How do I get the most out of my rig?
quickbrownfox1
Ive been running FAH on and off for about 2 years now. I would like to know any ways that do not involve hardware upgrades to increase my productivity. I am currently running the Windows graphical XP client.
Fold4life.com
Foxery
- Hardware configuration: Intel Core2 Quad Q9300 (Intel P35 chipset)
Radeon 3850, 512MB model (Catalyst 8.10)
Windows XP, SP2 - Location: Syracuse, NY
Re: How do I get the most out of my rig?
We'll need your current system specs to make a recommendation.
Core2 Quad/Q9300, Radeon 3850/512MB (WinXP SP2)
quickbrownfox1
John Naylor
EDIT: didn't read the "no hardware upgrades" bit
overclocking the CPU would be the simplest method... and keeping the graphical client window closed as much as possible.
quickbrownfox1
Would using the text only client be more efficient? Also How about RAM, when I said no hardware upgrades I meant upgrading CPU or installing a GPU, But id be willing to get some more RAM if it would help. Oh, also Could someone post a link do a good guide on how to OC a computer.
Fold4life.com
Keeping the GUI window closed is essentially the same as switching to the text-based console client and is a lot easier.
Adding RAM above 1GB will not improve FAH's performance, at least for the current clients.
quickbrownfox1
And what configuration is best for FAH should I run it "slightly higher" with the bar all the way to the right?
Fold4life.com
The bar should be at 100% unless you have a really good reason to change it.quickbrownfox1 wrote:And what configuration is best for FAH should I run it "slightly higher" with the bar all the way to the right?
There will probably be no difference at al between "lowest" and "slightly higher" but you might as well set it to "slightly higher"
When FAH is distributed, the default settings are the ones that are the best for most people. It's very difficult to improve on the default settings. That's why the only real option to improve most people's production is to upgrade their hardware.
Kingcarcas
theMASS
- Hardware configuration: 8 - Q6600s (mixed steppings) average clock speed 3.3GHz
1 - E6420 @ 3.2GHz (This box is bulletproof - Stable for over a year) Avg 2250/PPD
1 - E6600 @ Stock (The only Intel chip in the last 2 years that "only" ran stock)
P35 and G33 based Gigabyte motherboards
Dedicated boxes run Notfred's Linux
Production boxes run Vista and XP Pro with Linux SMP running in a VM - Location: Los Angeles
If this is a dedicated folding box you can try running notfred's CD http://reilly.homeip.net/folding/cd.html It automatically (without permanently) installs/runs about the most efficient OS and client for whatever hardware it detects.
Even with the SMP client and bigWUs set?bruce wrote:Adding RAM above 1GB will not improve FAH's performance, at least for the current clients.
Oh, you're right. I forgot about that option. In some cases it will help and in others it won't.Tobit wrote:Even with the SMP client and bigWUs set?bruce wrote:Adding RAM above 1GB will not improve FAH's performance, at least for the current clients.
