web control won't load
melas300
Post by melas300 »
Hello.
So, I just installed folding@home but the problem is that web control is stuck on loading. I've been searching for a while but I found nothing.
Here is a screenshot:
I'm using the latest version of Chrome. Javascript is enabled. Folding@home client is not blocked by firewall.
Hope you can help me!
Re: web control won't load
Can you use the FAH tray icon to launch Advanced Control until we get this sorted out?
melas300
Post by melas300 »
Yeah, sure. I just thought that maybe it had something to do with MY computer. If it doesn't, it's okay...
Yes, it is something local to your computer, but wanted to get you up and folding while we continue to troubleshoot. Step 1 is clear the browser cache. Also, which version of windows is this? Does IE have the same problem?
Post by calxalot »
I have the same problem with Chrome on OSX.
I think the current wrapper page has a browser detect issue with Chrome.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
calxalot wrote:I have the same problem with Chrome on OSX.
Web Control works fine for me with Chrome under Linux and (last I checked, about a month ago) Windows.
jimerickson
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16)
Post by jimerickson »
works fine here with chrome on ubuntu 13.10.
Post by calxalot »
Chrome developer resources panel shows an uncaught security error in intercom.min.js, and related uncaught reference error in main.js.
There are also some urls that begin "//" without "http:". Don't know if that matters.
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
calxalot wrote:Chrome developer resources panel shows an uncaught security error in intercom.min.js, and related uncaught reference error in main.js.
Good find. Any way of catching those exceptions? Is this is a bug with Web Control then?
melas300
Post by melas300 »
Clearing browser cache doesn't help. I have windows 7 64 bit.
Just tried with Internet explorer and it works...
melas300
Post by melas300 »
I should mention that this happens with another web page too. It loads normally on internet explorer but not in chrome(or firefox).
melas300
Post by melas300 »
I've actually found what was causing the problem. It seems that the site won't load if you've disabled cookies. Which I had and it is very unfortunate as I can't even set an exception for it, I must allow cookies from all sites. Well, I'll just stick to advanced control, it's not that I lose something anyway...
Jesse_V
CPU: i7-6700k
RAM: 24 GB DDR4
Post by Jesse_V »
melas300 wrote:I've actually found what was causing the problem. It seems that the site won't load if you've disabled cookies. Which I had and it is very unfortunate as I can't even set an exception for it, I must allow cookies from all sites. Well, I'll just stick to advanced control, it's not that I lose something anyway...
Good catch, I confirmed this. I had not realized that cookies were required. I disabled cookies in Chrome, then went to folding.stanford.edu/client. After a few seconds of countdown, (usually the amount of time required to load Web Control) I got to the page that you found. Usually this page only appears when the countdown reaches 0, but apparently not when cookies are disabled. The page lists the F@h software and Javascript as requirements, but not cookies. Sounds like an enhancement request to me.
Edit: https://fah-web.stanford.edu/projects/F ... icket/1036
us3rnam3
Post by us3rnam3 »
+1 I've been wondering why the web panel loads just fine on safari and chrome but breaks every now and then on firefox...clearing cookies for that specific page did it for me.
