New (used) PC with 980x and dual 5970's folding
bambihunter
- Hardware configuration: Fractal Design Define R7 XL USB-C Blackout case
Intel i9-9980xe @ 4.6ghz for 24/7 use (water cooled)
128gb GSkill TridentZ DDR4 3866 RAM
4TB Corsair MP600 PRO XT M.2 NVMe PCIe Gen. 4 x4 SSD
Asus WS x299 Sage motherboard
Asus RTX5090 Astral, RTX4090 TUF, EVGA RTX3090 XTC
Corsair AXi1600i 1600 watt digital power supply
Logitech G910 Spark Keyboard
Logitech G502 Hero Mouse
2 x Dell PowerEdge T630 servers
2 x E5-2699a-v4 (each server)
2 x EVGA RTX 2080ti
128gb (each server) - Location: S.E. Kansas, USA
After getting reprimanded on here a few years back for the 4850 which was simply terrible at folding, I stopped on it back then and went back to its competitor. However, I just bought a used Alienware computer and it is running an Intel i7 980 Extreme 6 core on water and it also has a pair of 5970 cards in them. It had a fresh OS without drivers so I threw the latest on there and grabbed the latest FAH and started it up. The CPU is really running well but all 4 GPU's fail nearly instantly.
So, I spent the last several hours on here reading about how to get these to fold first of all, and get the max out of them. Or, are they still so low PPD-Wise that it would be better just to fold with CPU only? Or, I could even throw some spare weak extra NV cards I have such as 430? If you suggest folding with them, which driver is the optimal one at this point? It appears more people are having luck with 13.1, is that correct?
Member since April 2009. Top 100 folder and proud of it.
bambihunter
2 x EVGA RTX 2080ti
Re: New (used) PC with 980x and dual 5970's folding
GPU-Z Device ID is: 1002-689C
I turned off GPU folding on it in the meantime so I wouldn't get work units I couldn't finish. I'll set them up again and post the first part you requested later. Thank you for your help.
The latest stable release of Catalyst for folding Core 16 WU's is known to be 12.8. Persons running later releases usually have used just the newer driver with the older SDK that was included in the 12.8 install. If you have installed a newer version, it needs to be completely cleaned out before reinstalling the older SDK and the driver. There are a couple of topics that have discussed this and the procedures needed. There is a newer core in development that works better with the newer versions of the SDK, you can read about that in the Beta Test Forum.
bambihunter
2 x EVGA RTX 2080ti
Well, before I saw Joes reply I let the CPU unit finish the reinstalled it so it would find the GPU's again. This time I put the latest drivers on it again, dummy plugs, DISABLED CROSSFIRE, and kicked it off and it is at least running and not failing instantly. However, one thing I notice is that all 4 GPU's combined don't total as much as just the CPU was before (running 4 ATI's uses up most of the 980x CPU.
20:46:09:FS00:Set client configured
20:46:09:Saving configuration to config.xml
20:46:09:<config>
20:46:09: <!-- Network -->
20:46:09: <proxy v=':8080'/>
20:46:09:
20:46:09: <!-- User Information -->
20:46:09: <passkey v='********************************'/>
20:46:09: <team v='********'/>
20:46:09: <user v='Bambihunter'/>
20:46:09:
20:46:09: <!-- Folding Slots -->
20:46:09: <slot id='0' type='GPU'/>
20:46:09: <slot id='1' type='GPU'/>
20:46:09: <slot id='2' type='GPU'/>
20:46:09: <slot id='3' type='GPU'/>
20:46:09: <slot id='4' type='CPU'/>
20:46:09:</config>
20:46:09:WU00:FS04:Connecting to assign-GPU.stanford.edu:80
20:46:09:WU00:FS04:Connecting to assign3.stanford.edu:8080
20:46:10:WU00:FS04:News: Welcome to Folding@Home
20:46:10:WU00:FS04:Assigned to work server 171.67.108.60
20:46:10:WU00:FS04:Requesting new work unit for slot 04: READY cpu:11 from 171.67.108.60
20:46:10:WU00:FS04:Connecting to 171.67.108.60:8080
20:46:11:WU00:FS04:Downloading 1.11MiB
20:46:13:WU00:FS04:Download complete
20:46:13:WU00:FS04:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8089 run:2326 clone:3 gen:44 core:0xa4 unit:0x000000346652edcc51528f7ca896965b
20:46:13:WU00:FS04:Starting
20:46:13:WU00:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 703 -lifeline 1468 -checkpoint 15 -np 11
20:46:13:WU00:FS04:Started FahCore on PID 1276
20:46:13:WU00:FS04:Core PID:5084
20:46:13:WU00:FS04:FahCore 0xa4 started
20:46:13:WU00:FS04:0xa4:
20:46:13:WU00:FS04:0xa4:*------------------------------*
20:46:13:WU00:FS04:0xa4:Folding@Home Gromacs GB Core
20:46:13:WU00:FS04:0xa4:Version 2.27 (Dec. 15, 2010)
20:46:13:WU00:FS04:0xa4:Preparing to commence simulation
20:46:13:WU00:FS04:0xa4:- Looking at optimizations...
20:46:13:WU00:FS04:0xa4:- Created dyn
20:46:13:WU00:FS04:0xa4:- Files status OK
20:46:13:WU00:FS04:0xa4:- Expanded 1167651 -> 3107144 (decompressed 266.1 percent)
20:46:13:WU00:FS04:0xa4:Called DecompressByteArray: compressed_data_size=1167651 data_size=3107144, decompressed_data_size=3107144 diff=0
20:46:13:WU00:FS04:0xa4:- Digital signature verified
20:46:13:WU00:FS04:0xa4:Project: 8089 (Run 2326, Clone 3, Gen 44)
20:46:13:WU00:FS04:0xa4:Assembly optimizations on if available.
20:46:13:WU00:FS04:0xa4:Entering M.D.
20:46:19:WU00:FS04:0xa4:Mapping NT from 11 to 10
20:46:19:WU00:FS04:0xa4:Completed 0 out of 250000 steps (0%)
20:46:36:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
20:46:36:WU01:FS00:News: Welcome to Folding@Home
20:46:36:WU01:FS00:Assigned to work server 171.67.108.44
20:46:36:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:Hemlock [ATI Radeon HD 5900 Series] from 171.67.108.44
20:46:36:WU01:FS00:Connecting to 171.67.108.44:8080
20:46:36:WU02:FS01:Connecting to assign-GPU.stanford.edu:80
20:46:36:WU02:FS01:News: Welcome to Folding@Home
20:46:36:WU02:FS01:Assigned to work server 171.67.108.44
20:46:36:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:Hemlock [ATI Radeon HD 5900 Series] from 171.67.108.44
20:46:36:WU02:FS01:Connecting to 171.67.108.44:8080
20:46:36:WU03:FS02:Connecting to assign-GPU.stanford.edu:80
20:46:36:WU01:FS00:Downloading 44.59KiB
20:46:36:WU03:FS02:News: Welcome to Folding@Home
20:46:36:WU03:FS02:Assigned to work server 171.67.108.44
20:46:36:WU03:FS02:Requesting new work unit for slot 02: READY gpu:2:Hemlock [ATI Radeon HD 5900 Series] from 171.67.108.44
20:46:36:WU03:FS02:Connecting to 171.67.108.44:8080
20:46:36:WU04:FS03:Connecting to assign-GPU.stanford.edu:80
20:46:36:WU02:FS01:Downloading 44.52KiB
20:46:36:WU01:FS00:Download complete
20:46:36:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11293 run:27 clone:21 gen:42 core:0x16 unit:0x0000198a6652edbc4d94ba641cd1b686
20:46:36:WU01:FS00:Starting
20:46:36:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 01 -suffix 01 -version 703 -lifeline 1468 -checkpoint 15 -gpu 0 -gpu-vendor ati
20:46:36:WU01:FS00:Started FahCore on PID 3792
20:46:36:WU01:FS00:Core PID:5368
20:46:36:WU01:FS00:FahCore 0x16 started
20:46:37:WU04:FS03:News: Welcome to Folding@Home
20:46:37:WU04:FS03:Assigned to work server 171.67.108.44
20:46:37:WU04:FS03:Requesting new work unit for slot 03: READY gpu:3:Hemlock [ATI Radeon HD 5900 Series] from 171.67.108.44
20:46:37:WU04:FS03:Connecting to 171.67.108.44:8080
20:46:37:WU02:FS01:Download complete
20:46:37:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11293 run:10 clone:143 gen:43 core:0x16 unit:0x000000486652edbc4d9257ca9fb7c561
20:46:37:WU02:FS01:Starting
20:46:37:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 02 -suffix 01 -version 703 -lifeline 1468 -checkpoint 15 -gpu 1 -gpu-vendor ati
20:46:37:WU02:FS01:Started FahCore on PID 4944
20:46:37:WU02:FS01:Core PID:6068
20:46:37:WU02:FS01:FahCore 0x16 started
20:46:37:WU01:FS00:0x16:
20:46:37:WU01:FS00:0x16:*------------------------------*
20:46:37:WU01:FS00:0x16:Folding@Home GPU Core
20:46:37:WU01:FS00:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
20:46:37:WU01:FS00:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
20:46:37:WU01:FS00:0x16:Build host: user-f6d030f24f
20:46:37:WU01:FS00:0x16:Board Type: AMD/OpenCL
20:46:37:WU01:FS00:0x16:Core : x=16
20:46:37:WU01:FS00:0x16: Window's signal control handler registered.
20:46:37:WU01:FS00:0x16:Preparing to commence simulation
20:46:37:WU01:FS00:0x16:- Looking at optimizations...
20:46:37:WU01:FS00:0x16:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
20:46:37:WU01:FS00:0x16:- Created dyn
20:46:37:WU01:FS00:0x16:- Files status OK
20:46:37:WU01:FS00:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:46:37:WU01:FS00:0x16:- Expanded 45149 -> 171163 (decompressed 379.1 percent)
20:46:37:WU01:FS00:0x16:Called DecompressByteArray: compressed_data_size=45149 data_size=171163, decompressed_data_size=171163 diff=0
20:46:37:WU01:FS00:0x16:- Digital signature verified
20:46:37:WU01:FS00:0x16:Project: 11293 (Run 27, Clone 21, Gen 42)
20:46:37:WU01:FS00:0x16:Assembly optimizations on if available.
20:46:37:WU01:FS00:0x16:Entering M.D.
20:46:37:WU03:FS02:Downloading 44.49KiB
20:46:37:WU03:FS02:Download complete
20:46:37:WU04:FS03:Downloading 44.53KiB
20:46:37:WU04:FS03:Download complete
20:46:37:WU02:FS01:0x16:
20:46:37:WU02:FS01:0x16:*------------------------------*
20:46:37:WU02:FS01:0x16:Folding@Home GPU Core
20:46:37:WU02:FS01:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
20:46:37:WU02:FS01:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
20:46:37:WU02:FS01:0x16:Build host: user-f6d030f24f
20:46:37:WU02:FS01:0x16:Board Type: AMD/OpenCL
20:46:37:WU02:FS01:0x16:Core : x=16
20:46:37:WU02:FS01:0x16: Window's signal control handler registered.
20:46:37:WU02:FS01:0x16:Preparing to commence simulation
20:46:37:WU02:FS01:0x16:- Looking at optimizations...
20:46:37:WU02:FS01:0x16:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
20:46:37:WU02:FS01:0x16:- Created dyn
20:46:37:WU02:FS01:0x16:- Files status OK
20:46:37:WU02:FS01:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:46:37:WU02:FS01:0x16:- Expanded 45075 -> 171163 (decompressed 379.7 percent)
20:46:37:WU02:FS01:0x16:Called DecompressByteArray: compressed_data_size=45075 data_size=171163, decompressed_data_size=171163 diff=0
20:46:37:WU02:FS01:0x16:- Digital signature verified
20:46:37:WU02:FS01:0x16:Project: 11293 (Run 10, Clone 143, Gen 43)
20:46:37:WU02:FS01:0x16:Assembly optimizations on if available.
20:46:37:WU02:FS01:0x16:Entering M.D.
20:46:37:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11293 run:13 clone:143 gen:43 core:0x16 unit:0x000000546652edbc4d92586614ce2ad1
20:46:37:WU03:FS02:Starting
20:46:37:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 03 -suffix 01 -version 703 -lifeline 1468 -checkpoint 15 -gpu 2 -gpu-vendor ati
20:46:37:WU03:FS02:Started FahCore on PID 6048
20:46:37:WU03:FS02:Core PID:3692
20:46:37:WU03:FS02:FahCore 0x16 started
20:46:38:WU04:FS03:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:11293 run:14 clone:143 gen:43 core:0x16 unit:0x000000416652edbc4d9258929d03b905
20:46:38:WU04:FS03:Starting
20:46:38:WU04:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 04 -suffix 01 -version 703 -lifeline 1468 -checkpoint 15 -gpu 3 -gpu-vendor ati
20:46:38:WU04:FS03:Started FahCore on PID 3416
20:46:38:WU04:FS03:Core PID:6072
20:46:38:WU04:FS03:FahCore 0x16 started
20:46:38:WU03:FS02:0x16:
20:46:38:WU03:FS02:0x16:*------------------------------*
20:46:38:WU03:FS02:0x16:Folding@Home GPU Core
20:46:38:WU03:FS02:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
20:46:38:WU03:FS02:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
20:46:38:WU03:FS02:0x16:Build host: user-f6d030f24f
20:46:38:WU03:FS02:0x16:Board Type: AMD/OpenCL
20:46:38:WU03:FS02:0x16:Core : x=16
20:46:38:WU03:FS02:0x16: Window's signal control handler registered.
20:46:38:WU03:FS02:0x16:Preparing to commence simulation
20:46:38:WU03:FS02:0x16:- Looking at optimizations...
20:46:38:WU03:FS02:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
20:46:38:WU03:FS02:0x16:- Created dyn
20:46:38:WU03:FS02:0x16:- Files status OK
20:46:38:WU03:FS02:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:46:38:WU03:FS02:0x16:- Expanded 45041 -> 171163 (decompressed 380.0 percent)
20:46:38:WU03:FS02:0x16:Called DecompressByteArray: compressed_data_size=45041 data_size=171163, decompressed_data_size=171163 diff=0
20:46:38:WU03:FS02:0x16:- Digital signature verified
20:46:38:WU03:FS02:0x16:Project: 11293 (Run 13, Clone 143, Gen 43)
20:46:38:WU03:FS02:0x16:Assembly optimizations on if available.
20:46:38:WU03:FS02:0x16:Entering M.D.
20:46:38:WU04:FS03:0x16:
20:46:38:WU04:FS03:0x16:*------------------------------*
20:46:38:WU04:FS03:0x16:Folding@Home GPU Core
20:46:38:WU04:FS03:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
20:46:38:WU04:FS03:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
20:46:38:WU04:FS03:0x16:Build host: user-f6d030f24f
20:46:38:WU04:FS03:0x16:Board Type: AMD/OpenCL
20:46:38:WU04:FS03:0x16:Core : x=16
20:46:38:WU04:FS03:0x16: Window's signal control handler registered.
20:46:38:WU04:FS03:0x16:Preparing to commence simulation
20:46:38:WU04:FS03:0x16:- Looking at optimizations...
20:46:38:WU04:FS03:0x16:DeleteFrameFiles: successfully deleted file=04/wudata_01.ckp
20:46:38:WU04:FS03:0x16:- Created dyn
20:46:38:WU04:FS03:0x16:- Files status OK
20:46:38:WU04:FS03:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:46:38:WU04:FS03:0x16:- Expanded 45091 -> 171163 (decompressed 379.5 percent)
20:46:38:WU04:FS03:0x16:Called DecompressByteArray: compressed_data_size=45091 data_size=171163, decompressed_data_size=171163 diff=0
20:46:38:WU04:FS03:0x16:- Digital signature verified
20:46:38:WU04:FS03:0x16:Project: 11293 (Run 14, Clone 143, Gen 43)
20:46:38:WU04:FS03:0x16:Assembly optimizations on if available.
20:46:38:WU04:FS03:0x16:Entering M.D.
20:46:39:WU01:FS00:0x16:Tpr hash 01/wudata_01.tpr: 1433674120 3109693964 2107104039 3278362299 4291427580
20:46:39:WU01:FS00:0x16:Working on ALZHEIMER DISEASE AMYLOID
20:46:39:WU01:FS00:0x16:Client config unavailable.
20:46:39:WU01:FS00:0x16:Starting GUI Server
20:46:39:WU02:FS01:0x16:Tpr hash 02/wudata_01.tpr: 1706448242 2478819193 2923470517 257050956 2512480759
20:46:39:WU02:FS01:0x16:Working on ALZHEIMER DISEASE AMYLOID
20:46:39:WU02:FS01:0x16:Client config unavailable.
20:46:39:WU02:FS01:0x16:Starting GUI Server
20:46:40:WU03:FS02:0x16:Tpr hash 03/wudata_01.tpr: 2301316212 3349959502 2619298168 1540291046 808606915
20:46:40:WU03:FS02:0x16:Working on ALZHEIMER DISEASE AMYLOID
20:46:40:WU03:FS02:0x16:Client config unavailable.
20:46:40:WU03:FS02:0x16:Starting GUI Server
20:46:40:WU04:FS03:0x16:Tpr hash 04/wudata_01.tpr: 2162727118 1094452545 1850657620 638112708 942731632
20:46:40:WU04:FS03:0x16:Working on ALZHEIMER DISEASE AMYLOID
20:46:40:WU04:FS03:0x16:Client config unavailable.
20:46:40:WU04:FS03:0x16:Starting GUI Server
20:46:46:WU03:FS02:0x16:Run: exception thrown in GuardedRun -- cannot continue further.
20:46:46:WU03:FS02:0x16:Going to send back what have done -- stepsTotalG=0
20:46:46:WU03:FS02:0x16:Work fraction=0.0000 steps=0.
20:46:47:WU01:FS00:0x16:Setting checkpoint frequency: 500000
20:46:47:WU01:FS00:0x16:Completed 3 out of 50000000 steps (0%).
20:46:47:WU02:FS01:0x16:Setting checkpoint frequency: 500000
20:46:47:WU02:FS01:0x16:Completed 3 out of 50000000 steps (0%).
20:46:47:WU04:FS03:0x16:Setting checkpoint frequency: 500000
20:46:47:WU04:FS03:0x16:Completed 3 out of 50000000 steps (0%).
20:46:50:WU03:FS02:0x16:logfile size=0 infoLength=0 edr=0 trr=23
20:46:50:WU03:FS02:0x16:+ Opened results file
20:46:50:WU03:FS02:0x16:- Writing 633 bytes of core data to disk...
20:46:51:WU03:FS02:0x16:Done: 121 -> 123 (compressed to 101.6 percent)
20:46:51:WU03:FS02:0x16: ... Done.
20:46:51:WU03:FS02:0x16:DeleteFrameFiles: successfully deleted file=03/wudata_01.ckp
20:46:51:WU03:FS02:0x16:Folding@home Core Shutdown: UNSTABLE_MACHINE
20:46:51:WARNING:WU03:FS02:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
20:46:51:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:11293 run:13 clone:143 gen:43 core:0x16 unit:0x000000546652edbc4d92586614ce2ad1
20:46:51:WU03:FS02:Uploading 635B to 171.67.108.44
20:46:51:WU03:FS02:Connecting to 171.67.108.44:8080
20:46:51:WU03:FS02:Upload complete
20:46:51:WU03:FS02:Server responded WORK_ACK (400)
20:46:51:WU03:FS02:Cleaning up
20:46:51:WU05:FS02:Connecting to assign-GPU.stanford.edu:80
20:46:51:WU05:FS02:News: Welcome to Folding@Home
20:46:51:WU05:FS02:Assigned to work server 171.67.108.44
20:46:51:WU05:FS02:Requesting new work unit for slot 02: READY gpu:2:Hemlock [ATI Radeon HD 5900 Series] from 171.67.108.44
20:46:51:WU05:FS02:Connecting to 171.67.108.44:8080
20:46:52:WU05:FS02:Downloading 44.45KiB
20:46:52:WU05:FS02:Download complete
20:46:52:WU05:FS02:Received Unit: id:05 state:DOWNLOAD error:NO_ERROR project:11293 run:27 clone:143 gen:43 core:0x16 unit:0x000000446652edbc4d94ba706a9aaff4
20:46:52:WU05:FS02:Starting
20:46:52:WU05:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/ATI/R600/Core_16.fah/FahCore_16.exe -dir 05 -suffix 01 -version 703 -lifeline 1468 -checkpoint 15 -gpu 2 -gpu-vendor ati
20:46:52:WU05:FS02:Started FahCore on PID 2660
20:46:52:WU05:FS02:Core PID:2632
20:46:52:WU05:FS02:FahCore 0x16 started
20:46:53:WU05:FS02:0x16:
20:46:53:WU05:FS02:0x16:*------------------------------*
20:46:53:WU05:FS02:0x16:Folding@Home GPU Core
20:46:53:WU05:FS02:0x16:Version 2.11 (Thu Dec 9 15:00:14 PST 2010)
20:46:53:WU05:FS02:0x16:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 15.00.30729.01 for 80x86
20:46:53:WU05:FS02:0x16:Build host: user-f6d030f24f
20:46:53:WU05:FS02:0x16:Board Type: AMD/OpenCL
20:46:53:WU05:FS02:0x16:Core : x=16
20:46:53:WU05:FS02:0x16: Window's signal control handler registered.
20:46:53:WU05:FS02:0x16:Preparing to commence simulation
20:46:53:WU05:FS02:0x16:- Looking at optimizations...
20:46:53:WU05:FS02:0x16:DeleteFrameFiles: successfully deleted file=05/wudata_01.ckp
20:46:53:WU05:FS02:0x16:- Created dyn
20:46:53:WU05:FS02:0x16:- Files status OK
20:46:53:WU05:FS02:0x16:sizeof(CORE_PACKET_HDR) = 512 file=<>
20:46:53:WU05:FS02:0x16:- Expanded 45002 -> 171163 (decompressed 380.3 percent)
20:46:53:WU05:FS02:0x16:Called DecompressByteArray: compressed_data_size=45002 data_size=171163, decompressed_data_size=171163 diff=0
20:46:53:WU05:FS02:0x16:- Digital signature verified
20:46:53:WU05:FS02:0x16:Project: 11293 (Run 27, Clone 143, Gen 43)
20:46:53:WU05:FS02:0x16:Assembly optimizations on if available.
20:46:53:WU05:FS02:0x16:Entering M.D.
20:46:54:WU05:FS02:0x16:Tpr hash 05/wudata_01.tpr: 149639062 1568657902 2456589885 2832477817 3378169060
20:46:54:WU05:FS02:0x16:Working on ALZHEIMER DISEASE AMYLOID
20:46:54:WU05:FS02:0x16:Client config unavailable.
20:46:55:WU05:FS02:0x16:Starting GUI Server
20:46:59:WU05:FS02:0x16:Setting checkpoint frequency: 500000
20:46:59:WU05:FS02:0x16:Completed 3 out of 50000000 steps (0%).
20:47:36:Saving configuration to config.xml
20:47:36:<config>
20:47:36: <!-- Folding Slot Configuration -->
20:47:36: <power v='full'/>
20:47:36:
20:47:36: <!-- Network -->
20:47:36: <proxy v=':8080'/>
20:47:36:
20:47:36: <!-- User Information -->
20:47:36: <passkey v='********************************'/>
20:47:36: <team v='162643'/>
20:47:36: <user v='Bambihunter'/>
20:47:36:
20:47:36: <!-- Folding Slots -->
20:47:36: <slot id='0' type='GPU'/>
20:47:36: <slot id='1' type='GPU'/>
20:47:36: <slot id='2' type='GPU'/>
20:47:36: <slot id='3' type='GPU'/>
20:47:36: <slot id='4' type='CPU'/>
20:47:36:</config>
20:52:13:WU02:FS01:0x16:Completed 500000 out of 50000000 steps (1%).
20:57:46:WU01:FS00:0x16:Completed 500000 out of 50000000 steps (1%).
20:58:09:WU02:FS01:0x16:Completed 1000000 out of 50000000 steps (2%).
21:02:31:WU04:FS03:0x16:Completed 500000 out of 50000000 steps (1%).
21:02:56:WU05:FS02:0x16:Completed 500000 out of 50000000 steps (1%).
21:04:12:WU02:FS01:0x16:Completed 1500000 out of 50000000 steps (3%).
21:09:56:WU01:FS00:0x16:Completed 1000000 out of 50000000 steps (2%).
21:10:06:WU02:FS01:0x16:Completed 2000000 out of 50000000 steps (4%).
21:14:40:WU05:FS02:0x16:Completed 1000000 out of 50000000 steps (2%).
21:16:07:WU02:FS01:0x16:Completed 2500000 out of 50000000 steps (5%).
21:22:00:WU01:FS00:0x16:Completed 1500000 out of 50000000 steps (3%).
21:22:03:WU02:FS01:0x16:Completed 3000000 out of 50000000 steps (6%).
21:24:59:WU00:FS04:0xa4:Completed 2500 out of 250000 steps (1%)
21:25:45:WU04:FS03:0x16:Completed 1000000 out of 50000000 steps (2%).
21:28:00:WU02:FS01:0x16:Completed 3500000 out of 50000000 steps (7%).
21:32:02:WU05:FS02:0x16:Completed 1500000 out of 50000000 steps (3%).
21:33:57:WU02:FS01:0x16:Completed 4000000 out of 50000000 steps (8%).
21:34:06:WU01:FS00:0x16:Completed 2000000 out of 50000000 steps (4%).
21:39:51:WU02:FS01:0x16:Completed 4500000 out of 50000000 steps (9%).
21:44:04:WU04:FS03:0x16:Completed 1500000 out of 50000000 steps (3%).
21:45:47:WU02:FS01:0x16:Completed 5000000 out of 50000000 steps (10%).
21:46:13:WU01:FS00:0x16:Completed 2500000 out of 50000000 steps (5%).
21:49:18:WU05:FS02:0x16:Completed 2000000 out of 50000000 steps (4%).
21:51:43:WU02:FS01:0x16:Completed 5500000 out of 50000000 steps (11%).
21:57:37:WU02:FS01:0x16:Completed 6000000 out of 50000000 steps (12%).
21:58:18:WU01:FS00:0x16:Completed 3000000 out of 50000000 steps (6%).
22:02:30:WU04:FS03:0x16:Completed 2000000 out of 50000000 steps (4%).
22:03:30:WU02:FS01:0x16:Completed 6500000 out of 50000000 steps (13%).
22:05:47:WU05:FS02:0x16:Completed 2500000 out of 50000000 steps (5%).
22:09:34:WU02:FS01:0x16:Completed 7000000 out of 50000000 steps (14%).
22:10:24:WU01:FS00:0x16:Completed 3500000 out of 50000000 steps (7%).
22:15:38:WU02:FS01:0x16:Completed 7500000 out of 50000000 steps (15%).Member since April 2009. Top 100 folder and proud of it.
Last time I checked, you need 1 CPU per AMD GPU to fold with FahCore_16. Thus you need 4 CPUs free but it seems that you only have 2 CPUs:
Try SMP:8 which will give you 100% CPU Usage or SMP:6 which will give you some free CPU Cycles to use for your non-folding applications if the system isn't a dedicated folding machine. Do note that FahCore_16 isn't very efficient on AMD GPUs.
bambihunter
2 x EVGA RTX 2080ti
Just to see what the cards would do on their own, I paused the CPU core and now they are all averaging ~5200 PPD (each) or so. I'll let it go overnight and see if anything changes production-wise. Then, I think I will do as you suggest Panther and see if I can net more than I was getting with just the CPU (which was around 20k +/-).
At this time anyway, this is a dedicated folder (as are most of my systems). I do game every few weeks for a day and I'll just shut it down during that time. To be honest, I thought I remembered these 1366 i7 Hexa-cores producing more than they are. I thought that at 6 cores (plus hyperthreading) would outperform my AMD FX-8150 8 core but that doesn't seem to be the case. Perhaps I am thinking of when people were running -bigadv on them and getting big bonus points.
Does anyone know if the new core they are working on for AMD's will work on the 5900 series GPU or is it just for the newer models? Perhaps I should consider selling/trading them off for cards from the other team (since they are really just for folding anyway).
FahCore_17 supports AMD HD 5000 Series or higher.
bambihunter
2 x EVGA RTX 2080ti
Sweet. I guess I'll hang onto them and see how they do.
bambihunter
2 x EVGA RTX 2080ti
Well, after running just the CPU for a week or so, I can say that while consuming around 800 watts from the wall to fold with the 4 ATI GPU's, and 5 CPU cores, I end up with ~26k ppd combined. With just the CPU alone, it pulls around 325 watts from the wall, and is getting over 30k ppd.
I guess that answers that question. I will see if I can get a trade on C-list. If not, I'll just wait until 17 is ready. That is wild, I never would have guessed it to be that much difference (other than the amount of heat produced).
Thanks everyone for helping out.
