FahCore returned: INTERRUPTED (102 = 0x66)
brigj
Post by brigj »
Over and over my system is getting this message, extremely irritating. I uninstall on my Mac and reinstall to get a new assignment but settings elsewhere on my machine seem to remember the old job and I can't break free. (In the process I seem to have upgraded to V 7.3.6) What should I do? (System gets 100% power, I have set Folding Core Priority to "Slightly Higher".)
Thanks
19:54:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
19:55:00:WU01:FS00:Starting
19:55:00:WU01:FS00:Removing old file './work/01/logfile_01-20130429-184850.txt'
19:55:00:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 01 -suffix 01 -version 703 -lifeline 28107 -checkpoint 15 -np 8
19:55:00:WU01:FS00:Started FahCore on PID 28295
19:55:00:WU01:FS00:Core PID:28298
19:55:00:WU01:FS00:FahCore 0xa4 started
19:55:00:WU01:FS00:0xa4:
19:55:00:WU01:FS00:0xa4:*------------------------------*
19:55:00:WU01:FS00:0xa4:Folding@Home Gromacs Core
19:55:00:WU01:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
19:55:00:WU01:FS00:0xa4:Preparing to commence simulation
19:55:00:WU01:FS00:0xa4:- Ensuring status. Please wait.
19:55:10:WU01:FS00:0xa4:- Looking at optimizations...
19:55:10:WU01:FS00:0xa4:- Working with standard loops on this execution.
19:55:10:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
19:55:10:WU01:FS00:0xa4:- Expanded 1065987 -> 4325376 (decompressed 405.7 percent)
19:55:10:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1065987 data_size=4325376, decompressed_data_size=4325376 diff=0
19:55:10:WU01:FS00:0xa4:- Digital signature verified
19:55:10:WU01:FS00:0xa4:Project: 7809 (Run 7, Clone 445, Gen 38)
19:55:10:WU01:FS00:0xa4:Entering M.D.
19:55:16:WU01:FS00:0xa4:Mapping NT from 8 to 8
19:55:16:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Mod Edit: Thread Split From -> viewtopic.php?f=19&t=24074 - PantherX
Re: FahCore returned: INTERRUPTED (102 = 0x66)
INTERRUPTED happens when you intentionally PAUSE folding or when you make changes to parameters that alter how a FahCore operates. It also happens when the PAUSE function is invoked if you've got a slot set to fold only when idle.
It would be helpful to us if you could post the initial section of your log so we can see how you have configured the fahclient and suggest changes based on your needs.
brigj
Post by brigj »
To my knowledge, I haven't done anything to trigger this behavior. It just started happening. I have looked for any settings which might be causing FAH to get less than 110% of resources, e.g. tweaked the Folding Core Priority. Are there specific places you can suggest where a stray setting has been corrupted that I might go back and fix?
I noticed the following at the start of my log after I tweaked Folding Core Priority. Would access to more/all of the xml help?
Thanks
19:48:46:Saving configuration to config.xml
19:48:46:<config>
19:48:46:  <!-- Folding Core -->
19:48:46:  <core-priority v='low'/>
19:48:46:
19:48:46:  <!-- Folding Slot Configuration -->
19:48:46:  <power v='full'/>
19:48:46:
19:48:46:  <!-- Network -->
19:48:46:  <proxy v=':8080'/>
19:48:46:
19:48:46:  <!-- Slot Control -->
19:48:46:  <pause-on-battery v='false'/>
19:48:46:
19:48:46:  <!-- User Information -->
19:48:46:  <team v='43289'/>
19:48:46:  <user v='ff_mbp1'/>
19:48:46:
19:48:46:  <!-- Folding Slots -->
19:48:46:  <slot id='0' type='CPU'/>
19:48:46:</config>
19:48:59:WU01:FS00:Starting
19:48:59:WU01:FS00:Removing old file './work/01/logfile_01-20130429-184249.txt'
When you change <core-priority v='low'/> that cannot be applied without stopping and restarting the FahCore so you'll always get an INTERRUPTED message.
Changing core-priority is almost never useful -- unless you're running some other application that uses core-priority=idle, which would be unusual. The real question you have to ask yourself is what other unneeded applications are you running that are taking priority over FAH. If they're unneeded, shut them down rather than preempt them.
From the log segmented posted, I noticed the following:
1) Is there a specific reason that you chose to change the default action for the battery:
2) You have posted in a thread that is for GPU project 11292. However, I can only see a CPU slot configured and no mention of GPU:
If you want to fold on a GPU that is supported, we can help you. If not, we can split the topic.
brigj
Post by brigj »
oops re GPU project 11292. I just saw what looked like unanswered problems re INTERRUPTED and posted here. Fine to split off.
I did the pause-on-battery switch because I'd just as soon my project keep working if I have to move my laptop from one place to another.
I changed core-priority to v='low' as another item from my kitchen sink of possible fixes.
Apps running on my Mac included Firefox, Safari and Chrome all monitoring separate twitter accounts. I just tried quitting the Chrome and Safari instances and I closed the Firefox sessions running twitter. Some facebook instances are still running on Firefox. (Didn't help, still went through the INTERRUPTED cycle.)
My point was that there were very few cases where changing priority would solve whatever your problem was, but you'll always get INTERRUPTED whenever you change priority. (I'm not sure about battery.)
Let's just say that if INTERRUPTED is a problem for you, don't make (unnecessary) changes.
Are you still encountering the issues? If so, can you post a fresh log after you restart your system and leave if running overnight so we can get a better picture of what is going on. Make sure that you include the initial section of the log which contain the system configuration and your fah set-up.
brigj
Post by brigj »
Here's the log after restart. Again, as far as I know, I made no changes, these INTERRUPTIONS started happening out of the blue. After a while of that I DID try making some changes, to no avail.
Thanks
*********************** Log Started 2013-04-29T22:25:37Z ***********************
22:25:37:************************* Folding@home Client *************************
22:25:37:    Website: http://folding.stanford.edu/
22:25:37:  Copyright: (c) 2009-2013 Stanford University
22:25:37:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
22:25:37:       Args:
22:25:37:     Config: /Library/Application Support/FAHClient/config.xml
22:25:37:******************************** Build ********************************
22:25:37:    Version: 7.3.6
22:25:37:       Date: Feb 18 2013
22:25:37:       Time: 15:24:11
22:25:37:    SVN Rev: 3923
22:25:37:     Branch: fah/trunk/client
22:25:37:   Compiler: GNU 4.2.1 (Apple Inc. build 5666) (dot 3)
22:25:37:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
22:25:37:             -fno-unsafe-math-optimizations -msse3 -arch x86_64
22:25:37:             -mmacosx-version-min=10.5 -isysroot /Developer/SDKs/MacOSX10.5.sdk
22:25:37:   Platform: darwin 10.8.0
22:25:37:       Bits: 64
22:25:37:       Mode: Release
22:25:37:******************************* System ********************************
22:25:37:        CPU: Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz
22:25:37:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
22:25:37:       CPUs: 8
22:25:37:     Memory: 8.00GiB
22:25:37:Free Memory: 6.70GiB
22:25:37:    Threads: POSIX_THREADS
22:25:37:Has Battery: true
22:25:37: On Battery: false
22:25:37: UTC offset: -7
22:25:37:        PID: 56
22:25:37:        CWD: /Library/Application Support/FAHClient
22:25:37:         OS: Darwin 12.3.0 x86_64
22:25:37:    OS Arch: AMD64
22:25:37:       GPUs: 1
22:25:37:      GPU 0: NVIDIA:3 GK107 [GeForce GT 650M]
22:25:37:       CUDA: Not detected
22:25:37:***********************************************************************
22:25:37:<config>
22:25:37:  <!-- Folding Core -->
22:25:37:  <core-priority v='low'/>
22:25:37:
22:25:37:  <!-- Folding Slot Configuration -->
22:25:37:  <power v='full'/>
22:25:37:
22:25:37:  <!-- Network -->
22:25:37:  <proxy v=':8080'/>
22:25:37:
22:25:37:  <!-- Slot Control -->
22:25:37:  <pause-on-battery v='false'/>
22:25:37:
22:25:37:  <!-- User Information -->
22:25:37:  <team v='43289'/>
22:25:37:  <user v='ff_mbp1'/>
22:25:37:
22:25:37:  <!-- Folding Slots -->
22:25:37:  <slot id='0' type='CPU'/>
22:25:37:</config>
22:25:37:Trying to access database...
22:25:37:Successfully acquired database lock
22:25:37:Enabled folding slot 00: READY cpu:8
22:25:37:WU01:FS00:Starting
22:25:37:WU01:FS00:Removing old file './work/01/logfile_01-20130429-215223.txt'
22:25:37:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 01 -suffix 01 -version 703 -lifeline 56 -checkpoint 15 -np 8
22:25:37:WU01:FS00:Started FahCore on PID 223
22:25:38:WU01:FS00:Core PID:226
22:25:38:WU01:FS00:FahCore 0xa4 started
22:25:39:WU01:FS00:0xa4:
22:25:39:WU01:FS00:0xa4:*------------------------------*
22:25:39:WU01:FS00:0xa4:Folding@Home Gromacs Core
22:25:39:WU01:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
22:25:39:WU01:FS00:0xa4:Preparing to commence simulation
22:25:39:WU01:FS00:0xa4:- Ensuring status. Please wait.
22:25:48:WU01:FS00:0xa4:- Looking at optimizations...
22:25:48:WU01:FS00:0xa4:- Working with standard loops on this execution.
22:25:48:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
22:25:49:WU01:FS00:0xa4:- Expanded 1065987 -> 4325376 (decompressed 405.7 percent)
22:25:49:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1065987 data_size=4325376, decompressed_data_size=4325376 diff=0
22:25:49:WU01:FS00:0xa4:- Digital signature verified
22:25:49:WU01:FS00:0xa4:Project: 7809 (Run 7, Clone 445, Gen 38)
22:25:49:WU01:FS00:0xa4:Entering M.D.
22:25:55:WU01:FS00:0xa4:Mapping NT from 8 to 8
22:25:56:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:25:56:WU01:FS00:Starting
22:25:56:WU01:FS00:Removing old file './work/01/logfile_01-20130429-215323.txt'
22:25:56:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 01 -suffix 01 -version 703 -lifeline 56 -checkpoint 15 -np 8
22:25:56:WU01:FS00:Started FahCore on PID 231
22:25:56:WU01:FS00:Core PID:232
22:25:56:WU01:FS00:FahCore 0xa4 started
22:25:57:WU01:FS00:0xa4:
22:25:57:WU01:FS00:0xa4:*------------------------------*
22:25:57:WU01:FS00:0xa4:Folding@Home Gromacs Core
22:25:57:WU01:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
22:25:57:WU01:FS00:0xa4:Preparing to commence simulation
22:25:57:WU01:FS00:0xa4:- Ensuring status. Please wait.
22:26:06:WU01:FS00:0xa4:- Looking at optimizations...
22:26:06:WU01:FS00:0xa4:- Working with standard loops on this execution.
22:26:06:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
22:26:06:WU01:FS00:0xa4:- Expanded 1065987 -> 4325376 (decompressed 405.7 percent)
22:26:06:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1065987 data_size=4325376, decompressed_data_size=4325376 diff=0
22:26:06:WU01:FS00:0xa4:- Digital signature verified
22:26:06:WU01:FS00:0xa4:Project: 7809 (Run 7, Clone 445, Gen 38)
22:26:06:WU01:FS00:0xa4:Entering M.D.
22:26:12:WU01:FS00:0xa4:Mapping NT from 8 to 8
22:26:13:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:26:57:WU01:FS00:Starting
22:26:57:WU01:FS00:Removing old file './work/01/logfile_01-20130429-215424.txt'
22:26:57:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 01 -suffix 01 -version 703 -lifeline 56 -checkpoint 15 -np 8
22:26:57:WU01:FS00:Started FahCore on PID 325
22:26:57:WU01:FS00:Core PID:328
22:26:57:WU01:FS00:FahCore 0xa4 started
22:26:57:WU01:FS00:0xa4:
22:26:57:WU01:FS00:0xa4:*------------------------------*
22:26:57:WU01:FS00:0xa4:Folding@Home Gromacs Core
22:26:57:WU01:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
22:26:57:WU01:FS00:0xa4:Preparing to commence simulation
22:26:57:WU01:FS00:0xa4:- Ensuring status. Please wait.
22:27:06:WU01:FS00:0xa4:- Looking at optimizations...
22:27:06:WU01:FS00:0xa4:- Working with standard loops on this execution.
22:27:06:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
22:27:06:WU01:FS00:0xa4:- Expanded 1065987 -> 4325376 (decompressed 405.7 percent)
22:27:06:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1065987 data_size=4325376, decompressed_data_size=4325376 diff=0
22:27:06:WU01:FS00:0xa4:- Digital signature verified
22:27:06:WU01:FS00:0xa4:Project: 7809 (Run 7, Clone 445, Gen 38)
22:27:06:WU01:FS00:0xa4:Entering M.D.
22:27:12:WU01:FS00:0xa4:Mapping NT from 8 to 8
22:27:13:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
22:27:57:WU01:FS00:Starting
22:27:57:WU01:FS00:Removing old file './work/01/logfile_01-20130429-215524.txt'
22:27:57:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper "/Library/Application Support/FAHClient/cores/www.stanford.edu/~pande/OSX/AMD64/Core_a4.fah/FahCore_a4" -dir 01 -suffix 01 -version 703 -lifeline 56 -checkpoint 15 -np 8
22:27:57:WU01:FS00:Started FahCore on PID 339
22:27:57:WU01:FS00:Core PID:342
22:27:57:WU01:FS00:FahCore 0xa4 started
22:27:57:WU01:FS00:0xa4:
22:27:57:WU01:FS00:0xa4:*------------------------------*
22:27:57:WU01:FS00:0xa4:Folding@Home Gromacs Core
22:27:57:WU01:FS00:0xa4:Version 2.27 (Thu Feb 10 09:46:40 PST 2011)
22:27:57:WU01:FS00:0xa4:Preparing to commence simulation
22:27:57:WU01:FS00:0xa4:- Ensuring status. Please wait.
22:28:06:WU01:FS00:0xa4:- Looking at optimizations...
22:28:06:WU01:FS00:0xa4:- Working with standard loops on this execution.
22:28:06:WU01:FS00:0xa4:Examination of work files indicates 8 consecutive improper terminations of core.
22:28:07:WU01:FS00:0xa4:- Expanded 1065987 -> 4325376 (decompressed 405.7 percent)
22:28:07:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=1065987 data_size=4325376, decompressed_data_size=4325376 diff=0
22:28:07:WU01:FS00:0xa4:- Digital signature verified
22:28:07:WU01:FS00:0xa4:Project: 7809 (Run 7, Clone 445, Gen 38)
22:28:07:WU01:FS00:0xa4:Entering M.D.
22:28:13:WU01:FS00:0xa4:Mapping NT from 8 to 8
22:28:13:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
In my experience with the A4 folding core on OS X, the FahCore returned: INTERRUPTED (102 = 0x66) message repeatedly showing up immediately after the 0xa4:Mapping NT from n to n entry in the log has usually meant the WU is bad or will not fold on my setup. If you are not doing anything else to pause the client folding, that is what I suspect is happening in your case. There is an open report on the core and client not discarding a WU after the 8 improper terminations mentioned in the log:
It is possible that the WU is not bad, but will fold for someone else with a different setup. But so far about two thirds of the WU's I have seen fail with this type of error did turn out to be bad for others as well. So far there are no reports in the database for this WU. I have notes at home on how to dump a WU under OS X, will check them after I get off work. Let us know if there is any change. In the meantime, I would suggest you undo any of the changes you have made as they are not doing anything useful. The pause on battery setting is one you can leave whichever way works for you. I happened to have made the same choice on my laptop, the magsafe adapter comes off fairly easily when the cat jumps into my lap and I just replug it in.
brigj
Post by brigj »
cool. I will revert the changes and look for your instructions regarding dumping a WU under OS X. I'm anxious to heat this puppy up again!
Thanks.
Post by calxalot »
The easiest way to dump the pesky WU is via FAHControl.
Delete the slot and create a new one:
Configure > Slots > select slot > click Remove > click Add > select CPU if not already selected > click OK > click Save.
brigj
Post by brigj »
I like that suggestion re remove/add the Slot but I don't see that the system went to get a new assignment. Still seems to want to work on:
Thanks
P5-133XL
Machine #2:
Machine 3:
Post by P5-133XL »
The remove & add slot won't work as a method of dumping a WU in this situation. You need to run the client without the CPU slot for the client to dump the WU. Running the client with no slots won't work because the config will be invalid so it will simply recreate a default CPU slot before dumping. So the solution is to remove the CPU slot and add a GPU slot then run the client. Only after the client has dumped the WU can you then fix the config to have the CPU slot and no GPU slot.
I contend it is easier to stop/pause the client (to eliminate any file-lock problems) and then go to the work folder and delete the work queue folder that matches the WU. Then simply restart/unpause the client. Since the data in the work queue is gone, the client just dumps the old WU and gets a new one.
