http://i.imgur.com/2ioNF2h.png (direct link in case the image doesn't load properly)
23:44:46:WU02:FS00:0x11:Completed 41%
23:45:12:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:5769 run:7 clone:91 gen:6082 core:0x11 unit:0x13ae792251b146e417c2005b00071689
23:45:12:WU01:FS00:Uploading 632B to 171.67.108.11
23:45:12:WU01:FS00:Connecting to 171.67.108.11:8080
23:45:12:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to read stream
23:45:12:WU01:FS00:Trying to send results to collection server
23:45:12:WU01:FS00:Uploading 632B to 171.67.108.25
23:45:12:WU01:FS00:Connecting to 171.67.108.25:8080
23:45:33:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
23:45:33:WU01:FS00:Connecting to 171.67.108.25:80
23:45:35:WU02:FS00:0x11:Completed 42%
23:45:54:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:46:24:WU02:FS00:0x11:Completed 43%
23:47:14:WU02:FS00:0x11:Completed 44%
23:48:04:WU02:FS00:0x11:Completed 45%
23:48:53:WU02:FS00:0x11:Completed 46%
23:49:42:WU02:FS00:0x11:Completed 47%
23:50:31:WU02:FS00:0x11:Completed 48%
23:51:20:WU02:FS00:0x11:Completed 49%
23:52:09:WU02:FS00:0x11:Completed 50%
23:52:58:WU02:FS00:0x11:Completed 51%
23:53:47:WU00:FS01:0xa4:Completed 570000 out of 1500000 steps  (38%)
23:53:47:WU02:FS00:0x11:Completed 52%
23:54:37:WU02:FS00:0x11:Completed 53%
23:55:27:WU02:FS00:0x11:Completed 54%
23:56:17:WU01:FS00:Sending unit results: id:01 state:SEND error:DUMPED project:5769 run:7 clone:91 gen:6082 core:0x11 unit:0x13ae792251b146e417c2005b00071689
23:56:18:WU01:FS00:Uploading 632B to 171.67.108.11
23:56:18:WU01:FS00:Connecting to 171.67.108.11:8080
23:56:18:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to read stream
23:56:18:WU01:FS00:Trying to send results to collection server
23:56:18:WU01:FS00:Uploading 632B to 171.67.108.25
23:56:18:WU01:FS00:Connecting to 171.67.108.25:8080
23:56:20:WU02:FS00:0x11:Completed 55%
23:56:39:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
23:56:39:WU01:FS00:Connecting to 171.67.108.25:80
23:57:00:ERROR:WU01:FS00:Exception: Failed to connect to 171.67.108.25:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
23:57:12:WU02:FS00:0x11:Completed 56%
