GTX 780 will not fold
I just upgraded one of my folding computers from a GTX 470 to a GTX 780. Now I am only CPU folding and the GPU does not seem to be recognized. I am running client 7.3.6. Is there something I need to do to flush out the old GPU process that was running on the GTX 470 card prior to the upgrade?
Re: GTX 780 will not fold
Stop the client. Go to Start / All Programs / FAHClient / Data Folder. Delete the GPUs.txt file. Restart the client so it downloads a new copy. It may help recognize the card.
If not, reinstall V7.3.6 over the top of the current install. The installer should autodetect the new GPU and install a new slot.
Upgrade the GPU whitelist. The GTX 780 is a new card.
Had the same initial experience with my 2 GTX 780ies
- Hardware configuration: Parts:
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16) - Location: ames, iowa
what AndyE said. just delete GPU.txt and the client will download a new one.
Thx for the help!
For the record:
1) Quit the process, delete the GPUs.txt file, restart = no change (GPUs.txt not recreated)
2) Quit the process, GPUs.txt file deleted, rerun the install file, restart = no change (GPUs.txt still missing)
3) Quit the process, use control panel program remove, run the install file, restart = now folding! (GPUs.txt file updated)
The upgrade more than doubled the Points per Day while using about 20W more power.
For the record:
Sounds like a bug to me. GPUs.txt should download automatically when missing. If I wasn't on my phone, I'd open a new ticket on this. Any volunteers?
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Done. https://fah-web.stanford.edu/projects/F ... icket/10357im wrote:Sounds like a bug to me. GPUs.txt should download automatically when missing. If I wasn't on my phone, I'd open a new ticket on this. Any volunteers?
Thank you.
CPU: i7-6700k
You quit FAHClient.exe, right? What do you mean by "restart"? Restart the whole computer, or just started FAHClient back up again?cafromaa wrote:1) Quit the process, delete the GPUs.txt file, restart = no change (GPUs.txt not recreated)
Just got word that a restart of FAHClient should trigger a download of a new copy of the list. It's a bug if that's not working, hence why I'm asking.
No, he did not quit FAHClient.
Restarting the slots and FAHControl didn't work for him. The full uninstall reinstall did work, as I read it. Round-about way to restart fahclient. Delete it and reinstall it...![Sad :(](./images/smilies/icon_sad.gif)
I assumed a reinstall would do the same and did not work.
We will have to manually end fahclient (task mangler) after pausing the slots, delete the file, then launch fahclient from the start menu again, which should work.
There is a ticket open to add fahclient start/stop functionality back in to fahcontrol in the future.
I did a right click on the little folding icon in the tray and selected "Quit".
The "restart" was just clicking the folding startup icon on my desktop. I did not do a computer restart.
I just did a test and the right click - Quit sequence does indeed stop the cores and the FAHclient.exe as reported in the Task Manager. The startup icon on my desktop behaves just like I would expect. Click it and the FAHclient and cores are launched and folding starts. I am not sure if restarting the computer would have done anything more since the FAHclient process terminated and was later recreated. It might be worth a try to see if it would have helped.
I can understand that some of the user data is not cleared on a software update using the installer but I would have expected that a replacement for the missing GPUs.txt would be copied into the directory.
The delete/reinstall process that I ultimately had to do abandoned the partially completed CPU work unit and I was assigned a fresh CPU work unit.
I hope this helps others. My system is working fine and the new card is a great improvement for my work output per energy used.
CPU: i7-6700k
Sounds like the proper procedure then. A full computer restart isn't likely to do anything different than the quit-relaunch method that you did.cafromaa wrote:I did a right click on the little folding icon in the tray and selected "Quit".
You would think...cafromaa wrote:I can understand that some of the user data is not cleared on a software update using the installer but I would have expected that a replacement for the missing GPUs.txt would be copied into the directory.
That original WU will expire eventually (probably in a few weeks) and someone else will end up working on it. That translates into a slight delay for the project, but at least you got your GPU to fold so in the long run it's a net benefit.cafromaa wrote:The delete/reinstall process that I ultimately had to do abandoned the partially completed CPU work unit and I was assigned a fresh CPU work unit.
While the new GTX 780 fold well under Vista I get it not running with Ubuntu.
Tried 319.23, 319.32 and 325.08 beta. In all cases I "bad work unit" , bad platform ID.
System read correct GK110. For those with 780 under Ubuntu/Linux: what driver version you use ?
13:22:49:WU01:FS01:Core PID:2358
13:22:49:WU01:FS01:FahCore 0x17 started
13:22:49:WU01:FS01:0x17:*********************** Log Started 2013-07-14T13:22:49Z ***********************
13:22:49:WU01:FS01:0x17:Project: 7811 (Run 0, Clone 257, Gen 7)
13:22:49:WU01:FS01:0x17:Unit: 0x000000070a3b1e8651db487a40fedb15
13:22:49:WU01:FS01:0x17:CPU: 0x00000000000000000000000000000000
13:22:49:WU01:FS01:0x17:Machine: 1
13:22:49:WU01:FS01:0x17:Reading tar file state.xml
13:22:49:WU01:FS01:0x17:Reading tar file system.xml
13:22:49:WU01:FS01:0x17:Reading tar file integrator.xml
13:22:49:WU01:FS01:0x17:Reading tar file core.xml
13:22:49:WU01:FS01:0x17:Digital signatures verified
13:22:49:WU01:FS01:0x17:ERROR:exception: Bad platformId size.
13:22:49:WU01:FS01:0x17:Saving result file logfile_01.txt
13:22:49:WU01:FS01:0x17:Saving result file log.txt
13:22:49:WU01:FS01:0x17:Folding@home Core Shutdown: BAD_WORK_UNIT
13:22:50:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
13:22:50:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:7811 run:0 clone:257 gen:7 core:0x17 unit:0x000000070a3b1e8651db487a40fedb15
13:22:50:WU01:FS01:Uploading 1.80KiB to 171.64.65.98
13:22:50:WU01:FS01:Connecting to 171.64.65.98:8080
13:22:50:WU01:FS01:Upload complete
13:22:50:WU01:FS01:Server responded WORK_ACK (400)
13:22:50:WU01:FS01:Cleaning up
13:22:57:FS01:Finishing
On Ubuntu 13.04 I'm using nvidia-319 from xorg-edgers and my GTX 780 appears to be working well.
Try updating the nvidia OpenCL libs
