Not getting points
dwfinley44
Not getting points
I have two machines. One gets only 2,300 PPD; the other about 15,000, both under "dfinley" of the Ubuntu team(41504). In February I applied for and received a passkey. I decided that I did not know what I was doing and did not use the number. I probably had more than 4 million points at the time. For many weeks I have only received credit for contributions from the small computer. Also, I cannot get back into the forums with my old name and password.
I do not know how I messed up, but is there a way to resume crediting the larger machine. The report shows that it is finishing work units and getting credit, but that does not seem to be the case.
Re: Not getting points
There was a glitch, recently fixed, where people without a passkey were getting bonus points. You are probably still getting credited, it just looks like so much less (not having a passkey) that it looks like no credit.
Add the passkey, and 10 work units later, your points will go back up.
P5-133XL
Machine #2:
Machine 3:
You need use a passkey to get the quick return bonus (QRB) points. If you do not use it the only point you will get is the base points. Depending upon the speed of the machine the QRB can be many times more valuable than the base points.
Please supply the folding log of the machine that is not being credited. There is no way we can determine what is happening without it. However, if you supply project( run, clone, gen) numbers we can tell you how many points a specific WU produced for you.
The most recent WUs credited from each client/slot for "dfinley" are:
Points Date Time (PST) Project
13337.2 2013-04-08 09:17:11 7809
1588 2013-06-05 05:08:40 6099
221.76 2013-06-09 23:04:47 8701
1835 2013-06-11 21:09:09 11293
0 2013-06-12 11:08:19 8575Posting FAH's log:
dwfinley44
Here is part of the log:
Note that the credit estimate was 11,000 and that none of it was credited. Also, I never used the passkey. It is not a matter of getting fewer points after failing to use the passkey. It seems that none of the points of this machine have been credited since at least the first week of April. My other machine could not turn 13,000 points in less than five days. Sorry for the trouble. I doubt that I know enough about what I am trying to do.
*********************** Log Started 2013-06-14T17:57:27Z ***********************
17:57:27:************************* Folding@home Client *************************
17:57:27: Website: http://folding.stanford.edu/
17:57:27: Copyright: (c) 2009-2013 Stanford University
17:57:27: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:57:27: Args: --child --lifeline 1528 /etc/fahclient/config.xml --run-as
17:57:27: fahclient --pid-file=/var/run/fahclient.pid --daemon
17:57:27: Config: /etc/fahclient/config.xml
17:57:27:******************************** Build ********************************
17:57:27: Version: 7.3.6
17:57:27: Date: Feb 18 2013
17:57:27: Time: 07:24:08
17:57:27: SVN Rev: 3923
17:57:27: Branch: fah/trunk/client
17:57:27: Compiler: GNU 4.4.7
17:57:27: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
17:57:27: -fno-unsafe-math-optimizations -msse2
17:57:27: Platform: linux2 3.2.0-1-amd64
17:57:27: Bits: 64
17:57:27: Mode: Release
17:57:27:******************************* System ********************************
17:57:27: CPU: AMD FX(tm)-8350 Eight-Core Processor
17:57:27: CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
17:57:27: CPUs: 8
17:57:27: Memory: 15.64GiB
17:57:27:Free Memory: 13.85GiB
17:57:27: Threads: POSIX_THREADS
17:57:27:Has Battery: false
17:57:27: On Battery: false
17:57:27: UTC offset: -5
17:57:27: PID: 1544
17:57:27: CWD: /var/lib/fahclient
17:57:27: OS: Linux 3.5.0-34-generic x86_64
17:57:27: OS Arch: AMD64
17:57:27: GPUs: 1
17:57:27: GPU 0: ATI:4 Barts PRO [ATI Radeon HD 6800 Series]
17:57:27: CUDA: Not detected
17:57:27:***********************************************************************
17:57:27:<config>
17:57:27: <!-- Client Control -->
17:57:27: <client-threads v='4'/>
17:57:27: <cycle-rate v='4'/>
17:57:27: <cycles v='-1'/>
17:57:27: <data-directory v='.'/>
17:57:27: <disable-sleep-when-active v='true'/>
17:57:27: <exec-directory v='/usr/bin'/>
17:57:27: <exit-when-done v='false'/>
17:57:27: <fold-anon v='true'/>
17:57:27: <idle-seconds v='300'/>
17:57:27: <open-web-control v='false'/>
17:57:27:
17:57:27: <!-- Configuration -->
17:57:27: <config-rotate v='true'/>
17:57:27: <config-rotate-dir v='configs'/>
17:57:27: <config-rotate-max v='16'/>
17:57:27:
17:57:27: <!-- Debugging -->
17:57:27: <assignment-servers>
17:57:27: assign3.stanford.edu:8080 assign4.stanford.edu:80
17:57:27: </assignment-servers>
17:57:27: <capture-directory v='capture'/>
17:57:27: <capture-on-error v='false'/>
17:57:27: <capture-packets v='false'/>
17:57:27: <capture-requests v='false'/>
17:57:27: <capture-responses v='false'/>
17:57:27: <capture-sockets v='false'/>
17:57:27: <debug-sockets v='false'/>
17:57:27: <exception-locations v='true'/>
17:57:27: <gpu-assignment-servers>
17:57:27: assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
17:57:27: </gpu-assignment-servers>
17:57:27: <stack-traces v='false'/>
17:57:27:
17:57:27: <!-- Error Handling -->
17:57:27: <max-slot-errors v='5'/>
17:57:27: <max-unit-errors v='5'/>
17:57:27:
17:57:27: <!-- Folding Core -->
17:57:27: <checkpoint v='15'/>
17:57:27: <core-dir v='cores'/>
17:57:27: <core-priority v='idle'/>
17:57:27: <cpu-affinity v='false'/>
17:57:27: <cpu-usage v='100'/>
17:57:27: <gpu-usage v='100'/>
17:57:27: <no-assembly v='false'/>
17:57:27:
17:57:27: <!-- Folding Slot Configuration -->
17:57:27: <cause v='ANY'/>
17:57:27: <client-subtype v='LINUX'/>
17:57:27: <client-type v='normal'/>
17:57:27: <cpu-species v='X86_AMD'/>
17:57:27: <cpu-type v='AMD64'/>
17:57:27: <cpus v='-1'/>
17:57:27: <cuda-index v='0'/>
17:57:27: <gpu v='false'/>
17:57:27: <max-packet-size v='normal'/>
17:57:27: <opencl-index v='0'/>
17:57:27: <os-species v='UNKNOWN'/>
17:57:27: <os-type v='LINUX'/>
17:57:27: <power v='light'/>
17:57:27: <project-key v='0'/>
17:57:27: <smp v='true'/>
17:57:27:
17:57:27: <!-- HTTP Server -->
17:57:27: <allow v='127.0.0.1'/>
17:57:27: <connection-timeout v='60'/>
17:57:27: <deny v='0/0'/>
17:57:27: <http-addresses v='0:7396'/>
17:57:27: <https-addresses v=''/>
17:57:27: <max-connect-time v='900'/>
17:57:27: <max-connections v='800'/>
17:57:27: <max-request-length v='52428800'/>
17:57:27: <min-connect-time v='300'/>
17:57:27: <threads v='8'/>
17:57:27:
17:57:27: <!-- Logging -->
17:57:27: <log v='log.txt'/>
17:57:27: <log-color v='true'/>
17:57:27: <log-crlf v='false'/>
17:57:27: <log-date v='false'/>
17:57:27: <log-date-periodically v='21600'/>
17:57:27: <log-debug v='true'/>
17:57:27: <log-domain v='false'/>
17:57:27: <log-header v='true'/>
17:57:27: <log-level v='true'/>
17:57:27: <log-no-info-header v='true'/>
17:57:27: <log-redirect v='false'/>
17:57:27: <log-rotate v='true'/>
17:57:27: <log-rotate-dir v='logs'/>
17:57:27: <log-rotate-max v='16'/>
17:57:27: <log-short-level v='false'/>
17:57:27: <log-simple-domains v='true'/>
17:57:27: <log-thread-id v='false'/>
17:57:27: <log-thread-prefix v='true'/>
17:57:27: <log-time v='true'/>
17:57:27: <log-to-screen v='true'/>
17:57:27: <log-truncate v='false'/>
17:57:27: <verbosity v='4'/>
17:57:27:
17:57:27: <!-- Network -->
17:57:27: <proxy v=':8080'/>
17:57:27: <proxy-enable v='false'/>
17:57:27: <proxy-pass v=''/>
17:57:27: <proxy-user v=''/>
17:57:27:
17:57:27: <!-- Process Control -->
17:57:27: <child v='true'/>
17:57:27: <daemon v='true'/>
17:57:27: <pid v='false'/>
17:57:27: <pid-file v='/var/run/fahclient.pid'/>
17:57:27: <respawn v='false'/>
17:57:27: <service v='false'/>
17:57:27:
17:57:27: <!-- Remote Command Server -->
17:57:27: <command-address v='0.0.0.0'/>
17:57:27: <command-allow-no-pass v='127.0.0.1'/>
17:57:27: <command-deny-no-pass v='0/0'/>
17:57:27: <command-port v='36330'/>
17:57:27:
17:57:27: <!-- Slot Control -->
17:57:27: <idle v='false'/>
17:57:27: <max-shutdown-wait v='60'/>
17:57:27: <pause-on-battery v='false'/>
17:57:27: <pause-on-start v='false'/>
17:57:27:
17:57:27: <!-- User Information -->
17:57:27: <machine-id v='0'/>
17:57:27: <passkey v=''/>
17:57:27: <team v='45104'/>
17:57:27: <user v='dfinley'/>
17:57:27:
17:57:27: <!-- Web Server -->
17:57:27: <session-timeout v='3600'/>
17:57:27: <web-allow v='127.0.0.1'/>
17:57:27: <web-deny v='0/0'/>
17:57:27:
17:57:27: <!-- Work Unit Control -->
17:57:27: <dump-after-deadline v='true'/>
17:57:27: <max-queue v='16'/>
17:57:27: <max-units v='0'/>
17:57:27: <next-unit-percentage v='99'/>
17:57:27:
17:57:27: <!-- Folding Slots -->
17:57:27: <slot id='0' type='CPU'/>
17:57:27:</config>
17:57:27:Switching to user fahclient
17:57:27:Trying to access database...
17:57:27:Successfully acquired database lock
17:57:27:Enabled folding slot 00: READY cpu:4
17:57:27:WU00:FS00:Starting
17:57:27:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a3.fah/FahCore_a3 -dir 00 -suffix 01 -version 703 -lifeline 1544 -checkpoint 15 -np 4
17:57:27:WU00:FS00:Started FahCore on PID 1588
17:57:27:WU00:FS00:Core PID:1592
17:57:27:WU00:FS00:FahCore 0xa3 started
17:57:28:WU00:FS00:0xa3:
17:57:28:WU00:FS00:0xa3:*------------------------------*
17:57:28:WU00:FS00:0xa3:Folding@Home Gromacs SMP Core
17:57:28:WU00:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
17:57:28:WU00:FS00:0xa3:Preparing to commence simulation
17:57:28:WU00:FS00:0xa3:- Ensuring status. Please wait.
17:57:37:WU00:FS00:0xa3:- Looking at optimizations...
17:57:37:WU00:FS00:0xa3:- Working with standard loops on this execution.
17:57:37:WU00:FS00:0xa3:- Previous termination of core was improper.
17:57:37:WU00:FS00:0xa3:- Going to use standard loops.
17:57:37:WU00:FS00:0xa3:- Files status OK
17:57:37:WU00:FS00:0xa3:- Expanded 3850546 -> 4387808 (decompressed 113.9 percent)
17:57:37:WU00:FS00:0xa3:Called DecompressByteArray: compressed_data_size=3850546 data_size=4387808, decompressed_data_size=4387808 diff=0
17:57:37:WU00:FS00:0xa3:- Digital signature verified
17:57:37:WU00:FS00:0xa3:Project: 8580 (Run 0, Clone 8, Gen 68)
17:57:37:WU00:FS00:0xa3:Entering M.D.
17:57:43:WU00:FS00:0xa3:Using Gromacs checkpoints
17:57:43:WU00:FS00:0xa3:Mapping NT from 4 to 4
17:57:44:WU00:FS00:0xa3:Resuming from checkpoint
17:57:44:WU00:FS00:0xa3:Verified 00/wudata_01.log
17:57:44:WU00:FS00:0xa3:Verified 00/wudata_01.trr
17:57:44:WU00:FS00:0xa3:Verified 00/wudata_01.edr
17:57:44:WU00:FS00:0xa3:Completed 401195 out of 500000 steps (80%)
18:06:22:WU00:FS00:0xa3:Completed 405000 out of 500000 steps (81%)
18:17:28:WU00:FS00:0xa3:Completed 410000 out of 500000 steps (82%)
18:28:28:WU00:FS00:0xa3:Completed 415000 out of 500000 steps (83%)
18:39:26:WU00:FS00:0xa3:Completed 420000 out of 500000 steps (84%)
18:50:24:WU00:FS00:0xa3:Completed 425000 out of 500000 steps (85%)
19:01:29:WU00:FS00:0xa3:Completed 430000 out of 500000 steps (86%)
19:13:06:WU00:FS00:0xa3:Completed 435000 out of 500000 steps (87%)
19:24:17:WU00:FS00:0xa3:Completed 440000 out of 500000 steps (88%)
19:35:51:WU00:FS00:0xa3:Completed 445000 out of 500000 steps (89%)
19:48:12:WU00:FS00:0xa3:Completed 450000 out of 500000 steps (90%)
20:00:42:WU00:FS00:0xa3:Completed 455000 out of 500000 steps (91%)
20:13:08:WU00:FS00:0xa3:Completed 460000 out of 500000 steps (92%)
20:24:19:WU00:FS00:0xa3:Completed 465000 out of 500000 steps (93%)
20:35:32:WU00:FS00:0xa3:Completed 470000 out of 500000 steps (94%)
20:46:49:WU00:FS00:0xa3:Completed 475000 out of 500000 steps (95%)
20:58:06:WU00:FS00:0xa3:Completed 480000 out of 500000 steps (96%)
21:09:24:WU00:FS00:0xa3:Completed 485000 out of 500000 steps (97%)
21:20:38:WU00:FS00:0xa3:Completed 490000 out of 500000 steps (98%)
21:20:39:WU01:FS00:Connecting to assign3.stanford.edu:8080
21:20:40:WU01:FS00:News: Welcome to Folding@Home
21:20:40:WU01:FS00:Assigned to work server 171.64.65.101
21:20:40:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.64.65.101
21:20:40:WU01:FS00:Connecting to 171.64.65.101:8080
21:20:40:WU01:FS00:Downloading 535.22KiB
21:20:41:WU01:FS00:Download complete
21:20:41:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7647 run:85 clone:1 gen:83 core:0xa4 unit:0x00000063664f2dcd4fa7fe5f63101519
21:31:50:WU00:FS00:0xa3:Completed 495000 out of 500000 steps (99%)
21:44:25:WU00:FS00:0xa3:Completed 500000 out of 500000 steps (100%)
21:44:25:WU00:FS00:0xa3:DynamicWrapper: Finished Work Unit: sleep=10000
21:44:36:WU00:FS00:0xa3:
21:44:36:WU00:FS00:0xa3:Finished Work Unit:
21:44:36:WU00:FS00:0xa3:- Reading up to 8058192 from "00/wudata_01.trr": Read 8058192
21:44:36:WU00:FS00:0xa3:trr file hash check passed.
21:44:36:WU00:FS00:0xa3:edr file hash check passed.
21:44:36:WU00:FS00:0xa3:logfile size: 61989
21:44:36:WU00:FS00:0xa3:Leaving Run
21:44:38:WU00:FS00:0xa3:- Writing 8157013 bytes of core data to disk...
21:44:39:WU00:FS00:0xa3:Done: 8156501 -> 7533150 (compressed to 92.3 percent)
21:44:39:WU00:FS00:0xa3: ... Done.
21:53:28:WU00:FS00:0xa3:- Shutting down core
21:53:28:WU00:FS00:0xa3:Folding@home Core Shutdown: FINISHED_UNIT
21:54:14:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:54:14:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8580 run:0 clone:8 gen:68 core:0xa3 unit:0x0000038d0a3b1e59512260a2d1a0d627
21:54:14:WU00:FS00:Uploading 7.18MiB to 128.143.231.202
21:54:14:WU00:FS00:Connecting to 128.143.231.202:8080
21:54:14:WU01:FS00:Starting
21:54:14:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/www.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 703 -lifeline 1544 -checkpoint 15 -np 4
21:54:14:WU01:FS00:Started FahCore on PID 23159
21:54:14:WU01:FS00:Core PID:23163
21:54:14:WU01:FS00:FahCore 0xa4 started
21:54:15:WU01:FS00:0xa4:
21:54:15:WU01:FS00:0xa4:*------------------------------*
21:54:15:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
21:54:15:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
21:54:15:WU01:FS00:0xa4:Preparing to commence simulation
21:54:15:WU01:FS00:0xa4:- Looking at optimizations...
21:54:15:WU01:FS00:0xa4:- Created dyn
21:54:15:WU01:FS00:0xa4:- Files status OK
21:54:15:WU01:FS00:0xa4:- Expanded 547551 -> 847092 (decompressed 154.7 percent)
21:54:15:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=547551 data_size=847092, decompressed_data_size=847092 diff=0
21:54:15:WU01:FS00:0xa4:- Digital signature verified
21:54:15:WU01:FS00:0xa4:Project: 7647 (Run 85, Clone 1, Gen 83)
21:54:15:WU01:FS00:0xa4:Assembly optimizations on if available.
21:54:15:WU01:FS00:0xa4:Entering M.D.
21:54:20:WU00:FS00:Upload 15.66%
21:54:21:WU01:FS00:0xa4:Completed 0 out of 2500000 steps (0%)
21:54:26:WU00:FS00:Upload 33.06%
21:54:32:WU00:FS00:Upload 50.45%
21:54:38:WU00:FS00:Upload 66.11%
21:54:44:WU00:FS00:Upload 82.64%
21:54:50:WU00:FS00:Upload 96.56%
21:54:53:WU00:FS00:Upload complete
21:54:53:WU00:FS00:Server responded WORK_ACK (400)
21:54:53:WU00:FS00:Final credit estimate, 11723.00 points
21:54:53:WU00:FS00:Cleaning up
22:12:59:WU01:FS00:0xa4:Completed 25000 out of 2500000 steps (1%)
22:31:18:WU01:FS00:0xa4:Completed 50000 out of 2500000 steps (2%)
22:49:34:WU01:FS00:0xa4:Completed 75000 out of 2500000 steps (3%)
23:07:46:WU01:FS00:0xa4:Completed 100000 out of 2500000 steps (4%)
23:25:58:WU01:FS00:0xa4:Completed 125000 out of 2500000 steps (5%)
Estimates from V7 always assume you are using a qualified passkey so do not expect 110000-13000 points.
Please reset the verbosity to the default value of 3.
The CPU project (core 0xa3) that was uploaded in that log WAS successfully credited.
Hi dfinley (team 45104),
Your WU (P8580 R0 C8 G68) was added to the stats database on 2013-06-14 15:04:54 PDT for 1673 points of credit.
You received the base points for the WU:
P.S. Changing the verbosity level of logging from the default serves little purpose and makes troubleshooting problems with the F@H client more difficult. The default level of 3 reports all parameters that have been changed from their default.
As mentioned, you need a passkey to get the base points and Quick Return Bonus points. The estimated points reported in the log are just that - an estimate , and assume you have a passkey and are eligible for the bonus. 7im mentioned the server glitch that was recently fixed which was giving QRB points to users without a passkey. So add a passkey as mentioned in the Points FAQ and Passkey FAQ and you will get the QRB once the passkey is qualified.Hi dfinley (team 45104),
Your WU (P8580 R0 C8 G68) was added to the stats database on 2013-06-14 15:04:54 for 1673 points of credit.
tlg
- Hardware configuration: Mobile:
i7 3610QM @ 2.3GHz
nVIDIA GTX 630m (not folding)
8GB Ram
Win 7 x64
Desktop:
i7 860 @ 2.8GHz
Asus nVIDIA GTX 660ti
8GB RAM
Win 7 x64 - Location: Calgary, AB
Is there any way we could sticky one of these QRB glitch threads? I've noticed a lot of duplicates lately.
It's not a retreat, it's a Tactical Withdrawal. Get it right!
Hello; Not sure if this posted in correct place.I'm starting again after a no internet hiatus. Started folding again approx.09/17/2013? But I'm not receiving any bonus at all.P.C. dedicated and running 24/7 with completed WU's returned quickly.Have folded 24/7. 20 WU's completed and I received 15500 points with PhenomII 955 b.e.Logs show base and bonus points but I get base that's it.Not 100% sure I'm getting base even.I do have a key with 100+ WU's. Don't know if I posted this correctly? Posted maybe 4X in 6-8 years!?? Any help appreciated.If points are how we keep track of contribution (not just competion) Then I'm financing a power plant for very little? Just gearing up again.Installed 650Ti today.re-boots for driver un-install/sweep/install made my logs kinda mess.If you need more info I will be more than happy post it.Thanks in advance for any/all assistance. P.S. Is there anyway to sync the clients and P.C's time? Mines set at -4 utc (should be -5) but it's still usuall 3-5 hours off. .
Mod edit: Added Code tags around log
*********************** Log Started 2013-10-02T16:42:47Z ***********************
16:42:47:************************* Folding@home Client *************************
16:42:47: Website: http://folding.stanford.edu/
16:42:47: Copyright: (c) 2009-2013 Stanford University
16:42:47: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:42:47: Args:
16:42:47: Config: C:/Documents and Settings/All Users.WINDOWS/Application
16:42:47: Data/FAHClient/config.xml
16:42:47:******************************** Build ********************************
16:42:47: Version: 7.3.6
16:42:47: Date: Feb 18 2013
16:42:47: Time: 15:25:17
16:42:47: SVN Rev: 3923
16:42:47: Branch: fah/trunk/client
16:42:47: Compiler: Intel(R) C++ MSVC 1500 mode 1200
16:42:47: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
16:42:47: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
16:42:47: Platform: win32 XP
16:42:47: Bits: 32
16:42:47: Mode: Release
16:42:47:******************************* System ********************************
16:42:47: CPU: AMD Phenom(tm) II X4 955 Processor
16:42:47: CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
16:42:47: CPUs: 4
16:42:47: Memory: 3.25GiB
16:42:47: Free Memory: 2.72GiB
16:42:47: Threads: WINDOWS_THREADS
16:42:47: Has Battery: false
16:42:47: On Battery: false
16:42:47: UTC offset: -4
16:42:47: PID: 2504
16:42:47: CWD: C:/Documents and Settings/All Users.WINDOWS/Application
16:42:47: OS: Microsoft Windows XP Service Pack 3
16:42:47: OS Arch: X86
16:42:47: GPUs: 1
16:42:47: GPU 0: UNSUPPORTED: G73 [GeForce 7600 GS]
16:42:47: CUDA: Not detected
16:42:47:Win32 Service: false
16:42:47:***********************************************************************
16:42:47:<config>
16:42:47: <!-- Folding Core -->
16:42:47: <core-priority v='low'/>
16:42:47:
16:42:47: <!-- Folding Slot Configuration -->
16:42:47: <client-type v='advanced'/>
16:42:47: <power v='full'/>
16:42:47:
16:42:47: <!-- Network -->
16:42:47: <proxy v=':8080'/>
16:42:47:
16:42:47: <!-- Slot Control -->
16:42:47: <pause-on-battery v='false'/>
16:42:47:
16:42:47: <!-- User Information -->
16:42:47: <passkey v='********************************'/>
16:42:47: <user v='GIMPY007'/>
16:42:47:
16:42:47: <!-- Work Unit Control -->
16:42:47: <next-unit-percentage v='100'/>
16:42:47:
16:42:47: <!-- Folding Slots -->
16:42:47: <slot id='0' type='CPU'/>
16:42:47:</config>
16:42:47:Trying to access database...
16:42:50:Successfully acquired database lock
16:42:50:Enabled folding slot 00: READY cpu:4
16:42:52:WU00:FS00:Starting
16:42:52:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users.WINDOWS/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 703 -lifeline 2504 -checkpoint 15 -np 4
16:42:52:WU00:FS00:Started FahCore on PID 892
16:42:56:WU00:FS00:Core PID:2260
16:42:56:WU00:FS00:FahCore 0xa4 started
16:42:57:WU00:FS00:0xa4:
16:42:57:WU00:FS00:0xa4:*------------------------------*
16:42:57:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
16:42:57:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
16:42:57:WU00:FS00:0xa4:Preparing to commence simulation
16:42:57:WU00:FS00:0xa4:- Ensuring status. Please wait.
16:43:06:WU00:FS00:0xa4:- Looking at optimizations...
16:43:06:WU00:FS00:0xa4:- Working with standard loops on this execution.
16:43:06:WU00:FS00:0xa4:- Previous termination of core was improper.
16:43:06:WU00:FS00:0xa4:- Going to use standard loops.
16:43:06:WU00:FS00:0xa4:- Files status OK
16:43:07:WU00:FS00:0xa4:- Expanded 2333789 -> 3295344 (decompressed 141.2 percent)
16:43:07:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=2333789 data_size=3295344, decompressed_data_size=3295344 diff=0
16:43:07:WU00:FS00:0xa4:- Digital signature verified
16:43:07:WU00:FS00:0xa4:Project: 7520 (Run 100, Clone 0, Gen 163)
16:43:09:WU00:FS00:0xa4:Entering M.D.
16:43:15:WU00:FS00:0xa4:Using Gromacs checkpoints
16:43:17:WU00:FS00:0xa4:Mapping NT from 4 to 4
16:43:21:WU00:FS00:0xa4:Resuming from checkpoint
16:43:21:WU00:FS00:0xa4:Verified 00/wudata_01.log
16:43:23:WU00:FS00:0xa4:Verified 00/wudata_01.trr
16:43:23:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
16:43:23:WU00:FS00:0xa4:Verified 00/wudata_01.edr
16:43:23:WU00:FS00:0xa4:Completed 246330 out of 500000 steps (49%)
16:51:11:WU00:FS00:0xa4:Completed 250000 out of 500000 steps (50%)
17:01:40:WU00:FS00:0xa4:Completed 255000 out of 500000 steps (51%)
17:05:11:5:127.0.0.1:New Web connection
17:05:36:WARNING:Exception: 9:127.0.0.1: Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:05:36:WARNING:Exception: 10:127.0.0.1: Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:05:36:WARNING:Exception: 11:127.0.0.1: Receive error: 10054: An existing connection was forcibly closed by the remote host.
17:05:38:WARNING:Exception: 13:127.0.0.1: Send error: 10054: An existing connection was forcibly closed by the remote host.
17:05:43:WARNING:Exception: 12:127.0.0.1: Send error: 10054: An existing connection was forcibly closed by the remote host.
17:12:13:WU00:FS00:0xa4:Completed 260000 out of 500000 steps (52%)
17:22:49:WU00:FS00:0xa4:Completed 265000 out of 500000 steps (53%)
17:33:24:WU00:FS00:0xa4:Completed 270000 out of 500000 steps (54%)
17:43:57:WU00:FS00:0xa4:Completed 275000 out of 500000 steps (55%)
17:54:33:WU00:FS00:0xa4:Completed 280000 out of 500000 steps (56%)
18:05:10:WU00:FS00:0xa4:Completed 285000 out of 500000 steps (57%)
18:15:38:WU00:FS00:0xa4:Completed 290000 out of 500000 steps (58%)
18:26:34:WU00:FS00:0xa4:Completed 295000 out of 500000 steps (59%)
18:37:03:WU00:FS00:0xa4:Completed 300000 out of 500000 steps (60%)
18:47:46:WU00:FS00:0xa4:Completed 305000 out of 500000 steps (61%)
18:58:17:WU00:FS00:0xa4:Completed 310000 out of 500000 steps (62%)
19:08:48:WU00:FS00:0xa4:Completed 315000 out of 500000 steps (63%)
19:19:36:WU00:FS00:0xa4:Completed 320000 out of 500000 steps (64%)
19:30:22:WU00:FS00:0xa4:Completed 325000 out of 500000 steps (65%)
19:41:00:WU00:FS00:0xa4:Completed 330000 out of 500000 steps (66%)
19:51:37:WU00:FS00:0xa4:Completed 335000 out of 500000 steps (67%)
20:05:37:WU00:FS00:0xa4:Completed 340000 out of 500000 steps (68%)
20:20:36:WU00:FS00:0xa4:Completed 345000 out of 500000 steps (69%)
20:31:57:WU00:FS00:0xa4:Completed 350000 out of 500000 steps (70%)
20:43:06:WU00:FS00:0xa4:Completed 355000 out of 500000 steps (71%)
20:53:36:WU00:FS00:0xa4:Completed 360000 out of 500000 steps (72%)
21:05:34:WU00:FS00:0xa4:Completed 365000 out of 500000 steps (73%)
21:16:55:WU00:FS00:0xa4:Completed 370000 out of 500000 steps (74%)
21:27:42:WU00:FS00:0xa4:Completed 375000 out of 500000 steps (75%)
21:42:38:WU00:FS00:0xa4:Completed 380000 out of 500000 steps (76%)
21:58:32:WU00:FS00:0xa4:Completed 385000 out of 500000 steps (77%)
22:14:25:WU00:FS00:0xa4:Completed 390000 out of 500000 steps (78%)
22:25:30:WU00:FS00:0xa4:Completed 395000 out of 500000 steps (79%)
22:36:29:WU00:FS00:0xa4:Completed 400000 out of 500000 steps (80%)
******************************* Date: 2013-10-02 *******************************
22:46:25:WU00:FS00:0xa4:Completed 405000 out of 500000 steps (81%)
22:56:24:WU00:FS00:0xa4:Completed 410000 out of 500000 steps (82%)
23:06:31:WU00:FS00:0xa4:Completed 415000 out of 500000 steps (83%)
23:16:32:WU00:FS00:0xa4:Completed 420000 out of 500000 steps (84%)
23:26:30:WU00:FS00:0xa4:Completed 425000 out of 500000 steps (85%)
23:36:48:WU00:FS00:0xa4:Completed 430000 out of 500000 steps (86%)
23:46:47:WU00:FS00:0xa4:Completed 435000 out of 500000 steps (87%)
23:56:48:WU00:FS00:0xa4:Completed 440000 out of 500000 steps (88%)
00:07:20:WU00:FS00:0xa4:Completed 445000 out of 500000 steps (89%)
00:17:16:WU00:FS00:0xa4:Completed 450000 out of 500000 steps (90%)
00:27:13:WU00:FS00:0xa4:Completed 455000 out of 500000 steps (91%)
00:37:08:WU00:FS00:0xa4:Completed 460000 out of 500000 steps (92%)
00:47:04:WU00:FS00:0xa4:Completed 465000 out of 500000 steps (93%)
00:57:19:WU00:FS00:0xa4:Completed 470000 out of 500000 steps (94%)
01:07:17:WU00:FS00:0xa4:Completed 475000 out of 500000 steps (95%)
01:07:19:Saving configuration to config.xml
01:07:19:<config>
01:07:19: <!-- Folding Core -->
01:07:19: <core-priority v='low'/>
01:07:19:
01:07:19: <!-- Folding Slot Configuration -->
01:07:19: <client-type v='advanced'/>
01:07:19: <extra-core-args v='-oneunit'/>
01:07:19: <power v='full'/>
01:07:19:
01:07:19: <!-- Network -->
01:07:19: <proxy v=':8080'/>
01:07:19:
01:07:19: <!-- Slot Control -->
01:07:19: <pause-on-battery v='false'/>
01:07:19:
01:07:19: <!-- User Information -->
01:07:19: <passkey v='********************************'/>
01:07:19: <user v='GIMPY007'/>
01:07:19:
01:07:19: <!-- Work Unit Control -->
01:07:19: <next-unit-percentage v='100'/>
01:07:19:
01:07:19: <!-- Folding Slots -->
01:07:19: <slot id='0' type='CPU'/>
01:07:19:</config>
01:17:16:WU00:FS00:0xa4:Completed 480000 out of 500000 steps (96%)
01:27:14:WU00:FS00:0xa4:Completed 485000 out of 500000 steps (97%)
01:42:00:WU00:FS00:0xa4:Completed 490000 out of 500000 steps (98%)
01:56:59:WU00:FS00:0xa4:Completed 495000 out of 500000 steps (99%)
01:56:59:WU01:FS00:Connecting to assign3.stanford.edu:8080
01:57:00:WU01:FS00:News: Welcome to Folding@Home
01:57:00:WU01:FS00:Assigned to work server 128.143.199.97
01:57:00:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.143.199.97
01:57:00:WU01:FS00:Connecting to 128.143.199.97:8080
01:57:01:WU01:FS00:Downloading 2.07MiB
01:57:07:WU01:FS00:Download 45.32%
01:57:13:WU01:FS00:Download 78.56%
01:57:16:WU01:FS00:Download complete
01:57:16:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:7515 run:0 clone:155 gen:257 core:0xa3 unit:0x00000124fbcb017d4ff759d572087c44
02:11:57:WU00:FS00:0xa4:Completed 500000 out of 500000 steps (100%)
02:11:59:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:12:09:WU00:FS00:0xa4:
02:12:09:WU00:FS00:0xa4:Finished Work Unit:
02:12:09:WU00:FS00:0xa4:- Reading up to 6826248 from "00/wudata_01.trr": Read 6826248
02:12:09:WU00:FS00:0xa4:trr file hash check passed.
02:12:09:WU00:FS00:0xa4:- Reading up to 7325028 from "00/wudata_01.xtc": Read 7325028
02:12:09:WU00:FS00:0xa4:xtc file hash check passed.
02:12:09:WU00:FS00:0xa4:edr file hash check passed.
02:12:09:WU00:FS00:0xa4:logfile size: 344774
02:12:09:WU00:FS00:0xa4:Leaving Run
02:12:10:WU00:FS00:0xa4:- Writing 14529078 bytes of core data to disk...
02:12:14:WU00:FS00:0xa4:Done: 14528566 -> 13856367 (compressed to 95.3 percent)
02:12:16:WU00:FS00:0xa4: ... Done.
02:13:16:WU00:FS00:0xa4:- Shutting down core
02:13:16:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:13:21:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:13:21:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:7520 run:100 clone:0 gen:163 core:0xa4 unit:0x000000b7fbcb017d51229ad3b9faace3
02:13:21:WU00:FS00:Uploading 13.21MiB to 128.143.199.97
02:13:21:WU01:FS00:Starting
02:13:21:WU00:FS00:Connecting to 128.143.199.97:8080
02:13:21:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" "C:/Documents and Settings/All Users.WINDOWS/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a3.fah/FahCore_a3.exe" -dir 01 -suffix 01 -version 703 -lifeline 2504 -checkpoint 15 -np 4 -oneunit
02:13:21:WU01:FS00:Started FahCore on PID 908
02:13:22:WU01:FS00:Core PID:380
02:13:22:WU01:FS00:FahCore 0xa3 started
02:13:22:WU01:FS00:0xa3:
02:13:22:WU01:FS00:0xa3:*------------------------------*
02:13:22:WU01:FS00:0xa3:Folding@Home Gromacs SMP Core
02:13:22:WU01:FS00:0xa3:Version 2.27 (Dec. 15, 2010)
02:13:22:WU01:FS00:0xa3:Preparing to commence simulation
02:13:22:WU01:FS00:0xa3:- Looking at optimizations...
02:13:22:WU01:FS00:0xa3:- Created dyn
02:13:22:WU01:FS00:0xa3:- Files status OK
02:13:22:WU01:FS00:0xa3:- Expanded 2168514 -> 3131648 (decompressed 144.4 percent)
02:13:22:WU01:FS00:0xa3:Called DecompressByteArray: compressed_data_size=2168514 data_size=3131648, decompressed_data_size=3131648 diff=0
02:13:22:WU01:FS00:0xa3:- Digital signature verified
02:13:22:WU01:FS00:0xa3:Project: 7515 (Run 0, Clone 155, Gen 257)
02:13:22:WU01:FS00:0xa3:Assembly optimizations on if available.
02:13:22:WU01:FS00:0xa3:Entering M.D.
02:13:27:WU00:FS00:Upload 2.84%
02:13:29:WU01:FS00:0xa3:Mapping NT from 4 to 4
02:13:29:WU01:FS00:0xa3:Completed 0 out of 500000 steps (0%)
02:13:33:WU00:FS00:Upload 6.15%
02:13:39:WU00:FS00:Upload 8.99%
02:13:45:WU00:FS00:Upload 12.30%
02:13:51:WU00:FS00:Upload 15.13%
02:13:57:WU00:FS00:Upload 17.97%
02:14:03:WU00:FS00:Upload 21.28%
02:14:09:WU00:FS00:Upload 24.12%
02:14:15:WU00:FS00:Upload 27.43%
02:14:21:WU00:FS00:Upload 30.74%
02:14:27:WU00:FS00:Upload 33.58%
02:14:33:WU00:FS00:Upload 36.89%
02:14:39:WU00:FS00:Upload 39.73%
02:14:45:WU00:FS00:Upload 43.04%
02:14:51:WU00:FS00:Upload 45.88%
02:14:57:WU00:FS00:Upload 49.19%
02:15:03:WU00:FS00:Upload 52.02%
02:15:09:WU00:FS00:Upload 55.34%
02:15:15:WU00:FS00:Upload 58.17%
02:15:21:WU00:FS00:Upload 61.48%
02:15:27:WU00:FS00:Upload 63.85%
02:15:33:WU00:FS00:Upload 66.69%
02:15:39:WU00:FS00:Upload 69.05%
02:15:45:WU00:FS00:Upload 71.89%
02:15:51:WU00:FS00:Upload 74.25%
02:15:57:WU00:FS00:Upload 77.09%
02:16:03:WU00:FS00:Upload 79.46%
02:16:10:WU00:FS00:Upload 82.29%
02:16:16:WU00:FS00:Upload 84.66%
02:16:23:WU00:FS00:Upload 87.02%
02:16:29:WU00:FS00:Upload 89.86%
02:16:36:WU00:FS00:Upload 92.23%
02:16:43:WU00:FS00:Upload 95.06%
02:16:49:WU00:FS00:Upload 97.90%
02:16:55:WU00:FS00:Upload 100.00%
02:16:58:WU00:FS00:Upload complete
02:16:58:WU00:FS00:Server responded WORK_ACK (400)
02:16:58:WU00:FS00:Final credit estimate, 3983.00 points
02:16:58:WU00:FS00:Cleaning up
02:27:25:WU01:FS00:0xa3:Completed 5000 out of 500000 steps (1%)
02:41:18:WU01:FS00:0xa3:Completed 10000 out of 500000 steps (2%)
02:46:15:Saving configuration to config.xml
02:46:15:<config>
02:46:15: <!-- Folding Core -->
02:46:15: <core-priority v='low'/>
02:46:15:
02:46:15: <!-- Folding Slot Configuration -->
02:46:15: <client-type v='advanced'/>
02:46:15: <power v='full'/>
02:46:15:
02:46:15: <!-- Network -->
02:46:15: <proxy v=':8080'/>
02:46:15:
02:46:15: <!-- Slot Control -->
02:46:15: <pause-on-battery v='false'/>
02:46:15:
02:46:15: <!-- User Information -->
02:46:15: <passkey v='********************************'/>
02:46:15: <user v='GIMPY007'/>
02:46:15:
02:46:15: <!-- Work Unit Control -->
02:46:15: <next-unit-percentage v='100'/>
02:46:15:
02:46:15: <!-- Folding Slots -->
02:46:15: <slot id='0' type='CPU'/>
02:46:15:</config>
02:52:55:WU01:FS00:0xa3:Completed 15000 out of 500000 steps (3%)
03:02:12:WU01:FS00:0xa3:Completed 20000 out of 500000 steps (4%)
03:11:41:WU01:FS00:0xa3:Completed 25000 out of 500000 steps (5%)
03:21:02:WU01:FS00:0xa3:Completed 30000 out of 500000 steps (6%)
03:30:40:WU01:FS00:0xa3:Completed 35000 out of 500000 steps (7%)
03:44:46:WU01:FS00:0xa3:Completed 40000 out of 500000 steps (8%)
03:57:30:WU01:FS00:0xa3:Completed 45000 out of 500000 steps (9%)
04:07:11:WU01:FS00:0xa3:Completed 50000 out of 500000 steps (10%)
04:16:44:WU01:FS00:0xa3:Completed 55000 out of 500000 steps (11%)
04:26:20:WU01:FS00:0xa3:Completed 60000 out of 500000 steps (12%)
04:35:58:WU01:FS00:0xa3:Completed 65000 out of 500000 steps (13%)
04:45:28:WU01:FS00:0xa3:Completed 70000 out of 500000 steps (14%)
******************************* Date: 2013-10-03 *******************************
04:55:00:WU01:FS00:0xa3:Completed 75000 out of 500000 steps (15%)
05:04:40:WU01:FS00:0xa3:Completed 80000 out of 500000 steps (16%)
05:14:04:WU01:FS00:0xa3:Completed 85000 out of 500000 steps (17%)
05:24:27:WU01:FS00:0xa3:Completed 90000 out of 500000 steps (18%)
05:34:43:WU01:FS00:0xa3:Completed 95000 out of 500000 steps (19%)
05:43:57:WU01:FS00:0xa3:Completed 100000 out of 500000 steps (20%)
05:54:37:WU01:FS00:0xa3:Completed 105000 out of 500000 steps (21%)
06:08:42:WU01:FS00:0xa3:Completed 110000 out of 500000 steps (22%)
06:20:50:WU01:FS00:0xa3:Completed 115000 out of 500000 steps (23%)
06:31:31:WU01:FS00:0xa3:Completed 120000 out of 500000 steps (24%)
06:42:46:WU01:FS00:0xa3:Completed 125000 out of 500000 steps (25%)
06:52:37:WU01:FS00:0xa3:Completed 130000 out of 500000 steps (26%)
07:03:02:WU01:FS00:0xa3:Completed 135000 out of 500000 steps (27%)
07:13:07:WU01:FS00:0xa3:Completed 140000 out of 500000 steps (28%)
07:22:51:WU01:FS00:0xa3:Completed 145000 out of 500000 steps (29%)
07:33:01:WU01:FS00:0xa3:Completed 150000 out of 500000 steps (30%)
07:42:52:WU01:FS00:0xa3:Completed 155000 out of 500000 steps (31%)
07:52:34:WU01:FS00:0xa3:Completed 160000 out of 500000 steps (32%)
08:03:35:WU01:FS00:0xa3:Completed 165000 out of 500000 steps (33%)
08:17:36:WU01:FS00:0xa3:Completed 170000 out of 500000 steps (34%)
08:28:46:WU01:FS00:0xa3:Completed 175000 out of 500000 steps (35%)
08:39:46:WU01:FS00:0xa3:Completed 180000 out of 500000 steps (36%)
08:49:32:WU01:FS00:0xa3:Completed 185000 out of 500000 steps (37%)
08:59:29:WU01:FS00:0xa3:Completed 190000 out of 500000 steps (38%)
09:10:09:WU01:FS00:0xa3:Completed 195000 out of 500000 steps (39%)
09:21:08:WU01:FS00:0xa3:Completed 200000 out of 500000 steps (40%)-
A check of your username showed that multiple passkeys have been used with that username. None of them currently are eligible for getting the QRB. You need to successfully complete 10 WU's with a passkey within the preferred deadline before getting bonus points and maintain an 80% successful return rate afterwards. If you send the passkey you are using in a PM to me or one of the other forum admins and moderators, we can look up specifics related to that passkey.
Regarding the time difference, FAHClient uses GMT/UTC regardless of the local time. This can't be changed.
Also, is there a reason to use the -oneunit flag for the FahCore:
One unit flag is for v6 client only and is ignored by V7 and should be removed.
