No credit for WU :7048 run:0 clone:944 gen:3
Fixit
Post by Fixit »
I have not received credit for this WU 7048
Thanks in advance for checking it out.
Fixit OACC
 17:38:01:WU02:FS01:0xa4:Completed 24749999 out of 25000000 steps  (99%)
******************************* Date: 2013-06-15 *******************************
18:17:22:WU01:FS00:0x11:Completed 58%
18:18:51:WU01:FS00:0x11:Completed 59%
18:18:58:WU02:FS01:0xa4:Completed 24999999 out of 25000000 steps  (100%)
18:18:58:WU02:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
18:19:08:WU02:FS01:0xa4:
18:19:08:WU02:FS01:0xa4:Finished Work Unit:
18:19:08:WU02:FS01:0xa4:- Reading up to 17079504 from "02/wudata_01.trr": Read 17079504
18:19:08:WU02:FS01:0xa4:trr file hash check passed.
18:19:08:WU02:FS01:0xa4:- Reading up to 1688376 from "02/wudata_01.xtc": Read 1688376
18:19:08:WU02:FS01:0xa4:xtc file hash check passed.
18:19:08:WU02:FS01:0xa4:edr file hash check passed.
18:19:08:WU02:FS01:0xa4:logfile size: 115800
18:19:08:WU02:FS01:0xa4:Leaving Run
18:19:12:WU02:FS01:0xa4:- Writing 18965492 bytes of core data to disk...
18:19:18:WU02:FS01:0xa4:Done: 18964980 -> 17675678 (compressed to 93.2 percent)
18:19:18:WU02:FS01:0xa4:  ... Done.
18:19:21:WU02:FS01:0xa4:- Shutting down core
18:19:21:WU02:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
18:19:21:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:19:21:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:7048 run:0 clone:944 gen:3 core:0xa4 unit:0x000000080001329c5145033307d21bb0
18:19:21:WU02:FS01:Uploading 16.86MiB to 129.74.246.143
18:19:21:WU00:FS01:Starting
18:19:21:WU02:FS01:Connecting to 129.74.246.143:8080
18:19:21:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "C:/Users/DUO CORE/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a3.fah/FahCore_a3.exe" -dir 00 -suffix 01 -version 703 -lifeline 4228 -checkpoint 15 -np 2
18:19:21:WU00:FS01:Started FahCore on PID 3044
18:19:21:Started thread 84 on PID 4228
18:19:22:WU00:FS01:Core PID:4296
18:19:22:WU00:FS01:FahCore 0xa3 started
18:19:22:WU00:FS01:0xa3:
18:19:22:WU00:FS01:0xa3:*------------------------------*
18:19:22:WU00:FS01:0xa3:Folding@Home Gromacs SMP Core
18:19:22:WU00:FS01:0xa3:Version 2.27 (Dec. 15, 2010)
18:19:22:WU00:FS01:0xa3:Preparing to commence simulation
18:19:22:WU00:FS01:0xa3:- Looking at optimizations...
18:19:22:WU00:FS01:0xa3:- Created dyn
18:19:22:WU00:FS01:0xa3:- Files status OK
18:19:22:WU00:FS01:0xa3:- Expanded 3848912 -> 4392332 (decompressed 114.1 percent)
18:19:22:WU00:FS01:0xa3:Called DecompressByteArray: compressed_data_size=3848912 data_size=4392332, decompressed_data_size=4392332 diff=0
18:19:22:WU00:FS01:0xa3:- Digital signature verified
18:19:22:WU00:FS01:0xa3:Project: 8566 (Run 0, Clone 5, Gen 83)
18:19:22:WU00:FS01:0xa3:Assembly optimizations on if available.
18:19:22:WU00:FS01:0xa3:Entering M.D.
18:19:27:WU02:FS01:Upload 3.71%
18:19:28:WU00:FS01:0xa3:Mapping NT from 2 to 2
18:19:30:WU00:FS01:0xa3:Completed 0 out of 500000 steps  (0%)
18:19:33:WU02:FS01:Upload 7.79%
18:19:39:WU02:FS01:Upload 11.86%
18:19:45:WU02:FS01:Upload 15.94%
18:19:51:WU02:FS01:Upload 20.39%
18:19:57:WU02:FS01:Upload 24.47%
18:20:03:WU02:FS01:Upload 28.55%
18:20:09:WU02:FS01:Upload 32.63%
18:20:15:WU02:FS01:Upload 37.08%
18:20:21:WU02:FS01:Upload 41.15%
18:20:22:WU01:FS00:0x11:Completed 60%
18:20:27:WU02:FS01:Upload 45.23%
18:20:33:WU02:FS01:Upload 49.31%
18:20:39:WU02:FS01:Upload 53.39%
18:20:45:WU02:FS01:Upload 57.84%
18:20:51:WU02:FS01:Upload 61.92%
18:20:57:WU02:FS01:Upload 66.00%
18:21:03:WU02:FS01:Upload 70.07%
18:21:09:WU02:FS01:Upload 74.52%
18:21:15:WU02:FS01:Upload 78.60%
18:21:21:WU02:FS01:Upload 82.68%
18:21:27:WU02:FS01:Upload 86.76%
18:21:33:WU02:FS01:Upload 91.21%
18:21:39:WU02:FS01:Upload 95.28%
18:21:45:WU02:FS01:Upload 99.36%
18:21:48:WU02:FS01:Upload complete
18:21:48:WU02:FS01:Server responded WORK_ACK (400)
18:21:48:WU02:FS01:Final credit estimate, 7084.00 points
18:21:48:WU02:FS01:Cleaning up
18:21:52:WU01:FS00:0x11:Completed 61%
******************************* Date: 2013-06-16 *******************************
00:18:11:WU02:FS00:0x11:Completed 65%
00:19:41:WU02:FS00:0x11:Completed 66%
bollix47
Re: No credit for WU :7048 run:0 clone:944 gen:3
Post by bollix47 »
Thank you for your report.
The database does not show any returns for this work unit.
PG notified and PRCG recorded for followup.
schwancr
Pande Group Member
Post by schwancr »
This should be fixed now. Thanks for the report, as other users were also affected.
Thanks,
Christian
bollix47
Post by bollix47 »
Hi Fixit (team 33015),
Your WU (P7048 R0 C944 G3) was added to the stats database on 2013-06-17 12:20:07 for 7793.56 points of credit.
Followup report closed.
Bill_Eriksen
Post by Bill_Eriksen »
I also have a slight problem with 7048. Here is information from the log showing the assignment on 2013-06-17:
18:00:09:WU01:FS00:0xa4:Project: 7048 (Run 0, Clone 544, Gen 6)
then here is the completion: 13:47:21:WU01:FS00:0xa4:Completed 24999999 out of 25000000 steps (100%)
13:47:21:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
13:47:43:WU01:FS00:0xa4:- Shutting down core
13:47:43:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
And then finally 13:55:25:WU01:FS00:Upload complete
13:55:25:WU01:FS00:Server responded WORK_ACK (400)
13:55:25:WU01:FS00:Final credit estimate, 7858.00 points
And this was finished on 2013-06-20
Here is the problem. I am showing that I only received 830 points. With only approx 2.5 days to complete the work, I think I should have received the 7858 points indicated.
Is anyone able to help me with this?
Thank you.
bollix47
Post by bollix47 »
Welcome to the folding@home support forum Bill_Eriksen.
The 830 points was for a different work unit:
Hi Bill_Eriksen (team 46123),
Your WU (P6354 R0 C7 G78) was added to the stats database on 2013-06-19 22:03:40 for 829.631 points of credit.
The is no record for Project: 7048 (Run 0, Clone 544, Gen 6) at this time so I will mark your post for followup and report the missing credit to the appropriate person.
bollix47
Post by bollix47 »
The missing credit has been updated:
Your WU (P7048 R0 C544 G6) was added to the stats database on 2013-06-20 11:51:26 for 8643.19 points of credit.
Bill_Eriksen
Thank you for looking into this for me. Thank you for welcoming me to the forum.
I found the P6354 R0 C7 G78 in the log on the Mac Mini upon which I run FAH, in addition to my PC. The log indicates that the estimated points would be 754, so I did not make the connection to the 830 that showed up in EOC's & Kakao's stats pages. Given that the PC had just completed the P7048 earlier this morning, I thought that the points award was in error. Now, we see that the system has not recognized my P7048 contribution as indicated by the log on my PC. Bummer! I guess I will have to exercise uncharacteristic patience as the appropriate person you mentioned above takes care of this little matter. In the meantime, I will not complain about the extra 76 points awarded for the Mac Mini's latest contribution. Thank you very much.
PS I see that while I was typing the above verbose reply, the matter has been completely resolved, and that with even more points than expected. Thank you, Bollix47, for your help. ((The amount of patience I had to exercise in this regard didn't actually hurt me very much.)) :D
On the Project 6354 WU, the estimate reported in the log is based on the base points and Quick Return Bonus. There is an additional 10% bonus for WU's using the A4 work core that was announced last year. That bonus is added on once the WU is returned to the server. Since this 10% bonus could be discontinued at some time, the client code did not get updated to include it in the estimated bonus it calculates.
