#1034 ERROR...Exception...Server responded: HTTP_SEE_OTHER
Peter_King
Post by Peter_King »
I am getting this error using an internet connection in an hotel. This error does not occur using other internet connections, but the hotel internet connection seems to function perfectly for browsing, email, downloads and video streaming. If you have run into this error before please advise how to overcome it - I would rather not change hotels.
Re: ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP
You would probably run into the same or similar error even if you changed hotels. Most, if not all, hotel internet services block a number of ports or communication types on their connections. They usually also have proxy servers involved. There might be information in your log that someone here could use to give you a workaround, but the only real good source would be someone who manages the hotel internet service.
Peter_King
OK, well here's the log:
*********************** Log Started 2013-05-27T17:51:51Z ***********************
17:51:51:************************* Folding@home Client *************************
17:51:51:      Website: http://folding.stanford.edu/
17:51:51:    Copyright: (c) 2009-2013 Stanford University
17:51:51:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:51:51:         Args:
17:51:51:       Config: C:/Users/petking/AppData/Roaming/FAHClient/config.xml
17:51:51:******************************** Build ********************************
17:51:51:      Version: 7.3.6
17:51:51:         Date: Feb 18 2013
17:51:51:         Time: 15:25:17
17:51:51:      SVN Rev: 3923
17:51:51:       Branch: fah/trunk/client
17:51:51:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
17:51:51:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
17:51:51:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
17:51:51:     Platform: win32 XP
17:51:51:         Bits: 32
17:51:51:         Mode: Release
17:51:51:******************************* System ********************************
17:51:51:          CPU: Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz
17:51:51:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
17:51:51:         CPUs: 4
17:51:51:       Memory: 3.89GiB
17:51:51:  Free Memory: 2.21GiB
17:51:51:      Threads: WINDOWS_THREADS
17:51:51:  Has Battery: true
17:51:51:   On Battery: true
17:51:51:   UTC offset: 1
17:51:51:          PID: 5956
17:51:51:          CWD: C:/Users/petking/AppData/Roaming/FAHClient
17:51:51:           OS: Windows 7 Professional
17:51:51:      OS Arch: AMD64
17:51:51:         GPUs: 0
17:51:51:         CUDA: Not detected
17:51:51:Win32 Service: false
17:51:51:***********************************************************************
17:51:51:<config>
17:51:51:  <!-- Network -->
17:51:51:  <proxy v=':8080'/>
17:51:51:
17:51:51:  <!-- User Information -->
17:51:51:  <team v='1'/>
17:51:51:  <user v='Peter_King'/>
17:51:51:
17:51:51:  <!-- Folding Slots -->
17:51:51:  <slot id='0' type='CPU'/>
17:51:51:</config>
17:51:51:Trying to access database...
17:51:51:Successfully acquired database lock
17:51:51:Enabled folding slot 00: PAUSED cpu:2 (on battery)
17:58:43:WU01:FS00:Starting
17:58:43:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/petking/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 703 -lifeline 5956 -checkpoint 15 -np 2
17:58:43:WU01:FS00:Started FahCore on PID 6200
17:58:43:WU01:FS00:Core PID:6364
17:58:43:WU01:FS00:FahCore 0xa4 started
17:58:44:WU01:FS00:0xa4:
17:58:44:WU01:FS00:0xa4:*------------------------------*
17:58:44:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
17:58:44:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
17:58:44:WU01:FS00:0xa4:Preparing to commence simulation
17:58:44:WU01:FS00:0xa4:- Ensuring status. Please wait.
17:58:53:WU01:FS00:0xa4:- Looking at optimizations...
17:58:53:WU01:FS00:0xa4:- Working with standard loops on this execution.
17:58:53:WU01:FS00:0xa4:- Previous termination of core was improper.
17:58:53:WU01:FS00:0xa4:- Files status OK
17:58:53:WU01:FS00:0xa4:- Expanded 375789 -> 690140 (decompressed 183.6 percent)
17:58:53:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=375789 data_size=690140, decompressed_data_size=690140 diff=0
17:58:53:WU01:FS00:0xa4:- Digital signature verified
17:58:53:WU01:FS00:0xa4:Project: 10450 (Run 492, Clone 0, Gen 31)
17:58:53:WU01:FS00:0xa4:Entering M.D.
17:58:59:WU01:FS00:0xa4:Using Gromacs checkpoints
17:58:59:WU01:FS00:0xa4:Mapping NT from 2 to 2
17:58:59:WU01:FS00:0xa4:Resuming from checkpoint
17:58:59:WU01:FS00:0xa4:Verified 01/wudata_01.log
17:59:00:WU01:FS00:0xa4:Verified 01/wudata_01.trr
17:59:00:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
17:59:00:WU01:FS00:0xa4:Verified 01/wudata_01.edr
17:59:00:WU01:FS00:0xa4:Completed 1825990 out of 2000000 steps  (91%)
18:04:31:WU01:FS00:0xa4:Completed 1840000 out of 2000000 steps  (92%)
18:12:16:WU01:FS00:0xa4:Completed 1860000 out of 2000000 steps  (93%)
18:20:07:WU01:FS00:0xa4:Completed 1880000 out of 2000000 steps  (94%)
18:28:00:WU01:FS00:0xa4:Completed 1900000 out of 2000000 steps  (95%)
18:36:23:WU01:FS00:0xa4:Completed 1920000 out of 2000000 steps  (96%)
18:44:26:WU01:FS00:0xa4:Completed 1940000 out of 2000000 steps  (97%)
18:52:19:WU01:FS00:0xa4:Completed 1960000 out of 2000000 steps  (98%)
18:52:20:WU00:FS00:Connecting to assign3.stanford.edu:8080
18:52:20:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
18:52:20:WU00:FS00:Connecting to assign4.stanford.edu:80
18:52:21:WU00:FS00:News: Welcome to Folding@Home
18:52:21:WU00:FS00:Assigned to work server 171.64.65.104
18:52:21:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.64.65.104
18:52:21:WU00:FS00:Connecting to 171.64.65.104:8080
18:52:21:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
18:52:21:WU00:FS00:Connecting to assign3.stanford.edu:8080
18:52:21:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
18:52:21:WU00:FS00:Connecting to assign4.stanford.edu:80
18:52:22:WU00:FS00:News: Welcome to Folding@Home
18:52:22:WU00:FS00:Assigned to work server 171.64.65.104
18:52:22:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.64.65.104
18:52:22:WU00:FS00:Connecting to 171.64.65.104:8080
18:52:22:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
18:53:21:WU00:FS00:Connecting to assign3.stanford.edu:8080
18:53:21:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
18:53:21:WU00:FS00:Connecting to assign4.stanford.edu:80
18:53:22:WU00:FS00:News: Welcome to Folding@Home
18:53:22:WU00:FS00:Assigned to work server 171.64.65.104
18:53:22:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.64.65.104
18:53:22:WU00:FS00:Connecting to 171.64.65.104:8080
18:53:22:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
18:54:59:WU00:FS00:Connecting to assign3.stanford.edu:8080
18:54:59:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
18:54:59:WU00:FS00:Connecting to assign4.stanford.edu:80
18:54:59:WU00:FS00:News: Welcome to Folding@Home
18:54:59:WU00:FS00:Assigned to work server 171.64.65.104
18:54:59:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.64.65.104
18:54:59:WU00:FS00:Connecting to 171.64.65.104:8080
18:54:59:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
18:57:36:WU00:FS00:Connecting to assign3.stanford.edu:8080
18:57:36:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
18:57:36:WU00:FS00:Connecting to assign4.stanford.edu:80
19:00:02:WU00:FS00:News: Welcome to Folding@Home
19:00:02:WU00:FS00:Assigned to work server 171.64.65.104
19:00:02:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.64.65.104
19:00:02:WU00:FS00:Connecting to 171.64.65.104:8080
19:00:02:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:00:13:WU01:FS00:0xa4:Completed 1980000 out of 2000000 steps  (99%)
19:01:50:WU00:FS00:Connecting to assign3.stanford.edu:8080
19:01:50:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
19:01:50:WU00:FS00:Connecting to assign4.stanford.edu:80
19:01:51:WU00:FS00:News: Welcome to Folding@Home
19:01:51:WU00:FS00:Assigned to work server 171.64.65.104
19:04:17:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:2 from 171.64.65.104
19:04:17:WU00:FS00:Connecting to 171.64.65.104:8080
19:04:17:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:08:04:WU01:FS00:0xa4:Completed 2000000 out of 2000000 steps  (100%)
19:08:04:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
19:08:14:WU01:FS00:0xa4:
19:08:14:WU01:FS00:0xa4:Finished Work Unit:
19:08:14:WU01:FS00:0xa4:- Reading up to 3558984 from "01/wudata_01.trr": Read 3558984
19:08:14:WU01:FS00:0xa4:trr file hash check passed.
19:08:14:WU01:FS00:0xa4:- Reading up to 530132 from "01/wudata_01.xtc": Read 530132
19:08:14:WU01:FS00:0xa4:xtc file hash check passed.
19:08:14:WU01:FS00:0xa4:edr file hash check passed.
19:08:14:WU01:FS00:0xa4:logfile size: 86675
19:08:14:WU01:FS00:0xa4:Leaving Run
19:08:19:WU01:FS00:0xa4:- Writing 4183715 bytes of core data to disk...
19:08:20:WU01:FS00:0xa4:Done: 4183203 -> 3920833 (compressed to 93.7 percent)
19:08:20:WU01:FS00:0xa4:  ... Done.
19:08:21:WU01:FS00:0xa4:- Shutting down core
19:08:21:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
19:08:21:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:08:21:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:08:22:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:08:22:WU01:FS00:Connecting to 171.64.65.81:8080
19:08:23:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:08:23:WU01:FS00:Trying to send results to collection server
19:08:23:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:08:23:WU01:FS00:Connecting to 171.65.103.160:8080
19:08:24:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:08:24:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:08:25:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:08:25:WU01:FS00:Connecting to 171.64.65.81:8080
19:08:26:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:08:26:WU01:FS00:Trying to send results to collection server
19:08:26:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:08:26:WU01:FS00:Connecting to 171.65.103.160:8080
19:08:27:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:08:42:WU00:FS00:Connecting to assign3.stanford.edu:8080
19:08:42:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
19:08:42:WU00:FS00:Connecting to assign4.stanford.edu:80
19:09:25:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:09:25:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:09:25:WU01:FS00:Connecting to 171.64.65.81:8080
19:09:26:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:09:26:WU01:FS00:Trying to send results to collection server
19:09:26:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:09:26:WU01:FS00:Connecting to 171.65.103.160:8080
19:09:28:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:09:46:WU00:FS00:News: Welcome to Folding@Home
19:09:46:WU00:FS00:Assigned to work server 171.64.65.104
19:11:02:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:11:02:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:11:02:WU01:FS00:Connecting to 171.64.65.81:8080
19:11:04:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:11:04:WU01:FS00:Trying to send results to collection server
19:11:04:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:11:04:WU01:FS00:Connecting to 171.65.103.160:8080
19:11:05:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:11:08:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 171.64.65.104
19:11:08:WU00:FS00:Connecting to 171.64.65.104:8080
19:11:08:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:13:39:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:13:39:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:13:39:WU01:FS00:Connecting to 171.64.65.81:8080
19:13:41:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:13:41:WU01:FS00:Trying to send results to collection server
19:13:41:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:13:41:WU01:FS00:Connecting to 171.65.103.160:8080
19:13:42:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:17:53:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:17:54:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:17:54:WU01:FS00:Connecting to 171.64.65.81:8080
19:17:55:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:17:55:WU01:FS00:Trying to send results to collection server
19:17:55:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:17:55:WU01:FS00:Connecting to 171.65.103.160:8080
19:17:56:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:19:47:WU00:FS00:Connecting to assign3.stanford.edu:8080
19:19:47:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
19:19:47:WU00:FS00:Connecting to assign4.stanford.edu:80
19:19:48:WU00:FS00:News: Welcome to Folding@Home
19:19:48:WU00:FS00:Assigned to work server 171.64.65.104
19:22:14:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 171.64.65.104
19:22:14:WU00:FS00:Connecting to 171.64.65.104:8080
19:22:14:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:24:45:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:24:45:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:24:45:WU01:FS00:Connecting to 171.64.65.81:8080
19:24:46:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:24:46:WU01:FS00:Trying to send results to collection server
19:24:46:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:24:46:WU01:FS00:Connecting to 171.65.103.160:8080
19:24:48:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:35:50:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:35:51:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:35:51:WU01:FS00:Connecting to 171.64.65.81:8080
19:35:52:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:35:52:WU01:FS00:Trying to send results to collection server
19:35:52:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:35:52:WU01:FS00:Connecting to 171.65.103.160:8080
19:35:53:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:37:44:WU00:FS00:Connecting to assign3.stanford.edu:8080
19:37:44:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
19:37:44:WU00:FS00:Connecting to assign4.stanford.edu:80
19:37:45:WU00:FS00:News: Welcome to Folding@Home
19:37:45:WU00:FS00:Assigned to work server 171.64.65.104
19:40:10:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 171.64.65.104
19:40:10:WU00:FS00:Connecting to 171.64.65.104:8080
19:40:10:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
19:53:47:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
19:53:47:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
19:53:47:WU01:FS00:Connecting to 171.64.65.81:8080
19:53:49:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
19:53:49:WU01:FS00:Trying to send results to collection server
19:53:49:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
19:53:49:WU01:FS00:Connecting to 171.65.103.160:8080
19:53:50:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
20:06:46:WU00:FS00:Connecting to assign3.stanford.edu:8080
20:06:46:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
20:06:46:WU00:FS00:Connecting to assign4.stanford.edu:80
20:06:47:WU00:FS00:News: Welcome to Folding@Home
20:06:47:WU00:FS00:Assigned to work server 171.64.65.104
20:09:13:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 171.64.65.104
20:09:13:WU00:FS00:Connecting to 171.64.65.104:8080
20:09:13:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
20:22:49:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10450 run:492 clone:0 gen:31 core:0xa4 unit:0x0000003d0a3b1e7550a53a49a4007725
20:22:49:WU01:FS00:Uploading 3.74MiB to 171.64.65.81
20:22:49:WU01:FS00:Connecting to 171.64.65.81:8080
20:22:51:WARNING:WU01:FS00:Exception: Failed to send results to work server: 10001: Server responded: HTTP_SEE_OTHER
20:22:51:WU01:FS00:Trying to send results to collection server
20:22:51:WU01:FS00:Uploading 3.74MiB to 171.65.103.160
20:22:51:WU01:FS00:Connecting to 171.65.103.160:8080
20:22:52:ERROR:WU01:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
20:53:45:WU00:FS00:Connecting to assign3.stanford.edu:8080
20:53:45:WARNING:WU00:FS00:Failed to get assignment from 'assign3.stanford.edu:8080': 10001: Server responded: HTTP_SEE_OTHER
20:53:45:WU00:FS00:Connecting to assign4.stanford.edu:80
20:53:46:WU00:FS00:News: Welcome to Folding@Home
20:53:46:WU00:FS00:Assigned to work server 171.64.65.104
20:56:11:WU00:FS00:Requesting new work unit for slot 00: READY cpu:2 from 171.64.65.104
20:56:11:WU00:FS00:Connecting to 171.64.65.104:8080
20:56:11:ERROR:WU00:FS00:Exception: 10001: Server responded: HTTP_SEE_OTHER
FAH's preferred connections start on port 8080 and if that fails, it reverts to port 80. Proxy servers commonly intercept port 8080.
I've never had to do this, but hopefully it will work. Tell the hotel ISP person that you don't mind using their proxy, but your software needs to be configured to address the proxy server directly. Presumably it will be a network address and port 8080. Configure FAH's proxy settings with whatever they give you.
Peter_King
Re: #1034 ERROR...Exception...Server responded: HTTP_SEE_OTH
I spoke with the ISP who told me that their service does not block any ports. Having used v 6.23 successfully for many years in hotels around the world I uninstalled v7 and reinstalled 6.23. I am happy to report that this connect to the internet from this hotel without any issue. Sorry it took so long to get back to you but the first WU it downloaded was a particularly big one. This would seem to point to an issue with v 7; could you investigate and let me know when it is fixed please?
Sounds like a IPv4 vs. IPv6 issue. v6 software doesn't suppport IPv6, so that may be the difference.
But you should really be using v6.34 for CPU & SMP, and v6.41 for GPU, to make sure you get full access to all available servers. Many work servers are set to v6.29 or higher as the minimum version.
Peter_King
But I don't see these versions on the downloads page. Could you post a link please? I am running a laptop using Windows 7.
On the home page, under the SET section, click the "Older Versions" link. Scroll down to the High Performance section.
Here's a direct link to what 7im was referring to -> http://folding.stanford.edu/English/Download2011#ntoc4
Peter_King
Thank you, I'll let you know how I get on; meanwhile will you investigate why v7 has connections problems?
Peter_King wrote:meanwhile will you investigate why v7 has connections problems?
This was investigated and Ticket #1034 was opened.
Peter_King
Has this issue now been fixed? I can see ticket 1034 but there is no indication if the problem has been fixed.
