 -> 3134204 (decompressed 268.2 percent)
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1168531 data_size=3134204, decompressed_data_size=3134204 diff=0
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:- Digital signature verified
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:Project: 8704 (Run 196, Clone 6, Gen 2)
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:Assembly optimizations on if available.
9:18:09:21:I1:TailFileToLog:WU00:FS00:0xa4:Entering M.D.
5:18:09:22:I1:CoreInterface:WU01:FS01:FahCore 17: Downloading 3.01MiB
10:18:09:26:I5:Thread:Started thread 10 on PID 15107
09:18:09:27:I1:TailFileToLog:WU00:FS00:0xa4:Using Gromacs checkpoints
09:18:09:28:I1:TailFileToLog:WU00:FS00:0xa4:Resuming from checkpoint
09:18:09:28:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.log
09:18:09:28:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.trr
09:18:09:28:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
09:18:09:28:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.edr
09:18:09:28:I1:TailFileToLog:WU00:FS00:0xa4:Completed 1112290 out of 1500000 steps (74%)
05:18:09:30:I1:PacifierCallback:WU01:FS01:FahCore 17: 4.15%
05:18:09:36:I1:PacifierCallback:WU01:FS01:FahCore 17: 20.75%
Reading file ./work/00/wudata_01.tpr, VERSION 4.5.3 (double precision)
05:18:09:42:I1:PacifierCallback:WU01:FS01:FahCore 17: 35.28%
05:18:09:48:I1:PacifierCallback:WU01:FS01:FahCore 17: 47.74%
05:18:09:54:I1:PacifierCallback:WU01:FS01:FahCore 17: 66.41%
05:18:10:00:I1:PacifierCallback:WU01:FS01:FahCore 17: 80.94%
05:18:10:08:I1:PacifierCallback:WU01:FS01:FahCore 17: 97.55%
05:18:10:09:I1:CoreInterface:WU01:FS01:FahCore 17: Download complete
05:18:10:09:I1:CoreInterface:WU01:FS01:Valid core signature
05:18:10:09:I3:CorePackage:WU01:FS01:Unpacked 8.16MiB to cores/www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17
05:18:10:09:I1:Unit:WU01:FS01:Starting
05:18:10:09:I3:LegacyCoreInstance:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/alex/.FAHClient/cores/www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 703 -lifeline 15107 -checkpoint 30 -gpu 0 -gpu-vendor nvidia -verbose
05:18:10:09:I3:LegacyCoreInstance:WU01:FS01:Started FahCore on PID 15163
11:18:10:09:I5:Thread:Started thread 11 on PID 15107
05:18:10:09:I1:LegacyCoreInstance:WU01:FS01:Core PID:15167
05:18:10:09:I1:Unit:WU01:FS01:FahCore 0x17 started
11:18:10:10:I1:TailFileToLog:WU01:FS01:0x17:*********************** Log Started 2013-07-02T18:10:09Z ***********************
11:18:10:10:I1:TailFileToLog:WU01:FS01:0x17:Project: 8900 (Run 51, Clone 1, Gen 36)
11:18:10:10:I1:TailFileToLog:WU01:FS01:0x17:Unit: 0x00000031028c126651a631c4ece6617c
11:18:10:10:I1:TailFileToLog:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
11:18:10:10:I1:TailFileToLog:WU01:FS01:0x17:Machine: 1
11:18:10:10:I1:TailFileToLog:WU01:FS01:0x17:Reading tar file state.xml
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:Reading tar file system.xml
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:Reading tar file integrator.xml
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:Reading tar file core.xml
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:Digital signatures verified
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:ERROR:exception: Bad platformId size.
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:Saving result file logfile_01.txt
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:Saving result file log.txt
11:18:10:11:I1:TailFileToLog:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
05:18:10:11:W :LegacyCoreInstance:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:18:10:11:I1:Unit:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:8900 run:51 clone:1 gen:36 core:0x17 unit:0x00000031028c126651a631c4ece6617c
05:18:10:11:I1:Unit:WU01:FS01:Uploading 1.85KiB to 171.64.65.69
05:18:10:11:I3:SocketDefaultImpl:WU01:FS01:Connecting to 171.64.65.69:8080
00:18:10:12:I3:SocketDefaultImpl:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
05:18:10:12:I1:Unit:WU01:FS01:Upload complete
05:18:10:12:I1:Unit:WU01:FS01:Server responded WORK_ACK (400)
05:18:10:13:I1:Unit:WU01:FS01:Cleaning up
^C01:18:10:13:I1:SignalManager:Caught signal SIGINT(2) on PID 15107
01:18:10:13:I1:ExitSignalHandler:Exiting, please wait. . .[5725332.540197]
[WARN]Received Interrupt signal.
[5725332.540214] [DEBUG]Socket closed.
00:18:10:13:I1:AssignmentManager:WU02:FS01:News: Welcome to Folding@Home
00:18:10:13:I1:AssignmentManager:WU02:FS01:Assigned to work server 171.64.65.69
00:18:10:13:I1:WSAssignment:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 675M] from 171.64.65.69
00:18:10:13:I3:SocketDefaultImpl:WU02:FS01:Connecting to 171.64.65.69:8080
00:18:10:14:I1:WSAssignment:WU02:FS01:Downloading 4.18MiB
00:18:10:15:E :UnitManager:WU02:FS01:Exception: Transfer failed
00:18:10:16:I1:Slot:FS00:Shutting core down
00:18:10:16:I1:ClientApp:Clean exit
09:18:10:16:I1:TailFileToLog:WU00:FS00:0xa4:Client no longer detected. Shutting down core.
09:18:10:16:I1:TailFileToLog:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
[5725335.758778] [DEBUG]SIGCHILD received, but wait failed with No child processes
[5725335.758807] [DEBUG]Socket closed.
[5725335.758813] [DEBUG]Killing all remaining processes.
alex@kubuntu:~/.FAHClient$ FAHClient
18:12:07:INFO(1):Read GPUs.txt
0:18:12:07:I1:Application:********************** Folding@home Client **********************
0:18:12:07:I1:Application: Website: http://folding.stanford.edu/
1:18:12:07:I5:Thread:Started thread 1 on PID 15242
0:18:12:07:I1:Application: Copyright: (c) 2009-2013 Stanford University
0:18:12:07:I1:Application: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
0:18:12:07:I1:Application: Args:
0:18:12:07:I1:Application: Config: /home/alex/.FAHClient/config.xml
0:18:12:07:I1:Application:***************************** Build *****************************
0:18:12:07:I1:Application: Version: 7.3.6
0:18:12:07:I1:Application: Date: Feb 18 2013
0:18:12:07:I1:Application: Time: 07:24:08
0:18:12:07:I1:Application: SVN Rev: 3923
0:18:12:07:I1:Application: Branch: fah/trunk/client
0:18:12:07:I1:Application: Compiler: GNU 4.4.7
0:18:12:07:I1:Application: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
0:18:12:07:I1:Application: -fno-unsafe-math-optimizations -msse2
0:18:12:07:I1:Application: Platform: linux2 3.2.0-1-amd64
0:18:12:07:I1:Application: Bits: 64
0:18:12:07:I1:Application: Mode: Release
0:18:12:07:I1:Application:**************************** System *****************************
0:18:12:07:I1:Application: CPU: Intel(R) Core(TM) i7-2760QM CPU @ 2.40GHz
0:18:12:07:I1:Application: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
0:18:12:07:I1:Application: CPUs: 8
0:18:12:07:I1:Application: Memory: 15.56GiB
0:18:12:07:I1:Application:Free Memory: 605.17MiB
0:18:12:07:I1:Application: Threads: POSIX_THREADS
0:18:12:07:I1:Application:Has Battery: true
0:18:12:07:I1:Application: On Battery: false
0:18:12:07:I1:Application: UTC offset: -7
0:18:12:07:I1:Application: PID: 15242
0:18:12:07:I1:Application: CWD: /home/alex/.FAHClient
0:18:12:07:I1:Application: OS: Linux 3.8.0-19-generic x86_64
0:18:12:07:I1:Application: OS Arch: AMD64
0:18:12:07:I1:Application: GPUs: 1
0:18:12:07:I1:Application: GPU 0: NVIDIA:2 GF114 [GeForce GTX 675M]
0:18:12:07:I1:Application: CUDA: Not detected
0:18:12:07:I1:Application:*****************************************************************
0:18:12:07:I2:Application:<config>
0:18:12:07:I2:Application: <!-- Client Control -->
0:18:12:07:I2:Application: <client-threads v='4'/>
0:18:12:07:I2:Application: <cycle-rate v='4'/>
0:18:12:07:I2:Application: <cycles v='-1'/>
0:18:12:07:I2:Application: <data-directory v='.'/>
0:18:12:07:I2:Application: <disable-sleep-when-active v='true'/>
0:18:12:07:I2:Application: <exec-directory v='/usr/bin'/>
0:18:12:07:I2:Application: <exit-when-done v='false'/>
0:18:12:07:I2:Application: <fold-anon v='false'/>
0:18:12:07:I2:Application: <idle-seconds v='300'/>
0:18:12:07:I2:Application: <open-web-control v='false'/>
0:18:12:07:I2:Application: <!-- Configuration -->
0:18:12:07:I2:Application: <config-rotate v='true'/>
0:18:12:07:I2:Application: <config-rotate-dir v='configs'/>
0:18:12:07:I2:Application: <config-rotate-max v='1000000'/>
0:18:12:07:I2:Application: <!-- Debugging -->
0:18:12:07:I2:Application: <assignment-servers>
0:18:12:07:I2:Application: assign3.stanford.edu:8080 assign4.stanford.edu:80
0:18:12:07:I2:Application: </assignment-servers>
0:18:12:07:I2:Application: <capture-directory v='capture'/>
0:18:12:07:I2:Application: <capture-on-error v='false'/>
0:18:12:07:I2:Application: <capture-packets v='false'/>
0:18:12:07:I2:Application: <capture-requests v='false'/>
0:18:12:07:I2:Application: <capture-responses v='false'/>
0:18:12:07:I2:Application: <capture-sockets v='false'/>
0:18:12:07:I2:Application: <debug-sockets v='false'/>
0:18:12:07:I2:Application: <exception-locations v='true'/>
0:18:12:07:I2:Application: <gpu-assignment-servers>
0:18:12:07:I2:Application: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
0:18:12:07:I2:Application: </gpu-assignment-servers>
0:18:12:07:I2:Application: <stack-traces v='false'/>
0:18:12:07:I2:Application: <!-- Error Handling -->
0:18:12:07:I2:Application: <max-slot-errors v='5'/>
0:18:12:07:I2:Application: <max-unit-errors v='5'/>
0:18:12:07:I2:Application: <!-- Folding Core -->
0:18:12:07:I2:Application: <checkpoint v='30'/>
0:18:12:07:I2:Application: <core-dir v='cores'/>
0:18:12:07:I2:Application: <core-priority v='idle'/>
0:18:12:07:I2:Application: <cpu-affinity v='true'/>
0:18:12:07:I2:Application: <cpu-usage v='100'/>
0:18:12:07:I2:Application: <gpu-usage v='100'/>
0:18:12:07:I2:Application: <no-assembly v='false'/>
0:18:12:07:I2:Application: <!-- Folding Slot Configuration -->
0:18:12:07:I2:Application: <cause v='CANCER'/>
0:18:12:07:I2:Application: <client-subtype v='LINUX'/>
0:18:12:07:I2:Application: <client-type v='advanced'/>
0:18:12:07:I2:Application: <cpu-species v='X86_PENTIUM_II'/>
0:18:12:07:I2:Application: <cpu-type v='AMD64'/>
0:18:12:07:I2:Application: <cpus v='-1'/>
0:18:12:07:I2:Application: <cuda-index v='0'/>
0:18:12:07:I2:Application: <extra-core-args v='-verbose'/>
0:18:12:07:I2:Application: <gpu v='false'/>
0:18:12:07:I2:Application: <max-packet-size v='big'/>
0:18:12:07:I2:Application: <opencl-index v='0'/>
0:18:12:07:I2:Application: <os-species v='UNKNOWN'/>
0:18:12:07:I2:Application: <os-type v='LINUX'/>
0:18:12:07:I2:Application: <power v='full'/>
0:18:12:07:I2:Application: <project-key v='0'/>
0:18:12:07:I2:Application: <smp v='true'/>
0:18:12:07:I2:Application: <!-- HTTP Server -->
0:18:12:07:I2:Application: <allow v='127.0.0.1 192.168.1.0/24'/>
0:18:12:07:I2:Application: <connection-timeout v='60'/>
0:18:12:07:I2:Application: <deny v='0/0'/>
0:18:12:07:I2:Application: <http-addresses v='0:7396'/>
0:18:12:07:I2:Application: <https-addresses v=''/>
0:18:12:07:I2:Application: <max-connect-time v='900'/>
0:18:12:07:I2:Application: <max-connections v='800'/>
0:18:12:07:I2:Application: <max-request-length v='52428800'/>
0:18:12:07:I2:Application: <min-connect-time v='300'/>
0:18:12:07:I2:Application: <threads v='8'/>
0:18:12:07:I2:Application: <!-- Logging -->
0:18:12:07:I2:Application: <log v='log.txt'/>
0:18:12:07:I2:Application: <log-color v='true'/>
0:18:12:07:I2:Application: <log-crlf v='false'/>
0:18:12:07:I2:Application: <log-date v='false'/>
0:18:12:07:I2:Application: <log-date-periodically v='21600'/>
0:18:12:07:I2:Application: <log-debug v='true'/>
0:18:12:07:I2:Application: <log-domain v='true'/>
0:18:12:07:I2:Application: <log-header v='true'/>
0:18:12:07:I2:Application: <log-level v='true'/>
0:18:12:07:I2:Application: <log-no-info-header v='true'/>
0:18:12:07:I2:Application: <log-redirect v='false'/>
0:18:12:07:I2:Application: <log-rotate v='true'/>
0:18:12:07:I2:Application: <log-rotate-dir v='logs'/>
0:18:12:07:I2:Application: <log-rotate-max v='1000000'/>
0:18:12:07:I2:Application: <log-short-level v='true'/>
0:18:12:07:I2:Application: <log-simple-domains v='true'/>
0:18:12:07:I2:Application: <log-thread-id v='true'/>
0:18:12:07:I2:Application: <log-thread-prefix v='true'/>
0:18:12:07:I2:Application: <log-time v='true'/>
0:18:12:07:I2:Application: <log-to-screen v='true'/>
0:18:12:07:I2:Application: <log-truncate v='false'/>
0:18:12:07:I2:Application: <verbosity v='5'/>
0:18:12:07:I2:Application: <!-- Network -->
0:18:12:07:I2:Application: <proxy v=':8080'/>
0:18:12:07:I2:Application: <proxy-enable v='false'/>
0:18:12:07:I2:Application: <proxy-pass v=''/>
0:18:12:07:I2:Application: <proxy-user v=''/>
0:18:12:07:I2:Application: <!-- Process Control -->
0:18:12:07:I2:Application: <child v='false'/>
0:18:12:07:I2:Application: <daemon v='false'/>
0:18:12:07:I2:Application: <pid v='false'/>
0:18:12:07:I2:Application: <pid-file v='Folding@home Client.pid'/>
0:18:12:07:I2:Application: <respawn v='false'/>
0:18:12:07:I2:Application: <service v='false'/>
0:18:12:07:I2:Application: <!-- Remote Command Server -->
0:18:12:07:I2:Application: <command-address v='0.0.0.0'/>
0:18:12:07:I2:Application: <command-allow-no-pass v='127.0.0.1'/>
0:18:12:07:I2:Application: <command-deny-no-pass v='0/0'/>
0:18:12:07:I2:Application: <command-port v='36330'/>
0:18:12:07:I2:Application: <password v='**********'/>
0:18:12:07:I2:Application: <!-- Slot Control -->
0:18:12:07:I2:Application: <idle v='false'/>
0:18:12:07:I2:Application: <max-shutdown-wait v='60'/>
0:18:12:07:I2:Application: <pause-on-battery v='false'/>
0:18:12:07:I2:Application: <pause-on-start v='false'/>
0:18:12:07:I2:Application: <!-- User Information -->
0:18:12:07:I2:Application: <machine-id v='0'/>
0:18:12:07:I2:Application: <passkey v='********************************'/>
0:18:12:07:I2:Application: <team v='0'/>
0:18:12:07:I2:Application: <user v='Stonecold1995'/>
0:18:12:07:I2:Application: <!-- Web Server -->
0:18:12:07:I2:Application: <session-timeout v='3600'/>
0:18:12:07:I2:Application: <web-allow v='127.0.0.1'/>
0:18:12:07:I2:Application: <web-deny v='0/0'/>
0:18:12:07:I2:Application: <!-- Work Unit Control -->
0:18:12:07:I2:Application: <dump-after-deadline v='true'/>
0:18:12:07:I2:Application: <max-queue v='16'/>
0:18:12:07:I2:Application: <max-units v='0'/>
0:18:12:07:I2:Application: <next-unit-percentage v='100'/>
0:18:12:07:I2:Application: <!-- Folding Slots -->
0:18:12:07:I2:Application: <slot id='0' type='CPU'>
0:18:12:07:I2:Application: <cpus v='6'/>
0:18:12:07:I2:Application: </slot>
0:18:12:07:I2:Application: <slot id='1' type='GPU'/>
0:18:12:07:I2:Application:</config>
0:18:12:07:I1:ClientDB:Trying to access database...
0:18:12:07:I3:ClientDB:Successfully acquired database lock
0:18:12:07:I1:SlotManager:Enabled folding slot 00: READY cpu:6
0:18:12:07:I1:SlotManager:Enabled folding slot 01: READY gpu:0:GF114 [GeForce GTX 675M]
0:18:12:07:I1:Unit:WU00:FS00:Starting
5:18:12:07:I5:Thread:Started thread 5 on PID 15242
8:18:12:07:I5:Thread:Started thread 8 on PID 15242
6:18:12:07:I5:Thread:Started thread 6 on PID 15242
7:18:12:07:I5:Thread:Started thread 7 on PID 15242
0:18:12:07:I3:LegacyCoreInstance:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /home/alex/.FAHClient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 00 -suffix 01 -version 703 -lifeline 15242 -checkpoint 30 -np 6 -verbose
0:18:12:07:I3:LegacyCoreInstance:WU00:FS00:Started FahCore on PID 15249
9:18:12:07:I5:Thread:Started thread 9 on PID 15242
0:18:12:07:I1:LegacyCoreInstance:WU00:FS00:Core PID:15253
0:18:12:07:I1:Unit:WU00:FS00:FahCore 0xa4 started
5:18:12:07:I3:SocketDefaultImpl:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:*------------------------------*
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:Preparing to commence simulation
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:- Looking at optimizations...
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:- Files status OK
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:- Expanded 1168531 -> 3134204 (decompressed 268.2 percent)
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1168531 data_size=3134204, decompressed_data_size=3134204 diff=0
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:- Digital signature verified
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:Project: 8704 (Run 196, Clone 6, Gen 2)
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:Assembly optimizations on if available.
9:18:12:08:I1:TailFileToLog:WU00:FS00:0xa4:Entering M.D.
5:18:12:09:I1:AssignmentManager:WU01:FS01:News: Welcome to Folding@Home
5:18:12:09:I1:AssignmentManager:WU01:FS01:Assigned to work server 171.64.65.69
5:18:12:09:I1:WSAssignment:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GF114 [GeForce GTX 675M] from 171.64.65.69
5:18:12:09:I3:SocketDefaultImpl:WU01:FS01:Connecting to 171.64.65.69:8080
5:18:12:10:I1:WSAssignment:WU01:FS01:Downloading 4.17MiB
10:18:12:12:I5:Thread:Started thread 10 on PID 15242
09:18:12:13:I1:TailFileToLog:WU00:FS00:0xa4:Using Gromacs checkpoints
09:18:12:14:I1:TailFileToLog:WU00:FS00:0xa4:Resuming from checkpoint
09:18:12:14:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.log
09:18:12:14:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.trr
09:18:12:14:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
09:18:12:14:I1:TailFileToLog:WU00:FS00:0xa4:Verified 00/wudata_01.edr
09:18:12:14:I1:TailFileToLog:WU00:FS00:0xa4:Completed 1112290 out of 1500000 steps (74%)
05:18:12:16:I1:PacifierCallback:WU01:FS01:Download 28.45%
05:18:12:22:I1:PacifierCallback:WU01:FS01:Download 65.88%
05:18:12:26:I1:WSAssignment:WU01:FS01:Download complete
05:18:12:26:I1:Unit:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8900 run:191 clone:1 gen:40 core:0x17 unit:0x00000038028c126651a65108df9b1887
05:18:12:26:I1:Unit:WU01:FS01:Starting
05:18:12:26:I3:LegacyCoreInstance:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/alex/.FAHClient/cores/www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 703 -lifeline 15242 -checkpoint 30 -gpu 0 -gpu-vendor nvidia -verbose
05:18:12:26:I3:LegacyCoreInstance:WU01:FS01:Started FahCore on PID 15271
11:18:12:26:I5:Thread:Started thread 11 on PID 15242
05:18:12:26:I1:LegacyCoreInstance:WU01:FS01:Core PID:15275
05:18:12:26:I1:Unit:WU01:FS01:FahCore 0x17 started
00:18:12:27:W :LegacyCoreInstance:WU01:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
08:18:12:27:I1:Unit:WU01:FS01:Starting
08:18:12:27:I3:LegacyCoreInstance:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /home/alex/.FAHClient/cores/www.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_17.fah/FahCore_17 -dir 01 -suffix 01 -version 703 -lifeline 15242 -checkpoint 30 -gpu 0 -gpu-vendor nvidia -verbose
08:18:12:27:I3:LegacyCoreInstance:WU01:FS01:Started FahCore on PID 15276
12:18:12:27:I5:Thread:Started thread 12 on PID 15242
08:18:12:27:I1:LegacyCoreInstance:WU01:FS01:Core PID:15280
08:18:12:27:I1:Unit:WU01:FS01:FahCore 0x17 started
08:18:12:27:W :LegacyCoreInstance:WU01:FS01:FahCore returned: UNKNOWN_ENUM (127 = 0x7f)
^C01:18:12:42:I1:SignalManager:Caught signal SIGINT(2) on PID 15242
01:18:12:42:I1:ExitSignalHandler:Exiting, please wait. . .
00:18:12:43:I1:Slot:FS00:Shutting core down
09:18:12:47:I1:TailFileToLog:WU00:FS00:0xa4:Client no longer detected. Shutting down core.
09:18:12:47:I1:TailFileToLog:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
00:18:12:47:I1:ClientApp:Clean exit
alex@kubuntu:~$ sudo dpkg -l | grep -E 'bumblebee|nvidia'
ii bumblebee 3.2.1-1~raringppa2 amd64 NVIDIA Optimus support
ii bumblebee-nvidia 3.2.1-1~raringppa2 amd64 NVIDIA Optimus support using the proprietary NVIDIA driver
rc libkwinactivenvidiahack4 4:4.9.5-0ubuntu0.1 amd64 library used by nvidia cards for the KDE window manager
ii libkwinnvidiahack4 4:4.10.4-0ubuntu0.1 amd64 library used by nvidia cards for the KDE window manager
ii nvidia-304 304.88-0ubuntu1 amd64 NVIDIA binary Xorg driver, kernel module and VDPAU library
ii nvidia-current 304.88-0ubuntu1 amd64 Transitional package for nvidia-current
rc nvidia-settings 304.88-0ubuntu0.2 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-settings-304 304.88-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
alex@kubuntu:~$ optirun glxgears
[5726803.589773] [WARN]Could not open configuration file: /etc/bumblebee/bumblebee.conf
[5726803.589861] [WARN]Using default configuration
7906 frames in 5.0 seconds = 1581.181 FPS
8016 frames in 5.0 seconds = 1603.070 FPS
8011 frames in 5.0 seconds = 1602.177 FPS
8027 frames in 5.0 seconds = 1605.306 FPS
8056 frames in 5.0 seconds = 1611.122 FPS
^C[5726830.581048] [WARN]Received Interrupt signal.
